Results 1 to 5 of 5
Thread: 2009 VW Rabbit
    Dec 2019
    Bradenton, FL, USA
    2009 VW Rabbit
    Hello all, hope you can help. First off I'm a DIY guy and not a tech. My 09 Rabbit doesn't get driven much. I bought it new in early 09 and put 50k on it in the first couple of years, since then I stopped traveling and it's only an extra vehicle now. I've had a bunch of issues recently that I've taken car of. First, about 3 months ago, the AC had a huge catastrophic failure. Apparently the charcoal filter in the drier broke and destroyed the entire system. So I let it sit idle while I gathered the funds for all of the needed parts, but by then the battery completely died. I bought new batteries (extra for stereo, but more on that later) and then replaced the entire AC system. Shortly after getting it all back together I had a headlamp go out so I replaced all of the lights up front. The car has always ran great, it still does, the are no running/driving issues, except now the epc has tripped and put the car into safe mode on 2 occasions. When you shut the car off the epc resets and it's fine. Also, I swapped the stock brakes for the R32s a few years ago. About a year after doing that the ABS and anti skid lights came on. I thought it was a dirty wheel speed sensor, because it was intermitten and was not throwing any P- codes (I didn't know about the vcds then). Everything worked, abs, antiskid, etc, but eventually the lights just stayed on so I though one went out.
    So then I took the car to a local garage because the dealer won't scan mine because of the aftermarket stereo. (I did the checks advised about stereos here on the FAQs and my K-line is fine.) The local garage found no codes with a Snap-on Solus scanner and we couldn't get the epc to trip. Now, fast forward to this week. I bought and just received the Ross-Tech scanner. The first thing I did is run an auto scan and, from what I see, you'd think I should just drive it straight to the junk yard. Malfunctions everywhere. It looks to me that most are intermitten and a lot may be related to the previous repairs, but I'm not sure. Also, there was also a recall done on the abs wiring harness about a year ago. So that's the story on the car and here's the scan. Should I start by just clearing all of the codes and then do another scan on it?
    Thu,Dec,19,2019,19:10:40 VCDS Mobile 0.4508.0.4 VIN: WVWAA71K19W071132 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65 VIN: WVWAA71K19W071132 01-Engine -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK
    0000 ----------------------------------------------------------------- Address 01: Engine	Labels: 07K-906-055-CBT.clb 	Part No SW: 07K 906 055 Q	HW: 07K906055M 	Component: 2,5l R5/4V G 9204 	Revision: G6H01---	Serial Number: VWX7Z0H63NL865 	Coding: 0000071 	Shop #: WSC 05234 444 100159 	VCID: 3C3BA7F34F73B7F1C74A0B-8069 2 Faults Found: 049441 - No Communication with ABS Brake Control Module 	U0121 - 000 - - - Intermittent 000802 - Engine Speed Sensor (G28) 	P0322 - 000 - No Signal - Intermittent ----------------------------------------------------------------- Address 03: ABS Brakes (-----)	Labels: 1K0-907-379-60EC1F.clb 	Part No SW: 1K0 907 379 CD	HW: 1K0 907 379 AD 	Component: ESP MK60EC1 H35 0120 	Revision: 00H35001 	Coding: 113B400D492900FB880C02E7921B00413000 	Shop #: WSC 08306 002 1048576 	VCID: 76AF75DB31DFADA1F18E89-8023 1 Fault Found: 01276 - ABS Hydraulic Pump (V64) 	012 - Electrical Fault in Circuit ----------------------------------------------------------------- Address 08: Auto HVAC	Labels: 1K0-820-047.lbl 	Part No SW: 1K0 820 047 JL	HW: 1K0820047JL 	Component: Climatic PQ35 142 1212 	Revision: 00142032	Serial Number: 00000000000000 	Shop #: WSC 00000 000 00000 	VCID: 77B178DF36D554A9EAB8BC-8022 2 Faults Found: 00229 - Refrigerant Pressure 	002 - Lower Limit Exceeded - Intermittent 01317 - Control Module in Instrument Cluster (J285) 	004 - No Signal/Communication - Intermittent ----------------------------------------------------------------- Address 09: Cent. Elect.	