Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: 2012 Audi A3 TDI abs module replacement and coding issues
    Dec 2019
    Hi there, I am new to this forum. I have read several post about this issue and looking for some help or direction of where to go?
    I had a local shop diagnose my troubles and verified it was the abs module that went bad. I recently purchased one from ecs tuning.
    I did the auto scan and saved the file to my desktop. Then I opened up the abs system and retrieved the long coding and other numbers perhaps needed.
    Installed the new abs module, connected to VCDS and have tried to enter new long coding and get this message..
    "VCDS has detected a change in coding length. Are you sure you want to continue?"
    Believing that I have the correct coding information from the previous abs module I select "Yes".
    Then this message pop up - "This appears to be an uninitialized control module, valid WSC/Importer/Equipment data may be required. Click Yes for VCDS to use defalt values of 12345/123/12345. Click No for VCDS to try the values currently in the module. Click cancel to manually edit the values."
    What I have read on this forum and researched seems like I am at the point where I could use some direction? Any help would be greatly appreciated!
    Eddie
    Please post both auto-scans; the one from before the ABS module swap, and the one with the new module installed.
    Dec 2019
    Hi there, thank you so much for your quick response!
    I don't believe I have a scan from before the swap... I realized from several other posts that I jumped the gun and should have performed an auto scan before moving forward!
    I have the scan from when I was trying to add the new coding to the new abs module. Let me know what you think?
    Monday,23,December,2019,17:31:19:19969
    VIN: WAUKJAFM5CA067047   License Plate:
    Mileage: 127440km-79187mi   Repair Order:
    Chassis Type: FM-AU35 (7N0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
              72 77
    VIN: WAUKJAFM5CA067047   Mileage: 127440km-79187miles
    4C-Tire Pressure II -- Status: Cannot be reached 1100
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H14---    Serial number: AUX7Z0K8FNT0IN
       Coding: 0050078
       Shop #: WSC 03377 002 1048576
       VCID: 2C010314DA0FD77745F-8078
                   U1017 - 000 -  - Intermittent
                        Fault Frequency: 255
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
       Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 9334
       Revision: 05351113    Serial number: 00001109200366
       Shop #: WSC 06314 000 00000
       VCID: 176BCCF8738944AF18D-8042
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -  - Intermittent
                        Reset counter: 1
                        Mileage: 127428 km
                        Date: 2019.12.22
                        Time: 23:57:06
    18261 - Powertrain Data Bus
                P1853 - 000 - Implausible Message from ABS Controller
                        Reset counter: 40
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 03:48:49
       Revision: 00H45001
       VCID: 005987A40A07E317C97-8054
    6 Faults Found:
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 0
                        Mileage: 127442 km
                        Count: 3
                        Count: 4096
                        Count: 143
                        Count: 44544
                        Count: 256
                        Reset counter: 0
                        Mileage: 127442 km
                        Count: 3
                        Count: 4096
                        Count: 279
                        Count: 44544
                        Count: 256
                        Reset counter: 0
                        Mileage: 127442 km
                        Count: 3
                        Count: 4096
                        Count: 295
                        Count: 44544
                        Count: 256
                        Reset counter: 0
                        Mileage: 127442 km
                        Count: 3
                        Count: 4096
                        Count: 270
                        Count: 44544
                        Count: 256
                        Reset counter: 0
                        Mileage: 127442 km
                        Count: 3
                        Count: 4096
                        Count: 195
                        Count: 44544
                        Count: 256
                        Reset counter: 0
                        Mileage: 127442 km
                        Count: 3
                        Count: 4096
                        Count: 212
                        Count: 44544
                        Count: 256
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0180
       Revision: 000046      Serial number: 8P0820043BM
       VCID: 78A9EF445ED7ABD7F17-802C
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
       Component: BCM PQ35  M   110 0719
       Revision: 00110 AF
       Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
       Shop #: WSC 09550 758 180955
       VCID: 42DD4DAC448B31079F3-8016
       Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
    01134 - Alarm Horn (H12)
                        Reset counter: 89
                        Mileage: 126101 km
                        Date: 2019.12.05
                        Time: 04:46:50
                            Term 15 Off
                        Voltage: 13.10 V
                            Term 50 Off
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Fault Frequency: 169
                        Reset counter: 89
                        Mileage: 126101 km
                        Date: 2019.12.05
                        Time: 04:54:55
                            Term 15 Off
                        Voltage: 12.65 V
                            Term 50 Off
                        Reset counter: 129
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:27:59
                        Voltage: 11.60 V
                            Term 50 Off
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7L0603354
       Coding: 0000100
       VCID: 3635217C14439DA723B-8062
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
       Component: Airbag AU1042 H09 0250
       Revision: --------    Serial number: 003FC001JVA5
       Coding: 303142393041303030374A55304C38503053
       ROD: EV_Airba10AURB4.rod
       VCID: 50F977E49A67D397197-8004
       Subsystem 1 - Part No SW: 8P0 959 339 D    HW: 8P0 959 339 D
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R1190600QZV
       Serial number: 3572DRB40000E005315E
       Serial number: 3582DRB40000E0087A4U
       Serial number: 35128RB400006601E0DF
       Serial number: 35228RB40000660A93CM
       Serial number: 35547RB4000066D588B.
