Results 1 to 2 of 2
Thread: can VCDS pull a Pre / Pending DTC event
    Aug 2018
    Oregon, USA
    Good day,
    Is there a way to see if anything is 'cooking' DTC wise in say the ECU? Eg. some fault is tripping yet hasn't gone past a pre-set fault frequency to generate a propper DTC? Being able to peak 'inside' for such activity would be neato.
    Cheers & Happy Holidays if you're into that sort of thing,
    Grant
    If curious, below is what happened + a full auto-scan (once a DTC showed up)
    Last week my '15 Passat TDI briefly ran like the old old firetruck in the first Disney Cars movie. Small children on their plastic big wheels were passing me on the sidewalk. However by the time I made it through the intersection (and finished thinking... call tow truck, insurance, maybe take morning off work) everything was fine.
    Long & short, only after two weeks and a couple tanks of fuel did I finally get a CEL with DTC.
    VIN: 1VWCV7A38FC0XXXXX   License Plate: OREGON
    Mileage: 144980km-90086mi   Repair Order: 121719Ax
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 75 77
    VIN: 1VWCV7A38FC0XXXXX   Mileage: 144980km-90086miles
    Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 997 016 D    HW: 04L 907 309 K
       Component: R4 2.0l TDI   X20 9466
       Revision: 8AX20---
       Coding: 011D0012032410089000
       Shop #: WSC 23048 444 00200
       ASAM Dataset: EV_ECM20TDI01104L997016D 004002
       ROD: EV_ECM20TDI01104L997016D.rod
       VCID: 3431E0213EB1E6571DF-8060
    21467 - Mass Airflow Sensor 1
              P00BC 00 [236] - Airflow too Low
                        Fault Frequency: 7
                        Mileage: 144972 km
                        Date: 2019.12.17
                        Time: 00:39:53
                        Engine speed: 1354.50 /min
                        Normed load value: 76.9 %
                        Vehicle speed: 79 km/h
                        Coolant temperature: 59 C
                        Intake air temperature: 46 C
                        Voltage terminal 30: 13.820 V
                        Mass airflow sensor 1 bank 1 airflow: raw value: 469.5 mg/stroke
                        Standardized airflow ratio: filtered: 1.3478
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.16 %
                        Charge air pressure specified value: 1399 hPa
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1397.6 hPa
                        Mean injection quantity: 27.71 mg/stroke
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans        Labels: User\02E-927-770.clb
       Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4518
       Revision: 05652104    Serial number: 00001407100202
       Coding: 0000024
       Shop #: WSC 09003 957 00200
       VCID: 25170D6589EB8FDF9A1-8070
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: C54BC0F549240002A30C03EB92210042A1100012
       VCID: 7EA5020940FDFC07BBB-802A
       Revision: 00092000    Serial number: 0341828660
       Coding: 130C0C
       VCID: 372BD72D2FC70D4F38D-8062
       Part No SW: 561 907 044 AP    HW: 561 907 044 AP
       Component: Climatronic   H03 0707
       Revision: 00001K01
       Coding: 0010019012
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 65974D65C5EB4FDF5A1-8030
       Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
       Component: BCM PQ35 H+   122 0174
       Revision: BL122001
       Coding: EF200E3BF86B28D409A80201360081C002F1A0B845A005B064806000BC70
       VCID: 78A9141162D9C237F17-802C
       Component: RLS 020814 05  54  0403
       Coding: 0630CD
       Part No SW: 5C0 959 655 AA    HW: 5C0 959 655 AA
       Component: AirbagVW10    500 0975
       Serial number: 003LYD0165TQ
       Coding: 00004D52
       Shop #: WSC 63966 001 1048576
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 71BF29350123937F369-8024
       Serial number: 6940000Y1400017T2X01
       Coding: 303047
       Serial number: 3572MSME3C696B47ZZZ8
       Serial number: 3582MSME7E676B47ZZZD
       Serial number: 3516KSME280D3E2FZZZ3
       Serial number: 3526KSME57153F2FZZZ0
       Serial number: 3556LSME106E0430ZZZM
       Serial number: 3566LSME3D450430ZZZR
       Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
       Revision: FF010042    Serial number: 20140728200240
       Coding: 000A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EA50209407DFC07BBB-802A
       Component: E221__MFL-YVJ  H07 0023
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 G    HW: 561 920 970 G
       Component: KOMBI         H04 0813
       Coding: 231C01
       VCID: 1E652289A03D5C07DBB-804A
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 28081403001306
       Coding: 461000
       VCID: 00597CF13A098AF7C97-8054
       Component: IMMO          H04 0813
       Coding: 000007
       VCID: 6A8D3E592CF560A7773-803E
       Revision: 00000000    Serial number: 14000174117002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3039EC31CAA9DA77797-8064
    Address 2E: Media Player 3
       Part No SW: 561 959 760 B    HW: 561 959 760 B
       Component: MEM-FS        H04 0182
       Revision: AA000000    Serial number: 00000111333537
       Coding: 00581B0000000000000021010100202020202120202020
       VCID: 221D167994C578E7FF3-8076
       Part No SW: 3C0 035 684 R    HW: 3C0 035 684 P
       Component: RNS-MID       H30 5382
       Revision: AB001001    Serial number: VWZ6Z7U0236003
       Coding: 04090042010000A2000B
       Shop #: WSC 13109 408 00200
       VCID: 323DE639C425E8670F3-8066
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V12  8534
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0008844439
       Coding: 0405FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1C612881B6214E1735F-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14202630140825185201
       Coding: 800000
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 215    3501
       Revision: 00H22000
       VCID: 392FD11515531B3FCE9-806C
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H08 6815
       Revision: --------    Serial number: EAA098A0162059
       VCID: 26150A69F86D84C793B-8072
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 01030108
       VCID: 6FBB2F4D1797858F20D-803A
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Serial number: 53388786011334903288
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0008817542
       Coding: 0405FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1D672585AD3B471FC21-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631140908144323
       Coding: 800000
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140526
       Coding: 02140102C2423A00000000000000
       ROD: EV_OCULow_001.rod
       VCID: 53F383BD9B7FC16F245-8006
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 130
                        Mileage: 144981 km
                        Date: 2019.12.17
                        Time: 00:54:50
       Component: TELEFON       H05 0592
       Revision: 1B001001    Serial number: 00007666098421
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 2E05F249D09DCC876BB-807A
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.6V/12.5V)-----------
                    Address 01: Engine       Labels: 04L-907-309-V1.clb
    Control Module Part Number: 04L 997 016 D    HW: 04L 907 309 K
      Component and/or Version: R4 2.0l TDI   X20 9466
               Software Coding: 011D0012032410089000
                Work Shop Code: WSC 23048 444 00200
                  ASAM Dataset: EV_ECM20TDI01104L997016D 004002 (VW41)
                        Fault Frequency: 7
                        Mileage: 144972 km
                        Date: 2019.12.17
                        Time: 00:39:53
    2015 Passat TDI SEL Pre
    former 2014 Passat TSI SE Sport
    former 2014 Passat TDI SE w/ Sunroof
    former 1974 Transporter 3-speed Automatic
    former 1994 Toyota 4Runner, 1987 Toyota 4Runner, 1987 Ford Bronco XLT Custom, 1977 Datsun 280Z, 1989 Acura Integra, 1994 Honda Del Sol
    As a general rule, DTCs will show up in native VAG mode (what VCDS does when you run an Auto-Scan) before the show up anywhere else.
    But for emissions-related faults, yes, VCDS can show anything that the car considers "pending" by clicking on the [OBD-II] button on the main screen, followed by the [Mode 7 Pending DTCs] button.
