I have installed:
BCM 7H0937090B
high line camera module 7E0907441 (coding 0000016) - I haven't OPS and trailer hitch module installed.
Camera 7E0980551A
RNS 510 (1T0035680R)
TV tuner 7L6919148A
wiring harness 7E7971327C
Steering angle sensor 6Q0959654D
Steering angle sensor and RNS 510 working properly, in addition, reverse gear is correctly detected.
I 've no error in RNS 510, in RVC module (6c) I've information that camera is not calibrated.
Unfortunately, when starting on RNS 510, a message is displayed saying that the rear view camera system is not currently available.
Nothing happens when reverse gear is engaged (no camera image displayed).
In the camera module measuring blocks I have:
Terminal 15 Status Term 15 On
Reverse Gear Status Reverse ON
Voltage (Terminal 30) 12.14 V
Camera Voltage 6.40 V
Connection to Camera Camera-sync
Connection Status (Camera) Active
Connection to Display Display-sync
Connection Status (Display) Active
Steering Angle (Current) -11.85°
Back-Up Cam. Status 3
Can anyone tell me what else I could have done wrong?
Should this hardware kit work? Does the BCM version support the camera module?
I have installed:
BCM 7H0937090B
Camera 7E0980551A
TV tuner 7L6919148A
