Results 1 to 4 of 4
Thread: Finding monitoring blocks
    New User
    Dec 2019
    Bristol UK
    Hi, in the process of registering - should have done it when I bought the cable but I thought I did.
    now on my 3rd car and hit a difficulty. I have a combination of open circuit and short to ground on N275 sensor and since its mounted to the plastic airbox I suspect damage in the wiring somewhere and figured that i should be able to real time monitor the sensor so I can inspect the wiring and hopefully find the damaged area when I get changes on that sensor.....
    so I discovered measuring blocks but how do I figure out which would be this particular sensor? I was hoping I could figure it out but nothing on the list seemed to be an obvious solution
    attached latest scan for reference (yes lots of gremlins to sort :-) )
    Monday,23,December,2019,14:53:25:34888
    VCDS Version: 19.6.2.0 (x64)
    VIN: xxxxxxxxxxx   License Plate: xxxxx
    Mileage: 92170km-57271mi   Repair Order: n275 fault
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 0E 10 13 14 15 16 17 19 1B 20 42 46 52 53
              55 56 5F 62 6C 6D 72
    VIN: WAUZZZ8R79A   Mileage: 92170km-57271miles
    Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
       Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
       Component: 3.0TDI EDC17  H01 0008
       Revision: 15H01---
       Coding: 0121002C240F0220
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
       ROD: EV_ECM30TDI0118R0907401J.rod
       VCID: 397F5D94B8D1DA87A0-806C
    4327 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:50
                        Engine speed: 642.50 /min
                        Normed load value: 23.1 %
                        Coolant temperature: 61 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 14.240 V
                        Crankshaft speed (RPM): 642.5 /min
                        Vehicle speed: 0.00 km/h
                        Acceleration: 0.000 m/s²
                        ACCI a Des: 0.007 m/s²
                        ACCI st State-Bits 0-7: 00000000
                        Cruise Control System (CCS): status-Bits 0-7: 00000110
                        ACCI st Brk Err mp-Bits 0-7: 00110000
    5308 - Throttle Body Actuator Bank 1 (J338)
              P0638 00 [175] - Implausible Signal
                        Mileage: 92175 km
                        Date: 2019.12.21
                        Time: 10:29:27
                        Engine speed: 1476.50 /min
                        Normed load value: 60.4 %
                        Vehicle speed: 19 km/h
                        Coolant temperature: 23 °C
                        Intake air temperature: 10 °C
                        Voltage terminal 30: 13.960 V
                        Crankshaft speed (RPM): 1476.5 /min
                        Vehicle speed: 18.41 km/h
                        Thr Vlv r: 100.00 %
                        Ambient temperature: 8.3 °C
                        Intake air temperature: 10.6 °C
                        Throttle valve output stage: 5.00 %
                        Vehicle voltage terminal 30: 13960 mV
    5380 - Valve for Air Filter Bypass Flap (N275)
              P1016 00 [100] - Open Circuit
                        Fault Frequency: 51
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 16:03:42
                        Engine speed: 845.00 /min
                        Normed load value: 70.2 %
                        Vehicle speed: 2 km/h
                        Coolant temperature: 34 °C
                        Intake air temperature: 11 °C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 13.340 V
                        Crankshaft speed (RPM): 0.0 /min
                        Coolant temperature: 7.9 °C
                        Ambient temperature: 8.5 °C
                        Ambient air pressure: 972 hPa
                        AFS dm: 0.0 kg/h
                        Intake air temperature: 9.7 °C
    5382 - Valve for Air Filter Bypass Flap (N275)
              P1015 00 [044] - Short to Ground
                        Fault Frequency: 16
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:41
                        Engine speed: 930.50 /min
                        Normed load value: 45.1 %
                        Coolant temperature: 8 °C
                        Intake air temperature: 9 °C
                        Voltage terminal 30: 11.600 V
                        Crankshaft speed (RPM): 930.5 /min
                        Coolant temperature: 8.0 °C
                        Ambient temperature: 8.8 °C
                        AFS dm: 79.7 kg/h
                        Intake air temperature: 9.4 °C
    Readiness: 1 1 0 0 0
       Part No SW: 8R0 927 156 D    HW: 0B5 927 156 D
       Component: 0B5 30 TDIRdW X02 0014
       Revision: --H02---    Serial number: 0000000071
       Coding: 000001
       Shop #: WSC 00019 210 80940
       ASAM Dataset: EV_TCMDL501 A02202
       ROD: EV_TCMDL501.rod
       VCID: 3C714480B7E3EFAFBB-8068
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
       Component: ESP8 quattro  H06 0230
       Coding: 0F7D00
       Shop #: WSC 06335 123 12345
