Results 1 to 10 of 18
Thread: 2012 Audi A8 Relay for Ride-Height Compressor Mechanical Failure
    Dec 2019
    A month or so ago I did the 100k-ish typical A8 front suspension service like I had to do on both, my 04 and 08. I replaced all control arms, sway bar links and both shocks. She rode like a dream again, but last week I've been getting a suspension warning indicator with these fault codes:
    358147 - Relay for Ride-Height Compressor
    C1038 07 [009] - Mechanical Failure
    Reset counter: 138
    Mileage: 185257 km
    Date: 2019.12.22
    Time: 18:11:56
    C10C8 00 [009] - -
    Reset counter: 138
    Mileage: 185257 km
    Date: 2019.12.22
    Time: 18:11:34
    Since I've been rolling with a leak for a couple of month while I didn't have time to do surgery, I went ahead and swapped out the compressor and the relay, but I can't get the darn compressor to kick in again and the relay fault won't go away. I tested my old and the new relay, they both close when I put 12V on it, and my multimeter is reading 0.1 resistance. I checked all the fuses for the supply voltage and everything looks good, I even get 12V on the relay socket. When I manually close the circuit on the relay the compressor runs fine. I am at a complete loss and haven't found any posts specific to this issue, all are where the compressor was running hot due to performance issues and burned out the relay.
    I did a full read out and the only other faults I found was for a coolant pump about to go out and an ABS code I can't read due to having the old interface. Anybody run into this issue or has an idea what this could be while I wait for the dealer to open to throw another relay at it?
    Full scan:
    Sunday,22,December,2019,18:55:09:40399
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAURVAFD7CN019433   License Plate: 1222191855
    Mileage: 185257km-115113mi   Repair Order:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 28 34 36 3B 42 46 47
              48 52 53 56 5B 5F 62 6C 6D 6F 72 81 84 88 89 8A 8D 8F 90
    VIN: WAURVAFD7CN019433   Mileage: 185257km-115113miles
    48-Seat, Rear, DS -- Status: OK 0000
    5B-Seat,Rear,PS -- Status: OK 0000
    84-Night Vision -- Status: OK 0000
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Component: 4.2l V8/4V    H07 0004
       Revision: N5H07---
       Coding: 0106000A290F0168
       Shop #: WSC 02313 785 00200
       ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
       ROD: EV_ECM42FSI0114H0907560C.rod
       VCID: 2A501E9D4D62E61FD9-807E
    Readiness: 1110 0101
       Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
       Component: 0BK 42 FSIUSA H08 1001
       Revision: --H08---
       Coding: 000002
       ASAM Dataset: EV_TCMALX51011 002018
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 010299319094C547A8-8054
       Part No SW: 4H0 907 379 D    HW: 4H0 907 379 D
       Component: ESP PREMIUM   H10 0352
       Coding: 44E6F20022674F00E200
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 336E03F99AA8A7D76A-8066
    0776 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
                        Reset counter: 138
                        Mileage: 185257 km
                        Date: 2019.12.22
                        Time: 18:11:23
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 39
                        F-Type: 23
                        Uz: B3
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
       Component: BCM2 2.0      H31 0510
       Coding: 0D872006000000000000
       Shop #: WSC 22155 444 131269
       VCID: 6ED8D28DB90ACA3F45-803A
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000236048012
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000017688159
       Coding: C018B60085043201010001010101112131313333283333
       VCID: 356A3DE19CDCB9E744-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
       Component: Klima 4 Zonen H20 0072
       Coding: 480122BEC8
       VCID: 254AEDA1247CC967F4-8070
    0378 - Coolant Circulation Pump
              B10D0 04 [009] - Internal System Fault
                        Reset counter: 138
                        Mileage: 185257 km
                        Date: 2019.12.22
                        Time: 17:35:17
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001283885
       Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
       Shop #: WSC 13561 002 1048576
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 111021  H35 0040
       Serial number:         111029044831
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10159346
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
       Component: E1 - LDS  H07 0044
       Serial number: 02 11 2011  00000930
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z02AA2F0F
       Serial number: 00000002051600010003
       Coding: 100000
       Serial number: 00000031101100010461
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA103159000000547376
       Coding: 020300
       Serial number: 95580AD5000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       VCID: 234EF3B9224837579A-8076
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901131600553
       Coding: 280102
       ROD: EV_EPHVA18AU57X0000_002_AU64.rod
       VCID: 3B7E2BD9B2F86F97B2-806E
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H41 0041
       Revision: --------    Serial number: 003JS00178VB
       Coding: 303143303230303030344A55304C34483053
       VCID: 377637E98ED04BF756-8062
       Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R11A3102B1V
       Serial number: 3575HRB405F0UJCIDGPH
       Serial number: 3585HRB405H0UJCI9PNN
       Serial number: 3515JRB40530R8ACLOCP
       Serial number: 3525JRB40550R8ACFPLW
       Serial number: 3554VRB40570ODIS6P9A
       Serial number: 3564VRB40590ODISB0H1
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90815KIG0009D
       Coding: 000034
       VCID: 377637E986D04BF756-8062
       Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
       Component: E221 - MFL  H09 0009
       Serial number: 30 09 2011  33138990
