Results 1 to 7 of 7
Thread: VW Crafter - Huge Loss of Power - EGR Shut Off
    Dec 2019
    ME - James
    MY VAN - VW - Crafter - 2011 - 2E - TDI 5-Cyl. 88-163 Hp Panel Van (LT3 / 2006 > 2016)
    MY POST - Hey guys, so have read all i can, esp Jacks guide, so here goes.
    I have a serious loss of power on my self build camper and this is my first post and
    first use of a system like Ross Tech VCDS, before i had a sub 20 ($20) OBDII scanner
    so please go easy on me.
    So for the last month the van have thrown code P2196 - O2 Sensor, which as it seemed
    all fine i have just been clearing and driving on and ignoring the check engine light.
    Mainly because people get telling me its likely the DPF not clearing because of short
    runs but as my van is a camper its mainly only ever making long trips of 100+ miles.
    So then, last week the engine goes limp, i thought actual limp mode but now i am not
    so sure, got engine light and flashing coil light (which i know is just another check
    engine. Meaning i did not get a flashing red exclamation light.
    OBDii scanner read: P2BAC, P2BAB, P202B, P0123, P2100.
    Took to garage (emergency find) and they fitted a new EGR after saying it was faulty,
    not sure i trust that now. It was very clean and seemed to flick around, should have
    kept the old but was stressed and was not thinking properly.
    Left there as had to get van home, got towed and cleared the codes.
    Now just from running stationary this is the scan i get, (see bellow) but after i drive it,
    still like its in limp mode but with no lights for a few miles, i get all those codes again.
    ---------- AFTER IDLE ENGINE SCAN ----------
    Tuesday,17,December,2019,15:20:52:64379
    VIN: WV1ZZZ2EZB6******   License Plate: MT60***
    Mileage: 178000   Repair Order: 001
    Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
              B0 B1 B2 B3 B4 B5 B6 C1
    VIN: WV1ZZZ2EZB6
    Address 91: LT3 Engine        Labels: Redir Fail!
       Part No SW: 076 906 022 P    HW: 076 906 022 G
       Component: R5 2,5L EDC A0A0SG  7730
       Coding: 0003032
       Shop #: WSC 80093 222 71269
       VCID: 2019E796C6CC54B7E97-8074
    No Faults Found
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
       Component: IMMO          0805  0815
       Revision: 00805000    Serial number: VWXDZ0J1023775
       VCID: 6D87CEA2419E49DF121-8038
    Address 94: LT3 Airbag
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3331.rod (*)
       VCID: 55F78642C58EE11FCA1-8000
    Address 95: LT3 ESP
       Part No SW: 9069022800    HW: 0004460153
       ASAM Dataset: 3 4101
       ROD: CRFT_ESP_3_36946.rod (*)
       VCID: 04518B067E94A897EDF-8050
    Address 96: LT3 Instruments
       Part No SW: 9069026400    HW: 9069012000
       ASAM Dataset: 32 787
       ROD: CRFT_KOMBI_32_787.rod
    Address 99: LT3 Ign. Switch
       Part No HW: 9065455808
       ASAM Dataset: 67 257
       ROD: CRFT_EZS_67_257.rod (*)
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0805  0815
       Revision: 00805000    Serial number: 12345678901234
    Address 9B: LT3 Driver Door
       Part No HW: 9068204126
       ASAM Dataset: 33 773
       ROD: CRFT_FTUHR_33_773.rod (*)
    Address B0: LT3 Roof Display
       Part No SW: 9069021000    HW: 9069010900
       ASAM Dataset: 21 3
       ROD: CRFT_DBE_21_3.rod (*)
       VCID: 7BA3F0FA036AD76F9C5-802E
    909C - Alarm Horn (H12): No or incorrect basic setting
                Test Complete - Active/Stored
    Address B4: LT3 Central Elec.
