Hey,
I bought a car with already retrofitted European S-Line seats to the US version. After some time a problem with PODS started to occur. It seems that the previous owner just stripped out PODS from the US seat and mounted it in the European S-Line one. The problem is that part can't be bought separately and Audi is strongly against even unplugging the connectors between the module and the occupancy detection sensor (which is basically glued to the seat). I'm wondering if there is a way to recode the airbag module the way it will use the European occupancy sensors instead of US PODS? I was only able to disable the occupancy detection but it causes 2 fault codes to appear and the airbag warning light is always on.
Saturday,21,December,2019,12:39:27:18015
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: WAUYGAFC9CN126609 License Plate:
Mileage: 162273km-100831mi Repair Order: 2
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAUYGAFC9CN126609 Mileage: 162273km-100831miles
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0010
Revision: --H07---
Coding: 1A2A0032052600060000
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 270BF8D81F6971CFA8D-8072
6140 - Fan 1 Control Circuit
P0691 00 [039] - Short to GND
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:32
Engine speed: 705.00 /min
Normed load value: 10.6 %
Coolant temperature: 85 ∞C
Intake air temperature: 39 ∞C
Voltage terminal 30: 14.523 V
Engine speed: actual: 672 /min
MAF_ENVD: 108.94117 mg/stroke
Coolant temperature (unfiltered): 85.50 ∞C
Engine: operating status: IS
Engine load: 10.546875 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 AJ
Component: 0BK 30TFSIUSA H16 1004
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 3B2334A8F3E1C52FDC5-806E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 44A70F0322E5F0C09B00
VCID: 3635259CC8C3184723B-8062
Part No SW: 4H0 907 064 BC HW: 4H0 907 064 BC
Component: BCM2 2.0 H31 0333
Coding: 098A3000000000000000
VCID: 6B83C4E8C38195AF0C5-803E
Component: J764 ELV MLB H39 0046
Serial number: 2311000286108010
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0062
Serial number: 26041100040316
Coding: 4682607800
ASAM Dataset: EV_AirCondiComfoUDS 002033
0315 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Sensor f¸r Luftfeuchte innen: kein Signal / Kommunikation]
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage terminal 30: 14.54 V
Outside air temperature: 11.5 ∞C
Engine speed: 694 /min
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001390239
Coding: 0600A091063C9FE08100008380003928CF9CD308A2090141000004402000
Shop #: WSC 00531 066 73451
VCID: 77ABE8988FC9214FF8D-8022
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120107 H35 0080
Serial number: 120119041159
Coding: 0045D7
Component: G397_RLFS H06 0002
Serial number: 20478020
Coding: 0200EE
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 08 03 2012 00001660
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 75A8CAB6000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901203001659
Coding: 282104
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8001RW42
Coding: 303145313131303030314A55304C34473853
VCID: 33331C88DBB10D6F045-8066
Serial number: 3575HRB405311PN8B1F0
Serial number: 3585HRB405311PN8DGBE
Serial number: 3515JRB405L12QE6M0SS
Serial number: 3525JRB405L12QE6IH3H
Serial number: 3554VRB405F0GR36D8LW
Serial number: 3564VRB405N0U2US88PZ
9442816 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 00 [137] - -
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:26
9445971 - Seat occupied recognition control module
B1022 53 [009] - Deactivated
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:27
Part No SW: 4H0 953 568 H HW: 7P6 953 507 T
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LL60002X
Coding: 000C34
Shop #: WSC 00046 123 12345
VCID: 38292BA4C257EE37317-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 11 11 2014 10037129
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:22
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 982 M HW: 4G8 920 982 M
Component: TBenUsa H79 0416
Revision: 25460175 Serial number: 658250112592016
Coding: 0BE501060B030008020100
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU57.rod
VCID: 3E253DBCE0F3D007FBB-806A
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000382250
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
VCID: 34311F94DEBF0A571DF-8060
Serial number: 7139958401
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 06071500041372
Coding: 20
0116 - Temperature Sensor for Rear Right Seat
B1114 15 [009] - Open or Short to Plus
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
0119 - Temperature Sensor for Rear Left Seat