Labels: 3C0-937-049-30-M.lbl 	Part No SW: 3C8 937 049 D	HW: 3C8937049D 	Component: Bordnetz-SG H54 2602 	Revision: 00H54000	Serial Number: 00000008697888 	Coding: 108D0F214004150047140000001400000008730B5C000100000000000000 	Shop #: WSC 01287 785 00200 	VCID: 322789CB9D3771811DE6B5-8067 	Subsystem 1 - 	Part No SW: 1K1-955-119-E	Labels: 1Kx-955-119.clb 	Component: Wischer 110708 021 0501 	Coding: 0038805 6 Faults Found: 01493 - Bulb for Blinkers; Front Left (M5) 	012 - Electrical Fault in Circuit - Intermittent 00532 - Supply Voltage B+ 	002 - Lower Limit Exceeded - Intermittent 01495 - Bulb for High-Beams; Left (M30) 	010 - Open or Short to Plus - Intermittent 00978 - Lamp for Low Beam; Left (M29) 	010 - Open or Short to Plus - Intermittent 00154 - Windshield Wiper Motor; Passenger Side (V217) 	002 - Lower Limit Exceeded - Intermittent 02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage 	002 - Lower Limit Exceeded - Intermittent ----------------------------------------------------------------- Address 15: Airbags	Labels: 1K0-909-605.lbl 	Part No SW: 1K0 909 605 AB	HW: 1K0959339G 	Component: 6K AIRBAG VW8R 034 8000 	Revision: 05034000	Serial Number: 003B6D0BNE61 	Coding: 0013899 	Shop #: WSC 01357 011 00200 	VCID: 6C9B57B37F93E771172A3B-8039 	Subsystem 1 - 	Part No SW: 1K0-959-339-G 	Component: BF-Gewichtsens. 007 0007 	Serial Number: 6332MSME3D314925B 	Subsystem 2 - 	Serial Number: 6342MSME3D312D54G 	Subsystem 3 - 	Serial Number: 6352QSME77260B15G 	Subsystem 4 - 	Serial Number: 6362QSME7E713C1BY 	Subsystem 5 - 	Serial Number: 63727SME173C514A3 	Subsystem 6 - 	Serial Number: 63827SME174567652 No fault codes found. ----------------------------------------------------------------- Address 16: Steering wheel	Labels: 1K0-953-549-MY8.lbl 	Part No SW: 1K0 953 549 BN	HW: 1K0953549BN 	Component: J0527 051 0101 	Coding: 0000022 	Shop #: WSC 01279 785 00200 	VCID: 7F4190FF1EE56CE9A2E8E4-802A 5 Faults Found: 00576 - Terminal 15 	012 - Electrical Fault in Circuit 00883 - Ignition Switch (D) Terminal S 	012 - Electrical Fault in Circuit 00885 - Ignition Switch (D) Terminal 50 	012 - Electrical Fault in Circuit - Intermittent 00884 - Ignition Switch (D) Terminal X 	012 - Electrical Fault in Circuit 01744 - Ignition Switch Terminal P (D) 	012 - Electrical Fault in Circuit ----------------------------------------------------------------- Address 17: Instruments	Labels: 1K0-920-xxx-17.lbl 	Part No SW: 1K0 920 954 S	HW: 1K0920954S 	Component: KOMBIINSTRUMENT VDD 1222 	Revision: V0003000	Serial Number: VWX7Z0H63NL865 	Coding: 0007203 	Shop #: WSC 05234 444 100159 	VCID: 3C3BA7F34F73B7F1C74A0B-8069 2 Faults Found: 00446 - Function Limitation due to Under-Voltage 	002 - Lower Limit Exceeded - Intermittent 00532 - Supply Voltage B+ 	002 - Lower Limit Exceeded - Intermittent ----------------------------------------------------------------- Address 19: CAN Gateway	Labels: 1K0-907-530-V3.clb 	Part No SW: 1K0 907 530 Q	HW: 1K0907951 	Component: J533 Gateway H07 0062 	Revision: H07 01	Serial Number: 100708F2002500 	