Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2010 VW Golf MK60EC1 Long Coding
    163B600D092900FA680C06E9901F008235
    0800
    163B600D092900FA680C06E9901F0082350900
    163B600D092900FA680C06E9901F00823509F0
    DANA /\
    OP Feel like testing these below & reporting?
    134B000C092900FAC80C00E9901F0000000000 FULL STRIP RHD
    144B200D212900FAC80C04E9841F0082300000 STRIPPED ATTRIBUTES
    163B600D092900FAC80C04E9841F0082300000 STRIPPED
    163B600D0929
    00FAC80C06E9841F0082310D10
    163B600D092900FAC80C06E9841F0082350910
  2. Likes downtime, Dana, Uwe liked this post
  3. #12
    Feb 2019
    Thanks for the new scan. I like downtime's suggestion. That would involve using the known good baseline with your VIN installed
    163B600D092900FA680C06E9901F0082350800
    .. followed by clearing codes and inserting the last two Bytes one at a time. For instance, the exact change order I'd use includes:
    We already know the last one resulted in the conflicts but it would be interesting to see if the 1st or 2nd happen to function fault-free.
    Edit, if 1 or 2 work ... do make sure to test the TPMS (again) -and- the park system!
    Yes, ID-R fehlt means that headlight slave is not communicating. The special notes here apply:
    http://wiki.ross-tech.com/wiki/index...#Special_Notes
    I would check for blown / missing fuses first and if the power is OK then you may need to inspect the light itself to see if that AFS slave is damaged or missing. If you need to pull the bumper off, then it may make sense to swap the good left side 7L6 941 329 B module and bolt it onto the right lamp to see if the next scan reports the right side part number properly.
    First Coding of: 163B600D092900FA680C06E9901F0082350800
    Worked perfectly first time, function test completed no ABS ESP lights on dash. thank you to everyone.
    below is the scan of the car currently.
    Will be testing the Headlamp issue in the next few days but will update this thread once all faults are gone.
    One last question is the reversing camera is not showing anything, it will flip down when engaged in reverse but is showing a blank screen. Any suggestions
    Wednesday,18,December,2019,20:29:15:12086
    VCDS Version: 19.6.2.0
    VIN: WVWZZZ1KZBW070156   License Plate: FY60 UTT
    Mileage: 201850km-125423mi   Repair Order: 18122019-20:28hrs
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 52 55 56
              77
    VIN: WVWZZZ1KZBW070156   Mileage: 201850km-125423miles
    Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 BB    HW: 03L 907 309 R
       Component: R4 2,0L EDC   X22 7818
       Revision: 42X22---    Serial number: 00000000000000
       Coding: 00190012042500080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018BB 003005
       ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
       VCID: 6BDE462182AAC61762-803E
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 163B600D092900FA680C06E9901F0082350800
       VCID: 040C0D9D8734296F83-8050
       Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
       Revision: 00003001
       Coding: 0000000002
       VCID: 7EF87F75E1D843BFD5-802A
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 4E180A3A8837F100408800807400092447550088727D8560648000200040
       VCID: 3874A96D8B7CBD8F5F-806C
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 12081  26  0512
       Coding: 009795
       Component: RLS 140810 05  54  0403
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:47
                        Voltage: 12.25 V
                            Term 50 Off
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:49
                        Voltage: 12.30 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 H    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0110
       Revision: --------    Serial number: 88591019724922
       Coding: 30100A
       VCID: 4084C18DD3ACF54FE7-8014
       Component: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serial number: 20081002830001
       Coding: 000180
       VCID: 27567A1156C22277C6-8072
    8 Faults Found:
    03263 - Functional Restriction
                        Reset counter: 102
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:45
                        Error Code: 7
                        Bin. Bits: 00000000
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:45
    01769 - Sensor for Vehicle Leveling; Front Right (G289)
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:45
    00142 - Left Front Dampening Adjustment Valve (N336)
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Reset counter: 62
                        Bin. Bits: 00000000 00100000
    00143 - Front Right Dampening Adjustment Valve (N337)
                        Reset counter: 62
    00144 - Rear Left Dampening Adjustment Valve (N338)
                        Reset counter: 62
    00145 - Rear Right Dampening Adjustment Valve (N339)
                        Reset counter: 62
    03264 - Functionalty Shut Off
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:25:20
                        Error Code: 9
                        Bin. Bits: 00000000
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRABDR63
       Coding: 00003133
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B7EB661B24A9697B2-806E
       Serial number: 3572MSME1F70124FZZZ
       Serial number: 3582MSME6E527456ZZZ0
       Serial number: 3512QSME023B6A33ZZZT
       Serial number: 3522QSME18476142ZZZP
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 201851 km
                        Date: 2019.12.18
                        Time: 20:23:46
                        Mileage: 201851 km
                        Date: 2019.12.18
                        Time: 20:23:46
              B1007 1B [137] - Resistance Too High
