Results 1 to 5 of 5
Thread: Adaptation is grayed out on Controller A5
    Dec 2019
    Canada
    Hello all,
    I'm not sure if it was always this way, or I somehow broke it with tweaking, or if it's another problem. To the best of my knowledge, coding for A5 is stock. I only have Coding and Security buttons on the right side available for this controller. Adaptation works with other controllers, such as 09. Vehicle is 2018 Atlas Execline (Canada). TIA!
    Friday,20,December,2019,15:27:50:55377
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
    VCDS Version 19.6.2.0
    VIN: 1V2NR2CA3JCxxxxxx   License Plate:
    Chassis Type  CA-VW41 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
              52 5F 69 6C 6D A5 CA
    VIN: 1V2NR2CA3JCxxxxxx   Mileage: 27314km-16972miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (0-32-CDVC)       Labels:. 03H-907-309-V1.clb
       Part No SW: 03H 906 026 J    HW: 03H 907 309 K
       Component: VR6 3.6l FSI  H21 6026
       Revision: 52H21000
       Coding: 012A003244740108B0000000000000000000000000000000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM36FSI01103H906026J 001005
       ROD: EV_ECM36FSI01103H906026J.rod
       VCID: 2C5683F547D3662F2B-8079
       CAN Converter 01:
    4718 - No Communication with Transmission Control Module
              U0101 00 [032] - -
       Part No SW: 09G 927 158 A    HW: 09G 927 158
       Component: AISIN AQ8     206 3387
       Coding: 0000000100000000000000000000000000000000
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 3168928160F10BC718-8065
       Revision: 00000000    Serial number: 51768000000083
       Coding: 44FC6B8D84281A70C57F0308A2CA6922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
       ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
       VCID: 77FC6C99CE1515F796-8023
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0480530147
       Coding: 1F20000723
       VCID: 3E72B9BDA1AFE4BF95-806B
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11078902
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 3CN 907 044 M    HW: 3CN 907 044 M
       Component: Climatronic   H05 2009
       Revision: 00001K03
       Coding: 1602002620001C001104214C5210150C
       ASAM Dataset: EV_ACClimaBHBVW416 002012
       ROD: EV_ACClimaBHBVW416.rod
       VCID: 4998DA61E861530730-801D
       Fresh Air Blower Back:
       Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
       Component: BCM MQBAB HNA H36 0253
       Serial number: 8163005002˙˙˙˙
       ROD: EV_BCMBOSCH_018.rod
       VCID: 081E1F65B3EB6A0FEF-805D
       Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
       Component: RLHSS  050 0122
       Serial number: S6Y18M05D15H20M25S36
       Coding: 00382D
       Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H08 0050
       Serial number: 0000009600363Z00IL02
       Coding: 150000
       Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
       Component: GTO BF  H06 0007
       Serial number: 8MW00108021800010090
       Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Component: SysNameFanLin  014 0101
       Serial number: ESE1002752
       Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE1025960
       Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE1005133
       Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE1026516
    8970 - Bulb for Right Fog Lamp
              B1220 15 [008] - Open or Short to Plus
    204546 - Remote key 2
       Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0453
       Serial number: 000145451R18168
       Coding: 0271267951
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 53A4F8093A2D19D74A-8007
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 320007C959FFC728949C810530400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
    1236 - Databus
       Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
       Component: Airbag VW21   006 0713
       Revision: --------    Serial number: 003SUMII5KMb
       Coding: 8CCCDC00000000005000001A420800000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0B142069A29D0117C2-805F
       Occupant Detection:
       Component: Occ.Detection  H13 0022
       Serial number: IBH0000J180009MFKY02
       Coding: 303030
       Subsystem 2 - Part No SW: -----------    HW: 454 000 605 18
       Serial number: 357000000009240D3036
       Subsystem 3 - Part No SW: -----------    HW: 454 001 204 18
       Serial number: 358000000001A74CDF2.
