Results 1 to 10 of 10
Thread: Seat Ateca 2016 Blind Spot retrofit. Please Help
    Nov 2018
    Hungary
    Need help
    Seat Ateca Blind Spot retrofit.
    Does not work. If I clear the fault code on the ignition then it works. Ignition off, ignition on, and control unit failure.
    Fault code: 1 Fault Found:
    267520 - invalid data record
    B2005 00 [009] - -
    [Control Unit - Invailed dataset]
    Reset counter: 219
    Nov 2018
    Hungary
    Wednesday,18,December,2019,08:58:11:60022
    VIN: VSSZZZ5FZH6505219   License Plate: NWW992
    Mileage: 104150km-64715mi   Repair Order:
    Chassis Type: 5F-SE37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 55 5F 6D
              A5 CA
    VIN: VSSZZZ5FZH6505219   Mileage: 104150km-64715miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 JT    HW: 04E 907 309 BJ
       Component: R4 1.4l TFS   H23 4145
       Revision: R6H23---
       Coding: 0125003223641D083000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_ECM14TFS01104E906027JT 001006
       ROD: EV_ECM14TFS01104E906027JT_AU37.rod
       VCID: 7F5BFFEA4773DB9FB0D-802A
       CAN Converter 01:
       Part No SW: 0CW 300 049 R    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0903
       Revision: 00005026    Serial number: CU501607146531
       Shop #: WSC 33361 790 00063
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4CC198264645B00765F-8018
       Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
       Component: ESC           H25 0507
       Revision: 00000000    Serial number: 61676000000466
       Coding: 21EE6A92342014718779660141CC2584562C28E16682A4733822F074C6A203
       ROD: EV_Brake1UDSContiMK100IPB_035_VW41.rod
       VCID: 78A914F6625DECA7F17-802C
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0412007821
       Coding: 132C2C0703
       VCID: 3C21C8E616E50087D5F-8068
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98081986
       Part No SW: 5F0 907 044 AE    HW: 5F0 907 044 AE
       Component: Climatronic   H05 1601
       Revision: 00001K09
       Coding: 02000024200110011105004001101020
       VCID: 698F41B229F7452F7E9-803C
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001619701330
       ROD: EV_BCMBOSCH_017.rod
       Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
       Component: RLHS  042 0105
       Serial number: S4Y16M07D27H12M29S06
       Coding: 06996E
       Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY181452PMW
       Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Serial number: 00000000000056607746
       Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0161
       Serial number: 000305183616202
       Coding: 0271067051
       ASAM Dataset: EV_EPHVA2CAU3700000 009017
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 0D4755227DDFF90FB21-8058
       Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0156
       Coding: 3204474314FF8728749C8065804081
       Shop #: WSC 00078 790 12345
       ASAM Dataset: EV_ACCMRRCONTIVW376 001011
       ROD: EV_ACCMRRCONTIVW376_001.rod
       VCID: 3B23CBFA13EB07BFDC5-806E
       Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
       Component: Airbag VW21   004 0305
       Revision: --------    Serial number: 003R6PDW7RP-
       Coding: 98CCC0C0000000005C5400CC000800000065
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 074B670A1FA3935F88D-8052
       Subsystem 1 - Part No SW: -----------    HW: 454 001 806 16
       Serial number: 35700000000C3439AB1P
       Subsystem 2 - Part No SW: -----------    HW: 454 000 707 16
       Serial number: 358000000009E274DB1Y
       Subsystem 3 - Part No SW: -----------    HW: 454 801 406 16
       Serial number: 351003485C90B000000I
       Subsystem 4 - Part No SW: -----------    HW: 454 801 906 16
       Serial number: 35200DB96C90B000000
       Subsystem 5 - Part No SW: -----------    HW: 454 802 805 16
       Serial number: 355005837470B000000F
       Part No SW: 3Q0 953 521 EE    HW: 5Q0 953 569 A
       Revision: FF036036    Serial number: 20160721400799
       Coding: 6C14
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 77AB17CA6F43E3DFF8D-8022
       Part No SW: 5F0 920 740 D    HW: 5F0 920 740 D
       Component: KOMBI         205 8311
       Coding: 07A5221A6F88000800893A0B5001000000000000
       VCID: 25170D82856FA14F9A1-8070
       Revision: --------    Serial number: 23071610800742
       Coding: 030100F42F085700EA0002501E0F00010001050000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewConti_013.rod
       VCID: 7CA108E65665C08795F-8028
       Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
       Serial number: 000000000B0649050416
       Coding: 012000
       Serial number: 75410803001607270054
       Serial number: 16000154551001
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BF29D20127BDEF369-8024
       Component: HRE_Master    H12 0080
       Serial number: 0484189069
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D27C5E20DFF098FE21-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0467402814
       Coding: 020111
              B2005 00 [009] - -
                        Reset counter: 219
       Serial number: 0000211224110
       Coding: 00311320D000040000001000
       VCID: 47CBA70A5F23535F48D-8012
       Serial number: 00000000000010835108
       Coding: 210000
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000934230
       Coding: 01010011004000
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       Serial number: 0000211032019
       Coding: 00311320DC00040000001000
       VCID: 46D5AA0E58294A57B3B-8012
       Serial number: 00000000000010887931
       Coding: 390000
       Coding: 068A000009000000
       VCID: 75B71DC2754F91CFEA1-8020
    Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
       Part No SW: 5QA 035 824 A    HW: 5QA 035 824 A
       Component: MU-S--ER      H30 0351
       Serial number: SEZAZ2S0121586
       Coding: 04230600D70A00001111000100080A002F0105C40120010002
       ASAM Dataset: EV_MUStd6C1TSAT 001015
       ROD: EV_MUStd6C1TSAT_SE37.rod
       VCID: 3E25C2EE00F91297FBB-806A
       Subsystem 1 - Part No SW: 575 919 606 A    HW: 575 919 606 A
       Component: ABT_High-2_R  H41 1041
       Serial number: SEZ8Z9SCC001A9
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30845819900000
       Coding: 1908
       ASAM Dataset: EV_DeckLidCONTIAU736 001012
       VCID: 3FDBBFEA07F31B9FF0D-806A
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0220
       Serial number: 22071611P21068
       Coding: 030307060000040000220054C040A9009A000E200020
       ROD: EV_MFKBoschMQBB_001_SE37.rod
       VCID: 3A2DCEFE1CD13EB7C73-806E
       Part No SW: 4M0 907 594 D    HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 408040532602
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 372BD7CA2FC323DF38D-8062
    End----------(Elapsed Time: 01:42, VBatt start/end: 12.3V/12.3V)-----------
    Apr 2018
    ITALY
    the module you retrofitted has no dataset, it means it was not parameterized. did you buy it new?
    anyways, VCDS cannot write the dataset to modules. you need the other tool or ODIS, the factory tool.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
    Nov 2018
    Hungary
    Used, for Seat Ateca
    Mar 2016
    It doesnt have a DataSet on it, you need to get it calibrated. Take it to a dealer to get it Calibrated.
    Should you not have a slave unit too - Module CF? Although if you did need it, 3C would be throwing a DTC, so maybe you dont on that particular Seat model
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
    Apr 2018
    ITALY
    no calibration is needed, and the Slave radar is correctly listed under the Master.
    I retrofitted the very same modules to my Golf and it was pretty easy. I don't
    know why but you modules need a dataset.
  7. #7
    May 2017
    Yes, these radar units don’t need static calibration. They dynamically calibrate themselves in traffic.
    Other writers are correct. You need a dataset for these but unfortunately dealer is not able to help you on it. You need other means.
    Welcome to the MQB retrofit joy’s
  8. #8
    Nov 2018
    Hungary
    there is no solution?
  9. #9
    May 2017
    Quote Originally Posted by toncsa View Post
    Yes there is but not with VCDS. You need VCP and suitable dataset to flash the modules.
    Also I was googling a bit for Ateca autoscans with BSD and they use B version of the modules and not C. This means that most likely there's no dataset for 686 C modules and you need to downflash to 686B.
    One example :
    Address 3C: Lane Change (J1086)       Labels: None
       Component: HRE_Master    H12 0071
       Serial number: 0423373954
       Coding: 02011103
       ROD: EV_HREntryHella.rod
       VCID: 3C6560EC8FE4D989ED-8068
    Nov 2018
    Hungary
    Smile
    One example :
       Coding: 02011103
    Completed. The parameter file was missing. I download it with VCP. Vw Tiguan Me parametric files.
    Thanks for the help.
  11. Likes downtime liked this post
