Results 1 to 10 of 10
Thread: VW T-ROC LIGHT ASSIST/DYNAMIC LIGHT ASSIST NOT WORKING
    Sep 2019
    Croatia
    Hello all, after trying to code Dynamic Light Assist, not worked. Tried with Light Assist, not working. Error continued to appear after being done with coding. I used the same procedure on T-roc with halogen lights, and this one had LED lights. Everything worked on the other car.
    Hope that come knows why is this now working?
    Is Traffic sign Assist going to work?
    Does anyone know how to get mirror dip(module 52,byte 4 bit 2 and 3 option is not working ) and option for daytime running lights in the menu?
    Here is the auto-scan:
    Saturday,21,December,2019,10:07:07:60999
    VIN: WVGZZZA1ZLVxxxxxx   License Plate: ZG-stric
    Mileage: 1868km-1160mi   Repair Order:
    Chassis Type: A1-VW27 (3Q0)
    Scan: 01 03 08 09 10 13 15 17 19 42 44 4B 52 5F A5 BB BC D6 D7
    VIN: WVGZZZA1ZLVxxxxxx   Mileage: 1868km-1160miles
    Address 01: Engine (J623-DKRF)       Labels: None
       Part No SW: 04C 906 025 BC    HW: 04C 907 309 BP
       Component: R3 1.0l TFS   H20 7060
       Revision: DGH20000
       Coding: 0119003223441D082000
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_ECM10TFS01104C906025BC 003001
       ROD: EV_ECM10TFS01104C906025AK_003_VW27.rod
       VCID: 629C51B7F4C15567BF3-8036
       Part No SW: 5Q0 614 517 ER    HW: 5Q0 614 517 BN
       Component: ESC           H35 0190
       Revision: 00000000    Serial number: 61809000001413
       Coding: 46FA6A7D20202472477A060062C42562560424E26046A4733420F078D0224B0B00000523525212121035351919323200
       VCID: 05566A2B05AFC25FFA1-8050
       Part No SW: 5G0 907 044 FC    HW: 5G0 907 044 FC
       Component: Climatronic   H04 2201
       Revision: 00001K10
       Coding: 060200032001100D1105000000101036
       ASAM Dataset: EV_ACClimaBHBVW37X 006150
       VCID: 6D86328B3D1F1A1F121-8038
       Air quality sensor:
       Part No SW: 5Q0 937 084 DL    HW: 5Q0 937 084 DK
       Component: BCM MQBAB MxL H40 0312
       Serial number: 00101919000811
       ASAM Dataset: EV_BCMMQB 020001
       ROD: EV_BCMBOSCH_020_VW27.rod
       Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
       Component: RLHS  051  0206
       Serial number: SAY19M07D08H09M14S27
       Coding: 0018DD
       Steering Column Switch:
       Subsystem 2 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
       Component: Lenks.Modul  H03  0170
       Serial number: 0100100720190C203414
    14858 - Bulb for Right Brake Lamp / Tail Lamp
              B133C 15 [008] - Open or Short to Plus
                        Reset counter: 53
                        Mileage: 459 km
                        Date: 2019.10.31
                        Time: 10:48:58
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058619192
       Coding: 0471151801
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       ROD: EV_EPHVA18AU3700000_009_VW27.rod
       VCID: 50F88B7F8A6DD7F7197-8004
       Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0372
       Coding: 2A04604210FF8748949C810560408700000000000000000004
       ASAM Dataset: EV_ACCMRRCONTIVW376 003016
       ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
       VCID: 43D2B4334B1B3C6F945-8016
    2141 - Databus
              [FAULT_DIS_FAIL]
                        Reset counter: 50
                        Mileage: 199 km
                        Date: 2019.10.12
                        Time: 14:41:31
                        Voltage terminal 15: 12.5 V
                        Control Module temperature: 31 °C
                        Vehicle speed: 0.00 m/s
                        Longitudinal acceleration: -0.22 m/s²
                        Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
       Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
       Revision: --------    Serial number: 003Z2PEEV7XZ
       Coding: 88CCC0C0000000005C5400CF000800000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0B425C1323CBB42FAC5-805E
       Subsystem 1 - Part No SW: -----------    HW: 454 002 506 19
       Serial number: 357000000008E4915C3S
       Subsystem 2 - Part No SW: -----------    HW: 454 002 706 19
       Serial number: 358000000005374D6B3P
       Subsystem 3 - Part No SW: -----------    HW: 454 800 306 19
       Serial number: 35100D798E518000000V
       Subsystem 4 - Part No SW: -----------    HW: 454 803 005 19
       Serial number: 35200D5AEE218000000Y
       Subsystem 5 - Part No SW: -----------    HW: 454 801 506 19
       Serial number: 35500A746FE18000000Z
    1051909 - Databus
              [NWD: 0x30B Kombi_01 error value KBI_Airbag_Lampe]
                        Reset counter: 50
                        Mileage: 189 km
                        Date: 2019.10.12
                        Time: 11:03:02
       Part No SW: 2GA 920 740 B    HW: 2GA 920 740 B
       Component: KOMBI         203 6700
       Coding: 05A402066F800008018823031001000000000000
       ROD: EV_DashBoardVDDMQBAB_VW27.rod
       VCID: 323CE1F7E4A185E70F3-8066
    10485833 - Internal Control Module Memory Check Sum Error
              B2000 49 [009] - Internal electronic failure
              [Steuergerät defekt (SiLa) "Sicherheitswarnlampe"]
                        Mileage: 189 km
                        Date: 2019.10.12
                        Time: 11:03:02
       Component: GW MQB High   442 4388
       Revision: --------    Serial number: 0009854811
       Coding: 030100046F08560022000258080F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 70B82BFF2A2DF7F7397-8024
       Component: 5-01-14-01-04
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 1841902113700138FJ2B
       Coding: 2C0000
       Serial number: 5853691705
       Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
       Component: TSG FS        007 0480
       Serial number: 0000381692666
       Coding: 003003208000028000001000
       VCID: 4BC29C13634BF42F6C5-801E
       Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
       Component: FOND_FHSG_DRV  007 0010
       Serial number: 00000000000031775153
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1082
       Coding: 151F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B027EF5E35CBD7DDF-8020
    17152 - Indicator Lamp for Electro-Mechanical Power Steering
              C10D5 04 [008] - Internal System Fault
                        Reset counter: 50
                        Mileage: 189 km
                        Date: 2019.10.12
                        Time: 11:03:02
                        Motor status: 00
                        Supply voltage: 12.50 V
                        Temperature: 49.0 °C
                        KFC: 43
                        KFA: 00 00
