Results 1 to 6 of 6
Thread: RS4 support for clutch wear?
    Dec 2019
    Does theRS4 have a clutch wear sensor? I dont see it on the Scanner?
    best regards, Maseratitmc
    Hi and welcome.
    It might be useful if we knew what year RS4, with what transmission. The best way to present that information would be for you to post an Auto-Scan.
  3. Likes PetrolDave liked this post
    Dec 2019
    Does VCDS display the percentage of clutch wear?
    It's a 2007 RS4 Manual 6 speed. Autoscan doesn't work on the RS4, works on my three other Audi's.
    Best Regards
    Address 01: Engine Labels: 079-910-560-BNS1.lbl
    Control Module Part Number: 8E1 910 560 A HW: 8E1 907 560
    Component and/or Version: 4.2L V8/4V FSI Ş0060
    Software Coding: 01040009180F0160
    Work Shop Code: WSC 09222 067 57207
    VCID: 2411EDA582DA25D78DF-8070
    Fault Codes have been Erased
    006435 - Please Check DTC Memory of ECU Number 2
    P1923 - 008 -
    Mileage: 180757 km
    RPM: 826 /min
    Load: 29.8 %
    Temperature: 24.0°C
    Temperature: 18.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 13.589 V
    Quote Originally Posted by MaseratiTMC View Post
    So that's a B7 RS4 then?
    Auto detect doesn't work on the B7 as the CAN "Gateway" (built-in to the instruments) doesn't keep an installation list, so you have to manually select the B7 platform from the dropdown list.
    Try that and then post the auto-Scan here - see my signature for a "How-To".
    There is no monitor for clutch wear on the B7 manual (A4, S4 or RS4) - what are you concerned about? I ran a B7 RS4 manual for 10 years and over 84,000 miles on the original clutch but others managed to need a new clutch after less then 20,000 miles so I think driving style has a big effect - but I did "enjoy" the performance to the full
    If you dump the clutch at big revs then the clutch does struggle to fully engage (with all that power and quattro it's not a surprise) so when I wanted a quick getaway I always engage the clutch at around 2000 rpm and only floored the throttle when the car was starting to roll.
  6. Likes Uwe liked this post
    VCDS can only show you what the car knows, and the car doesn't know. It's a manual transmission, and a manual clutch. There are no sensors of any kind.
    Dec 2019
    UWE,
    Thank you for the hints, I did get a scan out of the car! Bummed about no clutch sensor, that would really help. The clutch does not slip, seems to work fine, but about once a month I get that clutch smell, it's not strong bit I'm pretty sure that's what it is. I guess it could be something leaning against the exhaust system (not the clutch) but I've looked around several time and I can't see anything.
    Here is the scan, in case anyone is interested... The car has a brand new OEM intake manifold and flaps installed. New Coils, New Plugs. Also installed
    a new starter and a new battery. It's been an expensive year!
    VIN: WUARU78E17N901656   License Plate: RS4-2007
    Mileage: 180870km-112387mi   Repair Order: TMC-RS4
              67 69 75 76 77
    VIN: WUARU78E17N901656   Mileage: 180870km-112387miles
    Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560 A    HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     Ş0060
       Revision: 57H13---    Serial number: XXXXXXXXXXXXXX
       Shop #: WSC 09222 067 57207
    008567 - Bank 1; System Too Lean off Idle
                   P2177 - 001 -  - MIL ON
                        Fault Status: 11100001
                        Mileage: 180766 km
                        RPM: 2407 /min
                        Load: 20.0 %
                        Speed: 92.0 km/h
                        Temperature: 78.0°C
                        Temperature: 36.0°C
                        Voltage: 13.716 V
    Readiness: 0000 0001
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Component: ESP8 quattro    H06 0150
       Coding: 0004533
       Shop #: WSC 06335 000 00000
       VCID: 2B030699EF04EAAF4C5-807E
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6D87C8811480249F121-50F4
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 01023
       Shop #: WSC 65536
       VCID: 3D2738C10460741FE21-4AA4
    Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
       Shop #: WSC 09222 444 84347
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N0G03B4N
       Coding: 0432607
       VCID: 3C2135C51A6A7D17D5F-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 3BK6Y
       Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB4037E0795S˙†63
       Subsystem 5 - Serial number: E0795S˙†6342DRB4037B492CW˙†63
       Subsystem 6 - Serial number: B492CW˙†6352ARB4015CBA50Q˙†63
       Subsystem 7 - Serial number: CBA50Q˙†6362ARB4015F4A9E+˙†63
       Subsystem 8 - Serial number: F4A9E+˙†63729RB40169BD4B ˙†63
       Subsystem 9 - Serial number: 9BD4B ˙†63829RB40169BD21R˙
       Subsystem 10 - Serial number: 9BD21R˙
    Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
       Part No: 8E0 953 549 T
       Component: Lenksáulenmodul     0301
       Coding: 04441
       Shop #: WSC 06335
       VCID: 44D14D25678A05D7ADF-4AA4
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 981 S    HW: 8E0 920 981 S
       Component: KOMBI+WFS 4     H14 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0023261
       Shop #: WSC 09222 512 00000
       VCID: 3D2738C10160741FE21-5118
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023261
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71BFD4F10888C07F369-4B1E
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 J    HW: 8E0 035 192 J
       Component: RNS-E US3       H72 0110
       Revision:      03S    Serial number: AUZBZ7F2463116
       Coding: 0309637
       Shop #: WSC 02195 785 00200
       VCID: 2B030699EF24EAAF4C5-5160
                        Reset counter: 106
                        Date: 2005.08.27
                        Time: 15:48:11
                        Voltage: 12.40 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
    00857 - CD Changer Unit (R41)
                        Reset counter: 97
                        Date: 2019.08.12
                        Time: 16:46:40
    16352 - Control Module - Electrical Error
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 180
                        Date: 2013.05.02
                        Time: 18:41:42
    02218 - Satellite Radio (R146)
                        Reset counter: 52
                        Date: 2019.06.09
                        Time: 16:29:54
       Part No: 8E0 959 433 CG
       Component: Komfortgerát T7B    4135
       Coding: 11820
       Shop #: WSC 06335
       VCID: 78A9E9D56BC29137F17-4AA4
       Component: Tőrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tőrsteuer.BF BRM 0706
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
       Coding: 0000019
       VCID: 290FFC91E5F8F8BFBE9-807C
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H03 0010
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH03 0010
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0309637
                        Reset counter: 106
                        Date: 2005.08.27
                        Time: 15:48:11
                        Voltage: 12.40 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
                        Reset counter: 97
                        Date: 2019.08.12
                        Time: 16:46:40
                014 - Defective
                        Reset counter: 180
                        Date: 2013.05.02
                        Time: 18:41:42
                        Reset counter: 52
                        Date: 2019.06.09
                        Time: 16:29:54
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0062523
       Shop #: WSC 02197 785 00200
       VCID: 2A0D039DE0DEF3A7B73-513C
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
       Component: Parkhilfe 4-Kan H06 0010
       Revision: 00H06000    Serial number: 00067802020618
       Coding: 0000304
       VCID: 313F14F1CD08807F769-5160
       Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
       Component: FSE_255x BT     H21 0290
       Revision: 00000001    Serial number: 00000000493814
       Coding: 0011877
       VCID: 3D2738C10160741FE21-50D0
    End----(Elapsed Time: 04:32, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
