Results 1 to 7 of 7
Thread: 2007/2008 VW Golf mk5 (1k) manual gearbox coding to engine ECU?
    Pirate
    Dec 2019
    Holywell, UK
    Hi guys,
    I am new here
    My wife's car developed gearbox fault, in result I was pushed to replace the gearbox.
    Original gearbox was JCR with following gear ratios
    Mechanism 61 : 18 = 3,389
    1. gear 34 : 09 = 3,778
    2. gear 33 : 16 = 2,063
    3. gear 31 : 23 = 1,348
    4. gear 29 : 30 = 0,967
    5. gear 29 : 39 = 0,744
    6. gear - -
    Reverse 36 : 20 X 18 : 9 = 3,600
    I have bough matching second hand JCR gearbox but unfortunately gentlemen who sold it to me, send me wrong one.
    Gearbox he send me is KBL, which physically fits the car but got completely different gear ratios which are as follows
    3. gear 30 : 24 = 1,25
    4. gear 27 : 32 = 0,843
    5. gear 30 : 48 = 0,625
    6. gear - - - -
    Reverse 36 : 20 x 18 : 9 = 3,600
    So as you can see final gear ratio is the same and gears: reverse, 1st and 2nd are the same.
    Gears 3rd, 4th and 5th are different.
    In result engine speed does not match wheels speed in ECU and cruise control in gears 4th and 5th does not work.
    Well... it works at low speed in 4th, but trips out when you accelerate, in 5th doesn't work at all.
    I would like to avoid changing gearbox again as it was nightmare to do it outside, in a rain, having only two axle stands and single hydraulic jack...
    If it is possible to input new values into ECU, please... tell me how.
    Any help really appreciated.
    Thanks in advance
    Marcin
    Without knowing what ECU hardware and firmware versions are fitted to your Mk5 Golf (they're not all the same) it will be difficult/impossible to answer your question, so a full unedited VCDS Auto-Scan will be needed.
    Pirate
    Dec 2019
    Holywell, UK
    Please see auto-scan attached below.
    I am fully aware of dtc's stored and these are on their way to be resolved.
    Only this one mentioned before gives me a bit headache.
    Removed.  Data from a clone/pirate copy of VCDS is not acceptable here.
    No, this is not possible with VCDS. The ECU would need to be re-flashed with tables appropriate to the gear ratios in question.
    Getting more help than that n this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#uk
    Let us know if/when you get one and we'll adjust your forum status.
    Pirate
    Dec 2019
    Holywell, UK
    I am wondering how is this even possible that my piece is a clone. It has been bought from one of your dealers few years back… I think 2016 or 2017.
    https://ibb.co/BcjDN8c
    https://ibb.co/1z3TNq3
    Quote Originally Posted by Wasyli90 View Post
    Really? Which dealer?
  7. #7
    Serial Number = 000000 means a clone; no ifs, no buts, no maybes
  8. Likes Uwe liked this post