       Part No SW: 4H0 920 820 F    HW: 4H0 920 820 F
       Component: TBenUSA---NV- H71 0416
       Revision: 32081056    Serial number: 658221011593066
       Coding: 0B6608011300D705020000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU64.rod
       VCID: 2756E7A95E70DB77C6-8072
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1111019000173
       Part No SW: 4H0 907 468 G    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000301519
       Coding: 00C1034A00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 356A3DE194DCB9E744-8060
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650836575
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H15 0062
       Coding: 0000000000
       ROD: EV_AirCondiHeck_AU64.rod
       VCID: 316209F160B495C718-8064
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C5C18854796F82F2B-8078
                        Reset counter: 138
                        Mileage: 185257 km
                        Date: 2019.12.22
                        Time: 18:11:56
              C10C8 00 [009] - -
                        Reset counter: 138
                        Mileage: 185257 km
                        Date: 2019.12.22
                        Time: 18:11:34
       Revision: AA000000    Serial number: 00000017676086
       Coding: C018BF8085853201030001010101112131313333203333
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA310131030
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6CDCD8858716382F6B-8038
       Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
       Component: TSG FA        H06 0261
       Revision: --------    Serial number: 0000121938724
       Coding: 011F1F005E0062C202003006
       VCID: 3D7A25C1A4EC61A78C-8068
       Revision: 00002001    Serial number: 0163122272
       Coding: 0106023A00FA759FB0B0C780020301000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000055064
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J245  007C  H06 0005
       Serial number: 144300008665
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
       Component: Dachelektroni  H11 0080
       Serial number: A2011000000000500242
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J394  0014  H06 0005
       Serial number: 143200003344
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J392  006A  H06 0005
       Serial number: 144300008664
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J867  00E0  H06 0005
       Serial number: 143200003345
       Coding: 020200
       Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84181635
       Revision: CJ007000    Serial number: 00000000033503
       Coding: 030000
       Shop #: WSC 02583 002 1048576
       VCID: 1D3AC541042C01A7AC-8048
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860     HW: 4H0 959 860
       Component: MEM-FS-Fond   H06 0155
       Revision: AA000000    Serial number: 00000016567105
       Coding: 001892800000300D0A00392038193A2039203B3B202020
       VCID: 71E2C9F1A834D5C758-8024
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0261
       Revision: --------    Serial number: 0000121897008
       VCID: 3C7C28C5BFF668AFBB-8068
       Revision: --------    Serial number: 00000000176958
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4H0 035 082 H    HW: 4H0 035 082
       Component: Radio U SIRIU H53 0138
       Revision: AB001007    Serial number: 155K%0B7516095
       Coding: 020007010000000001
       VCID: 2648EAAD517AC27FFD-8072
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H06 0155
       Revision: AA000000    Serial number: 00000016566434
       Coding: 001896800000300D0A00392038193A2039203B3B382020
       Part No SW: 4H0 035 746 M    HW: 4H0 035 746 J
       Component: H-BNT-NA      H42 1038
       Revision: --------    Serial number: 503EQ0G7506111
       Coding: 020200000001F1EF45168B1E00000003140001000000000000
       Shop #: WSC 12538 002 1048576
       VCID: 326006FD6DB2AEDF61-8066
       Subsystem 1 - Part No: 8R0 060 884 CJ
       Component: NAR 2015  1102
       Subsystem 2 - Part No SW: 4H0 919 604 D    HW: 4H0 919 604 D
       Component: DU8 D4 SV NB  H47 0021
       Serial number: AUZ8ZDB6900FZ6+
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000058002
       Component: CD-Database  5950
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0261
       Revision: --------    Serial number: 0000121942038
       Coding: 010F1F00420062C202003006
       Part No SW: 4H0 907 441 A    HW: 4H0 907 441
       Revision: --H04---    Serial number: 525 PA8J19D05C
       Coding: 1080003
       VCID: 2648EAAD917AC27FFD-8072
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 117100785
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000051214
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63CEB3B96AC87757DA-8036
       Component: TSG HR        H06 0261
       Revision: --------    Serial number: 0000121942017
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5013    Serial number: SN111014  0056
       ROD: EV_GSM2x3Mono.rod
       VCID: 2B5E1B994298FF1722-807E
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 E    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H09 0028
       Serial number: 0K84AE40052431
       Coding: 1200
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H08 0007
       Serial number: 00000000001129900607
       Serial number: 00002603252501
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F660F89768083370E-807A
       Serial number: 00002603255902
       Coding: 364FF2
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Component: IVB           H08 0042
       Serial number: 00002662136201
       Coding: 200F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
       VCID: 2E58128D718A8A3F05-807A
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
       Serial number: 00002662138802
       Coding: 200F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326006FD65B2AEDF61-8066
    End-------------------------(Elapsed Time: 07:23)--------------------------
    Hello OP and welcome to the VCDS Forum!