       Part No SW: 9064420700    HW: 9065453801
       ASAM Dataset: 33 772
       ROD: CRFT_EZE_33_772.rod (*)
    Address C1: LT3 Battery Mgmt        Labels:
       VCID: 55F78642CC0EE11FCA1-FFFE
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.9V/12.8V)-----------
    ---------- SCAN COMPLETE ----------
    So here is the scan after i run it stationary for a while.
    ---------- RUNNING SCAN ----------
    Wednesday,18,December,2019,09:53:08:64379
       Revision: 24H37---    Serial number: VWXDZ0J1023775
       Coding: 0003032
    000261 - Manifold / Barometric Pressure Sensor (G71) / (F96)
                   P0105 - 001 - Malfunction - Intermittent
                        Fault Status: 00100001
                        Voltage: 12.62 V
                        Torque: 90.0 Nm
                        Temperature: 49.5C
                        Bin. Bits: 00010000
    008235 - Control Circuit for Reductant Tank Heating
                   P202B - 000 - Short to GND
                        Voltage: 12.31 V
                        Temperature: 6.3C
                        Temperature: 7.2C
                        Voltage: 0.750 V
                        Voltage: 0.000 V
    009304 - Diesel Particulate Filter
                   P2458 - 000 - Regeneration Duration - MIL ON
                        Fault Status: 11100000
                        RPM: 735 /min
                        Pressure: 5 mbar
                        Hex Value: 0xFF00
                        Temperature: 78.0C
                        (no units): 25.5
                        Mileage: 270 km
    Address 95: LT3 ESP
       ASAM Dataset: 21 3
    Address B6: LT3 Steering Wheel
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 0655910E48A89A87F3B-8052
    End----------(Elapsed Time: 01:21, VBatt start/end: 13.2V/12.8V)-----------
    QUESTIONS and IDEAS
    So firstly i am thinking O2 Lambda Sensor, but does anyone know the module to measure it and
    what the values should be?
    I know these codes also say the MAF sensor, so what can be done to test and measure this too?
    Also wondering if the short to ground on the reductant tank has the power to thrown the NOX and then
    the EGR?
    All ideas and help welcomed.
    James
  2. Likes Jack@European_Parts liked this post
  3. #2
    Aug 2016
    The Hague, NL
    How is the DPF and its sensors/wirings?
    2458 seems to indicate that the DPF is not particularly happy. Perhaps the filter is clogged/full or G450 (diff. pressure sensor) faulty?
  4. Likes Uwe, Jack@European_Parts, Lightboy liked this post
  5. #3
    Dec 2019
    Could be
    Cheers for the reply will look at the DPF values in the VCDS to check (if i can find the group codes to measure the blocks)
    SO that code has only happened since i have been running it standing still.
    It was not on the original OBDII scan i did and so guessing that its not regenerating based on the incorrect air flow i see in the EGR cutoff.
    Essentially it feels like its in limp mode, although no red hazard on the dash, which i assume it does when in official limp mode, only a flashing coil light
    and a fixed engine check. (coil light is just a more severe check engine light when flashing)
    I was asked to check the DPF but as its very hard to look at from behind the Turbo i opted for removing the sensors at the top and bottom of the DPF.
    My assumption is that if the DPF was packed with soot, that either one of these sensors would be dirty but they were both very clean.
    As i said the EGR valve was also very clean and i tend to do long runs when i do drive so it gets plenty of opportunity to recycle itself,
    and as i said it was not in the original fault codes i read from the OBDii scan tool, done prior to the buying of the Ross Tech System.
    The DPF seems to get hot enough for it to recycle but because the lack of power i think it fails to regenerate based on not enough air flow.
    Gonna pull out the Lambda and check, and replace the MAP sensor to account for the first code, then pull the nox sensor, letting it run with
    clean air, which should open the EGR valve its thats the issues. Have disconected the EGR to see if it ran better but no joy, ran the same, leads me to think
    the turbo, although no codes there, or the MAP, due to bad sensor or a leak in the system.
    Also thinking the intake manifold?
    But question is, do you or anyone know the group codes to know what i am looking at inside the VCDS,
    as i dont get group titles due to the MERC VW mash up?