       Serial number: 35647RB4000066D5877X
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0014142
       VCID: 46D551BC64A30D27B3B-8012
       Component: E0221           H02 0100
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
       Component: KOMBIINSTR. VDO H02 0150
       Revision: D0H02002    Serial number: 2248K002001786
       Coding: 0272288
       Shop #: WSC 12345 067 57207
       VCID: 3B2330482F6140CFDC5-806E
                        Mileage: 104614 km
                        Date: 2019.03.26
                        Time: 01:39:04
       Revision:   H42       Serial number: 210911F2002401
       Coding: 352102
       VCID: 35372670054596BF2A1-8060
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 03:48:52
       Revision: D0H02002    Serial number: AUX7Z0K8FNT0IN
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0001181
       VCID: 49CF5A8075BDE25F5E9-801C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 233    3201
       Revision: 00H20000
       VCID: 34311B74023F8FB71DF-8060
                        Fault Status: 00101101
                        Reset counter: 129
                        Mileage: 127429 km
                        Date: 2019.12.22
                        Time: 23:57:45
                        Voltage: 13.50 V
                            DU
                        Temperature: 21.0°C
                        RPM: 1651 /min
                        Speed: 22.0 km/h
                        Speed: 22.0 km/h
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158124266503
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0001181
       VCID: 4ACD658C70BBE947573-801E
       Part No: 8P3 907 357 B
       Coding: 0000013
       VCID: 3C2133542A6F47F7D5F-8068
                        Fault Frequency: 173
                        Reset counter: 129
                        Mileage: 111384 km
                        Date: 2019.06.10
                        Time: 18:58:31
       Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
       Component: R Concert2+     H05 0293
       Revision: 00H05000    Serial number: AUZ1Z3L2599809
       Coding: 0750112
       VCID: 73B3D86847B1C88FC45-8026
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001176
       Shop #: WSC 06314 000 1012544
       VCID: 42DD4DAC488B31079F3-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001176
       VCID: 43D348A85791380F945-8016
       Part No SW: 8P1 862 336 A    HW: 8P1 862 336
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005158070
       Coding: 0001277
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.1V/12.1V)-----------
    Gateway Installation List:  7N0 907 530 H
    VCDS Release 19.6.2:  SRI Reset
    Control Module Part Number: 8P0 920 983 D       Labels:  8P0-920-xxx-17-MY8.clb
    Component:KOMBIINSTR. VDO H02 0150, Coding:0272288
    Channel  	Description                                       	Unit      	Current val.  	New val.
    02       	Service Reminder Status                           	          	1             	---
    40       	Distance since Service                            	km x100   	49            	---
    41       	Time since Service                                	Days      	70            	---
    42       	Minimum Distance to Service                       	km x100   	150           	---
    43       	Maximum Distance to Service                       	km x100   	150           	---
    44       	Maximum Time to Service                           	Days      	365           	---
    45       	Oil Quality                                       	          	1             	---
    47       	Soot Quantity                                     	km x100   	0             	---
    48       	Thermal Load                                      	km x100   	0             	---
    49       	Minimum Time to Service                           	Days      	365           	---
    50       	Basic Distance Value for Oil Change               	km x100   	160           	---
    51       	Basic Time Value for Oil Change                   	Days      	365           	---
    52       	Basic Distance Value for Inspection               	km x100   	160           	---
    53       	Distance since Inspection                         	km x100   	286           	---
    54       	Basic Time Value for Inspection                   	Days      	365           	---
    55       	Time since Inspection                             	Days      	346           	---
    56       	Day Counter                                       	Days      	2472          	---
    Tuesday,24,December,2019,15:46:30:19969
              72 77
       Coding: 0050078
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
                        Reset counter: 40
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:14
                        Reset counter: 1
                        Mileage: 127442 km
                        Date: 2019.12.24
                        Time: 03:26:13
       Revision: 00H45001
    7 Faults Found:
                        Fault Status: 00101100
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.24
                        Time: 03:26:13
                        Count: 3
                        Count: 12800
                        Count: 64
                        Count: 49674
                        Count: 7680
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 143
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 279
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 295
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 270
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 195
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 212
                        Count: 42752
       Revision: 00110 AF
       Coding: 00DD13
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:32:32