    Have you checked all fuses yet & as per RTFB/WD and did you JPPSG?
    Did you shut air ride down in MMI or put vehicle in transport mode at any point?
    Dec 2019
    Yes, I checked all fuses from the big 40A air ride supply fuse, down to the smaller fuses for all indicated air ride components. Since I've been banging my head against the wall I pulled every fuse in every panel to make sure they are all good on Saturday. The car is not in transport mode or tire change mode.
    When I clear the codes, I can run a relay test and the compressor kicks in, but then turns off and shows the relay mechanical failure again. That happens when I run tests or simply turn the ignition on for a minute. I get proper supply voltage to the relay block as well, and when I close the relay manually the compressor kicks on. Unless I am underestimating the complexity of the relay, it should close by getting 12V signal to run the compressor, which is present at 11.6V to 12.2V and then pass the 12V supply voltage to the compressor which is also there at 12.1V to 12.3V.
    I even questioned the 11.6V so I tested the relay with a 9V battery that is sufficient to close the circuit.
    But what about the ground side of the relay the ECU is looking at for a resistance value?
    Post a picture of WD you are using?
    Ever hear of the term "asshole ground"?
    Dec 2019
    I can't find the copyrights to the wiring diagrams I am using or I'd post them, but they are Alldata for said vehicle diagrams 14/1 through 14/5.
    I've been using the terminals on the relay block during resistance/voltage testing according to the diagram of the relay itself. Theory if there's no proper ground or voltage I'd see degraded results on my Fluke.
    I've also confirmed identical values at the module diagram 14/2 wires t18b & 13 which go to the relay.
    I had to abandon my nightmare for the holiday, which is a good thing so I don't burn her to the ground from frustration. This is a tricky one where I am attempting I know the difference of asshole ground.
    Next attempts, 3rd relay then ride control module replacement.
    Jan 2018
    Cheshire UK
    Check the main power cables that go to the compressor. The thick cables just by the compressor tend to burn out when there has been a leak due to excess current. There might be a few strands of cable still in there but not enough to power the compressor
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  7. #7
    Dec 2019
    I can get the compressor to run when I close the relay manually. It just keeps going into function shut off with the relay mechanical failure. Wires are looking good.
  8. #8
    Is it not self evident that if the wiring is good and fuses are good than the air ride suspension controller would be in error?
    Where does the 12 V come from to the relay you are missing & what fuse in WD, are you sure 12 volts is fed to the relay from the controller and does ground get switched to the relay for compressor by controller?
    Are you sure you know what you are doing?
    Isn't "All DATA" like "NO DATA" at all?
    Is the relay the correct part number, just what part number is it?
    Vehicle Identification No. WAURVAFD7CN019433
    Model Audi A8L qu. 4.2
    A8Q
    Date of production 18.11.2011
    Model year 2012
    Sales type 4H85AA
    Engine Code CDRA
    Transmission Code MXR
    Axle drive 8A
    Emission standard 7GB Emission standard ULEV 2
    Coding: 008000
    Reset counter: 138
    Mileage: 185257 km
    Date: 2019.12.22
    Time: 18:11:56
    C10C8 00 [009] - -
    Reset counter: 138
    Mileage: 185257 km
    Date: 2019.12.22
    Time: 18:11:34
    https://i.postimg.cc/Zb978h26/CESSPO...-RIDE.png?dl=1
  9. #9
    Dec 2019
    Usually those darn things go belly up and result in "no communication from controller" or give you some sort of indication they are bad. I ordered one so we shall see if another relay doesn't fix it.
    Relay part number 4H0-951-253 labeled as a 644. S110 is your 40A supply fuse to the J197 air ride controller, which does feed the proper signals to the relay block per the wires you circled, which close the relay and feed 12V to the compressor. Exactly what I tried to explain in my last post from the Alldata diagrams which happen to be exactly what you posted. So since we're both looking at the same thing, do I know what I am doing?
  10. #10
    Nope, because you are here and not already fixed!
    Ordering the same relay again & after verifying it switches implies this too, no?
    What is status of T18b/9 at controller directly for output & are all sub fuses to J197 check out for when checked?
