Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: 2012 Audi A3 TDI abs module replacement and coding issues
    New User
    May 2019
    Kiev, Ukraine
    Так.
    000000000000000000000000000000000000
    1442401209280001280B02E8902000423F04
  2. #12
    Dec 2019
    Unfortunately the last two codes that you sent were rejected.
    Here is the latest auto scan after my attempts...
    Sunday,29,December,2019,09:17:28:19969
    VIN: WAUKJAFM5CA067047   License Plate:
    Mileage: 127440km-79187mi   Repair Order: 12.29.19
    Chassis Type: FM-AU35 (7N0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
              72 77
    VIN: WAUKJAFM5CA067047   Mileage: 127440km-79187miles
    4C-Tire Pressure II -- Status: Cannot be reached 1100
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H14---    Serial number: AUX7Z0K8FNT0IN
       Coding: 0050078
       Shop #: WSC 03377 002 1048576
       VCID: 2C010314DA0FD77745F-8078
                   U1017 - 000 -  - Intermittent
                        Fault Frequency: 255
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
       Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 9334
       Revision: 05351113    Serial number: 00001109200366
       Shop #: WSC 06314 000 00000
       VCID: 176BCCF8738944AF18D-8042
    18261 - Powertrain Data Bus
                P1853 - 000 - Implausible Message from ABS Controller
                        Reset counter: 40
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:39:30
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -  - Intermittent
                        Reset counter: 1
                        Mileage: 127443 km
                        Date: 2019.12.27
                        Time: 06:25:04
       Revision: 00H45001
       VCID: 005987A40A07E317C97-8054
    9 Faults Found:
                        Fault Status: 00101100
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.24
                        Time: 03:26:13
                        Count: 3
                        Count: 12800
                        Count: 64
                        Count: 49674
                        Count: 7680
                        Fault Status: 00100011
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:13:27
                        Count: 3
                        Count: 4608
                        Count: 67
                        Count: 49677
                        Count: 5120
    03306 - Coding Not Valid
                        Reset counter: 89
                        Mileage: 264453 km
                        Date: 2001.12.04
                        Time: 00:04:08
                        Count: 768
                        Count: 159
                        Count: 22784
                        Count: 4161
                        Count: 256
                        Count: 36609
                        Count: 212
                        Count: 22785
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 143
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 279
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 295
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 270
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 195
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 212
                        Count: 42752
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0180
       Revision: 000046      Serial number: 8P0820043BM
       VCID: 78A9EF445ED7ABD7F17-802C
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
       Component: BCM PQ35  M   110 0719
       Revision: 00110 AF
       Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
       Shop #: WSC 09550 758 180955
       VCID: 42DD4DAC448B31079F3-8016
       Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
    01134 - Alarm Horn (H12)
                        Fault Frequency: 7
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:33:03
                        Voltage: 11.70 V
                            Term 50 Off
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:34:28
                            Term 15 Off
                        Voltage: 12.00 V
                            Term 50 Off
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7L0603354
       Coding: 0000100
       VCID: 3635217C14439DA723B-8062
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
       Component: Airbag AU1042 H09 0250
       Revision: --------    Serial number: 003FC001JVA5
       Coding: 303142393041303030374A55304C38503053
       ROD: EV_Airba10AURB4.rod
       VCID: 50F977E49A67D397197-8004
       Subsystem 1 - Part No SW: 8P0 959 339 D    HW: 8P0 959 339 D
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R1190600QZV
       Serial number: 3572DRB40000E005315E
       Serial number: 3582DRB40000E0087A4U
       Serial number: 35128RB400006601E0DF
       Serial number: 35228RB40000660A93CM
       Serial number: 35547RB4000066D588B.
       Serial number: 35647RB4000066D5877X
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0014142
       VCID: 46D551BC64A30D27B3B-8012
       Component: E0221           H02 0100
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
       Component: KOMBIINSTR. VDO H02 0150
       Revision: D0H02002    Serial number: 2248K002001786
       Coding: 0272288
       Shop #: WSC 12345 067 57207
       VCID: 3B2330482F6140CFDC5-806E
       Revision:   H42       Serial number: 210911F2002401
       Coding: 352102
       VCID: 35372670054596BF2A1-8060
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:39:34
       Revision: D0H02002    Serial number: AUX7Z0K8FNT0IN
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0001181
       VCID: 49CF5A8075BDE25F5E9-801C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 233    3201
       Revision: 00H20000
       VCID: 34311B74023F8FB71DF-8060
                        Fault Status: 00101101
                        Reset counter: 129
                        Mileage: 127443 km
                        Date: 2019.12.27
                        Time: 06:25:04
                        Voltage: 13.63 V
                            DU
                        Temperature: 18.0C
                        RPM: 992 /min
                        Speed: 1.0 km/h
                        Speed: 1.0 km/h
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158124266503
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0001181
       VCID: 4ACD658C70BBE947573-801E
       Part No: 8P3 907 357 B
       Coding: 0000013
       VCID: 3C2133542A6F47F7D5F-8068
       Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
       Component: R Concert2+     H05 0293
       Revision: 00H05000    Serial number: AUZ1Z3L2599809
       Coding: 0750112
       VCID: 73B3D86847B1C88FC45-8026
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001176
       Shop #: WSC 06314 000 1012544
       VCID: 42DD4DAC488B31079F3-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001176
       VCID: 43D348A85791380F945-8016
       Part No SW: 8P1 862 336 A    HW: 8P1 862 336
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005158070
       Coding: 0001277
    End----(Elapsed Time: 01:38, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
  3. #13
    New User
    May 2019
    Kiev, Ukraine
    1142401209280001880B02E8902000513808
    Пробуй.
