Results 1 to 10 of 13
Thread: VW t5 OEM RC High Line retrofit
    Jan 2019
    Poland
    I have installed:
    BCM 7H0937090B
    high line camera module 7E0907441 (coding 0000016) - I haven't OPS and trailer hitch module installed.
    Camera 7E0980551A
    RNS 510 (1T0035680R)
    TV tuner 7L6919148A
    wiring harness 7E7971327C
    Steering angle sensor 6Q0959654D
    Steering angle sensor and RNS 510 working properly, in addition, reverse gear is correctly detected.
    I 've no error in RNS 510, in RVC module (6c) I've information that camera is not calibrated.
    Unfortunately, when starting on RNS 510, a message is displayed saying that the rear view camera system is not currently available.
    Nothing happens when reverse gear is engaged (no camera image displayed).
    In the camera module measuring blocks I have:
    Terminal 15 Status Term 15 On
    Reverse Gear Status Reverse ON
    Voltage (Terminal 30) 12.14 V
    Camera Voltage 6.40 V
    Connection to Camera Camera-sync
    Connection Status (Camera) Active
    Connection to Display Display-sync
    Connection Status (Display) Active
    Steering Angle (Current) -11.85
    Back-Up Cam. Status 3
    Can anyone tell me what else I could have done wrong?
    Should this hardware kit work? Does the BCM version support the camera module?
    VW T5 Caravelle 2.5 96KW TDISG6 engine code:AXD, transmission code:GWB color: LA6W, interior color: GV, year 2005
    Aug 2016
    The Hague, NL
    --> yes, we need an autoscan please See below on how to post
  3. Likes myounus liked this post
    Jan 2019
    Poland
    Tuesday,17,December,2019,12:53:05:64257
    Chassis Type: 6N0
    Scan: 04 09 19 37 56 57 6C
    57-TV Tuner -- Status: Malfunction 0010
       Part No SW: 7H0 937 090 B    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H74 0712
       Revision: B9074001    Serial number: 0571 308130974
       Coding: E0A0393A0A212012002008102C2B8CFC0080430F60860000320000000000
       VCID: 2D070A04FD1E8E7F521-8078
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H74 0712
       Revision: B9074001
       Coding: 042200
       VCID: 70B9D3702AACA397397-8024
                        Reset counter: 234
       Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
       Component: RNS-MID       H31 6276
       Revision: AB001001    Serial number: VWZ6Z7T1195825
       Coding: 00010200010000A00014
       VCID: 3D273A442D7E1EFFE21-8068
       Subsystem 1 - Part No: 1T0 919 859 B
       Component: EU West V15  8515
    00869 - Line Output; Rear Right
                        Reset counter: 199
    00860 - Line-Output; Rear Left
                        Reset counter: 199
                        Reset counter: 199
    00001 - Brake Control Unit
                        Reset counter: 200
                        Reset counter: 199
                        Reset counter: 199
                        Reset counter: 199
                        Reset counter: 200
    Address 57: TV Tuner        Labels: 7L6-919-148.clb
       Part No SW: 7L6 919 148 A    HW: 7L6 919 148
       Component: R0078 TVhybridDVB   0150
       Revision: R0H21000    Serial number: 93900500870301
       Coding: 0020801
       Shop #: WSC 01065 000 00000
       VCID: 3A2D3158305029C7C73-806E
    03230 - Video Input for Rear Seat Entertainment
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 234
       Part No SW: 7E0 907 441     HW: 7E0 907 441
       Revision: 00H13000    Serial number: 525PA8-J440305
       Coding: 0000016
       Shop #: WSC 02971 612 181466
       VCID: 6597B224E96E763F5A1-8030
    03006 - Back-up Camera System not calibrated
                        Reset counter: 234
                        Reset counter: 234
                            Reverse OFF
                        Count: 3
                        Reset counter: 234
                            Reverse OFF
                        Count: 3
    End----(Elapsed Time: 00:50, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
    Jun 2014
    Poland
    why you edit VCDS autoscan ?
    do we ask for part of Autoscan ?
    or.....just begining ?
    maybe unvisible??
    or.....custom ?
    no .....
  6. Likes Uwe liked this post
    Jan 2019
    Poland
    I don't edit autoscan. I have two CAN installations. One factory vehicle (2005 and TP1.6), the other with separate BCM and TP2.0.
  8. Likes dnoermann liked this post
  9. #6
    Aug 2016
    The Hague, NL
    RVC will not work if instrument cluster is not present.
  10. #7
    Jan 2019
    Poland
    Even if I've gateway in BCM?
  11. #8
    Aug 2016
    The Hague, NL
    yes, will not work. it needs instrument cluster, just like the PDC. I don't know why, but it is the case.
  12. #9
    Jan 2019
    Poland
    Ups.... It hurt ... It means that I would have to replace the cockpit installation. Has anyone tried to run ECU16U31 (old engine) the new BCM?
  13. #10
    Jan 2019
    Hallo Alex, cool retrofit attempt.
    Whell i dont know if the T5.2 BCm can do this, but the BCM does have a Coding bit to enable TP1.6 on Engine Can.
    See Picture from VCDS coding here.
    https://forums.ross-tech.com/showthr...op-active-quot