B1113 15 [009] - Open or Short to Plus
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
0124 - Rear Right Seat Heater
B1118 15 [009] - Open or Short to Plus
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
0127 - Rear Left Seat Heater
B1117 15 [009] - Open or Short to Plus
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000022715198
Coding: 0058130000002001000001010101102030303232203232
Shop #: WSC 02311 785 00200
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200RT5I0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070AF03D955B9F521-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-08
Coding: 0000003
VCID: 3635259CC443184723B-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H02 0030
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F16.01.1200H020003CZ20741ˇ
Subsystem 4 - Serial number: Z20741ˇ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F5E025E20628202080413
VCID: 45D7525085A583DFBA1-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H56 0202
Revision: 00000001 Serial number: 0000895681
Coding: 101000010000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D31ACFCDBFC27C73-806E
Revision: 00002001 Serial number: 0169055735
Coding: 0126063A20FAB08482B00A80020100000000000000000000000000000000
Subsystem 2 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO14928143
Coding: 101F00
Subsystem 3 - Part No SW: 4G0 947 135 F HW: 4G0 947 135
Serial number: 0000000AP00011492381
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0028
Serial number: WA102902000000868163
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000000098
Coding: 030000
Shop #: WSC 52563 001 1048576
VCID: 1D67DA304DB5AB1FC21-8048
02753 - Inside Microphone (R74)
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:27
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F5E025E20628202080402
VCID: 44D14F548E9FBAD7ADF-8010
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000244661
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D01EC0C7B4CA7B73-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 120127-0001-117
Coding: 1223A6101002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2C0107F4068F529745F-8078
Part No SW: 4G0 035 082 C HW: 4G0 035 082
Component: Radio U SIRIU H53 0101
Revision: AB001007 Serial number: 236BS0C7510167
Coding: 000007020100000001
VCID: 2019E3C47AC786F7E97-8074
7 Faults Found:
02617 - Satellite Antenna (R170)
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:33
Voltage: 15.00 V
00417 - Left Front DSP Mid-Bass Speaker (R101)
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage: 15.00 V
00418 - Front Right DSP Mid-Bass Speaker (R102)
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage: 15.00 V
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage: 15.00 V
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage: 15.00 V
02246 - Loudspeaker; Center
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage: 15.00 V
03405 - Bass Loudspeaker
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:24
Voltage: 15.00 V
Part No SW: 4G0 035 746 J HW: 4G0 035 746
Component: H-BNT-NA H48 1034
Revision: -------- Serial number: 031AM0C7527341
Coding: 090100040103E1FF55108B4E00000003100001000100000202
Shop #: WSC 70410 259 45725
VCID: 2E050DFC301320876BB-807A
Subsystem 1 - Part No: 8R0 060 884 FC
Component: EUR 2018 2601
Subsystem 2 - Part No SW: 4G0 919 605 HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB940116SJ
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LB3000O7
Component: CD-Database 3371
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:27
Text: DUA009,Front,M,0,0,6
03175 - Invalid Data Set
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:25
Voltage: 14.90 V
01524 - Antenna for Telephone
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:36
Voltage: 14.90 V
03623 - Invalid Security/Release Code
Reset counter: 145
Mileage: 162273 km
Date: 2019.12.21
Time: 12:35:25
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0507
Coding: 010F1C024020628202080002
VCID: 47CB5858BFA991CF48D-8012
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 C HW: 4H0 907 441 B
Component: SG Rueckfahrkamera 0161
Revision: --H05--- Serial number: 525 PA8J1ZG2G9
Coding: 1080013
VCID: 270BF8D813E971CFA8D-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 P HW: 4G8 959 107 G
Component: HDSG-Modul H13 0039
Revision: 12013001 Serial number: 005200695
Coding: 0A3305C002
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 42DD494C940BB4E79F3-8016
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F168021AD3F7F769-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D198C24AB04670F3-8066
End----------(Elapsed Time: 02:16, VBatt start/end: 14.7V/14.8V)-----------