  4. #14
    Dec 2019
    The last one did not work either.
    Just to make sure I am doing this correctly...
    Open VCDS, go to Select Control Module - 03 - ABS Brakes - Coding 07 - New Coding then enter new code in space below? Click Do It!
    Below that section has Workshop# , Importer # and Equipment # Do I need to enter anything for those values?
    On my previous abs module for the Workshop # it had 06314
    Thanks again!
  5. #15
    New User
    May 2019
    Kiev, Ukraine
    Yes need. The coding may not be accepted if there are 00000
    sorry
    00 - 14
    01 - 50 USA ?????
    02 - 40
    14424012хх280001280B02E8xx200051B900
    1442401209280001280B02E890200051B900
    1442401249280001280B02E892200051B900
    14424012хх280001280B02E8xx200051????
  6. #16
    Dec 2019
    So I went back and tried to enter each code again also adding the work shop # 06314 they are all rejected. Still not coding properly.
    Do you need an updated auto scan?
  7. #17
    Dec 2019
    here is the updated scan.
    Monday,30,December,2019,17:20:16:19969
    Mileage: 127440km-79187mi   Repair Order: 12.30.19
              72 77
       Coding: 0050078
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
                        Reset counter: 40
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:39:30
                        Reset counter: 1
                        Mileage: 127443 km
                        Date: 2019.12.27
                        Time: 06:25:04
       Revision: 00H45001
    8 Faults Found:
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.24
                        Time: 03:26:13
                        Count: 3
                        Count: 12800
                        Count: 64
                        Count: 49674
                        Count: 7680
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:13:27
                        Count: 3
                        Count: 4608
                        Count: 67
                        Count: 49677
                        Count: 5120
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 143
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 279
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 295
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 270
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 195
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 212
                        Count: 42752
       Revision: 00110 AF
       Coding: 00DD13
                        Fault Frequency: 9
                        Reset counter: 129
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:33:03
                        Voltage: 11.70 V
                            Term 50 Off
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:34:28
                            Term 15 Off
                        Voltage: 12.00 V
                            Term 50 Off
       Coding: 0000100
       Coding: 0014142
       Coding: 0272288
       Coding: 352102
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:39:34
       Coding: 0001181
       Revision: 00H20000
                        Reset counter: 129
                        Mileage: 127443 km
                        Date: 2019.12.28
                        Time: 23:11:37
                        Voltage: 13.88 V
                            DU
                        Temperature: 13.0C
                        RPM: 922 /min
       Coding: 0001181
       Coding: 0000013
                        Reset counter: 129
                        Mileage: 127448 km
                        Date: 2019.12.28
                        Time: 21:26:28
       Coding: 0750112
       Coding: 0001176
       Coding: 0001176
       Coding: 0001277
    End----(Elapsed Time: 01:38, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  8. #18
    Quote Originally Posted by Bozwhizzle View Post
    Did you also try non-zero values for Importer and Equipment Number?
    Try with WSC = 07221, Importer = 444, and Equipment Number = 09104.
  9. #19
    Dec 2019
    I went back through and tried all the codes provided adding the WCS, Importer and Equipment #'s... still a no go? Any ideas?
    Do you need any info from either the old abs module or the new one?
  10. #20
    New User
    May 2019
    Kiev, Ukraine
    Блок HW: 1K0 907 379 AP не ставился на эту модель автомобиля.
    Был случай когда после аварии из двух авто делали один, тоже были похожие проблеммы. Блок вприлюбых правильных кодировках выдавал код 31
    Block HW: 1K0 907 379 AP was not placed on this model of car.
    There was a case when after an accident they made one of two cars, there were similar problems too. The block in any correct encoding gave code 31
