VW T-ROC LIGHT ASSIST/DYNAMIC LIGHT ASSIST NOT WORKING
ib97
Croatia
C?ID=375363
Hello all, after trying to code Dynamic Light Assist, not worked. Tried with Light Assist, not working. Error continued to appear after being done with coding. I used the same procedure on T-roc with halogen lights, and this one had LED lights. Everything worked on the other car.
Hope that come knows why is this now working?
Is Traffic sign Assist going to work?
Does anyone know how to get mirror dip(module 52,byte 4 bit 2 and 3 option is not working ) and option for daytime running lights in the menu?
Here is the auto-scan:
Saturday,21,December,2019,10:07:07:60999
VIN: WVGZZZA1ZLVxxxxxx   License Plate: ZG-stric
Mileage: 1868km-1160mi   Repair Order:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 4B 52 5F A5 BB BC D6 D7
VIN: WVGZZZA1ZLVxxxxxx   Mileage: 1868km-1160miles
Address 01: Engine (J623-DKRF)       Labels: None
   Part No SW: 04C 906 025 BC    HW: 04C 907 309 BP
   Component: R3 1.0l TFS   H20 7060
   Revision: DGH20000
   Coding: 0119003223441D082000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM10TFS01104C906025BC 003001
   ROD: EV_ECM10TFS01104C906025AK_003_VW27.rod
   VCID: 629C51B7F4C15567BF3-8036
   Part No SW: 5Q0 614 517 ER    HW: 5Q0 614 517 BN
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 61809000001413
   Coding: 46FA6A7D20202472477A060062C42562560424E26046A4733420F078D0224B0B00000523525212121035351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 05566A2B05AFC25FFA1-8050
   Part No SW: 5G0 907 044 FC    HW: 5G0 907 044 FC
   Component: Climatronic   H04 2201
   Revision: 00001K10
   Coding: 060200032001100D1105000000101036
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   VCID: 6D86328B3D1F1A1F121-8038
   Part No SW: 5Q0 937 084 DL    HW: 5Q0 937 084 DK
   Component: BCM MQBAB MxL H40 0312
   Serial number: 00101919000811
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: SAY19M07D08H09M14S27
   Coding: 0018DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100100720190C203414
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [008] - Open or Short to Plus
                    Reset counter: 53
                    Mileage: 459 km
                    Date: 2019.10.31
                    Time: 10:48:58
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058619192
   Coding: 0471151801
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 50F88B7F8A6DD7F7197-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A04604210FF8748949C810560408700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D2B4334B1B3C6F945-8016
2141 - Databus
          [FAULT_DIS_FAIL]
                    Reset counter: 50
                    Mileage: 199 km
                    Date: 2019.10.12
                    Time: 14:41:31
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 31 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.22 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PEEV7XZ
   Coding: 88CCC0C0000000005C5400CF000800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B425C1323CBB42FAC5-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 506 19
   Serial number: 357000000008E4915C3S
   Subsystem 2 - Part No SW: -----------    HW: 454 002 706 19
   Serial number: 358000000005374D6B3P
   Subsystem 3 - Part No SW: -----------    HW: 454 800 306 19
   Serial number: 35100D798E518000000V
   Subsystem 4 - Part No SW: -----------    HW: 454 803 005 19
   Serial number: 35200D5AEE218000000Y
   Subsystem 5 - Part No SW: -----------    HW: 454 801 506 19
   Serial number: 35500A746FE18000000Z
1051909 - Databus
          [NWD: 0x30B Kombi_01 error value KBI_Airbag_Lampe]
                    Reset counter: 50
                    Mileage: 189 km
                    Date: 2019.10.12
                    Time: 11:03:02
   Part No SW: 2GA 920 740 B    HW: 2GA 920 740 B
   Component: KOMBI         203 6700
   Coding: 05A402066F800008018823031001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 323CE1F7E4A185E70F3-8066
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [009] - Internal electronic failure
          [Steuergerät defekt (SiLa) "Sicherheitswarnlampe"]
                    Mileage: 189 km
                    Date: 2019.10.12
                    Time: 11:03:02
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0009854811
   Coding: 030100046F08560022000258080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70B82BFF2A2DF7F7397-8024
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 1841902113700138FJ2B
   Coding: 2C0000
   Serial number: 5853691705
   Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
   Component: TSG FS        007 0480
   Serial number: 0000381692666
   Coding: 003003208000028000001000
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 4BC29C13634BF42F6C5-801E
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031775153
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 151F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B027EF5E35CBD7DDF-8020
17152 - Indicator Lamp for Electro-Mechanical Power Steering
          C10D5 04 [008] - Internal System Fault
                    Reset counter: 50
                    Mileage: 189 km
                    Date: 2019.10.12
                    Time: 11:03:02
                    Motor status: 00
                    Supply voltage: 12.50 V
                    Temperature: 49.0 °C
                    KFC: 43
                    KFA: 00 00
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.50 V
                    uAdSensI_SwitchedKl30_xdu16: 12.36 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 28061910522624
   Coding: 000000070900204200000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372AD0E30FC360CF38D-8062
   Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