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.50 V
                        uAdSensI_SwitchedKl30_xdu16: 12.36 V
                        NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
                        NoInitCause_RackPos_Rohwert: 00 00
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_KMN_RACKPOS_SET: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_WHLSPDPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
       Component: FCM MQB Low   003 0367
       Serial number: 28061910522624
       Coding: 000000070900204200000900000000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003.rod
       VCID: 372AD0E30FC360CF38D-8062
       Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
       Component: TSG BFS       007 0480
       Serial number: 0000380834904
       Coding: 003001208000028000001000
       VCID: 4ACC99176C31ED27573-801E
       Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
       Component: FOND_FHSG_PSG  007 0010
       Serial number: 00000000000031789643
       Coding: 190000
       Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
       Component: MU-S--ER      724 0890
       Coding: 02720600BE0000004111000100080A001F0500D40120010003
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 2D06F28BFD9FDA1F521-8078
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H61 8214
       Serial number: VWZ6ZJW2121344
    6720 - Rear View Camera
              B1102 31 [008] - No Signal
                        Reset counter: 66
                        Mileage: 1505 km
                        Date: 2019.11.07
                        Time: 17:45:20
                        Voltage terminal 30: 12.8 V
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H12 0610
       Serial number: 07061915K13168
       Coding: 0002070600000401002200448150A90084000E20000000
       ROD: EV_MFKBoschMQBB_002_VW27.rod
       VCID: 40D8BB3F5A0D2777897-8014
    Address BB: Door Rear Drv
    Address BC: Door Rear Pass
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
       Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
       Component: LED1L         H07 0009
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
       VCID: 025C71371481F567DF3-8056
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
       Component: LED1R         H07 0009
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
    Ad-map of 09:
    	Component:BCM MQBAB MxL H40 0312, Coding:000000000000000000000000000000000000000000000000000000000000
    	EV_BCMMQB,020001,EV_BCMBOSCH_020_VW27.rod
    	Saturday,21,December,2019,11:59:25:60999
    	VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 00 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 00 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,1 ,30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
    IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,not installed ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
    IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
    ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
    ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,55 min,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
    ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
    ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
    ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
    ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246991-digital_key-pa_Two_Keys,not active ,3
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Sollspannungsanforderung 13.5 ,6
    ENG141682-ENG141966-Front_wiper-Frontwischertyp,Direct ,6
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,47.5 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,47.5 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,47.5 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,47.5 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,45.0 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,42.5 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,35.5 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,28.5 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,24.0 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,15 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,127 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake light ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,15 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,127 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Parking light right ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake light ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,49 ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,3A ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,4B ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,44 ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parking light right ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 10 00 39 08 09 0F 18 00 7F 00 00 00 00 00 00 22 20 00 3A 08 0A 0F 18 00 7F 00 00 00 00 00 00 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 1B 00 80 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
    ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
    ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
    ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
    ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
    ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
    ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
    ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
    ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
    ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
    ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
    ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
    ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
    ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
    ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
    ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
    ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
    ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
    ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
    ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
    ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
    ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
    ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
    ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
    ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
    ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
    ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
    ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
    ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
    ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
    ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
    ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
    ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
    ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
    ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
    ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
    ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
    ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
    ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
    ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
    ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
    ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
    ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
    ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
    ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
    ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
    ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
    ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
    ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
    ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
    ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
    ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
    ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
    ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
    ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
    ENG122927-RLS_close_glazing,2.0 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
    ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,320 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,320 ms,10
    ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
    ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
    ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
    ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
    ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
    ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
    ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
    ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
    ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
    ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
    ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
    ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
    ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
    ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
    ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
    ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
    ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
    ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
    ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
    ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
    ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
    ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
    ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
    ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
    ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
    ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
    ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
    ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
    ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
    ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
    ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
    ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
    ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
    ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
    ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,5
    ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,not active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
    ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
    ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
    ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
    ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
    ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
    ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
    ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
    Elapsed Time: 01:50
    May 2014
    DLA: This car has mid-level BCM?
    DRL menu switch: ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich > active
    Reverse Mirror Dip: are you sure that the passenger side mirror has the required memory module? Try looking in Advanced Measuring Values as per picture below.
    If memory fitted to hex52 module:
    • 046 and 047 should have the values shown above.
    • 044 and 045 can be different (it depends on where your mirror is adjusted when reading the X/Y coordinates) - but the values cannot be 255 (this indicates no memory module)
  3. Likes Uwe liked this post
    Jul 2014
    Tallinn, Estonia
    Part No SW: 5Q0 937 084 DL HW: 5Q0 937 084 DK
    Component: BCM MQBAB MxL H40 0312
    Some new variation of the MQB BCM?
    The A5 module clearly doesn't have any light assist functions coded. Change last Byte of A5 coding to "40". There might be other coding and BCM adaptation changes to achieve the desired end result. This article might be of help -> https://www.ascoding.ch/en/activatin...ht-assist-dla/
    Jun 2017
    Mirror dip: via coding not possible anymore since MY19.
    Dynamic Light Assist: What makes you think you have the right headlights?
    Light Assist: You're doing something wrong
    Traffic Sign Detection: Would work when you have navigation
    You probably mean second last Byte, Byte 21.
    Sep 2019
    Croatia
    I used the article from ascoding.ch
    When I coded dynamic, high beams stopped working.
    Then i reverted everything and tried coding light assist, same thing.
    Reverted everything to the original and posted an post.
    Sep 2019
    Croatia
    I did put it to 40.
  9. #8
    Jun 2017
    Light Assist, based on the data in your first post:
    Coding A5: 0002070600000401002200448150A90084000E20002000
    Adaptation 09:
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung to AFS: FLA: Fernlicht ueber AFS
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent to present
    Done.
  10. #9
    Dec 2016
    DE
    This one is the reason the High Beams don’t work right now. Your Headlights are controlled by AFS, not BCM.
    Changing the value as suggested by hadez16 fixes the issue.
  11. Likes Uwe liked this post
  12. #10
    Jun 2017
    Copy-Paste issue resolved in my post above... "Menusteuerung" channel was wrong.
