A month or so ago I did the 100k-ish typical A8 front suspension service like I had to do on both, my 04 and 08. I replaced all control arms, sway bar links and both shocks. She rode like a dream again, but last week I've been getting a suspension warning indicator with these fault codes:
358147 - Relay for Ride-Height Compressor
C1038 07 [009] - Mechanical Failure
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:56
403200 - Function Shut-Off Active
C10C8 00 [009] - -
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:34
Since I've been rolling with a leak for a couple of month while I didn't have time to do surgery, I went ahead and swapped out the compressor and the relay, but I can't get the darn compressor to kick in again and the relay fault won't go away. I tested my old and the new relay, they both close when I put 12V on it, and my multimeter is reading 0.1 resistance. I checked all the fuses for the supply voltage and everything looks good, I even get 12V on the relay socket. When I manually close the circuit on the relay the compressor runs fine. I am at a complete loss and haven't found any posts specific to this issue, all are where the compressor was running hot due to performance issues and burned out the relay.
I did a full read out and the only other faults I found was for a coolant pump about to go out and an ABS code I can't read due to having the old interface. Anybody run into this issue or has an idea what this could be while I wait for the dealer to open to throw another relay at it?
Full scan:
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:56
C10C8 00 [009] - -
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:34
Full scan:
Sunday,22,December,2019,18:55:09:40399
VCDS Version: 19.6.2.0 (x64)
VIN: WAURVAFD7CN019433 License Plate: 1222191855
Mileage: 185257km-115113mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 28 34 36 3B 42 46 47
48 52 53 56 5B 5F 62 6C 6D 6F 72 81 84 88 89 8A 8D 8F 90
VIN: WAURVAFD7CN019433 Mileage: 185257km-115113miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (------CDRA) Labels:| 079-907-560-CFS.clb
Part No SW: 4H0 907 560 C HW: 4H0 907 560
Component: 4.2l V8/4V H07 0004
Revision: N5H07---
Coding: 0106000A290F0168
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
ROD: EV_ECM42FSI0114H0907560C.rod
VCID: 2A501E9D4D62E61FD9-807E
Readiness: 1110 0101
Part No SW: 4H1 927 158 BR HW: 0BK 927 156 K
Component: 0BK 42 FSIUSA H08 1001
Revision: --H08---
Coding: 000002
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 010299319094C547A8-8054
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 D HW: 4H0 907 379 D
Component: ESP PREMIUM H10 0352
Coding: 44E6F20022674F00E200
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 336E03F99AA8A7D76A-8066
0776 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:23
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 23
Uz: B3
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 BD
Component: BCM2 2.0 H31 0510
Coding: 0D872006000000000000
Shop #: WSC 22155 444 131269
VCID: 6ED8D28DB90ACA3F45-803A
Component: J764 ELV MLB H39 0046
Serial number: 2311000236048012
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000017688159
Coding: C018B60085043201010001010101112131313333283333
VCID: 356A3DE19CDCB9E744-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0072
Coding: 480122BEC8
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 254AEDA1247CC967F4-8070
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 17:35:17
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001283885
Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
Shop #: WSC 13561 002 1048576
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 111021 H35 0040
Serial number: 111029044831
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10159346
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Serial number: 02 11 2011 00000930
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02AA2F0F
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000002051600010003
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000031101100010461
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103159000000547376
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 95580AD5000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 234EF3B9224837579A-8076
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Revision: 11001001 Serial number: 55901131600553
Coding: 280102
ROD: EV_EPHVA18AU57X0000_002_AU64.rod
VCID: 3B7E2BD9B2F86F97B2-806E
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H41 0041
Revision: -------- Serial number: 003JS00178VB
Coding: 303143303230303030344A55304C34483053
VCID: 377637E98ED04BF756-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R11A3102B1V
Serial number: 3575HRB405F0UJCIDGPH
Serial number: 3585HRB405H0UJCI9PNN
Serial number: 3515JRB40530R8ACLOCP
Serial number: 3525JRB40550R8ACFPLW
Serial number: 3554VRB40570ODIS6P9A
Serial number: 3564VRB40590ODISB0H1
