Results 1 to 10 of 13
Thread: VCDS Mobile No Asam data found
    Nov 2019
    Romania
    I try to use my hex-net on my passat 2011, 2.0TDI CFGB, using mobile app, but if i try to go to the engine module, or even if i do auto scan, i end up with the message that ASAM data is not found locally.
    I then push the download button, but it then downloads something and is stuck. I tried this several times, but result is the same.
    This the engine module using desktop version:
    Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 BD HW: 03L 907 309 N
    Component: R4 2,0L EDC H24 9953
    Revision: 47H24--- Serial number: 00000000000000
    Coding: 001D0012040401080000
    Shop #: WSC 10127 599 00000
    ASAM Dataset: EV_ECM20TDI01103L906018BD 003007
    ROD: EV_ECM20TDI01103L906018BD.rod
    VCID: ED92519C3CB9F027FC-80B8
    Also these are error messages from the mobile app:
    https://ibb.co/G3MvvDD
    https://ibb.co/KXPyZDN
    Can you let me know how i can fix this? I read several posts but no concrete steps to solve it. Is there an official guideline for this issue, as i see i'm not the only one with this issue.
    Thanks,
    Ciprian
    You can connect with usb and check for updates with VCIConfig
    Nov 2019
    Romania
    Hi Shaun,
    This helped, and missing files were downloaded and written to hex-net, but i still have HVAC module for which i think there is no available file, since is the only module for which is still complaining of missing asam data.
    If i connect the interface to the laptop and use VCIConfig, it says that that rods needs to be update, downloads it, and then it will be written to the interface.
    Next time i do autoscan, finds that i have missing asam data. I connect then interface again via usb, i do the updates using VCIConfig, but still no asam data for HVAC:
    Part No SW: 1K0 907 044 AB
    Component: ClimatronicPQ35 066 0404
    VCID: 6791289F5E86C479DF18EC-8032
    Can something be done about this?
    Thanks,
    Ciprian
  4. Likes Uwe liked this post
    Dec 2019
    I was getting the same issue with my Hex-Net too. I had to do the 50 second reset first before it would accept the data.
    I'm a little bit confused, that appears to be a regular CAN hvac, it doesn't have ASAM data since it does not talk with the UDS protocol. Any info that is documented should be in that label file, is there some information in particular that you feel is missing?
  7. Likes Uwe liked this post
    Nov 2019
    Romania
    Hi Shaun,
    Happy new year!!!
    Well the problem i have is that i can't use Advanced Measuring Values at all. When i enter to that module it says No Asam data found locally, and i select Continue Anyway. Then if i try to choose Advanced Measuring Values, i receive a screen where it says Loading ASAM dataset 0% and it stays like this forever. Only way to get rid is to choose exit, which closes the mobile app, which also don't know if is safe, as somehow the communication is ongoing during that time.
    Also entering the module it says Communicating UDS.
    https://ibb.co/RHjtC3D
    https://ibb.co/gyPjqmH
    https://ibb.co/7yC0TPz
    Quote Originally Posted by ciprianglg View Post
    Hi Shaun,
    Happy new year!!!
    Let's check some basics here. Is this happening on the HVAC module you showed details about in post #3? Because that makes no sense at all...
  10. #8
    Nov 2019
    Romania
    Hi Uwe,
    Yes it is happening when i select from the the list of installed modules, HVAC one.
    Also when i do autoscan, when hits this HVAC module it says i have missing ASAM data.
    Thanks,
    Ciprian
  11. #9
    Hi Uwe,
    I'm scratching my head. This HVAC module:
    ... does not need, want, or use ASAM data.
    Please post a complete Auto-Scan. The only explanation I can think of is that VCDS-Mobile is actually complaining about needing a ASAM data for a different module.
  12. #10
    Nov 2019
    Romania
    Hi Uwe,
    This is it:
    VCDS Mobile 0.4508.0.4
    VIN: WVWZZZ3CZBE320102
    Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61
    	 62 6C 72 77
    08-Auto HVAC -- Status: OK 16000
    09-Cent. Elect. -- Status: Malfunction 16010
    16-Steering wheel -- Status: OK 16000
    17-Instruments -- Status: OK 16000
    25-Immobilizer -- Status: OK 16000
    42-Door Elect, Driver -- Status: OK 16000
    46-Central Conv. -- Status: OK 16000
    4F-Centr. Electr. II -- Status: OK 16000
    52-Door Elect, Pass. -- Status: OK 16000
    62-Door, Rear Left -- Status: OK 16000
    72-Door, Rear Right -- Status: OK 16000
    Address 01: Engine  (CFGB J)	Labels: 03L-906-018-CFF.clb
    	Revision: 47H24---
    	VCID: 6D9D5AB77C7A7629A5542E-8038
    No fault codes found.
