Results 1 to 2 of 2
Thread: Why "Extended UDS fault detail is only supported by current gen. interfaces" MY09?
    Sep 2016
    Riga, Latvia
    My question is in the title. Why does this show up instead of fault code details/description using HEX-CAN-USB interface and 19.x VCDS on 09' MY Golf, for example?
    I can't remember seeing this with older 17.x, 18.x VCDS versions.
    One example:
    Friday,20,December,2019,21:09:09:32442
    VCDS Version: 19.6.1.0
    VIN: WVWZZZ1KZ9W535590   License Plate:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 77
    VIN: WVWZZZ1KZ9W535590   Mileage: 483100km-300184miles
    42-Door Elect, Driver -- Status: Sporadic communication error 1000
    52-Door Elect, Pass. -- Status: Malfunction 1010
    Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 MC    HW: 03L 906 022 G
       Component: R4 2,0L EDC G000SG  3593
       Revision: 13H01---    Serial number:
       Coding: 0000071
       Shop #: WSC 12345 935 999999
       VCID: 72EBB0F76DD19BDF9F-8026
    001652 - Cylinder 4 Glow Plug Circuit (Q13)
                   P0674 - 000 - Electrical Fault
                        Fault Frequency: 7
                        Mileage: 451300 km
                        Date: 2013.05.17
                        Time: 17:58:34
                        RPM: 1081 /min
                        Voltage: 11.25 V
                        Temperature: -1.8C
                        Bin. Bits: 10110000
                        Time: 2.52 s
                        Temperature: -1.8C
    008200 - Intake Manifold Flap; Bank 1
                   P2008 - 000 - Electrical Malfunction - Intermittent
                        Fault Frequency: 28
                        Mileage: 480008 km
                        Date: 2014.03.17
                        Time: 17:36:37
                        Load: 17.3 %
                        Load: 100.0 %
                        Lambda: 100.2 %
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 15.3C
    001575 - Fuel Pump Relay Control Circuit
                   P0627 - 000 - Open Circuit - Intermittent
                        Mileage: 481481 km
                        Voltage: 11.78 V
                        Pressure: 8.0 bar
                        Inj. Quantity: 0.0 mg/str
                        Lambda: 15.0 %
                        Lambda: 7.9 %
    009778 - Relay for Fuel Pump 2 (J49)
                   P2632 - 000 - Open Circuit - Intermittent
                        Mileage: 481481 km
                        Date: 2014.04.12
                        Time: 14:55:37
                        Voltage: 10.49 V
                        Pressure: 0.0 bar
                        Lambda: 31.6 %
                        Lambda: 11.0 %
    009571 - Turbocharger Boost Control Position Sensor Circuit
                   P2563 - 000 - Implausible Signal - Intermittent
                        Mileage: 481658 km
                        Date: 2014.04.22
                        Time: 21:37:25
                        RPM: 782 /min
                        Voltage: 14.29 V
                        Lambda: 88.4 %
                        Lambda: -20.5 %
                        Bin. Bits: 00011110
                        Voltage: 1.748 V
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Load: 0.0 %
                        Voltage: 0.00 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00000000
                        Temperature: -90.0C
    Readiness: 0 1 0 0 0
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 113B200D092500FF881004ED901900423000
       VCID: 74E7B6EFD7C595EF8D-8020
       Part No SW: 3C8 907 336     HW: 3C8 907 336
       Component: Climatic      120 0102
       Revision: 00004001
       Coding: 0000000000
       Shop #: WSC 80093 222 69422
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6ADBA8978D01531F27-803E
    9473905 - Motor for Temperature Flap
              B108F 71 [008] - Actuator stuck
                        Fault Frequency: 61
                        Reset counter: 32
                        Mileage: 482177 km
                        Date: 2019.12.11
                        Time: 19:55:40
    9477394 - Motor for Air Distribution Flap
              B109D 12 [009] - Short to Plus
                        Reset counter: 253
                        Mileage: 450843 km
                        Date: 2018.12.19
                        Time: 07:32:04
    13701488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 20
                        Mileage: 481481 km
                        Date: 2019.11.19
                        Time: 14:19:06
    13701504 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 31
