Does theRS4 have a clutch wear sensor? I dont see it on the Scanner?
best regards, Maseratitmc
Does VCDS display the percentage of clutch wear?
It's a 2007 RS4 Manual 6 speed. Autoscan doesn't work on the RS4, works on my three other Audi's.
VCDS can only show you what the car knows, and the car doesn't know. It's a manual transmission, and a manual clutch. There are no sensors of any kind.Does VCDS display the percentage of clutch wear?
VIN: WUARU78E17N901656 License Plate: RS4-2007
Mileage: 180870km-112387mi Repair Order: TMC-RS4
67 69 75 76 77
VIN: WUARU78E17N901656 Mileage: 180870km-112387miles
Address 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0060
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 09222 067 57207
VCID: 2411EDA582DA25D78DF-8070
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 180766 km
RPM: 2407 /min
Load: 20.0 %
Speed: 92.0 km/h
Temperature: 78.0°C
Temperature: 36.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B030699EF04EAAF4C5-807E
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
VCID: 6D87C8811480249F121-50F4
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D2738C10460741FE21-4AA4
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
Shop #: WSC 09222 444 84347
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G03B4N
Coding: 0432607
VCID: 3C2135C51A6A7D17D5F-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3BK6Y
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB4037E0795Sÿ†63
Subsystem 5 - Serial number: E0795Sÿ†6342DRB4037B492CWÿ†63
Subsystem 6 - Serial number: B492CWÿ†6352ARB4015CBA50Qÿ†63
Subsystem 7 - Serial number: CBA50Qÿ†6362ARB4015F4A9E+ÿ†63
Subsystem 8 - Serial number: F4A9E+ÿ†63729RB40169BD4B ÿ†63
Subsystem 9 - Serial number: 9BD4B ÿ†63829RB40169BD21Rÿ
Subsystem 10 - Serial number: 9BD21Rÿ
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 04441
Shop #: WSC 06335
VCID: 44D14D25678A05D7ADF-4AA4
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 S HW: 8E0 920 981 S
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 09222 512 00000
VCID: 3D2738C10160741FE21-5118
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71BFD4F10888C07F369-4B1E
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H72 0110
Revision: 03S Serial number: AUZBZ7F2463116
Coding: 0309637
Shop #: WSC 02195 785 00200
VCID: 2B030699EF24EAAF4C5-5160
Reset counter: 106
Date: 2005.08.27
Time: 15:48:11
Voltage: 12.40 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00857 - CD Changer Unit (R41)
Reset counter: 97
Date: 2019.08.12
Time: 16:46:40
16352 - Control Module - Electrical Error
014 - Defective
Fault Status: 01101110
Reset counter: 180
Date: 2013.05.02
Time: 18:41:42
02218 - Satellite Radio (R146)
Reset counter: 52
Date: 2019.06.09
Time: 16:29:54
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11820
Shop #: WSC 06335
VCID: 78A9E9D56BC29137F17-4AA4
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 290FFC91E5F8F8BFBE9-807C
Component: AFS-Modul links H03 0010
Component: AFS-Modul rechtsH03 0010
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0309637
Reset counter: 106
Date: 2005.08.27
Time: 15:48:11
Voltage: 12.40 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Reset counter: 97
Date: 2019.08.12
Time: 16:46:40
014 - Defective
Reset counter: 180
Date: 2013.05.02
Time: 18:41:42
Reset counter: 52
Date: 2019.06.09
Time: 16:29:54
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 02197 785 00200
VCID: 2A0D039DE0DEF3A7B73-513C
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020618
Coding: 0000304
VCID: 313F14F1CD08807F769-5160
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H21 0290
Revision: 00000001 Serial number: 00000000493814
Coding: 0011877
VCID: 3D2738C10160741FE21-50D0
End----(Elapsed Time: 04:32, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
