Results 1 to 10 of 11
Thread: Function not supported by gateway
    Dec 2019
    India
    My car just came back from Audi service center after service and i found they have deleted all the tweaks done by me and restore it to original so i tried to do all that again but as i connected vcds its coming Function not supported by gateway. Please help what could be the reason before this i have used same laptop same cable on same car never had this issue.
    Lansdale, PA
    What kind of car? What version of VCDS? Is the key on in the ignition? What color are the LEDs on the interface cable?
    Dec 2019
    India
    Audi A6 c7 2018 petrol, VCDS 19.6.2, yes it’s in ignition, green blink on cable.
    Green LED just means it has power on Vbatt (pin 16 of the diagnostic connector).
    [Options] -> [Test] in VCDS please. Look at the last line: What is the voltage shown by Vign?
    If that's less than 11V, your ignition isn't really on. If it's over 11V, try opening the car's hood ("bonnet").
    Dec 2019
    India
    It’s showing 12.5v
    Dec 2019
    India
    Have done by opening Bonet also result is same.
  7. #7
    What happens if you try to access the Gateway directly?
    [Select]
    [19-CAN Gateway]
  8. #8
    Dec 2019
    India
    Same not supported by gateway
  9. #9
    Quote Originally Posted by samridh View Post
    That doesn't make sense to me.
    At what point, exactly, does VCDS say that when you click:
    [Select]
    [19-CAN Gateway]
  10. #10
    Dec 2019
    India
    It try 2-3 times then this error comes
