Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: 2012 Audi A3 TDI abs module replacement and coding issues
  1. #41
    Dec 2019
    So I have gotten through a few sections and now I am stuck on one.
    Hydronic Unit Intake Valve
    Ive gotten through the first part - (116-123) press the pedal and hold then I get the (46-53) range and it keeps repeating without ever calibrating correct. Or at least just continues....
    Engine is running, it about 70degrees in the shop I am working in. Engine bay too hot?
    Not sure whats keeping it from progressing to the next step?
    Thanks
  2. #42
    Sep 2016
    Riga, Latvia
    Autoscan from current state?
  3. #43
    Dec 2019
    Here is my latest scan. It looks like I do nbot have the 00003 code and do not need to perform basic settings for hydraulic unit? Just move on to the next?
    Thanks
    Thursday,30,January,2020,13:06:14:19969
    VIN: WAUKJAFM5CA067047   License Plate:
    Mileage: 127440km-79187mi   Repair Order: 1.30.20 c
    Chassis Type: FM-AU35 (7N0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
              72 77
    VIN: WAUKJAFM5CA067047   Mileage: 127440km-79187miles
    4C-Tire Pressure II -- Status: Cannot be reached 1100
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H14---    Serial number: AUX7Z0K8FNT0IN
       Coding: 0050078
       Shop #: WSC 03377 002 1048576
       VCID: 2C010314DA0FD77745F-8078
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
                   U1017 - 000 -  - Intermittent
                        Fault Frequency: 255
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
    009298 - Diesel Particle Filter; Differential Pressure Sensor
                   P2452 - 000 - Elect. Malfunction - Intermittent
                        Mileage: 127443 km
                        Mileage: 450 km
                        Pressure: 0 mbar
                        Pressure: 0 mbar
                        (no units): 0.0
                        Temperature: 18.0C
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 002 -  - Intermittent
                        Mileage: 127443 km
                        Temperature: 18.0C
                        Voltage: 9.88 V
                        Bin. Bits: 00000000
                        Torque: 219.0 Nm
                        Temperature: 17.1C
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Load: 0.0 %
                        Voltage: 0.00 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00000000
                        Temperature: -90.0C
    008449 - Throttle Valve Actuator Control System
                   P2101 - 000 - Malfunction - Intermittent
                        Voltage: 13.98 V
                        Lambda: 99.4 %
                        Bin. Bits: 00000000
       Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 9334
       Revision: 05351113    Serial number: 00001109200366
       Shop #: WSC 06314 000 00000
       VCID: 176BCCF8738944AF18D-8042
       Revision: 00H31001
       VCID: 7BA3F04863E180CF9C5-802E
                        Fault Status: 01100101
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:56:40
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 212
                        Count: 54272
                        Count: 256
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:56:40
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 279
                        Count: 54272
                        Count: 256
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:56:40
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 295
                        Count: 54272
                        Count: 256
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:56:40
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 270
                        Count: 54272
                        Count: 256
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0180
       Revision: 000046      Serial number: 8P0820043BM
       VCID: 78A9EF445ED7ABD7F17-802C
    00532 - Supply Voltage B+
                        Fault Status: 00100001
                        Reset counter: 129
                        Mileage: 127444 km
                        Voltage: 17.40 V
    01301 - Control Module for Voice Recognition (J507)
                        Reset counter: 129
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 01:11:05
                        Reset counter: 129
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 00:47:20
                        Voltage: 15.50 V
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:42:54
       Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
       Component: BCM PQ35  M   110 0719
       Revision: 00110 AF
       Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
       Shop #: WSC 09550 758 180955
       VCID: 42DD4DAC448B31079F3-8016
       Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
    01134 - Alarm Horn (H12)
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:57:54
                            Term 15 On
                        Voltage: 13.35 V
                            Term 50 Off
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7L0603354
       Coding: 0000100
       VCID: 3635217C14439DA723B-8062
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
       Component: Airbag AU1042 H09 0250
       Revision: --------    Serial number: 003FC001JVA5
       Coding: 303142393041303030374A55304C38503053
       ROD: EV_Airba10AURB4.rod
       VCID: 50F977E49A67D397197-8004
       Subsystem 1 - Part No SW: 8P0 959 339 D    HW: 8P0 959 339 D
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R1190600QZV
       Serial number: 3572DRB40000E005315E
       Serial number: 3582DRB40000E0087A4U
       Serial number: 35128RB400006601E0DF
       Serial number: 35228RB40000660A93CM
       Serial number: 35547RB4000066D588B.