    I was told by Ross Tech uk dealer i would have issues but to not get a name label from a module on what i thought was a VW engine in a Merc chassis seems like a bummer. I accept stuff like the ABS or other modules down from the Engine so if anyone can help that would be grand.
    Cheers
  6. #4
    16.4905 S, 151.7375 W
    Hello James,
    - For the fault code P0105, I would look at the Measuring Value Block(MVB) group [010] to compare the G71-Manifold Absolute Pressure sensor and the F96-Barometric Pressure sensor with the Key-On and the Engine-Off.
    These two values should be the same (+/- 100mbar, typical)
    MVB-010, 2 = Ambient Raw Value
    MVB-010, 3 = Charge Air Pressure, actual
    For the fault code 'P202B-Control Circuit for Reductant Tank Heating: Short to GND', I suggest to check the wiring, connections, etc to the J891-Control Unit for Reducing Agent Heater. This would include checking the two fuses under the drivers seat, SD34 and SD35, both are 15A fuses.
    If all of the above are okay, there is an [Output Test] you can perform with VCDS on the ECM to activate the Heater for reducing agent tank.
    You will want to have the Key-On and the Engine-Off when running this test.
    [Select]
    [01-Engine]
    [Output Tests - 03]
    - Press [Start/Next] to find and activate the heater for reducing agent (In some cases an [Activate] will be displayed)
    When the test is running, VCDS will display the status of this test [On/Off] and the Voltage supplied to the heater (must be greater than 1.0V)
    The fault code P2458 seems to mean that a regeneration was started but was interrupted for some reason, perhaps due to the P202B fault code.
    After the other faults have been corrected/cleared you will want to perform an extended road test to see if the ECM can perform a successful regeneration.
    By the way, the ECM does appear to have a software update.... However, I can not seem to find any documentation to verify this, so I suggest to check this out with the manufacture.
    ref:
    ECM update - [076-906-022-P], from (7730) to (9022)
    We recommend the use of the Official Factory Repair Information when working on these vehicles.
    Hope this helps,
    drpeter
  7. Likes Jack@European_Parts, Uwe, Lightboy liked this post
  8. #5
    Dec 2019
    3 great ideas and places to look but sadly to no avail.
    So looked at the measuring block you suggested both pressures are the same. Not sure if the group codes are the same in my MERC VW mash up?
    Here is the measuring blocks in Engine 01.
    (sorry for the format, how do you put scans and logs in there own scroll box?)
    Thursday,19,December,2019,09:24:19:64379
    Mileage:    Repair Order: 100
                    Address 01: Engine  (076 906 022 P)
    09:24:02 Group 001
      0 /min  RPM
      0.0 mg/str  Inj. Quantity
      0.0 bar  Pressure
      9.9C  Temperature
    09:24:02 Group 002
      0 /min  RPM
      0.0 %  Load
      00000000  Bin. Bits
      9.9C  Temperature
    09:24:02 Group 003
      0 /min  RPM
      1175.0 mg/str  Mass Air / Rev.
      0.0 mg/str  Mass Air / Rev.
      100.0 %  Load
    09:24:32 Group 004
      0 /min  RPM
      0.0 BTDC  Ign. Timing
      0.0  (no units)
      0.0 bar  Pressure
    09:24:32 Group 005
      0 /min  RPM
      1.0  (no units)
      9.9C  Temperature
    09:24:32 Group 006
      0.0 km/h  Speed
      00010000  Bin. Bits
      0.0 km/h  Speed
      00000000  Bin. Bits
    09:25:00 Group 007
      10.8C  Temperature
      9.0C  Temperature
      12.6C  Temperature
      9.9C  Temperature
    09:25:00 Group 008
      0 /min  RPM
      90.0 Nm  Torque
      0.0 Nm  Torque
      615.0 Nm  Torque
    09:25:00 Group 009
      0 /min  RPM
      -1280.0 Nm  Torque
      615.0 Nm  Torque
      0.0 Nm  Torque
    09:25:09 Group 010
      989.4 mbar  Absolute Pres.
