Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: ABS coding/calibration
    Dec 2019
    KY, USA
    So, I have a 2012 Jetta 2.0. My brakes go to the floor before grabbing. I checked a few things before running VCDS only to find out out it's my ABS module that's bad...
    My question is, do I need to swap it with one of the exact part number or can i use one that has a slightly different number? For example, mine is 1K0 907 379 BJ, could i use one with slightly different number(letters) as in one that ends in BC or BL or so on, or get the one ending with BJ? And do I still need to code it and calibrate the sensors if I get one with the same part number? Thanks you in advance.
    Oct 2017
    Northwest UK
    Hi
    Please can you provide a full autoscan.
    You can change to one with different letters after it, usually this refers to a later version, e.g A is the first and AG is a later revision.
    Dec 2019
    KY, USA
    Ok, I can provide a full auto scan later. Currently at work... I found a used replacement from a 2015, same part number but the letters end with "BS".. the attached pump doesnt have the same part number as my current pump. Does that matter?
    Oct 2017
    Northwest UK
    Quote Originally Posted by 1990loyale View Post
    That should be fine. We need to see the scan and you'll need to make a record of the coding and adaptations to save headache later. Upload it when you get a chance.
    Dec 2019
    KY, USA
    below is my AutoScan on the vehicle.
    Monday,23,December,2019,16:59:19:33639
    VIN: 3VW2K7AJ7CM304346   License Plate: 2012JETTA
    Mileage: 123210km-76559mi   Repair Order:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 56
    VIN: 3VW2K7AJ7CM304346   Mileage: 123210km-76559miles
    Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
       Part No SW: 06G 906 055 S    HW: 06G 906 055 B
       Component: 2.0l / 85 KW     01 1106
       Revision: T5H04---    Serial number:
       Coding: 0001015
       Shop #: WSC 03200 444 83878
       VCID: 392FD1DEB551A4BFCE9-806C
       Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
       Component: AQ 250 6F           1791
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 7F5BFFC6EBF54A8FB0D-802A
       Revision: 00H31001
       Coding: B14B240C512208FE8D0E24E88A1F1061A70000
       VCID: 7BA30BD6F3ED56AF9C5-802E
    02214 - Tire Pressure Warning
                        Reset counter: 50
                        Mileage: 122773 km
                        Date: 2014.05.09
                        Time: 08:05:54
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 51713
                        Count: 1023
                        Count: 49
       Part No SW: 5C0 820 047 AM    HW: 5C0 820 047 AM
       Component: J301  Klimaanlage   0203
       Revision: 2001010S    Serial number: 00000000443369
       VCID: 6B833B968F8DC62F0C5-803E
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0251
       Revision: B2066001    Serial number: 04371190110523
       Coding: 7B994B3828AB0B0000302000240884D4904250EE60000000300000000000
       Shop #: WSC 00066 123 12345
       VCID: 2F3BEF8677157A0F60D-807A
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3464
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3464
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3464
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3464
       Coding: 800000
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   013 0807
       Serial number: 003GTD0B8YM7
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3431E0EA9EB359D71DF-8060
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1100005FXZ0E
       Coding: 303148
       Serial number: 3572MSME742E555FZZZ7
       Serial number: 3582MSME577A135EZZZ3
       Serial number: 3516KSME6F1F7710ZZZ+
       Serial number: 3526KSME59236C10ZZZS
       Serial number: 3556LSME5A023610ZZZL
       Serial number: 3566LSME442C3610ZZZR
       Part No SW: 5C6 920 951     HW: 5C6 920 951
       Component: KOMBI         H04 0604
       Coding: 270201
       Shop #: WSC 00066 000 00122
       VCID: 6889449A92FBED37617-803C
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0251
       Revision: B2066001
       Coding: 102200
       VCID: 70B92CFAAAAB25F7397-8024
       Component: IMMO          H04 0604
       VCID: 6A8D3E928CF7DF27773-803E
       Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
       Component: LOW NAR       H02 0004
       Revision: -----03S    Serial number: VWZ4Z6L3159832
       Coding: 05000400010006
       VCID: 231313B62BDDCE6FF45-8076
    End----------(Elapsed Time: 01:00, VBatt start/end: 12.1V/12.0V)-----------
    OP is now Verified; moving to Car Repair Support.
    Oct 2017
    Northwest UK
    You now need to make a admap of 03 ABS. If you search the wiki it will tell you how to do it, it's very easy.
  9. #8
    Dec 2019
    KY, USA
    Quote Originally Posted by myounus View Post
    Ok, thank you! I found it... I'm new to the coding part of all this, I've only done basic coding for tweaks and such. Where will I find the coding to program the new module?
  10. #9
    Isn't this repair under safety recall campaign?
  11. #10
    Oct 2017
    Northwest UK
    You put in your current coding as that is what your car is set to.
