Results 1 to 4 of 4
Thread: AUDI A4 B8K 2008 Control Head 00003 Control Module No or Incorrect Basic Setting
    Dec 2019
    Australia
    I was attempting to install a Throttle Controller. Install went OK but after starting the engine and revving the engine up past 3000rpm a number of faults appeared. I removed the throttle controller and this is the only fault remaining. Can anyone help me clear this fault??
    Autoscan is attached
    Monday,16,December,2019,12:47:33:10623
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8K08A034692   License Plate: NBF70P
    Mileage: 251200km-156088mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
              55 56 62 72 77
    VIN: WAUZZZ8K08A034692   Mileage: 251200km-156088miles
    Address 01: Engine (J623-CALA)       Labels:| 06E-907-559-CAL.clb
       Part No SW: 8T0 907 559 D    HW: 8T0 907 559 A
       Component: 3.2 SIMOS8.2  H02 0003
       Revision: --------
       Coding: 01040003190F0121
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM32FSI8T0907559D A01002
       ROD: EV_ECM32FSI8T0907559D.rod
       VCID: 43853246CABCA757FA-8016
    Readiness: 0110 0101
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158     HW: 0B6 927 156
       Component: 0B6 32 FSIRdW H04 0030
       Revision: --H04---
       Coding: 001001
       ASAM Dataset: EV_TCMAL651 A01001
       ROD: EV_TCMAL651.rod
       VCID: 73E5A286DA9C57D7AA-8026
       Part No SW: 8K0 907 379 Q    HW: 8K0 907 379 Q
       Component: ESP8 quattro  H04 0170
       Coding: 0F0500
       VCID: 479D2656F6848B7726-8012
       Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
       Component: BCM2 1.1      H71 0134
       Coding: 051100
       VCID: 7AFB8FA2F5F6269FE9-802E
       Subsystem 1 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
       Component: ELVAUDIB8  H35 0039
       Serial number: 0208000008014007
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 N    HW: 4E0 035 729
       Component: Interfacebox    H43 5170
       Revision: 00000000    Serial number: 329C.087549096
       VCID: 4487315A07B2A06FC3-8010
       Subsystem 1 - Part No: 8T0 919 609 C
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000052635
       Subsystem 3 - Serial number: 0126.02.080000000100010109˙
       Subsystem 4 - Serial number: 010109˙
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 47
                        Mileage: 251209 km
                        Date: 2019.12.16
                        Time: 12:41:19
       Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
       Component: KLIMA 3 ZONEN H05 0120
       Revision: D0000000    Serial number: 0112.03.080291
       Coding: 46046000
       VCID: 3C7749BABF42D8AFBB-8068
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Component: BCM1 1.0      H21 0253
       Revision: 04021001    Serial number: 00000000109697
       Coding: 260050914014AF010001000000001D0D0F1D430800010141000000
       VCID: 2F6D6EF67E3433370E-807A
       Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 110308  H05 0060
       Serial number: SWFBIE 0000114
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10076288
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000001403080110
       Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
       Component: MP3-Changer     H42 0390
       Revision: 00042001    Serial number: AUZ5ZBH4574020
       VCID: 2B557AE68A2C4F1722-807E
       Part No SW: 8K0 919 475 C    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0010
       Revision: 11001001    Serial number: 75230807204762
       Coding: 100103
       VCID: 397950AEB070ED87A0-806C
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD13W5MK
       Coding: 30373434363030303030554A3052384B3053
       VCID: 3C7749BAB742D8AFBB-8068
       Serial number: 6334MSME2A2632446
       Serial number: 6344MSME385312163
       Serial number: 6352QSME58122E5BP
       Serial number: 6362QSME5B0B237BS
       Serial number: 63732SME4F163C3BB
       Serial number: 63832SME567377271
       Component: Lenks.Modul   H11 0012
       Revision: --------    Serial number: 90315HCB00089
       Coding: 000036
       VCID: 3D7144BEA458D1A78C-8068
       Part No SW: 8K0 920 930 A    HW: 8K0 920 930 A
       Component: KOMBIINSTR.   H14 0216
       Revision: 00200000    Serial number: 7BU28VD38
       Coding: AF07090002000008010000
       VCID: 2B557AE64A2C4F1722-807E
       Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
       Component: GW-BEM 4CAN-M H07 0084
       Revision: EB002032    Serial number: 3200E0831283B0
       Coding: 000003
       Shop #: WSC 23050 822 88145
       VCID: 4487315AC7B2A06FC3-8010
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H03 0150
       Serial number: 1800AACA260208
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 D    HW: 4E0 035 785
       Component: SG ext.Player H15 0830
       Revision: 00000000
       VCID: 295980EE40D05D07D0-807C
       Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1050
       Revision: 00000000    Serial number: 333CO087549610
       Shop #: WSC 23050 822 83558
       VCID: 306F6D8AA30A2CCF17-8064
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000006919242
       Coding: 011C12204101410001
       VCID: 3F8D3EB6AE54C3B79E-806A
       Revision: 00002001    Serial number: 0110017364
       Coding: 01000E2200390405003001
       Subsystem 1 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS033  H06 0036
       Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
       Component: DSP Prem      H14 0400
       Revision: 00H14003    Serial number: 34871001180003
       Coding: 020101
       Shop #: WSC 12336 024 394758
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000006920579
       VCID: 3E7343B2A95ECABF95-806A
       Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
       Component: EPB Audi B8   H04 0050
       Revision: 00000003    Serial number: 00000000095464
       VCID: 306F6D8A630A2CCF17-8064
       Part No: 8K0 907 357 B
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 3467619A571210EF73-8060
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336CZ087544758
       VCID: 2E5373F2B93E3A3F05-807A
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000006917809
       Coding: 010C12204001210001
       VCID: 7F0D7EB6EED403B7DE-802A
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000006913149
       VCID: 7EF383B2E9DE0ABFD5-802A
    Address 77: Telephone
    End-------------------------(Elapsed Time: 03:58)--------------------------
    What value do you have in [07] adaptation channel 01 and 12 ?
    Dec 2019
    Australia
    [07]
    Channel 01 = 4396
    Channel 12 = 2
    Dec 2019
    Australia
    I have it sorted. Channel 12 should be 0
  5. Likes Dana, Uwe liked this post