      0.0 %  Load
    09:25:09 Group 011
      0 /min  RPM
      999.6 mbar  Absolute Pres.
      9.8 %  Load
    09:25:09 Group 012
      01010000  Bin. Bits
      1.98 s  Time
      12.31 V  Voltage
      9.9C  Temperature
    09:25:16 Group 013
      0.00 mg/str  Inj. Quantity
    09:25:16 Group 014
    09:25:16 Group 015
      0 /min  RPM
      -150.0 Nm  Torque
      0.00 l/h  Fuel Consump.
      90.0 Nm  Torque
    09:25:46 Group 016
      0.0 %  Lambda
      00000000  Bin. Bits
      0.0  (no units)
      12.31 V  Voltage
    09:25:46 Group 017
      0.0  (no units)
      0.00  (no units)
      42.6 l  Tank Cont.
      777 /min  RPM
    09:25:46 Group 018
      0 /min  RPM
      10.8C  Temperature
      0.0  (no units)
      1.0  (no units)
    09:26:10 Group 019
      0 /min  RPM
      221.85  (no units)
      448.0 bar  Pressure
      9984.0
    09:26:10 Group 021
      0 /min  RPM
      224.0 bar  Pressure
      0.0 bar  Pressure
      4.7 %  Lambda
    09:26:10 Group 021
      0 /min  RPM
      224.0 bar  Pressure
      0.0 bar  Pressure
      4.7 %  Lambda
    09:26:21 Group 022
      0 /min  RPM
       0001000  Bin. Bits
       0000000  Bin. Bits
       0111000  Bin. Bits
    09:26:21 Group 024
      0 /min  RPM
      0.0  (no units)
      0.0 bar  Pressure
    09:26:21 Group 024
      0 /min  RPM
      0.0  (no units)
      0.0 bar  Pressure
    09:26:29 Group 025
      0 /min  RPM
      0.0  (no units)
      0.0 bar  Pressure
    09:26:29 Group 027
      0 /min  RPM
      0.0  (no units)
      0.0 bar  Pressure
    09:26:29 Group 027
      0 /min  RPM
      0.0  (no units)
      0.0 bar  Pressure
    09:26:42 Group 028
      0 /min  RPM
      0.0  (no units)
      0.0 bar  Pressure
    09:26:42 Group 030
      0.304 V  Voltage
      0.152 V  Voltage
      00000000  Bin. Bits
      0.0 %  Load
    09:26:42 Group 030
      0.304 V  Voltage
      0.152 V  Voltage
      00000000  Bin. Bits
      0.0 %  Load
    09:26:54 Group 031
      5B75
    09:26:54 Group 033
      0 /min  RPM
      12.0C  Temperature
      1.00  (no units)
      1.00  (no units)
    09:26:54 Group 033
      0 /min  RPM
      12.0C  Temperature
      1.00  (no units)
      1.00  (no units)
    09:27:02 Group 034
      0 /min  RPM
      9.8 %  Load
      -0.8 %  Lambda
      4.7 %  Lambda
    09:27:02 Group 036
      0 /min  RPM
      100.0 %  Load
      97.8 %  Lambda
      0.0 %  Lambda
    09:27:02 Group 036
      0 /min  RPM
      100.0 %  Load
      97.8 %  Lambda
      0.0 %  Lambda
    09:27:15 Group 037
    09:27:15 Group 039
      0 /min  RPM
      12.6C  Temperature
      0.0 %  Lambda
    09:27:15 Group 039
      0 /min  RPM
      12.6C  Temperature
      0.0 %  Lambda
    09:27:23 Group 040
      0 /min  RPM
      100.0 %  Load
      100.2 %  Lambda
      0.0 %  Lambda
    09:27:23 Group 042
      0.15  (no units)
      1.6 %  Lambda
      3.300 V  Voltage
      25.40  (no units)
    09:27:23 Group 042
      0.15  (no units)
      1.6 %  Lambda
      3.300 V  Voltage
      25.40  (no units)
    09:27:32 Group 043
      0.0  (no units)
      10.8C  Temperature
      00000000  Bin. Bits
      0.000 V  Voltage
    09:27:32 Group 045
      9.9C  Temperature
      100.0 %  Load
      0.0 %  Lambda
      0.0 %  Lambda
    09:27:32 Group 045
      9.9C  Temperature
      100.0 %  Load
      0.0 %  Lambda
      0.0 %  Lambda
    09:28:02 Group 046
      10.8C  Temperature
      9.9C  Temperature
      -0.9C  Temperature
      00000001  Bin. Bits
    09:28:02 Group 047
      89.1C  Temperature
      -0.9C  Temperature
      0.0 %  Load
      0.0 %  Lambda
    09:28:02 Group 048
      0 /min  RPM
      0 /min  RPM
             1  Bin. Bits
      1270.0 Nm  Torque
    09:28:10 Group 049
    09:28:10 Group 050
      0 /min  RPM
            10  Bin. Bits
    09:28:10 Group 051
      0 /min  RPM
      0 /min  RPM
      1.0  (no units)
      0.0KW  Idle Stabilization
    09:28:17 Group 052
      0 /min  RPM
      0xFF00  Hex Value
      0xFF00  Hex Value
      21.6C  Temperature
    09:28:17 Group 053
      00000000  Bin. Bits
      00000000  Bin. Bits
      00000000  Bin. Bits
      00000000  Bin. Bits
    09:28:17 Group 054
      0.0  (no units)
      0 /min  RPM
    09:28:27 Group 055
    09:28:27 Group 056
    09:28:27 Group 057
      0 /min  RPM
      0.0 km/h  Speed
      0.0 %  Duty Cycle
      0.0 %  Duty Cycle
    09:28:54 Group 058
      0 /min  RPM
      0.0 km/h  Speed
      0.0 %  Duty Cycle
      99.6 %  Duty Cycle
    09:28:54 Group 059
      0 /min  RPM
      -150.0 Nm  Torque
      39.0 Nm  Torque
      0.0 Nm  Torque
    09:28:54 Group 060
      39.0 Nm  Torque
      -42.0 Nm  Torque
      0.0 Nm  Torque
      0.0 %  Lambda
    09:29:03 Group 061
      0 /min  RPM
      9.0C  Temperature
      63.0 mm  Content
      76.0 mm  Content
    09:29:03 Group 062
      0 /min  RPM
      0.0  (no units)
      0.0  (no units)
    09:29:03 Group 063
      0 /min  RPM
      0 /min  RPM
      0 /min  RPM
      0 /min  RPM
    09:29:10 Group 064
      0 /min  RPM
    09:29:10 Group 065
    09:29:10 Group 066
    09:29:21 Group 067
    09:29:21 Group 068
    09:29:21 Group 069
      10011101  Bin. Bits
      00000011  Bin. Bits
      10011110  Bin. Bits
      00000011  Bin. Bits
    09:29:32 Group 070
      10011110  Bin. Bits
      00000011  Bin. Bits
      1.00  (no units)
    09:29:32 Group 071
      11111111  Bin. Bits
      00011111  Bin. Bits
    09:29:32 Group 072
      9.28  (no units)
      6.40  (no units)
      0.64  (no units)
    09:29:58 Group 076
      16.00  (no units)
      11.20  (no units)
      3.20  (no units)
    09:29:58 Group 077
      6.40  (no units)
      0.64  (no units)
      0.00  (no units)
    09:29:58 Group 078
    09:30:07 Group 079
    09:30:07 Group 080
      Please use
      the first row
      for this
      data type
    09:30:07 Group 081
      Please use
      the first row
      for this
      data type
    09:30:17 Group 082
      0000000000000 00.00.00 78       79  <>
    09:30:17 Group 083
    09:30:17 Group 084
    09:30:28 Group 085
      29540 km  Mileage
      23  Count
      3149  Count
      10568  Count
    09:30:28 Group 086
      11110000  Bin. Bits
      10111110  Bin. Bits
      11110100  Bin. Bits
      11111111  Bin. Bits
    09:30:28 Group 087
      11111111  Bin. Bits
      11111111  Bin. Bits
      11111111  Bin. Bits
    09:30:36 Group 088
    09:30:36 Group 089
      10000100  Bin. Bits
      00001110  Bin. Bits
      10100000  Bin. Bits
      00100000  Bin. Bits
    09:30:36 Group 090
      0 /min  RPM
      00000000  Bin. Bits
    09:30:48 Group 091
      323.85  (no units)
      -326.40  (no units)
      323.85  (no units)
    09:30:48 Group 092
    09:30:48 Group 093
      00000000  Bin. Bits
      3.97  (no units)
      0.0  (no units)
      0.0  (no units)
    09:31:02 Group 094
    09:31:02 Group 095
      00000000  Bin. Bits
      00000000  Bin. Bits
      0.0  (no units)
    09:31:02 Group 096
      00000000  Bin. Bits
      00000000  Bin. Bits
            00  Bin. Bits
      12.31 V  Voltage
    09:31:16 Group 097
      -3 mbar  Pressure
      -3 mbar  Pressure
    09:31:16 Group 098
      0 /min  RPM
      12.6C  Temperature
    09:31:16 Group 099
      0 /min  RPM
      12.0C  Temperature
      6.0C  Temperature
      12.0C  Temperature
    09:31:27 Group 100
      12.0C  Temperature
      6.0C  Temperature
      -3 mbar  Pressure
      -3 mbar  Pressure
    09:31:27 Group 101
      0 /min  RPM
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
    09:31:27 Group 102
      00000000  Bin. Bits
      00000001  Bin. Bits
      00000000  Bin. Bits
      00000000  Bin. Bits
    09:31:40 Group 103
      00000000  Bin. Bits
      00000000  Bin. Bits
      00000000  Bin. Bits
      00000000  Bin. Bits
    09:31:40 Group 104
      0xFF01  Hex Value
      0xFF10  Hex Value
      00000000  Bin. Bits
      00000000  Bin. Bits
    09:31:40 Group 105
      00000000  Bin. Bits
      8.0  (no units)
      12.0C  Temperature
      0.0  (no units)
    09:31:50 Group 106
      34.3 l  Tank Cont.
      270 km  Mileage
      1128.0  (no units)
    09:31:50 Group 107
      48.0
      45.6
      26.4
    09:31:50 Group 108
      78 ml  milliliters
      32.4
      38.4
    09:32:03 Group 109
      00000000  Bin. Bits
      00000000  Bin. Bits
      144.0  (no units)
    09:32:03 Group 110
      00000000  Bin. Bits
      0.0 km/h  Speed
    09:32:03 Group 111
      0 /min  RPM
      0.0 km/h  Speed
      0.00  (no units)
      0.0  (no units)
    09:32:13 Group 112
      0.00  (no units)
      1270.0 Nm  Torque
      -1280.0 Nm  Torque
      0.0 Nm  Torque
    09:32:13 Group 113
      00000000  Bin. Bits
      0.0  (no units)
      1.0  (no units)
      0.0  (no units)
    09:32:13 Group 114
      255.0  (no units)
      255.0  (no units)
      0.00  (no units)
      0.00  (no units)
    09:32:23 Group 115
    09:32:23 Group 116
      0.0 %  Load
      -0.9C  Temperature
      192.0  (no units)
      0.0  (no units)
    09:32:23 Group 117
      0.0 %  Lambda
      -0.9C  Temperature
      00010100  Bin. Bits
      7.0  (no units)
    09:32:31 Group 118
    09:32:31 Group 119
    09:32:31 Group 120
      7.1 %  Lambda
      -7.9 %  Lambda
      00000000  Bin. Bits
      4.256 V  Voltage
    09:33:09 Group 121
      0.0 %  Lambda
      -11.8 %  Lambda
      00000100  Bin. Bits
      1.216 V  Voltage
    09:33:09 Group 122
    09:33:09 Group 123
      -3.9 %  Lambda
      3.2 %  Lambda
      00000100  Bin. Bits
      3.952 V  Voltage
    09:33:16 Group 124
