Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Golf 6 r inner brake led lights coding
    Nov 2017
    Croatia
    Hello i want to try coding rear led inner lights on boot. I have tool for that bit i see on forum i must change byte 18 on bcm to "00" first. I save my coding first. Is it possible some trouble if i change value now is 04 to 00
    Jan 2015
    Bosnia and Herzegovina
    there is no problem since your byte 18 is known 04, problem is when byte 18 is 00 (it newer is a 00, 00 is just a mask, true value is hidden)
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
    Nov 2017
    Croatia
    I must put 00 than change with tool eeprome and when i finished again put 04 is it correct
    Nov 2017
    Croatia
    May 2016
    No modify and no back to 04
    Nov 2017
    Croatia
    Ok better dont change anything
  7. #7
    Nov 2017
    Croatia
    Vastechnics do you tell me if i change something in eeprome no posible back to 04
  8. #8
    Nov 2017
    Croatia
    I am scared to change byte 18 because if not possible back to 04 coding
  9. #9
    Mar 2019
    Poland
    Nov 2017
    Croatia
    Thanks for reply I see allready this but some guys on forum tell me dont change anything in byte 18
