Results 1 to 5 of 5
Thread: Audi S5 DL501 0B5 DSG 7 speed Jerk issue
    New User
    Dec 2019
    Hi All
    Long time VCDS user / VAG owner/Tuner
    I have an issue with my own S5 2010
    It has had a replacement TCU 18 moths ago and has been fine until I decided to run Clutch engagement point adaption.
    since doing so it has a nasty jerk when selecting 1st (common issue it seems) but was fine before
    I have re run adaptions as per DrPeters instruction and tried cluctch enganement at process at different temps etc to no avail.
    Its an 8K5927156H 0009 / H06 0B5927156K
    latest SW version etc
    does anyone have any help as it was not doing this before I ran the adaption
    Thanks in Advance
    Woody
    Please post a full unedited VCDS Auto-Scan so we can see exactly what hardware and software versions the modules in your S5 have.
  3. Likes Uwe liked this post
    New User
    Dec 2019
    Monday,30,December,2019,15:25:53:35713
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8FXAN021448   License Plate:
    Mileage: 152520km-94771mi   Repair Order:
    Chassis Type: 8F-AU48 (8T0)
    Scan: 01 02 03 05 06 08 09 10 14 15 16 17 19 1B 26 30 36 42 46 47
              52 53 55 56 5F 62 6C 72
    VIN: WAUZZZ8FXAN021448   Mileage: 152520km-94771miles
    26-Auto Roof -- Status: Malfunction 0010
    Address 01: Engine (J623-CAKA)       Labels:. 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551     HW: 8K0 907 551
       Component: 3.0T SIMOS84  X06 0006
       Revision: --X06---
       Coding: 011C000C240F0128
       Shop #: WSC 00078 790 12345
       ASAM Dataset: EV_ECM30TFS8K0907551 A02008
       ROD: EV_ECM30TFS0218K0907551C.rod
       VCID: 6ED3B97FB11C843F45-803A
    Readiness: 0110 0001
       Part No SW: 8K5 927 156 H    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H06 0009
       Revision: --H06---    Serial number: 0000000783
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_TCMDL501021 A03005
       ROD: EV_TCMDL501021_A03.rod
       VCID: 3E73493FA1FC34BF95-806A
       Part No SW: 8K0 907 379 BE    HW: 8K0 907 379 BE
       Component: ESP8 quattro  H04 0030
       Coding: 292D08
       Shop #: WSC 02391 823 56573
       VCID: 7DF18E33E47AEFA7CC-8028
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0327
       Coding: 013300
       Shop #: WSC 02399 823 56573
       VCID: 0109F2C398828B47A8-8054
       Subsystem 1 - Part No SW: 8T0 959 754 Q    HW: 8T0 959 754 Q
       Serial number: 0510000010361007
       Serial number: 0210000022737004
       Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
       Component: MEM-BFS       H10 0074
       Revision: AA000000    Serial number: 00001010095189
       Coding: 00217025002C00000000
       VCID: 438538CBC21E5957FA-8016
       Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
       Component: KLIMA 3 ZONEN H08 0171
       Revision: D1000000    Serial number: 01040320100616
       Coding: 66170000
       VCID: 77FD9C1BC646C5F796-8022
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000610315
       Coding: 260050914134AF311F09000300005D5D4F9DC2CA00010141000000
       VCID: 3C774337BFE026AFBB-8068
       Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 260210  H05 0021
       Serial number: SWF10020265070
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10814431
       Coding: 02562A
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002502101329
       Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0070
       Revision: 11001001    Serial number: 50941006907303
       Coding: 300102
       VCID: 489F2FE7FB387A0F2F-801C
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8R0 907 364 B    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H09 0053
       Revision: 00000000    Serial number: 04031000860003
       Coding: 050181
       VCID: 39795A23B0D21387A0-806C
    Address 15: Airbags (J234)       Labels:* 8F0-959-655.clb
       Part No SW: 8F0 959 655     HW: 8F0 959 655
       Component: AirbagVW-AU10 H10 0430
       Serial number: 003A4D0670FF
       Coding: 30363635353130303030554A305238463053
       Shop #: WSC 02135 785 00200
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaECUVWAUDI010.rod
       VCID: 75E19613D44AB7E784-8020
       Serial number: 6334MSME4F502B14F
       Serial number: 6344MSME5063493EI
       Serial number: 6352QSME6454042EG
       Serial number: 6362QSME09541526A
       Serial number: 63732SME2E560F345
       Serial number: 63832SME23534912T