                        Mileage: 482134 km
                        Date: 2019.12.07
                        Time: 15:13:59
       Part No SW: 1K0 937 085     HW: 1K0 937 085
       Component: BCM PQ35  B+  020 0360
       Revision: 00020000
       Coding: 46180A3A90251A9040000080100000E445010088524D8960648000000000
       Shop #: WSC 79103 146 83050
       VCID: 6CD7AE8F8FF54D2F55-8038
       Component: Wischer 13030  21  0501
       Coding: 009795
    00984 - Left Tail Light (M4)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 76
                        Reset counter: 6
                        Mileage: 482229 km
                        Date: 2014.05.07
                        Time: 19:24:36
                            Term 15 On
                        Voltage: 14.40 V
                            Term 50 Off
    03266 - Control Circuit for Signal Horn
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 248
                        Mileage: 482229 km
                        Date: 2014.05.07
                        Time: 19:24:36
                            Term 15 On
                        Voltage: 14.40 V
                            Term 50 Off
                        Fault Frequency: 26
                        Reset counter: 45
                        Mileage: 482229 km
                        Date: 2014.05.07
                        Time: 20:15:11
                            Term 15 On
                        Voltage: 11.90 V
                            Term 50 Off
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2R36057M
       Coding: 00003135
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77FD81E3CEB3FEF7A8-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 5F280243ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 19523146ZZZZZZZZZZZZ
       Serial number: 12231C11ZZZZZZZZZZZZ
       Serial number: 16041E0EZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
       Component: J0527           051 0101
       Coding: 0001042
       Shop #: WSC 12345 123 12345
       VCID: 7CF79ECF3F95DDAFC5-8028
       Part No SW: 5K0 920 860 E    HW: 5K0 920 860 E
       Component: KOMBI         H21 0030
       Coding: 170A00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       VCID: 2E5364877169FF3F3B-807A
       Part No SW: 1K0 907 530 S    HW: 1K0 907 951
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K09316059F
       Coding: E9801F06000602000002
       VCID: 377D41E346333EF768-8062
    01304 - Radio
                        Reset counter: 5
                        Mileage: 450177 km
                        Date: 2013.05.04
                        Time: 00:02:05
                        Reset counter: 19
                        Mileage: 481481 km
                        Date: 2014.04.11
                        Time: 14:19:05
                        Reset counter: 30
                        Mileage: 482134 km
                        Date: 2014.04.29
                        Time: 15:13:59
                        Fault Status: 01101011
                        Reset counter: 5
                        Mileage: 478411 km
                        Date: 2014.02.22
                        Time: 22:11:07
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H21 0030
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
       Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
       Component: Tuer-SG         008 2041
       Coding: 0000118
       VCID: 79F987DB30A7E887DE-802C
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A5B68978581931FE7-807E
       Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
       Coding: 0000118
       VCID: 7AFB98D735A1E39FD7-802E
    00940 - Mirror Adjust Motor; Passenger Side (V150)
    Address 56: Radio
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730 B    HW: 1K8 035 730 B
       Component: Telefon       H08 5400
       Revision: 00008000    Serial number: 20389520082400
       Coding: 001120
       VCID: 285F929F5B8DA10FF1-807C
    03427 - Right Audio Channel
                        Reset counter: 238
                        Mileage: 450177 km
                        Date: 2013.05.04
                        Time: 00:01:30
    01304 - Radio
                        Reset counter: 5
                        Mileage: 450177 km
                        Date: 2013.05.04
                        Time: 00:02:08
    End-------------------------(Elapsed Time: 02:19)--------------------------
    Older versions did not have the "Extended UDS fault detail" at all. I don't remember exactly at what version it got added, but it was definitely after the older HEX+CAN had been discontinued, and we elected to implement it only for current interfaces.