    Address 02: Auto Trans	Labels: 02E-927-770.lbl
    	Part No SW: 02E 300 054 H	HW: 02E927770AL
    	Component: GSG DSG AG6     511  2602
    	Revision: 05351112	Serial Number: 00001011020719
    	Shop #: WSC 05311 000 00000
    	VCID: 1B79446FD24ED0998B00B0-804E
    Address 03: ABS Brakes	Labels: 3AA-614-109.clb
    	Part No SW: 3AA 614 109 M	HW: 3AA614109M
    	Component: J104   C2 450M V4F5  0005
    	Revision: --H07---	Serial Number: 00000003484231
    	Coding: 0006588
    	VCID: 3731B8DF4EA694F98F38FC-8062
    Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
    	Part No SW: 5K0 907 044 EA	HW: 5K0 907 044 EA
    	Component: Climatronic   H17 1010
    	Revision: 00003001
    	Coding: 0000000003
    	Shop #: WSC 00015 115 00000
    	ROD: N/A
    	VCID: 6E9F5DBB717C8D319C5E21-803B
    	No ASAM data for: "EV_Climatronic"
    Address 09: Cent. Elect.  (J519)	Labels: 3AA-937-087.clb
    	Part No SW: 3AA 937 087 A	HW: 3AA 937 087 A
    	Component: BCM PQ47 H    413 0452
    	Revision: BB413001
    	Coding: 000000000000000000180080540081E443510088426D85606480C7200041
    	VCID: 3833BBE343B81B818622F7-806D
    	Subsystem 1 - 	Part No SW: 3AB-955-419	Labels: 1Kx-955-119.clb
    	Component: Wischer 1511110  0603
    	Coding: 00B795
    	Subsystem 2 - 	Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
    	Component: RLS 171110 0554  0403
    	Coding: 033028
    		Fault Status: 00100001
    		Reset Counter: 27
    		Mileage: 239694 km
    		Date: 2039.14.12
    		Time: 15:36:36
    		: Term 15 On
    		Voltage: 14.85 V
    		: ON
    		: ON
    		: ON
    		: OFF
    		: ON
    Address 10: Park/Steer Assist  (J446)	Labels: 3AE-919-475.clb
    	Part No SW: 3AE 919 475	HW: 7N0 919 475
    	Component: PARKHILFE 8K  H04 0009
    	Revision: --------
    	Coding: 308102
    	ASAM Dataset: EV_EPHVA18VW47X0000 001003
    	ROD: EV_EPHVA18VW47X0000.rod
    	VCID: FCBBE7F3B7006FA1A2CA4B-80A9
    Address 15: Airbags	Labels: 5N0-959-655.lbl
    	Part No SW: 5N0 959 655 R	HW: 5N0959655R
    	Component: J234__101 VW10 HI    1918
    	Revision: 22014000	Serial Number: 003K0PPEDR42
    	Coding: 0012337
    	VCID: 4CDBF73327200721D2EADB-8019
    	Subsystem 1 - 	Serial Number: 6332MTS647353070
    	Subsystem 2 - 	Serial Number: 6342MTS654763070
    	Subsystem 3 - 	Serial Number: 6351HTS6FQA1G6KJ
    	Subsystem 4 - 	Serial Number: 6361HTS61HC1G6KJ
    	Subsystem 5 - 	Serial Number: 00000000000000000
    	Subsystem 6 - 	Serial Number: 00000000000000000
    Address 16: Steering wheel  (J527)	Labels: 3C-16.lbl
    	Part No SW: 3C9 953 501 BF	HW: 5K0 953 569 S
    	Component: LENKS.MODUL   009 0136
    	Revision: FF010039
    	Coding: 199A050000
    Address 17: Instruments  (J285)	Labels: 3C8-920-xxx-17.clb
    	Part No SW: 3AA 920 870 A	HW: 3AA 920 870 A
    	Coding: 161B00
    	Shop #: WSC 36860 001 1048576
    	ROD: EV_Kombi_UDS_VDD_RM09_A04_VW46.rod
    	VCID: 302383C3ABC8DBC1CEF28F-8065
    Address 19: CAN Gateway  (J533)	Labels: 7N0-907-530-V2.clb
    	Part No SW: 7N0 907 530 G	HW: 1K0 907 951
    	Component: J533  Gateway H41 1614
    	Revision:   H41
    	Coding: 462006
    	Shop #: WSC 05314 000 00000
    	VCID: 342B8FD35FD0FFE1AA1AA3-8061
    Address 25: Immobilizer	Labels: 3C0-959-433-25.clb
    	Part No SW: 3AA 959 433	HW: 3AA959433
    	Component:    IMMO         043  0399
    	Revision: 00043000	Serial Number: VWZCZ000000000