   Component: TSG BFS       007 0480
   Serial number: 0000380834904
   Coding: 003001208000028000001000
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4ACC99176C31ED27573-801E
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031789643
   Coding: 190000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      724 0890
   Coding: 02720600BE0000004111000100080A001F0500D40120010003
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2D06F28BFD9FDA1F521-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H61 8214
   Serial number: VWZ6ZJW2121344
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 66
                    Mileage: 1505 km
                    Date: 2019.11.07
                    Time: 17:45:20
                    Voltage terminal 30: 12.8 V
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 07061915K13168
   Coding: 0002070600000401002200448150A90084000E20000000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002_VW27.rod
   VCID: 40D8BB3F5A0D2777897-8014
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 025C71371481F567DF3-8056
   Component: LED1R         H07 0009
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
Ad-map of 09:
	Component:BCM MQBAB MxL H40 0312, Coding:000000000000000000000000000000000000000000000000000000000000
	EV_BCMMQB,020001,EV_BCMBOSCH_020_VW27.rod
	Saturday,21,December,2019,11:59:25:60999
	VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 00 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,1 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,55 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,not active ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Sollspannungsanforderung 13.5 ,6
ENG141682-ENG141966-Front_wiper-Frontwischertyp,Direct ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,47.5 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,47.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,47.5 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,47.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,45.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,42.5 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,35.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,28.5 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,24.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,15 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake light ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,15 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Parking light right ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake light ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,49 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,3A ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,4B ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,44 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parking light right ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 10 00 39 08 09 0F 18 00 7F 00 00 00 00 00 00 22 20 00 3A 08 0A 0F 18 00 7F 00 00 00 00 00 00 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 1B 00 80 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
ENG122929-RLS_LIN_Communication,4 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,1
ENG122935-RLS_Washer_Front,15 s,1
ENG122926-RLS_wiper_position_parking,15 s,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,320 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,320 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,not active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
Elapsed Time: 01:50
DV52
C?ID=194404
DLA: This car has mid-level BCM?
DRL menu switch: ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich > active
Reverse Mirror Dip: are you sure that the passenger side mirror has the required memory module? Try looking in Advanced Measuring Values as per picture below.
If memory fitted to hex52 module:
  • 046 and 047 should have the values shown above.
  • 044 and 045 can be different (it depends on where your mirror is adjusted when reading the X/Y coordinates) - but the values cannot be 255 (this indicates no memory module)
siLc
Tallinn, Estonia
C?ID=330192
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DL HW: 5Q0 937 084 DK
Component: BCM MQBAB MxL H40 0312
Some new variation of the MQB BCM?
The A5 module clearly doesn't have any light assist functions coded. Change last Byte of A5 coding to "40". There might be other coding and BCM adaptation changes to achieve the desired end result. This article might be of help -> https://www.ascoding.ch/en/activating-dynamic-light-assist-dla/
hadez16
C?ID=289891
Mirror dip: via coding not possible anymore since MY19.
Dynamic Light Assist: What makes you think you have the right headlights?
Light Assist: You're doing something wrong
Traffic Sign Detection: Would work when you have navigation
NEtech
C?ID=56995
ib97
Croatia
C?ID=375363
I used the article from ascoding.ch
When I coded dynamic, high beams stopped working.
Then i reverted everything and tried coding light assist, same thing.
Reverted everything to the original and posted an post.
ib97
Croatia
C?ID=375363
I did put it to 40.
hadez16
C?ID=289891
Light Assist, based on the data in your first post:
Coding A5: 0002070600000401002200448150A90084000E20002000
Adaptation 09:
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung to AFS: FLA: Fernlicht ueber AFS
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent to present
Done.
TBAx
C?ID=287144
This one is the reason the High Beams don’t work right now. Your Headlights are controlled by AFS, not BCM.
Changing the value as suggested by hadez16 fixes the issue.
hadez16
C?ID=289891
Copy-Paste issue resolved in my post above... "Menusteuerung" channel was wrong.