       Subsystem 4 - Part No SW: -----------    HW: 454 800 906 18
       Serial number: 351001737BA14000000A
       Subsystem 5 - Part No SW: -----------    HW: 454 800 706 18
       Serial number: 352001E2CF214000000I
       Subsystem 6 - Part No SW: -----------    HW: 454 801 204 18
       Serial number: 35500DC793114000000K
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 454 801 204 18
       Component: FrontSensor_P  304 0149
       Serial number: 35600767431140000004
       Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
       Component: Lenks. Modul  004 0140
       Revision: --------    Serial number: 26041804400771
       Coding: 0C10
       VCID: 030408498ACD4957BA-8057
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 3CG 920 791 A    HW: 3CG 920 791 A
       Component: KOMBI         406 3196
       Coding: 0BAD0F1DEF8C880902886B0B50010000A0000000
       VCID: 3A7AB5ADBD87C89FA9-806F
    16777012 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
       Component: GW MQB High   518 5323
       Serial number: 02021800840537
       Coding: 0B0500347F087300FB0322581E0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 387EAFA5838BDA8F5F-806D
       Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
       Serial number: 33180000793870081439
       Coding: 36FFFF
       Serial number: 9436445800
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
       Component: U13DCAC  H23 0860
       Serial number: 0035597
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00007.05.18
       Coding: 0301
       VCID: 4C96E375E713462F0B-8019
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000172160001
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 336498899AED39D76A-8067
    No ASAM data for: "EV_ELVMarqMQBA0" (VW41)
       Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
       Serial number: Y0006RFE20574
       Coding: 0010000000000500018280808080000000008100000000F400
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       VCID: 3D70BEB1ACA9FFA78C-8069
    Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
       Component: HRE_Master    H12 0081
       Serial number: 0480117485
       Coding: 02012103
       ROD: EV_HREntryHella_VW27.rod
    No ASAM data for: "EV_HREntryHella" (VW41)
       Serial number: 210518A0080TB7
       Coding: 001F1B20D200020000000000
       VCID: 4384C849CA4D8957FA-8017
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000425611
       Coding: 011000
       Revision: 00000000    Serial number: 0002534175
       Coding: 01010311004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
       VCID: 408EC745DB5B924FE7-8015
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1JMD02J7T
       Coding: 2214060002AAAFAA000000000000
       ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
       ROD: EV_AMPMst12C3Gen2ALPI.rod
       VCID: 2E5289FD71CF143F05-807B
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 270518A0080L89
       Coding: 001F1320DE00020000000000
       VCID: 428ACD4DD557805FF1-8017
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000458364
       Coding: 091000
       Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
       Component: MU-S-NS-US    851 0867
       Coding: 021406020000000051220002001828001F0500E4012004008E
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 489EDF65F36BAA0F2F-801D
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZJV1450327
       Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
       Component: NAR 2018  --- 0715
       Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
       Component: Anhaenger     H27 0260
       Revision: 8C001004    Serial number: 0479210374
       Coding: 0200000200000000
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG028414
       Coding: 01140604A30F20003000400C
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       VCID: 3978AAA1B881C387A0-806D
       Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0266
       Revision: --------    Serial number: A2-C758-8680-2
       Coding: 0988
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       ROD: EV_DeckLidCONTIAU736_VW41.rod
       VCID: 4580D651C479B767D4-8011
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
       Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 1272
       Serial number: 16031841P13324
       Coding: 000401060001020100221355C150890084000E200120
       ROD: EV_MFKBoschMQBB_001_VW27.rod
    No ASAM data for: "EV_MFKBoschMQBB" (VW41)
    Address CA: Sunroof
    End-------------------------(Elapsed Time: 07:08)--------------------------
    Adaptation is grayed out because VCDS couldn't load any ASAM data. I'm not exactly sure why. It may be a chassis identification problem with the HEX+CAN you're using on that vehicle. As you can see from some of the other modules that it can't talk to at all, that's a marginal situation at best.
    Lansdale, PA
    Have you tried running it on a non emulated environment?
  4. Likes Uwe liked this post
    Dec 2019
    Canada
    Quote Originally Posted by Santos View Post
    Hi Santos, it would be worth a try but I don't have a bare-metal Windows device at present.
    Dec 2019
    Canada
    Adaptation is grayed out because VCDS couldn't load any ASAM data. I'm not exactly sure why. It may be a chassis identification problem with the HEX+CAN yoTu're using on that vehicle. As you can see from some of the other modules that it can't talk to at all, that's a marginal situation at best.
    Thanks, Uwe. I assumed the non-communicative modules were the ones that I couldn't get to because my cable is too old. Did you see some other ones that I should be able to get to, adding another symptom to my problem? TIA.