       Serial number: 35647RB4000066D5877X
       Component: J0527           H37 0070
       Coding: 0014142
       VCID: 46D551BC64A30D27B3B-8012
       Component: E0221           H02 0100
       Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
       Component: KOMBIINSTR. VDO H02 0150
       Revision: D0H02002    Serial number: 2248K002001786
       Coding: 0272288
       Shop #: WSC 12345 067 57207
       VCID: 3B2330482F6140CFDC5-806E
       Part No SW: 7N0 907 530 H    HW: 1K0 907 951
       Component: J533  Gateway H42 1620
       Revision:   H42       Serial number: 210911F2002401
       Coding: 352102
       VCID: 35372670054596BF2A1-8060
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:56:45
       Revision: D0H02002    Serial number: AUX7Z0K8FNT0IN
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0001181
       VCID: 49CF5A8075BDE25F5E9-801C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 233    3201
       Revision: 00H20000
       Shop #: WSC 02069 000 90108
       VCID: 34311B74023F8FB71DF-8060
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:56:38
                        Battery Volts: 13.8 V
                            DD
                        Temperature: 23.0C
                        Count: 2
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158124266503
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0001181
       VCID: 4ACD658C70BBE947573-801E
       Part No: 8P3 907 357 B
       Coding: 0000013
       VCID: 3C2133542A6F47F7D5F-8068
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
       Component: R Concert2+     H05 0293
       Revision: 00H05000    Serial number: AUZ1Z3L2599809
       Coding: 0750112
       VCID: 73B3D86847B1C88FC45-8026
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001176
       Shop #: WSC 06314 000 1012544
       VCID: 42DD4DAC488B31079F3-8016
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001176
       VCID: 43D348A85791380F945-8016
       Part No SW: 8P1 862 336 A    HW: 8P1 862 336
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005158070
       Coding: 0001277
                        Reset counter: 89
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 02:53:31
    End----------(Elapsed Time: 01:35, VBatt start/end: 13.8V/15.6V)-----------
  4. #44
    Dec 2019
    Just ran a new scan and now 00003 appears?
    Friday,31,January,2020,16:37:54:19969
    Mileage: 127440km-79187mi   Repair Order: 1.31.20 a
              72 77
       Coding: 0050078
                        Mileage: 113554 km
                        Date: 2019.06.29
                        Time: 15:15:21
                        RPM: 1196 /min
                        Speed: 15.0 km/h
                        Load: 29.0 %
                        Voltage: 13.15 V
                        Torque: 96.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00101100
                        Mileage: 127443 km
                        Mileage: 450 km
                        Pressure: 0 mbar
                        Pressure: 0 mbar
                        (no units): 0.0
                        Temperature: 18.0C
                        Mileage: 127443 km
                        Temperature: 18.0C
                        Voltage: 9.88 V
                        Bin. Bits: 00000000
                        Torque: 219.0 Nm
                        Temperature: 17.1C
                        Load: 0.0 %
                        Voltage: 0.00 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00000000
                        Temperature: -90.0C
                        Voltage: 13.98 V
                        Lambda: 99.4 %
                        Bin. Bits: 00000000
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -  - Intermittent
                        Reset counter: 1
                        Mileage: 127444 km
                        Date: 2020.01.14
                        Time: 06:15:51
       Revision: 00H31001
                        Fault Status: 00101100
                        Reset counter: 90
                        Mileage: 127444 km
                        Date: 2020.01.14
                        Time: 06:23:13
                        Count: 3
                        Count: 12
                        Count: 20480
                        Count: 88
                        Count: 45824
                        Count: 65280
    00003 - Control Module
                        Reset counter: 90
                        Date: 2020.01.13
                        Time: 08:43:41
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 143
                        Count: 46848
                        Reset counter: 90
                        Date: 2020.01.13
                        Time: 08:43:41
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 195
                        Count: 46848
                        Fault Status: 01101100
                        Reset counter: 90
                        Mileage: 127444 km
                        Date: 2020.01.14
                        Time: 06:15:51
                        Count: 16387
                        Count: 4
                        Count: 12800