       VCID: 40893070D30B8B4FE7-8014
                003 - Mechanical Failure - Intermittent - MIL ON
                        Fault Status: 10100011
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:50
                        Hex Value: 0x0200
                        Hex Value: 0x40A6
                        Hex Value: 0x1241
                        Hex Value: 0xA8B8
                        Hex Value: 0x00FF
                        Fault Status: 00101101
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:51
                        Hex Value: 0x0000
                        Hex Value: 0x43A6
                        Hex Value: 0x1216
                        Hex Value: 0x02B7
                        Hex Value: 0x00FF
    03159 - TPMS Functionality in ESP
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 11:06:02
                        Hex Value: 0x0000
                        Hex Value: 0x43A6
                        Hex Value: 0x121B
                        Hex Value: 0x0DB7
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 AQ    HW: 8K0 907 064 AQ
       Component: BCM2 1.1      H80 0145
       Coding: 051500
       VCID: 7F0B738CEE7534B7DE-802A
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000072133010
    00192 - Rear Left Door Handle Touch Sensor (G417)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 190
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:30:04
       Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D1000000    Serial number: 0124.09.080152
       Coding: 36150000
       VCID: 43833F7CC21D9057FA-8016
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000139537
       Coding: 2600D0914074AF311F01000300001D0D0F9DC74800010141000000
       VCID: 306960B063AB1BCF17-8064
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 080415  H10 0041
       Serial number: 90243015070307114556
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 10282856
       Coding: 024D25
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0080
       Serial number: 00000000000110081778
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
       Component: CDC-MP3-Pana  H47 0050
       Revision: 00000011
       VCID: 214F95F43841A24788-8074
       Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0020
       Revision: 11001001    Serial number: 52830827106538
       Coding: 300105
       VCID: 3B73479CBAEDE897B2-806E
    Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
       Part No SW: 8R0 907 561     HW: 8R0 907 561
       Component: ACC2          H01 0020
       Coding: 0079B6
       VCID: 76E596A8C14F75FF8D-8022
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:50
                        Temperature: 22.0°C
                        Voltage: 14.46 V
                        Bin. Bits:    00000
                        Hex Value: 0x044B
                        Hex Value: 0x0015
                        Speed: -3.6 km/h
                        Lateral Accel.: -0.12 m/s^2
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:50
                        Temperature: 22.0°C
                        Voltage: 14.34 V
                        Bin. Bits:    00000
                        Hex Value: 0x044B
                        Hex Value: 0x0013
                        Speed: -3.6 km/h
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8R0 907 364 A    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H08 0051
       Revision: 00000000    Serial number: 30090807490002
       Coding: 070181
       Shop #: WSC 00022 210 64013
       VCID: 387958908BDBC38F5F-806C
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 B    HW: 8R0 959 655 B
       Component: AirbagVW-AU10 H02 0310
       Serial number: 003E8D023ZRJ
       Coding: 30353131313030303030554A305238523053
       ASAM Dataset: EV_AirbaAU10SMEAU416 001001
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 43833F7CCA1D9057FA-8016
       Serial number: 6334MSME42231129/
       Serial number: 6344MSME41304542/
       Serial number: 6352QSME440E1D2ET
       Serial number: 6362QSME56100020Z
       Serial number: 63732SME1C101F0A$
       Serial number: 63832SME28115406R
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HJ2000AE
       Coding: 00003F
       VCID: 3E754E88A9FFFDBF95-806A
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:50
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 980 G    HW: 8R0 920 980 G
       Component: KOMBIINSTR.   H07 0224
       Revision: 00100000    Serial number: 9EX661Y98
       Coding: 230F22003F002600010000
       VCID: 3D774984A4F9E6A78C-8068
       Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0094
       Revision: 4FB50047    Serial number: 4700F089238062
       Coding: 000303
       VCID: 4A9D1258E537411F39-801E
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0100
       Serial number: 00000000002730321367
                        Reset counter: 190
                        Mileage: 92175 km
                        Date: 2019.12.21
                        Time: 10:28:05
       Part No SW: 8K0 907 144 C    HW: 8K0 907 144 C
       Component: DYNAMIKLENK.  H06 0500
       Revision: 50001003    Serial number: --------------
       Coding: 020000
       Shop #: WSC 06334 000 00000
       VCID: 2F6B63CC7E9504370E-807A
       Part No SW: 8K0 857 511 C    HW: 8K0 857 511 A
       Component: FLA           H04 0003
       Revision: AA001002
       Coding: 02022064747464545425363E
       VCID: 316F65B468A112C718-8064
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000007704646
       Coding: 011D12205001440004
       VCID: 418F3574D8018247E8-8014
       Revision: 00002001    Serial number: 0114955063
       Coding: 013B0E2220393495042005
       Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J245EE16SKB10  H01 0180
       Subsystem 4 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J394EE16SKB10  H01 0180
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007700380
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 10000000112999
                        Reset counter: 230
                        Mileage: 92176 km
                        Date: 2019.12.21
                        Time: 10:51:50
                        Voltage: 14.60 V
                        Count: 62
                        Hex Value: 0x0263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Address 55: Headlight Range        Labels: 8T0-907-357.clb
       Part No SW: 8H0 907 357 C    HW: 8H0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000022
       Shop #: WSC 22785 002 1048576
       VCID: 326D6AB8ADA729DF61-8066
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Part No SW: 4F0 035 061 D    HW: 4F0 035 061
       Component: Radio U DAB   H45 0024
       Revision: AB001007    Serial number: 343AK0A7543113
       Coding: 010103020100000001
       Shop #: WSC 00720 210 86430
       VCID: 1D37A904043986A7AC-8048
    02877 - Digital Radio Antenna (R183)
                        Reset counter: 189
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:14
                        Voltage: 12.30 V
                        Reset counter: 189
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:05
    03175 - Invalid Data Set
                        Reset counter: 189
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:04
                        Voltage: 12.30 V
                        Bin. Bits: 00000000 00001110
       Part No SW: 8T2 035 666 D    HW: 8T2 035 666
       Component: H-BN-EU       H60 0047
       Revision: --------    Serial number: 344J$087508573
       Coding: 010101060005E9EF27001F1E000000030001
       VCID: 3C714480BFE3EFAFBB-8068
       Subsystem 1 - Part No: 8R0 060 884
       Component: EUROPE 2008  5505
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356JL081018121
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000165008
                        Reset counter: 189
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:10
                        Bin. Bits: 00000001 00000000
                        Bin. Bits: 00000000 00000000
       Revision:             Serial number: 0000007792876
       Coding: 010C12204001240004
       Part No SW: 8R0 907 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J89A04S
       Coding: 1023010
       VCID: 73E3AFBC123D60D7AA-8026
       Part No SW: 8R0 827 851 A    HW: 8R0 827 851
       Component: J605  Master  H24 0240
       Revision: --------    Serial number: 8R0827851
       VCID: 3A7D4298B5D7D19FA9-806E
       Subsystem 1 - Part No SW: 8R0 827 852 A    HW: 8R0 827 852
       Component: J756  Slave  H24 0240
       Serial number: 8R0827852
    16347 - Control Module - EEPROM Error
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 189
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:03
    02242 - Rear Lid Lock Button in Luggage Compartment (E406)
                        Reset counter: 189
                        Mileage: 92175 km
                        Date: 2019.12.20
                        Time: 12:26:03
       Revision:             Serial number: 0000007792953
    End-------------------------(Elapsed Time: 04:09)--------------------------
    I think you are working on an incorrect premise. N275 is not a sensor, it's an actuator. I'm not sure whether it's just on/off or whether it's duty-cycle controlled.
    Some actuators do have position feedback sensors, but the faults in this case don't indicate that.
    IMO, the correct way to pursue this is with wiring diagrams and a multi-meter, because I doubt there is a measuring value that will show you what you think you're looking for.
  3. Likes opentoideas liked this post
    And you should be able to activate it with [Output Tests-03] if wiring/connection/fuse is okay, with "Intake air switch-over valve"
  5. Likes Uwe, opentoideas liked this post
  6. #4
    New User
    Dec 2019
    Bristol UK
    thanks for the suggestions, i am still finding my way around elsawin so i guess i need to see if i can find this in the wiring diagrams. makes sense there isnt a channel in measuring blocks, i presume the electrical connection probably is the solenoid to actuate the vacuum servo.
    will have a look at the output test too as this may let me find it as it seems to be an intermittent fault any type of real time monitoring should help narrow down the location of the fault in the wiring.