    	VCID: F6AFF5DB892CADF1D48E09-80A3
    	Subsystem 1 - 	Part No SW: 3C0-905-861-J
    	Component:    ELV          029  0380
    Address 37: Navigation  (J0506)	Labels: 1T0-035-680.clb
    	Part No SW: 1T0 035 680 C	HW: 1T0 035 680 C
    	Component: RNS-MID       H42 2720
    	Revision: AB001001
    	Coding: 0C0004000400008000
    	Shop #: WSC 49522 150 89505
    	VCID: 2E1F9DBBB1FCD531DCDE61-807B
    Address 42: Door Elect, Driver  (J386)	Labels: 3C0-959-70X-GEN4.clb
    	Part No SW: 3AA 959 701 A	HW: 3C0 959 793 C
    	Component: TUER-SG FT    002 0529
    	Revision: 12110009
    	Coding: 0200B7
    	Shop #: WSC 05311 115 00000
    	ROD: EV_TSGFPQ35BRFVW46X.rod
    	VCID: 352DB2D754AAFEE99D04D6-8060
    Address 44: Steering Assist	Labels: 5N1-909-144.clb
    	Part No SW: 5N1 909 144 L	HW: 5N1909148G
    	Component: J500__APA-BS KL.310  0802
    	Revision: 1AH03729	Serial Number: 00103270191001
    	Coding: 0000258
    	VCID: 3B39A4EF728EB0996B4010-806E
    Address 46: Central Conv.	Labels: 3C0-959-433-46.clb
    	Component:    KSG PQ47 ELV 043  0631
    	Coding: 0091020052830E76300494157C084F0B607801
    	Subsystem 1 - 	Component:   Sounder n.mounted
    	Subsystem 2 - 	Component:       NGS n.mounted
    	Subsystem 3 - 	Component:      IRUE n.mounted
    Address 4F: Centr. Electr. II  (J520)	Labels: 1K0-907-532.clb
    	Part No SW: 7N0 907 532	HW: 1K0 907 951
    	Component: EZE_2         H41 1614
    	Revision:   H41
    	Coding: 00000008
    	VCID: EFA1C0BFF6761C391748D4-80BA
    	Subsystem 1 - 	Part No SW: 3AA-919-204
    	Component: Analoguhr    003 0003
    Address 52: Door Elect, Pass.  (J387)	Labels: 3C0-959-70X-GEN4.clb
    	Part No SW: 3AA 959 702 A	HW: 3C0 959 792 C
    	Component: TUER-SG BT    002 0529
    	Revision: 14110009
    	Coding: 0200B6
    	ROD: EV_TSGBPQ35BRFVW46X.rod
    	VCID: 362FB5DB49ACF5F1940EC9-8063
    Address 53: Parking Brake	Labels: 3AA-907-801.clb
    	Part No SW: 3AA 907 801 E	HW: 3AA907801E
    	Component: J540 EPB4  VW-55183  0007
    	Revision:   H18   	Serial Number: 00000000059084
    	Coding: 0022067
    	VCID: 33298CCF5ADE78D9B310A8-8066
    Address 56: Radio  (J0506)	Labels: 1T0-035-680.clb
    	Revision: AB001001
    Address 61: Battery Regul.  (J840)	Labels: 1K0-907-534.clb
    	Part No SW: 7N0 907 534	HW: 1K0 907 951
    	Component: Batt.regelung H41 1614
    	Coding: 030B185A
    	VCID: F1A5C6C7E0420AC9017CC2-80A4
    	Subsystem 1 - 	Part No SW: 1K0-915-181-F
    	Component: J367-BDM     H07 0150
    Address 6C: Back-up Cam.	Labels: 5N0-907-441.clb
    	Part No SW: 3C9 907 441	HW: 3C9907441
    	Component: J772__Rearview       0020
    	Revision: 00H08000	Serial Number: 525PA8-J0Y0628
    	Coding: 0020007
    	VCID: E893ABA3D3984B01560267-80BD
    Address 77: Telephone  (J412)	Labels: 7P6-035-730.clb
    	Part No SW: 7P6 035 730 D	HW: 7P6 035 730 D
    	Component: TELEFON       H05 0440
    	Revision: 1B001001
    	Coding: 0A01000000000001
    	ASAM Dataset: UHVNA A01007
    	ROD: UHVNA.rod
    	VCID: 33298CCF5ADEE0D9B310A8-8066
    End--(Elapsed Time: 02:20, VBatt start/end: 12.2/12.2 Vign: 12.2)-
    So seems there is an ASAM dataset used by HVAC module, and my previously paste didn't included this one, which is odd somehow as i don't recall from where i took it, either mobile or desktop.
    Anyway now maybe makes more sense:
    Revision: 00003001
    Coding: 0000000003
    ROD: N/A
