Monday,30,December,2019,15:25:53:35713
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8FXAN021448 License Plate:
Mileage: 152520km-94771mi Repair Order:
Chassis Type: 8F-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 14 15 16 17 19 1B 26 30 36 42 46 47
52 53 55 56 5F 62 6C 72
VIN: WAUZZZ8FXAN021448 Mileage: 152520km-94771miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine (J623-CAKA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 HW: 8K0 907 551
Component: 3.0T SIMOS84 X06 0006
Revision: --X06---
Coding: 011C000C240F0128
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_ECM30TFS8K0907551 A02008
ROD: EV_ECM30TFS0218K0907551C.rod
VCID: 6ED3B97FB11C843F45-803A
Readiness: 0110 0001
Part No SW: 8K5 927 156 H HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H06 0009
Revision: --H06--- Serial number: 0000000783
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 3E73493FA1FC34BF95-806A
Part No SW: 8K0 907 379 BE HW: 8K0 907 379 BE
Component: ESP8 quattro H04 0030
Coding: 292D08
Shop #: WSC 02391 823 56573
VCID: 7DF18E33E47AEFA7CC-8028
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Coding: 013300
Shop #: WSC 02399 823 56573
VCID: 0109F2C398828B47A8-8054
Subsystem 1 - Part No SW: 8T0 959 754 Q HW: 8T0 959 754 Q
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0510000010361007
Component: J764 ELV MLB H37 0042
Serial number: 0210000022737004
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001010095189
Coding: 00217025002C00000000
VCID: 438538CBC21E5957FA-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0171
Revision: D1000000 Serial number: 01040320100616
Coding: 66170000
VCID: 77FD9C1BC646C5F796-8022
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000610315
Coding: 260050914134AF311F09000300005D5D4F9DC2CA00010141000000
VCID: 3C774337BFE026AFBB-8068
Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 260210 H05 0021
Serial number: SWF10020265070
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10814431
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002502101329
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941006907303
Coding: 300102
VCID: 489F2FE7FB387A0F2F-801C
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 B HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Serial number: 04031000860003
Coding: 050181
VCID: 39795A23B0D21387A0-806C
Address 15: Airbags (J234) Labels:* 8F0-959-655.clb
Part No SW: 8F0 959 655 HW: 8F0 959 655
Component: AirbagVW-AU10 H10 0430
Serial number: 003A4D0670FF
Coding: 30363635353130303030554A305238463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaECUVWAUDI010.rod
VCID: 75E19613D44AB7E784-8020
Serial number: 6334MSME4F502B14F
Serial number: 6344MSME5063493EI
Serial number: 6352QSME6454042EG
Serial number: 6362QSME09541526A
Serial number: 63732SME2E560F345
Serial number: 63832SME23534912T
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JC2000MQ
Coding: 000036
VCID: 3E73493FA9FC34BF95-806A
Component: E221 - MFL H02 0010
Part No SW: 8T0 920 981 M HW: 8T0 920 981 M
Component: KOMBIINSTR. H34 0255
Revision: 00000000 Serial number: CSI5AD33A
Coding: 236F190033002600010000
VCID: 468321DFF12C6C7FDD-8012
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0116
Revision: EB900055 Serial number: 5500E1022780A2
Coding: 00C303
VCID: 0305F8CB829E9957BA-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1000D27F050310
Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
Component: DYNAMIKLENK. H06 0570
Revision: 50001005 Serial number: --------------
Coding: 8C0000
VCID: 306F670763A8D2CF17-8064
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H10 0170
ASAM Dataset: EV_ElectRoofContr 001007
ROD: EV_ElectRoofContr.rod
VCID: 71E9A203A0229BC758-8024
0020 - Convertible Top Compartment Switch; Left
B1181 29 [008] - Signal Implausible
0021 - Convertible Top Compartment Switch; Right
B1182 29 [008] - Signal Implausible
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000014177
Coding: 01010101000000000000000102
Shop #: WSC 02391 823 56541
VCID: 2D517E73749ABF273C-8078
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001010095074
Coding: 00397325002C00000000
Shop #: WSC 00134 210 91052
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0308
Revision: Serial number: 0000010289046
Coding: 011C42725E29330C03
VCID: 458126D3CC2A6767D4-8010
Revision: 00002001 Serial number: 0127666624
Coding: 011B06A200390CA00330033280000000
Subsystem 1 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0040
Part No SW: 8F0 035 223 D HW: 8F0 035 223 C
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34863000403602
VCID: 2149924338426B4788-8074
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0308
Revision: Serial number: 0000010241300
Coding: 011C42325E29330C03
VCID: 44873BD7C7105E6FC3-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000455914
VCID: 34676B1797B0EEEF73-8060
Part No: 8K0 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000003
Shop #: WSC 02145 785 00200
VCID: 34676B1757B0EEEF73-8060
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341CU0A7713187
Coding: 010003010000000101
VCID: 1C37A3B71F2046AF5B-8048
Part No SW: 8R2 035 670 M HW: 8R2 035 670 E
Component: H-BNT-EU H48 1036
Revision: -------- Serial number: 208L00D7512836
Coding: 140101030206E1FF45804F5D00000403040000000100000102
Shop #: WSC 06325 000 00000
Subsystem 1 - Part No: 8R0 060 884 FK
Component: EUR 2018/2019 2702
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356CH0A1214331
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000001529588
Component: CD-Database 5571
02169 - Front Right Microphone (R141)
01524 - Antenna for Telephone
03623 - Invalid Security/Release Code
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0306
Revision: Serial number: 0000103109179
Coding: 010C02324029370C03
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Revision: --H03--- Serial number: 525PA8-J02B0BN
Coding: 1023009
VCID: 67DDCC5B56E6557706-8032
Component: TSG HR H10 0306
Revision: Serial number: 0000103109180
End-------------------------(Elapsed Time: 04:11)--------------------------
