Saturday,07,December,2019,10:06:30:14741
VCDS Version: 19.10.0.0 (x64) HEX-NET CB: 0.4517.4
Data version: 20190930 DS316.0
VIN: 3VWH17AU0KM518424 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F 75 A5 CA D6 D7
VIN: 3VWH17AU0KM518424 Mileage: 45km-27miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00235
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: C6DEBD52A824F46113A7-8092
Readiness: 0010 0101
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01907081318
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: D9E4662E099A6B994E65-808C
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 52119000000548
Coding: 43FA6AA130210974807B0302A0C729C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200
Shop #: WSC 00066 790 00154
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 865E7D52E8A434615327-80D2
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0522428421
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: C5DCBA5E9522FF791AAD-8090
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 02020024200118000104000012111008
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: C8C2B36AA230E211E1CB-809C
Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C86430081904HX
Shop #: WSC 00066 790 00075
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019.rod
VCID: FBA81CA6A36679893CC9-80AE
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190625 043 0551
Serial number: 97022066190704200215
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY19M07D12H02M22S30
Coding: 0008DD
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300060820190C200323
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000137089R19231
Coding: 0271167811
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: D1F49E0E516A23D9B635-8084
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 350000C141FFC728949C810520401600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
VCID: C4DAA75A9E18C6710DB3-8090
Component: AirbagVW20 010 0830
Serial number: 003GCR0CBT1P
VCID: C7C0B056AF2EED69E8D1-8092
Occupant Detection:
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000BYXHP.
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 307 19
Serial number: 357000000001B1CC6D3V
Subsystem 3 - Part No SW: ----------- HW: 480 001 607 19
Serial number: 358000000005D7B46D3Z
Subsystem 4 - Part No SW: ----------- HW: 480 401 507 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001ACF08AF86142F
Subsystem 5 - Part No SW: ----------- HW: 480 401 507 19
Component: SideSensor_Pr 005 6149
Serial number: 35200019AF051DC1B338
Subsystem 6 - Part No SW: ----------- HW: 480 402 507 19
Component: FrontSensor_D 005 6149
Serial number: 35500019EF092D9776CV
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 507 19
Component: FrontSensor_P 005 6149
Serial number: 35600019EF092D96F8A$
Part No SW: 5G1 920 840 D HW: 5G1 920 840 D
Component: KOMBI 252 2700
Coding: 0BA4101DED88CF0502886A0B5001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: A80213EA02700211018B-80FC
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 26081900841026
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: EE8E25F2E0141C218B57-80BA
Component: 0-00-0d-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MDM H18 0052
Serial number: 33190001039080021439
Coding: 2EFFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H55 0041
Serial number: 0334944
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00024.05.19
Coding: 0001
VCID: CCCA8F7AB6480E31C5E3-8098
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000183236013
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: B134FE8E31AA43D9D6F5-80E4
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0521418943
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: BD2CD2BEFDF2B7B9427D-80E8
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0525183581
Coding: 020111
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038921701278
Coding: 003A13200000040000000000
Shop #: WSC 01383 790 50316
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: CFF09876475E3529A001-809A
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000003985068
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 930A0000
ROD: EV_SteerAssisMQB_015.rod
VCID: D0F29B0A5A602AD1B93B-8084
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD05PSPM
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: AE0EE5F220945C21CBD7-80FA
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 16081900840373
Coding: 000000050900211200110F01030000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: B53CCA9EC5C26FF98A0D-80E0
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46038921800153
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: CECE857240543C21AB17-809A
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000003985856
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Coding: 027312020000000041220002001808009F0508F401200505C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: B338F486CBB671C9A419-80E6
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 254 8130
Serial number: VWZ6ZMW2445952
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: C3D8A4469B16C14934B9-8096
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 28051912K24694
Coding: 000307020002020100221354C150490084000E20012000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: C0D2AB4A8A00DA51299B-8094
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804073720C
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: F5BC0A9E85422FF94A8D-80A0
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: B924C6AEE9DA8B996E25-80EC
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.2V)-----------