                            Term 15 Off
                        Voltage: 12.05 V
                            Term 50 Off
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:34:31
                            Term 15 Off
                        Voltage: 13.60 V
                            Term 50 Off
       Coding: 0000100
       Coding: 0014142
       Coding: 0272288
       Coding: 352102
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:19
       Coding: 0001181
       Revision: 00H20000
                        Reset counter: 129
                        Mileage: 127443 km
                        Date: 2019.12.24
                        Time: 03:36:27
                        Voltage: 11.88 V
                            DD
                        Temperature: 11.0°C
       Coding: 0001181
       Coding: 0000013
                        Reset counter: 129
                        Mileage: 127448 km
                        Date: 2019.12.24
                        Time: 03:26:17
       Coding: 0750112
       Coding: 0001176
       Coding: 0001176
       Coding: 0001277
    End----(Elapsed Time: 01:33, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Address 03,1K0 907 379 AP,recoded (Long Coding),from,000000000000000000000000000000000000,to,1150400F49280001880B02E892200042BF0C00,(00000/000/00000),
    New User
    May 2019
    Kiev, Ukraine
    1142401209280001880B02E890200042xxxx
    to complete two bytes to add
    Или
    1142401209280001880B02E8902000423800
    Dec 2019
    I really appreciate the help!
    Just so I am sure...
    Enter the first code...what do you mean to “complete two bytes to add”?
    Do I just enter the long coding and see if it takes?
    The second coding would be if the first didn’t work?
    Sorry for the questions, this is my first time going through this.
    Quote Originally Posted by Bozwhizzle View Post
    Have you looked in your Scans sub-folder?
    So you're saying you don't have the original coding?
  7. #7
    New User
    May 2019
    Kiev, Ukraine
    Do not think, but do it when a specialist advises. I need information, pleasant coding or rejected, and then we’ll compose it according to the configuration.
    Вместо ххх вставьте ноли 0000.
    Последние байты ручками составим, главное что бы блок скушал кодинг.
  8. #8
    Dec 2019
    Yes I do not have an auto scan from before the swap.
    The original long code for the abs module before swap is the following:
    When I enter the first long code that you provided I get Error 22 “coding rejected, conditions not correct or request sequence error”
    Also, Error 31: request out of range.
    I will run another auto scan and attach it.
    Thanks again!!!
  9. #9
    Dec 2019
    Latest s
    auto scan after I tried the code you sent me.
    Friday,27,December,2019,18:20:42:19969
    Mileage: 127440km-79187mi   Repair Order: 12.27.19
              72 77
       Coding: 0050078
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
                        Reset counter: 40
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:39:30
       Revision: 00H45001
    9 Faults Found:
                        Fault Status: 00100011
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:13:27
                        Count: 3
                        Count: 4608
                        Count: 67
                        Count: 49677
                        Count: 5120
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.24
                        Time: 03:26:13
                        Count: 3
                        Count: 12800
                        Count: 64
                        Count: 49674
                        Count: 7680
    03306 - Coding Not Valid
                        Reset counter: 89
                        Mileage: 264453 km
                        Date: 2001.12.04
                        Time: 00:08:07
                        Count: 768
                        Count: 159
                        Count: 22784
                        Count: 4161
                        Count: 256
                        Count: 36609
                        Count: 212
                        Count: 22785
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 143
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 279
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 295
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 270
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 195
                        Count: 42752
                        Reset counter: 89
                        Mileage: 127442 km
                        Date: 2019.12.23
                        Time: 05:31:15
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 212
                        Count: 42752
       Revision: 00110 AF
       Coding: 00DD13
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:33:03
                        Voltage: 11.70 V
                            Term 50 Off
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:34:28
                            Term 15 Off
                        Voltage: 12.00 V
                            Term 50 Off
       Coding: 0000100
       Coding: 0014142
       Coding: 0272288
       Coding: 352102
                        Reset counter: 89
                        Mileage: 127443 km
                        Date: 2019.12.25
                        Time: 03:39:34
       Coding: 0001181
       Revision: 00H20000
       Coding: 0001181
       Coding: 0000013
       Coding: 0750112
       Coding: 0001176
       Coding: 0001176
       Coding: 0001277
    End----(Elapsed Time: 01:33, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
  10. #10
    Old coding:
    Current module:
    Old coding is one byte too long for current module!
    Try:
