Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: VCDS not showing Haldex on A3?
  1. #31
    Aug 2014
    Getting closer I think. It seems to read 22 now, but access to 2B has gotten intermittent. Even direct access fails a few times first now before I can get to 2B. Is this a glitch on my end or unlucky? Also oddly the transmission randomly shows faults and no faults every few times I scan. I assume this is nothing to worry about.
    Thursday,29,January,2015,12:52:19:06722
    VCDS Version: 15.1.3.0 (x64)
    Data version: 20150118
    VIN: WAUKFGFF3F1042366   License Plate:
    Mileage: 6194km-3848mi   Repair Order:
    Chassis Type: FF (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 55 5F
              6C A5
    VIN: WAUKFGFF3F1042366   Mileage: 6194km-3848miles
    Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 0A1D00324466000F3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C79DEA94711755895-8079
    Readiness: 1010 0101
       Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H52 4513
       Revision: 03252204    Serial number: TFK01406220847
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1E1D046101AD97C80B-804B
    11 Faults Found:
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21154 - Gear 2
              P072D 00 [002] - Not Selectable
    21155 - Gear 3
              P072E 00 [002] - Not Selectable
    21156 - Gear 4
              P072F 00 [002] - Not Selectable
    21157 - Gear 5
              P073A 00 [002] - Not Selectable
    21158 - Gear 6
              P073B 00 [002] - Not Selectable
    21159 - Gear R
    10732 - Valve 3 in Transmission Part 2
              P174E 00 [002] - Electrical malfunction
    10909 - Cooling Oil Valve
    10906 - Cooling Oil Valve
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
       Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
       Component: ESC           H31 0571
       Revision: 00000000    Serial number: 61534000000547
       Coding: 13FF6A9234240A6E017A030681C929C8562C5080C08194B4F84150588608
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 46AD8C01F9BDAF0863-8013
       Revision: 00021000    Serial number: 0339427358
       Coding: 030C0C
       Shop #: WSC 12345 123 12345
       VCID: 3A55E8F1BD45DBE817-806F
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000373158
       VCID: 334BC5D59A2F2AA0D4-8066
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0134
       Serial number: 01011417400970
       Coding: 04151C46C04106FD41C04004511007000800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 79D737FDF8C310F05E-802C
       Slave 1:
       Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
       Component: WWS371 140705  042 0585
       Serial number:         140709020143
       Coding: 0A47F7
       Slave 2:
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Serial number: 22835410
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
       Serial number: 23 04 2014  00000842
       Serial number: 00000000000030305291
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO30791273
       Coding: 101F00
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331419000984
       Coding: 0070150011
       ROD: EV_EPHVA18AU3700000.rod
       VCID: 42A59011D59593284F-8017
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H04 0304
       Serial number: 24051477030515
       Coding: 01241501FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001015
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 3851F2F98349C9F8E1-806D
       Serial number: 003GCR00HTCU
       VCID: 47B38105FEB7B60098-8012
       Seat belt tensioner; left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34178311A08071440230
       Coding: 333135
       Seat belt tensioner; right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34178312A14071471255
       Coding: 333135
       Seat occupant detection; front passenger side:
       Serial number: 6940000Y1400014P8X00
       Coding: 303139
       Subsystem 4 - Part No SW: -----------    HW: 480 000 507 14
       Serial number: 35700000000E43451014
       Subsystem 5 - Part No SW: -----------    HW: 480 000 507 14
       Serial number: 35800000000BB3451019
       Subsystem 6 - Part No SW: -----------    HW: 480 400 307 14
       Serial number: 3510002B71656B83735+
       Subsystem 7 - Part No SW: -----------    HW: 480 400 307 14
       Serial number: 3520002BB1656B848153
       Subsystem 8 - Part No SW: -----------    HW: 480 400 207 14
       Serial number: 3550002B31656B858160
       Subsystem 9 - Part No SW: -----------    HW: 480 400 207 14
       Serial number: 3560002BD1656B82D0CI
       Part No SW: 8V0 953 521 ED    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 02071408490329
       Coding: E818