                        Count: 64
                        Count: 50688
                        Count: 65280
                        Count: 256
                        Count: 1280
                        Reset counter: 129
                        Mileage: 127444 km
                        Voltage: 17.40 V
                        Reset counter: 129
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 01:11:05
                        Reset counter: 129
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 00:47:20
                        Voltage: 15.50 V
       Revision: 00110 AF
       Coding: 00DD13
       Subsystem 2 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  9005
                        Fault Frequency: 6
                        Reset counter: 90
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 08:43:54
                            Term 15 Off
                        Voltage: 12.95 V
                            Term 50 Off
                        Fault Status: 01100010
                        Reset counter: 90
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 08:43:56
                            Term 15 Off
                        Voltage: 12.95 V
                            Term 50 Off
       Coding: 0000100
       Coding: 0014142
       Coding: 0272288
       Coding: 352102
                        Reset counter: 90
                        Mileage: 127444 km
                        Date: 2020.01.13
                        Time: 08:43:46
       Coding: 0001181
       Revision: 00H20000
    01316 - ABS Control Module
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 90
                        Mileage: 127444 km
                        Date: 2020.01.14
                        Time: 06:25:28
                        Voltage: 12.50 V
                            DD
                        Temperature: 20.0C
       Coding: 0001181
       Coding: 0000013
                        Fault Status: 00101101
                        Reset counter: 130
                        Mileage: 127448 km
                        Date: 2020.01.14
                        Time: 06:15:55
       Coding: 0750112
       Coding: 0001176
       Coding: 0001176
       Coding: 0001277
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.5V/12.5V)-----------
  5. #45
    Sep 2016
    Riga, Latvia
    Try to do coding and basic settings at one diagnostic session.
    Check wiring to rear left wheel speed sensor. Replace sensor if wiring is ok.
  6. Likes Uwe liked this post
  7. #46
    Dec 2019
    May I will try what you suggest. My problem seems to be the engine bay getting too hot and only being able to get part way through the brake test, hydraulic unit valve section.
  8. #47
    Dec 2019
    Any ideas on why it would keep getting stuck on that particular brake pressure test?
    Thanks
  9. #48
    Dec 2019
    SO I have cleared all the dtc's in each individual group, then performed the basic settings needed from coding abs module on up to the basic settings for intake unite valve and keep getting stuck. Anything direction based on the auto scan?
    Recent auto scan...
    Tuesday,04,February,2020,16:18:44:19969
    Mileage: 127440km-79187mi   Repair Order: 2.4.20
              72 77
       Coding: 0050078
       Revision: 00H31001
       Coding: 1150400F49280001880B02E892200042BF0C00
                        Reset counter: 94
                        Mileage: 127444 km
                        Date: 2020.01.18
                        Time: 05:56:20
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 143
                        Count: 46336
                        Count: 251
                        Reset counter: 94
                        Mileage: 127444 km
                        Date: 2020.01.18
                        Time: 05:56:20
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 16390
                        Count: 46336
                        Count: 251
       Revision: 00110 AF
       Coding: 00DD13
       Component: LIN BACKUP HO  H11 9005
                        Reset counter: 94
                        Mileage: 127444 km
                        Date: 2020.01.18
                        Time: 05:56:33
                            Term 15 On
                        Voltage: 12.75 V
                            Term 50 Off
       Coding: 0000100
       Coding: 0014142
       Coding: 0272288
       Coding: 352102
       Coding: 0001181
       Revision: 00H20000
       Coding: 0001181
       Coding: 0000013
       Coding: 0750112
       Coding: 0001176
       Coding: 0001176
       Coding: 0001277
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.8V/12.8V)-----------
  10. #49
    Sep 2016
    Riga, Latvia
    What if You run output tests for hydraulic valves? Does those tests store more fault codes in ABS module? Does the pump motor can be heard when switched on via output test?
  11. Likes Uwe liked this post
  12. #50
    Dec 2019
    So when I did the brake bleed through vcds the abs pump runs. I have not tried the output test yet. I will try that and see if it stores any other codes.
    Thanks for the reply!