      -0.8 %  Lambda
      0.0 %  Lambda
      00000000  Bin. Bits
      4.484 V  Voltage
    09:33:16 Group 125
      ABS 1
      Instruments 1
    09:33:16 Group 126
    09:33:23 Group 127
      El.Ign.Lock 1
    09:33:23 Group 128
    09:33:23 Group 129
    09:33:30 Group 130
    09:33:30 Group 131
    09:33:30 Group 133
    09:33:38 Group 133
    09:33:38 Group 134
    09:33:38 Group 136
    09:33:50 Group 133
    09:33:50 Group 134
    09:33:50 Group 136
    09:34:26 Group 137
    09:34:26 Group 138
    09:34:26 Group 139
    09:34:35 Group 140
    09:34:35 Group 141
    09:34:35 Group 142
    09:34:48 Group 143
    09:34:48 Group 144
    09:34:48 Group 145
    09:34:57 Group 146
    09:34:57 Group 147
    09:34:57 Group 148
    09:35:09 Group 149
    09:35:09 Group 151
    09:35:09 Group 151
    09:35:16 Group 152
    09:35:16 Group 154
    09:35:16 Group 154
    09:35:22 Group 155
    09:35:22 Group 157
    09:35:22 Group 157
    09:36:34 Group 166
      0.070  Angle
      0.043  Angle
      0.055  Angle
      0.032  Angle
    09:36:34 Group 167
      0.070  Angle
    09:36:34 Group 168
    09:36:40 Group 169
    09:36:40 Group 170
      0.00 %
      0.0  (no units)
      0.00 %
      0.0 bar
    09:36:40 Group 171
    09:36:48 Group 172
      0.0  (no units)
      0.0  (no units)
      10.8C  Temperature
      66.7 %  Load
    09:36:48 Group 173
    09:36:48 Group 174
      2.0  (no units)
      0.0  (no units)
      0.000 V  Voltage
      0.000 V  Voltage
    09:36:55 Group 175
      0.0  Ohms
      0.000 A  Current
      0.000 A  Current
      6.0C  Temperature
    09:36:55 Group 176
      0 ppm
      0.000 V  Voltage
      0.00  (no units)
      00000000  Bin. Bits
    09:36:55 Group 177
      0 ppm
      0.000 V  Voltage
      0.00  (no units)
      00000000  Bin. Bits
    09:37:02 Group 178
      2960 km  Mileage
      1.0  (no units)
      00000000  Bin. Bits
    09:37:02 Group 179
      255.0 kg  Mass/Weight
    09:37:02 Group 180
      0 ppm
    09:37:10 Group 181
      0.0 bar
      10.8C  Temperature
    09:37:10 Group 182
      10.7  (no units)
    09:37:10 Group 183
      1.02  (no units)
    09:37:19 Group 184
    09:37:19 Group 185
    09:37:19 Group 186
    09:37:29 Group 187
    09:37:29 Group 188
    09:37:29 Group 189
    09:38:09 Group 200
      0 ppm
      0 ppm
      0 ppm
      0 ppm
    09:38:09 Group 201
      0.00  (no units)
      1.00  (no units)
      0.02  (no units)
      1.00  (no units)
    09:38:09 Group 202
      0.00  (no units)
      0.95  (no units)
      18.0C  Temperature
    09:38:17 Group 203
      0.00  (no units)
      0.00  (no units)
      0.0  (no units)
      0 mg/s
    09:38:17 Group 204
      1.02  (no units)
    09:38:17 Group 205
    09:38:24 Group 206
      25.5 l/1000km
    09:38:24 Group 207
      10.8C  Temperature
      0.0 s  Time
      10.8C  Temperature
      0.0 s  Time
    09:38:24 Group 208
      1.0  (no units)
      0.0 s  Time
      0.0 s  Time
      0.0 s  Time
    09:38:33 Group 209
      2.0  (no units)
      51.2 s  Time
      102.4 s  Time
      64.0  (no units)
    09:38:33 Group 210
      0.00 V  Voltage
    09:38:33 Group 210
      0.00 V  Voltage