                        Mileage: 201851 km
                        Date: 2019.12.18
                        Time: 20:23:46
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JHB0002U
       Coding: 108A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 72E05B45A58017DFA1-8026
       Serial number: 0002786
       Coding: 820000
       Part No SW: 5K6 920 971 A    HW: 5K6 920 971 A
       Component: KOMBI         H04 0406
       Coding: 470D01
       VCID: 336E9E419A1A5ED76A-8066
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 020810F2001039
       Coding: E9A91F0650061200000001
       VCID: 6DDA483974BEC8277C-8038
       Component: IMMO          H04 0406
       VCID: 6AD043258D50DF1F19-803E
       Revision: A1001003    Serial number: 7668470026
       Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
       Component: RNS-MID       H41 5238
       Revision: AB001001    Serial number: VWZ6Z7K7220118
       Coding: 04070042010000900000
       VCID: 3776AA518662B2F756-8062
    00856 - Radio Antenna
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 62
                        Mileage: 201848 km
                        Reset counter: 62
                        Mileage: 201848 km
       Component: Tuer-SG         009 2112
       Coding: 0000564
       VCID: 31629449A8066CC718-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 177    3001
       Revision: 00H17000
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0340
       Revision: --------    Serial number: BP218109098982
       VCID: 67D63A119E42E27706-8032
    9462803 - Front Right Treble Speaker
              B1064 13 [009] - Open Circuit
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2019.12.18
                        Time: 20:23:46
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Component: Tuer-SG         009 2150
       Coding: 0004918
       VCID: 356AA0595C6E40E744-8060
       Component: AFS-Steuergeraet    0142
       Coding: 1445212
       Shop #: WSC 18786 002 1048576
       VCID: 346C9D5D571459EF73-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
       Component: AFS-Lst.-Modul r    ....
       Coding: 00000255
    7 Faults Found:
                        Fault Status: 11100100
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:45
                        Voltage: 12.07 V
                            ABS 1
                000 - - - MIL ON
                        Reset counter: 62
                            Invalid
                            Invalid
                            Invalid
    02656 - Power Output Stage for Left Headlight (J667); Not Coded
                000 - - - MIL ON
                        Reset counter: 62
                            Invalid
                            Invalid
                            Invalid
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
                000 - - - MIL ON
                        Reset counter: 62
                            Invalid
                            Invalid
                            Invalid
                        Fault Status: 11100101
                        Reset counter: 62
                            Invalid
                            Invalid
                            Invalid
    00471 - Control Module for Elect. Regulated Dampers (J250)
                        Fault Status: 11101101
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:23:45
                        Voltage: 12.07 V
                            ABS 1
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 62
                        Mileage: 201851 km
                        Date: 2014.05.10
                        Time: 20:25:19
                        Voltage: 12.07 V
                            ABS 1
                        Reset counter: 62
                        Mileage: 201848 km
                        Reset counter: 62
                        Mileage: 201848 km
    Address 77: Telephone        Labels: RETROFIT77.lbl
       Part No SW: KTC 364 96P     HW: KTC 364 96P
       Component: SWP:3.31.6      H24 0216
       Shop #: WSC 21977 142 74100
       VCID: 3E78BF75695883BF95-806A
    End-------------------------(Elapsed Time: 03:05)--------------------------
  4. Likes downtime, Uwe liked this post
  5. #13
    Feb 2019
    DANA /\
    163B600D092900FAC80C06E9841F0082310D10
    Sorry, car has now gone but when i have it back i will test and send individual scans with each of the codings you have provided.
    Thank you
  6. Likes Dana, Jack@European_Parts, Uwe liked this post
  7. #14
    United States
    Excellent! I believe I over compensated for 7X5 based on the PLA component and PR-code 7X6 Park assist. Do let us know if there are any concerns in that area later. If so, try some of the versions Jack provided.
    RVC wise, the coding of 56 is OK. The faults for the antenna(s) may be be due to issues in the back of the car but I wonder if pulling the head unit out to inspect for issues and rebooting it may shed light. On the other hand, if the radio antennas are diversity in the back glass then I wonder if wiring is breaking in the moving area of hatch which could be causing video feed issues to the camera. Bump this back up if you need help with that and one of us can check a wiring diagram to see what's what.
  8. Likes Jack@European_Parts, Uwe, m3nt4l liked this post
  9. #15
    Feb 2019
    Thank you didnt manage to test the parking function but will do that once i have the car back and i will do all the other ABS coding checks. i will check all wiring as you have said and go from there.
    Thank you very much to everyone who has helped. Much appreciated.
    thanks
  10. #16
    thanks
    Yes test please and can you subvert navigating these special cones?
  11. Likes m3nt4l liked this post