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 00215A199B19413819-8055
       Part No SW: 8V0 920 971 G    HW: 8V0 920 971 G
       Coding: 0BC518196F88D7050280E8001800000000000000
       VCID: 41A79F1DD093883056-8014
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 03071410800466
       Coding: 0101000820085A005B00021C180B00000001010000000000000000000000
       ASAM Dataset: EV_GatewConti 011017
       ROD: EV_GatewConti_AU37.rod
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 30 06 2014  C0090877
       Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7081
       Serial number: HA1-00012.06.14
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
    Address 2B: Steer. Col. Lock
    Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Serial number: 0337624190
       Coding: 030211
       ROD: EV_LaneChangAssis.rod
       Serial number: 01071404080526
       Coding: 005D1F205C00048000000003
       VCID: 40A19A19DB99813859-8015
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 1102
       ROD: EV_SteerAssisMQB.rod
       Serial number: 22061402090458
       Coding: 005D17205E00048000000003
       VCID: 3FA399E5A667FEC020-806A
       Component: AFS-ECU       H01 0091
       Coding: 012A000023200400
       ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
       Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G
       Component: LED LeiMo li.  H07 7540
       Coding: E00100
       Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G
       Component: LED LeiMo re.  H07 7540
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo links  H01 7040
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo rechts  H01 7040
       Coding: E00100
       Part No SW: 8V0 035 038     HW: 8V0 035 038
       Component: MU-H-LNS-US   H42 0289
       Serial number: A302G0E7510011
       Coding: 017301020000000021220002041A00102F000125010001047E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       VCID: 71C70FDDA0B358B0E6-8024
       Engine Control Module 2:
       Subsystem 1 - Part No SW: V03 959 800 SR    HW: -----------
       Component: NAR 2014/2015  --- 0032
       Seat Adjustment Driver Side:
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201C10
       Sound System:
       Serial number: C1000002071400030014
       Door Electronics Rear Left:
       Component: Gracenote  --- 3005
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
       Coding: 027300010201000300
       ROD: EV_CamSysRearPANAAU914.rod
       VCID: 3041CAD96B3911B8A9-8065
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0052
       Serial number: 00000194614
       Coding: 0100000000010303000500010100000100
       ROD: EV_MFKBoschAU370.rod
       VCID: 3B5BEDF5B27FE2E00C-806E
    End--------------------(Elapsed Time: 04:29, Deb=1024)---------------------
  2. Likes Eric liked this post
  3. #32
    Yeah, 22 looks great. I'm wondering if your battery is running low maybe... If you have the time, do a couple scans with the beta, then a couple with the release, and let us know if the 2B issues persist with the release. As far as I can tell it's just the gateway not responding at that point, but I'll take another look at the modifications I did to the micro-CAN code since the release.
  4. #33
    Aug 2014
    Sure I'll try 14.10.0 and see if the issue persists. It seemed to only start on 15.1.2.
  5. Likes Eric liked this post
  6. #34
    Don't go out in the snow for this. I'm able to reproduce this issue on Andy's GTI through some address faking.
  7. Likes Uwe, jyoung8607 liked this post
  8. #35
    Aug 2014
    Reproduce the 2B error? I even drove the car around for an extra hour lol to make sure the battery was charged :P
    Also I think you guys need a S3 for um... research purposes on the new MQB chassis... I know it's DSG only, but umm I think you guys need "direct access" to the modules
    On a side note it's cheap to lease a 2.0T A3
  9. Likes jyoung8607 liked this post
  10. #36
    Should be fixed in impending 14.10.1 ; let us know either way!
  11. #37
    Aug 2014
    Rather than keep refreshing/checking, do you know when 14.10.1 will be out so I can know when to give it a whirl?
  12. #38
    Been out since Saturday, I think... CTRL+F5 on the download page?
    http://www.ross-tech.com/vcds/download/current.html
  13. Likes Sebastian, fibrizo liked this post
  14. #39
    Administrator Andy's Avatar
    Sector 7G
    Quote Originally Posted by fibrizo View Post
    If forced, I guess I would allow Haldex to be retrofitted to my 2015 GTI ... but only in the interest of science.
  15. Likes Uwe, Sebastian, Dana, fibrizo liked this post
  16. #40
    Aug 2014
    Might be easier to retrofit your GTI with a Golf R. I hear the new ones have a crazy 70% residual on a 3 year lease.