Coding: E9801F070002020000 	Shop #: WSC 01279 785 00200 	VCID: 352DB2D76C5966B93804D6-8060 1 Fault Found: 01305 - Databus for Infotainment 	004 - No Signal/Communication ----------------------------------------------------------------- Address 25: Immobilizer	Labels: 1K0-920-xxx-25.clb 	Part No SW: 1K0 920 954 S	HW: 1K0920954S 	Component: IMMO VDD 1222 	Revision: V0003000	Serial Number: VWX7Z0H63NL865 	Shop #: WSC 00000 000 00000 	VCID: 3C3BA7F34F73B7F1C74A0B-8069 No fault codes found. ----------------------------------------------------------------- Address 42: Door Elect, Driver	Labels: 1K0-959-701-MIN3.lbl 	Part No SW: 1K0 959 701 M	HW: 1K0959701M 	Component: Tuer-SG 006 1207 	Coding: 0001077 	Shop #: WSC 01279 785 00200 	VCID: 3833BBE37B4B9BD12322F7-806D 1 Fault Found: 01811 - Supply Voltage for Door Controller; Drivers Side (J386) 	002 - Lower Limit Exceeded - Intermittent ----------------------------------------------------------------- Address 44: Steering Assist	Labels: 1Kx-909-14x-44.clb 	Part No SW: 1K1 909 144 M	 	Component: EPS_ZFLS Kl.069 H08 1901 	Shop #: WSC 00000 028 00001 	VCID: 352DB2D76C5966B93804D6-8060 No fault codes found. ----------------------------------------------------------------- Address 46: Central Conv.	Labels: 1K0-959-433-MAX.clb 	Part No SW: 1K0 959 433 CT	HW: 1K0959433CT 	Component: KSG PQ35 RDK 052 0221 	Revision: 00052000	Serial Number: 00000000000000 	Coding: 139006885103281B0904058FB0080A04889C80 	Shop #: WSC 01287 785 00200 	VCID: 844B9F13F7038F317F3A33-80D1 	Subsystem 1 - 	Component: Sounder n.mounted 	Subsystem 2 - 	Component: NGS n.mounted 	Subsystem 3 - 	Component: IRUE n.mounted 1 Fault Found: 00532 - Supply Voltage B+ 	002 - Lower Limit Exceeded - Intermittent ----------------------------------------------------------------- Address 52: Door Elect, Pass.	Labels: 1K0-959-702-MIN3.lbl 	Part No SW: 1K0 959 702 M	HW: 1K0959702M 	Component: Tuer-SG 006 1207 	Coding: 0001076 	Shop #: WSC 01279 785 00200 	VCID: 3935BEE7404182D9DC2CEA-806C 1 Fault Found: 01812 - Supply Voltage for Door Controller; Pass. Side (J387) 	002 - Lower Limit Exceeded - Intermittent ----------------------------------------------------------------- Address 56: Failed to respond ----------------------------------------------------------------- Address 65: Tire Pressure	Labels: 3C0-959-433-65.lbl 	Part No SW: 1K0 959 433 CT	HW: 1K0959433CT 	Component: RDK 0450 	Revision: 00052000	Serial Number: 00000000000000 	Coding: 0100101 	Shop #: WSC 01279 785 00200 	VCID: 844B9F13F7038F317F3A33-80D1 No fault codes found. End--(Elapsed Time: 01:51, VBatt start/end: 11.9/12.0 Vign: 0.0)-
    Thanks in advance for any help you can provide.
    Hi and welcome.
    Your scan is almost impossible to read hard to read due to the lack of line breaks. I'm not sure what software it passed through that messed with them.
    Oct 2017
    Northwest UK
    Yes clear all faults and run another scan. Thanks.
    Quote Originally Posted by myounus View Post
    And post the scan using the .txt file that VCDS saves without 'mangling' it with any other piece of software!
    Dec 2019
    Bradenton, FL, USA
    Thank you all for replying and I'm sorry about the file. The "how to post the scan" instructions differ from the desktop on my tablet so I had to improvise. The post preview did look fine when I checked it before posting, but it altered once I posted.
    Thank you myounus, I will clear the codes and then run a second scan. After, I will post both the first again and then the sound scan to compare.