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Revision: --------    Serial number: 90304JC2000MQ
       Coding: 000036
       VCID: 3E73493FA9FC34BF95-806A
       Component: E221 - MFL  H02 0010
       Part No SW: 8T0 920 981 M    HW: 8T0 920 981 M
       Component: KOMBIINSTR.   H34 0255
       Revision: 00000000    Serial number: CSI5AD33A
       Coding: 236F190033002600010000
       VCID: 468321DFF12C6C7FDD-8012
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0116
       Revision: EB900055    Serial number: 5500E1022780A2
       Coding: 00C303
       VCID: 0305F8CB829E9957BA-8056
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 1000D27F050310
       Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
       Component: DYNAMIKLENK.  H06 0570
       Revision: 50001005    Serial number: --------------
       Coding: 8C0000
       VCID: 306F670763A8D2CF17-8064
    Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H10 0170
       ASAM Dataset: EV_ElectRoofContr 001007
       ROD: EV_ElectRoofContr.rod
       VCID: 71E9A203A0229BC758-8024
    0020 - Convertible Top Compartment Switch; Left
              B1181 29 [008] - Signal Implausible
    0021 - Convertible Top Compartment Switch; Right
              B1182 29 [008] - Signal Implausible
       Part No SW: 8K0 907 440 B    HW: 8K0 907 440
       Component: STS           H04 0020
       Revision: S0H04000    Serial number: 00000000014177
       Coding: 01010101000000000000000102
       Shop #: WSC 02391 823 56541
       VCID: 2D517E73749ABF273C-8078
       Component: MEM-FS        H10 0074
       Revision: AA000000    Serial number: 00001010095074
       Coding: 00397325002C00000000
       Shop #: WSC 00134 210 91052
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0308
       Revision:             Serial number: 0000010289046
       Coding: 011C42725E29330C03
       VCID: 458126D3CC2A6767D4-8010
       Revision: 00002001    Serial number: 0127666624
       Coding: 011B06A200390CA00330033280000000
       Subsystem 1 - Part No: 8P7 951 177
       Component: DWA-Sensor  H03 0040
       Part No SW: 8F0 035 223 D    HW: 8F0 035 223 C
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34863000403602
       VCID: 2149924338426B4788-8074
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0308
       Revision:             Serial number: 0000010241300
       Coding: 011C42325E29330C03
       VCID: 44873BD7C7105E6FC3-8010
       Revision: 00000003    Serial number: 10000000455914
       VCID: 34676B1797B0EEEF73-8060
       Part No: 8K0 907 357 B
       Coding: 0000003
       Shop #: WSC 02145 785 00200
       VCID: 34676B1757B0EEEF73-8060
       Part No SW: 4F0 035 053 B    HW: 4F0 035 053
       Component: Radio U Basic H45 0020
       Revision: AB001007    Serial number: 341CU0A7713187
       Coding: 010003010000000101
       VCID: 1C37A3B71F2046AF5B-8048
       Part No SW: 8R2 035 670 M    HW: 8R2 035 670 E
       Component: H-BNT-EU      H48 1036
       Revision: --------    Serial number: 208L00D7512836
       Coding: 140101030206E1FF45804F5D00000403040000000100000102
       Shop #: WSC 06325 000 00000
       Subsystem 1 - Part No: 8R0 060 884 FK
       Component: EUR 2018/2019  2702
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356CH0A1214331
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001529588
       Component: CD-Database  5571
    02169 - Front Right Microphone (R141)
    01524 - Antenna for Telephone
    03623 - Invalid Security/Release Code
       Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000103109179
       Coding: 010C02324029370C03
       Part No SW: 8F0 907 441     HW: 4L0 907 441 B
       Revision: --H03---    Serial number: 525PA8-J02B0BN
       Coding: 1023009
       VCID: 67DDCC5B56E6557706-8032
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000103109180
    End-------------------------(Elapsed Time: 04:11)--------------------------
    Quote Originally Posted by woodysjw View Post
    Did you follow a written procedure for this? I don't have one handy, but VCDS does tell you right on the tin, and in the product manual, that running Basic Settings willy-nilly without following the appropriate procedures can produce undesirable results.
    New User
    Dec 2019
    Yes I followed the updated version by DrPeter and have done many times since but an unable to solve this jerk
    I’ve flashed with latest frf etc
    But doesn’t make any difference
    Between 40-60degrees etc
    Does anyone know if it’s clutch balance calibration or clutch engagement point
    I should be doing