Revision: -------- Serial number: 90815KIG0009D
Coding: 000034
VCID: 377637E986D04BF756-8062
Subsystem 1 - Part No SW: 4H0 951 528 J HW: 4H0 951 528 J
Component: E221 - MFL H09 0009
Serial number: 30 09 2011 33138990
Part No SW: 4H0 920 820 F HW: 4H0 920 820 F
Component: TBenUSA---NV- H71 0416
Revision: 32081056 Serial number: 658221011593066
Coding: 0B6608011300D705020000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU64.rod
VCID: 2756E7A95E70DB77C6-8072
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1111019000173
Part No SW: 4H0 907 468 G HW: 4H0 907 468 C
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000301519
Coding: 00C1034A00
ROD: EV_GatewUDS_AU57.rod
VCID: 356A3DE194DCB9E744-8060
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650836575
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H15 0062
Coding: 0000000000
ROD: EV_AirCondiHeck_AU64.rod
VCID: 316209F160B495C718-8064
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
VCID: 2C5C18854796F82F2B-8078
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:56
C10C8 00 [009] - -
Reset counter: 138
Mileage: 185257 km
Date: 2019.12.22
Time: 18:11:34
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000017676086
Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA310131030
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6CDCD8858716382F6B-8038
Part No SW: 4H0 959 793 G HW: 4H0 959 793 G
Component: TSG FA H06 0261
Revision: -------- Serial number: 0000121938724
Coding: 011F1F005E0062C202003006
VCID: 3D7A25C1A4EC61A78C-8068
Revision: 00002001 Serial number: 0163122272
Coding: 0106023A00FA759FB0B0C780020301000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000055064
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 144300008665
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2011000000000500242
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 143200003344
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 144300008664
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 143200003345
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84181635
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000033503
Coding: 030000
Shop #: WSC 02583 002 1048576
VCID: 1D3AC541042C01A7AC-8048
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 HW: 4H0 959 860
Component: MEM-FS-Fond H06 0155
Revision: AA000000 Serial number: 00000016567105
Coding: 001892800000300D0A00392038193A2039203B3B202020
VCID: 71E2C9F1A834D5C758-8024
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000121897008
VCID: 3C7C28C5BFF668AFBB-8068
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000176958
ROD: EV_ParkiBrake_VW51.rod
Part No SW: 4H0 035 082 H HW: 4H0 035 082
Component: Radio U SIRIU H53 0138
Revision: AB001007 Serial number: 155K%0B7516095
Coding: 020007010000000001
VCID: 2648EAAD517AC27FFD-8072
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0155
Revision: AA000000 Serial number: 00000016566434
Coding: 001896800000300D0A00392038193A2039203B3B382020
Part No SW: 4H0 035 746 M HW: 4H0 035 746 J
Component: H-BNT-NA H42 1038
Revision: -------- Serial number: 503EQ0G7506111
Coding: 020200000001F1EF45168B1E00000003140001000000000000
Shop #: WSC 12538 002 1048576
VCID: 326006FD6DB2AEDF61-8066
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 4H0 919 604 D HW: 4H0 919 604 D
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDB6900FZ6+
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000058002
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0261
Revision: -------- Serial number: 0000121942038
Coding: 010F1F00420062C202003006
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Revision: --H04--- Serial number: 525 PA8J19D05C
Coding: 1080003
Shop #: WSC 02391 785 00200
VCID: 2648EAAD917AC27FFD-8072
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 117100785
Coding: 0210044100
ROD: EV_DeckLidContrUnit.rod
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000051214
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63CEB3B96AC87757DA-8036
Component: TSG HR H06 0261
Revision: -------- Serial number: 0000121942017
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5013 Serial number: SN111014 0056
ROD: EV_GSM2x3Mono.rod
VCID: 2B5E1B994298FF1722-807E
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0028
Serial number: 0K84AE40052431
Coding: 1200
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001129900607
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00002603252501
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F660F89768083370E-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00002603255902
Coding: 364FF2
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00002662136201
Coding: 200F00
ASAM Dataset: EV_IVBDriveSideRear 001003
VCID: 2E58128D718A8A3F05-807A
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00002662138802
Coding: 200F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 326006FD65B2AEDF61-8066
End-------------------------(Elapsed Time: 07:23)--------------------------