    09:38:48 Group 212
      -1.30  (no units)
    09:38:48 Group 213
      0.00 mg/s
      0.00 mg/s
      0.78  (no units)
      0.00  (no units)
    09:38:48 Group 214
      -6.0C  Temperature
      -6.0C  Temperature
      -6.0C  Temperature
    09:38:58 Group 215
    09:38:58 Group 216
    09:38:58 Group 217
      0.0
      0.0
      0.0
      0.0
    09:39:09 Group 218
      0.0
      0 km  Mileage
      0.0  (no units)
      0.0  (no units)
    09:39:09 Group 219
      -276.0C  Temperature
      -276.0C  Temperature
      0.0 km/h  Speed
      0.0 km/h  Speed
    09:39:09 Group 220
      0.0  (no units)
    09:39:16 Group 221
      1.22  (no units)
    09:39:16 Group 223
      969.0 mbar  Pressure
      969.0 mbar  Pressure
      0.0  (no units)
      0.0  (no units)
    09:39:16 Group 224
    09:39:21 Group 224
    09:39:21 Group 227
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
    09:39:21 Group 227
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
    09:39:29 Group 227
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
    09:39:29 Group 230
    09:39:29 Group 230
    09:39:36 Group 230
    09:39:36 Group 233
    09:39:36 Group 233
    09:40:16 Group 246
      979.2 mbar  Absolute Pres.
      0.8 %  Load
    09:40:16 Group 247
      121.6 km/h  Speed
      161.3 km/h  Speed
      0.0  (no units)
      0.0 km/h  Speed
    09:40:24 Group 248
      235  Count
      65.0  (no units)
      16.0  (no units)
      161.3 km/h  Speed
    09:40:24 Group 249
      -150.0 Nm  Torque
      0.0  (no units)
    09:40:24 Group 250
      0.0 bar  Absolute Pres.
      0.0 Nm  Torque
      00000001  Bin. Bits
    09:40:34 Group 251
      0 /min  RPM
      0 /min  RPM
      2982 /min  RPM
      00001000  Bin. Bits
    09:40:34 Group 252
      -150.0 Nm  Torque
      0.0 Nm  Torque
      00000000  Bin. Bits
      00001000  Bin. Bits
    09:40:34 Group 253
      0 /min  RPM
      1.0  (no units)
      00000000  Bin. Bits
      0.0  (no units)
    09:40:45 Group 254
    09:40:45 Group 254
    09:40:45 Group 254
  9. #6
    Dec 2019
    Other points
    Checked the fuses, all seemed fine, although going to double check with a tester.
    Reducing tank heater had 2 voltages, box 3 and box 4.
    RPM - 0
    On/Off - ON
    Voltage - 0.825
    Voltage 12.24
    If it was the heater circuit, why would the NOX sensor not throw a code, if it shut down the EGR?
    If i pull the plug on the EGR will it leave it open or closed? Will it let me drive it or will it put it into
    limp mode?
    Is there a way to force it open with the VCDS ?
    Cheers for ya help
  10. #7
    Dec 2019
    Not sure if this will help anyone help me but
    Thursday,19,December,2019,10:23:55:64379
    VCDS Release 19.6.2 (x64): Generic OBD2
    Freeze Frame Data for address 7E8
    PID02 DTC that caused freeze frame data storage: P2BAC
    PID04 Calculated load value: 47.1 %
    PID05 Engine coolant temperature: 89 C
    PID0B Intake Manifold Absolute Pressure: 107 kPa abs
    PID0C Engine RPM: 1595 /min
    PID0D Vehicle speed: 16 km/h
    PID0F Intake air temperature: 16 C
    PID10 Mass Air Flow: 32.69 g/s
    PID11 Throttle position sensor: 79.2 %
