Results 1 to 2 of 2
Thread: VW Crafter VCDS Auto Scan Issues
    Dec 2019
    Hey, so i know my Crafter wont read fully but what it does read is a little hit and miss.
    Meaning sometimes it reads other times it does not and the auto scan has failed to
    read some massive codes.
    I, like other users have also had to switch the ignition off and on in order to connect to a
    module which is a a rather painful work around every time i do anything.
    Anyway, here are 2 auto scans and a fault log in a module.
    Both auto scans fail to read the codes, only when i go into the module can i read the codes.
    ------------------------- AUTO SCAN 01 ------------------------------------------------
    Friday,20,December,2019,11:55:25:64379
    VIN: WV1ZZZ2EZB6*******   License Plate:
    Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
              B0 B1 B2 B3 B4 B5 B6 C1
    Address 91: LT3 Engine        Labels: Redir Fail!
       Part No SW: 076 906 022 P    HW: 076 906 022 G
       Component: R5 2,5L EDC A0A0SG  7730
       Coding: 0003032
       Shop #: WSC 80093 222 71269
       VCID: 2019E796C6CC54B7E97-8074
    No Faults Found
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
       Component: IMMO          0805  0815
       Revision: 00805000    Serial number: VWXDZ0J1023775
       VCID: 6D87CEA2419E49DF121-8038
    Address 94: LT3 Airbag
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3331.rod (*)
       VCID: 55F78642C58EE11FCA1-8000
    Address 95: LT3 ESP
       Part No SW: 9069022800    HW: 0004460153
       ASAM Dataset: 3 4101
       ROD: CRFT_ESP_3_36946.rod (*)
       VCID: 04518B067E94A897EDF-8050
    Address 96: LT3 Instruments
       Part No SW: 9069026400    HW: 9069012000
       ASAM Dataset: 32 787
       ROD: CRFT_KOMBI_32_787.rod
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0805  0815
       Revision: 00805000    Serial number: 12345678901234
    Address 9B: LT3 Driver Door
       Part No HW: 9068204126
       ASAM Dataset: 33 773
       ROD: CRFT_FTUHR_33_773.rod (*)
    Address B0: LT3 Roof Display
       Part No SW: 9069021000    HW: 9069010900
       ASAM Dataset: 21 3
       ROD: CRFT_DBE_21_3.rod (*)
       VCID: 7BA3F0FA036AD76F9C5-802E
    909C - Alarm Horn (H12): No or incorrect basic setting
                Test Complete - Active/Stored
    Address B4: LT3 Central Elec.
       Part No SW: 9064420700    HW: 9065453801
       ASAM Dataset: 33 772
       ROD: CRFT_EZE_33_772.rod (*)
    90A1 - Engine Coolant Level (ECL) Sensor (G32): Short to Plus
    Address B6: LT3 Steering Wheel
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 0655910E48A89A87F3B-8052
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.6V/12.6V)-----------
    ------------------------- AUTO SCAN 02 ------------------------------------------------
    Friday,20,December,2019,12:31:07:64379
    VIN: WV1ZZZ2EZB6******   License Plate:
       VCID: 55F78642CC0EE11FCA1-FFFE
    Address 95: LT3 ESP
    Address 99: LT3 Ign. Switch
       Part No HW: 9065455808
       ASAM Dataset: 67 257
       ROD: CRFT_EZS_67_257.rod (*)
       ASAM Dataset: 21 3
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.5V/12.5V)-----------
    ------------------------------------MODULE FAULT LOG -------------------------------------
    FYI - Many Codes here are due to lots of things not being connected, which i am guessing should have been read by the Auto Scan?
    Friday,20,December,2019,12:33:02:64379
    VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
    Control Module Part Number: 076 906 022 P    HW: 076 906 022 G
      Component and/or Version: R5 2,5L EDC A0A0SG  7730
               Software Coding: 0003032
                Work Shop Code: WSC 80093 222 71269
    10 Faults Found:
    000261 - Manifold / Barometric Pressure Sensor (G71) / (F96)
                   P0105 - 001 - Malfunction
                        Fault Status: 01100001
                        Voltage: 12.62 V
                        Torque: 90.0 Nm
                        Temperature: 49.5C
                        Bin. Bits: 00010000
    008235 - Control Circuit for Reductant Tank Heating
                   P202B - 000 - Short to GND - MIL ON
                        Fault Status: 11100000
                        Voltage: 12.31 V
                        Temperature: 6.3C
                        Temperature: 7.2C
                        Voltage: 0.750 V
                        Voltage: 0.000 V
    009304 - Diesel Particulate Filter
                   P2458 - 000 - Regeneration Duration - MIL ON
                        RPM: 735 /min
                        Pressure: 5 mbar
                        Hex Value: 0xFF00
                        Temperature: 78.0C
                        (no units): 25.5
                        Mileage: 270 km
    005762 - Powertrain Data Bus
                   P1682 - 000 - Implausible Message from ABS Controller - Intermittent
                        Voltage: 12.69 V
                        Torque: 90.0 Nm
                        Temperature: 43.2C
                        Bin. Bits: 00010000
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early
                        Voltage: 0.00 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00000000
                        Temperature: -90.0C
    000291 - Throttle Position Sensor (G69)
                   P0123 - 000 - Signal too High - MIL ON
                        Voltage: 11.86 V
                        Lambda: 99.4 %
                        Lambda: -0.8 %
                        Bin. Bits: 00000000
                        Voltage: 5.016 V
    001029 - EGR Sensor 1
                   P0405 - 000 - Signal too Low
                        Voltage: 11.86 V
                        Lambda: 99.4 %
                        Lambda: -3.9 %
                        Bin. Bits: 00000000
                        Voltage: 0.000 V
    008448 - Throttle Actuator Control Circuit
                   P2100 - 000 - Open Circuit - MIL ON
                        Load: 100.0 %
                        Lambda: 99.4 %
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 8.1C
    005184 - EGR Valve (N18)
                   P1440 - 000 - Open Circuit
                        Load: 100.0 %
                        Lambda: 99.4 %
                        Temperature: 8.1C
    004374 - Oxygen (Lambda) Sensor Heating; B1 S1
                   P1116 - 000 - Open Circuit
                        Lambda: 1.6 %
                        Voltage: 0.000 V
                        (no units): 0.15
                        Voltage: 3.300 V
    Please help as am wondering if i would have been better spending the 200 on booze instead
    of this VCDS system as at least it would have made me feel better.
    That generation of Crafter has been a bugger for us. They're a mix of VAG and MBZ parts, and even the VAG parts don't always behave "normally". It's complicated by the fact that we can't just get a hold of one to beat things into submission because they simply don't exist on this side of the pond.
    Anyway, the
    No Faults Found
    and the lack of any detail regarding the ECU are in the second scan are a definite clue to that you should dig deeper, and directly accessing the ECU as you did in the third section above is a good way to do that.
