Golf 6 r inner brake led lights coding
Ljubo
Croatia
C?ID=271067
Hello i want to try coding rear led inner lights on boot. I have tool for that bit i see on forum i must change byte 18 on bcm to "00" first. I save my coding first. Is it possible some trouble if i change value now is 04 to 00
Thanks
m87a
Bosnia and Herzegovina
C?ID=156900
there is no problem since your byte 18 is known 04, problem is when byte 18 is 00 (it newer is a 00, 00 is just a mask, true value is hidden)
Ljubo
Croatia
C?ID=271067
I must put 00 than change with tool eeprome and when i finished again put 04 is it correct
vastechnics
C?ID=143747
No modify and no back to 04
Ljubo
Croatia
C?ID=271067
Ok better dont change anything
Ljubo
Croatia
C?ID=271067
Vastechnics do you tell me if i change something in eeprome no posible back to 04
Ljubo
Croatia
C?ID=271067
I am scared to change byte 18 because if not possible back to 04 coding
Ljubo
Croatia
C?ID=271067
Thanks for reply I see allready this but some guys on forum tell me dont change anything in byte 18
m87a
C?ID=156900
susjed neznam sto komplikujes stvari, iscitaj sa vcp-om eeprom modifikuj vrijednosti da ti rade i unutrasnje kao kociono svjetlo i gotovo, u slucaju da sta zaseres upises 04 u byte 18 i mozes opet testirati do mile volje, ako te toliko strah da diras byte 18 nemoj nista dirati nadji ko smije i nek ti odradi....
ps. answer written in native language to summarize I explained that he can revert to 04 in byte 18 in case of any issue.
Ljubo
Croatia
C?ID=271067
Ok susjed bilo me strah jer neki kazu da se moze zasrat hvala puno Thanks
Ljubo
Croatia
C?ID=271067
Još ako moze pitanje susjed dali kad iskodiram byte 18 vracem na 04 ili ostavljam 00 hvala ti puno
vastechnics
C?ID=143747
You van change. But need vcp to do. Vcds not possible
Ljubo
Croatia
C?ID=271067
Thanks for reply I have vcp tool. When finish coding is i must put in byte 18 "04"or leave
" 00"
m87a
C?ID=156900
after editing with vcp byte 18 won't be 04 so don't change it just leave it at 00
n4s
Portugal
C?ID=351319
For 5K0 BCMs, when you do changes in EEPROM, byte 18 change to 00
For 1K0 BCMs, when you do changes in EEPROM, byte 18 don't change, if you wan't to view your changes you have to change to 00 before.
All options of byte 18 are in flash files, I have passed all the info to Excel file:
https://drive.google.com/file/d/1GoAwsNHGie_fTnpmFb4Tu_FuK5aQhqsJ/view?usp=sharing
In line with value 04 you can see what is used in our car. At any point if you change byte 18 to 04 it will use those values.
VagHelper is a great tool to understand what those bytes do.
Ljubo
Croatia
C?ID=271067
Thanks for reply if I changed byte 18 from 04 to 00 nothings screw up is it ok
Ljubo
Croatia
C?ID=271067
Hello i have done coding but inner lamp i think not bright same brighthess does it possible with vcp dimmer thanks
