Results 11 to 20 of 25
Thread: Golf 6 r inner brake led lights coding
    Jan 2015
    Bosnia and Herzegovina
    susjed neznam sto komplikujes stvari, iscitaj sa vcp-om eeprom modifikuj vrijednosti da ti rade i unutrasnje kao kociono svjetlo i gotovo, u slucaju da sta zaseres upises 04 u byte 18 i mozes opet testirati do mile volje, ako te toliko strah da diras byte 18 nemoj nista dirati nadji ko smije i nek ti odradi....
    ps. answer written in native language to summarize I explained that he can revert to 04 in byte 18 in case of any issue.
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  2. #12
    Nov 2017
    Croatia
    Ok susjed bilo me strah jer neki kazu da se moze zasrat hvala puno Thanks
  3. #13
    Nov 2017
    Croatia
    Još ako moze pitanje susjed dali kad iskodiram byte 18 vracem na 04 ili ostavljam 00 hvala ti puno
  4. #14
    May 2016
    You van change. But need vcp to do. Vcds not possible
  5. #15
    Nov 2017
    Croatia
    Thanks for reply I have vcp tool. When finish coding is i must put in byte 18 "04"or leave
    " 00"
  6. #16
    Jan 2015
    after editing with vcp byte 18 won't be 04 so don't change it just leave it at 00
    GOOD CHEAP FAST
  7. #17
    Jan 2017
    Portugal
    For 5K0 BCMs, when you do changes in EEPROM, byte 18 change to 00
    For 1K0 BCMs, when you do changes in EEPROM, byte 18 don't change, if you wan't to view your changes you have to change to 00 before.
    All options of byte 18 are in flash files, I have passed all the info to Excel file:
    https://drive.google.com/file/d/1GoA...ew?usp=sharing
    In line with value 04 you can see what is used in our car. At any point if you change byte 18 to 04 it will use those values.
    VagHelper is a great tool to understand what those bytes do.
  8. Likes Uwe liked this post
  9. #18
    Nov 2017
    Croatia
    Thanks for reply if I changed byte 18 from 04 to 00 nothings screw up is it ok
  10. #19
    Nov 2017
    Croatia
    Hello i have done coding but inner lamp i think not bright same brighthess does it possible with vcp dimmer thanks
  11. #20
    Jan 2015
    yes of course
    GOOD CHEAP FAST
