jameeduardo
- Nov 17, 2014
- 19
- 10
- USA
- HC425404 (2nd hand?)
Hi, I need help, i replace used ABS Module and iI need Coding:
Thanks in Advance
Thanks in Advance
Sunday,22,December,2019,11:49:17:15187
VCDS Version: 19.6.2.0
VIN: 3VWRM71K99M024700 License Plate: JUAN
Mileage: 180370km-112076mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K99M024700 Mileage: 180370km-112076miles
04-Steering Angle -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 P HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H02--- Serial number: VWX7Z0H624F0BC
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 3B74B19E7A5EF397B2-806E
Readiness: 0010 1101
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 7DF07F8624CA3DA7CC-8028
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
VCID: 74E65AA2D7807CEFB3-8020
03306 - Coding Not Valid
Reset counter: 183
Mileage: 180377 km
Count: 3
Count: 12
Count: 12288
Count: 4161
Count: 42240
Fault Status: 01100101
Reset counter: 183
Mileage: 180377 km
Count: 16391
Count: 12
Count: 512
Count: 279
Count: 41984
Reset counter: 183
Mileage: 180377 km
Count: 16391
Count: 12
Count: 512
Count: 270
Count: 41984
Reset counter: 183
Mileage: 180377 km
Count: 16391
Count: 12
Count: 512
Count: 195
Count: 41984
Reset counter: 183
Mileage: 180377 km
Count: 16391
Count: 12
Count: 512
Count: 291
Count: 41984
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CF672823FD034AFFB-8028
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001027626
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: 326A9CBAAD1432DF61-8066
Component: Wischer 290708 021 0501
Coding: 00038805
Shop #: WSC 00066
Fault Status: 01101100
Reset counter: 183
Mileage: 180375 km
Voltage: 13.95 V
Reset counter: 183
Mileage: 180375 km
Voltage: 13.95 V
Reset counter: 183
Mileage: 180377 km
Voltage: 11.60 V
Revision: 00000000 Serial number: AUZ4Z7H0371149
Coding: 0000100
VCID: 336499BE520E3BD76A-8066
Reset counter: 180
Mileage: 180375 km
Time: 05:09:31
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M067C8W
Coding: 0013889
VCID: 6CD642C24FB0A42F6B-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME25706D51A
Subsystem 3 - Serial number: 6342MSME39252E19H
Subsystem 4 - Serial number: 6351HSME16612B295
Subsystem 5 - Serial number: 6361HSME12601867%
Subsystem 6 - Serial number: 63727SME1671175C0
Subsystem 7 - Serial number: 63827SME16711456Z
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 0304097E422E4B57BA-8056
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H624F0BC
Coding: 0023203
Shop #: WSC 00066 067 57207
VCID: 3C76B2827F50F4AFBB-8068
Reset counter: 221
Mileage: 180377 km
Time: 05:35:41
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 170608F2000163
Coding: ED807F070003021002
VCID: 3560A7A65C7A25E744-8060
Fault Status: 00110100
Reset counter: 221
Mileage: 180377 km
Time: 05:35:42
Reset counter: 221
Mileage: 180377 km
Time: 05:35:42
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000294288710
Coding: 0001205
VCID: 6FEC55CE7EA65F374E-803A
Fault Status: 00100101
Reset counter: 221
Mileage: 180375 km
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 00101100
Reset counter: 223
Mileage: 180375 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5A84DA85C47A1FD9-807E
Fault Status: 11100101
Mileage: 180375 km
Time: 05:09:29
Battery Volts: 14.2 V
DU
Temperature: 15.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 04060A6247204C6F83-8050
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000020388712
Coding: 0001204
VCID: 70EE56B2639840CF57-8024
Fault Frequency: 7
Reset counter: 183
Mileage: 180375 km
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7J2290982
Coding: 0010400
VCID: 29587BD680C27107D0-807C
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003311201
Coding: 0001168
VCID: 76E260AA01FC6EFF8D-8022
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003278686
Coding: 0001168
VCID: 77FC6DAE06F617F796-8022
Fault Status: 00111000
Reset counter: 223
Mileage: 180375 km
01554 - Motors for Central Locking; Rear Doors; Lock
Fault Status: 01111100
Reset counter: 183
Mileage: 180375 km
