Chassis Type: 5L-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 56 62 69 72
77
VIN: TMBMD75L6C6021292 Mileage: 225400km-140057miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DB HW: 03L 906 018 BR
Component: R4 2,0L EDC H25 7098
Revision: 42H25--- Serial number:
Coding: 001D0012042700080000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01103L906018DB 003004
ROD: EV_ECM20TDI01103L906018DB.rod
VCID: 6D92DC87BCE341277C-8038
4481 - Cruise Control Switch (E45)
P0568 00 [047] - Implausible Signal
Fault Frequency: 198
Mileage: 221657 km
Date: 2019.11.07
Time: 19:57:00
Engine speed: 981.00 /min
Normed load value: 26.3 %
Coolant temperature: 31 °C
Intake air temperature: 13 °C
Voltage terminal 30: 14.460 V
Cruise Control System (CCS): switch position-Bits 0-7: 192
Cruise Control System (CCS): status-Bits 0-7: 204
Cruise control switch-off: irreversible-Bits 0-7: 0
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Fault Frequency: 200
Mileage: 221657 km
Date: 2019.11.07
Time: 19:57:00
Part No SW: 02E 300 014 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2712
Revision: 05351113 Serial number: 00001107261168
VCID: 106CA5730311CCCF37-8044
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 933F400E092401FBC90D02ED901B808A310000
VCID: 7BB6E2DFFA97DF97F2-802E
Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
Component: Climatronic H18 0506
Revision: 00001007
Coding: 0000000002
VCID: 7CB4E1C3F799D8AFFB-8028
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 48000AB8E00508C040080082110001E4417000AE526D81605C8140000040
VCID: 3A3827DBB52D269FA9-806E
Subsystem 1 - Part No: 5L2 955 119 A Labels: 1KX-955-119.CLB
Component: SK356 26 0604
Coding: 00F7B5
Component: RLS 150811 05 54 0403
Coding: 0730ED
00985 - Right Tail Light (M2)
Fault Status: 00101110
Fault Frequency: 80
Reset counter: 104
Mileage: 212793 km
Date: 2013.11.09
Time: 21:35:23
Voltage: 14.00 V
Term 50 Off
Reset counter: 77
Mileage: 221657 km
Date: 2014.03.30
Time: 19:33:43
Term 15 Off
Voltage: 12.30 V
Term 50 Off
Fault Status: 00101010
Fault Frequency: 10
Reset counter: 103
Mileage: 223574 km
Date: 2014.04.16
Time: 11:02:13
Term 15 Off
Voltage: 12.00 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 1Z0-919-475-V2.clb
Part No SW: 1Z0 919 475 E HW: 7N0 919 475
Component: PARKHILFE 8K H06 0005
Revision: --H06--- Serial number: 28291119404869
Coding: 108106
ASAM Dataset: EV_EPHVA18SKxxx0000 001001
ROD: EV_EPHVA18SKxxx0000_001.rod
VCID: 43C65A3FCAE76757FA-8016
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA8WWNR
Coding: 00005443
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 312A00F7605BE5C718-8064
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME15481563ZZZQ
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME512A7461ZZZU
Serial number: 3512QSME7A045A53ZZZZ
Serial number: 3522QSME56275C70ZZZ-
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20190704200148
Coding: 7982A00000
Shop #: WSC 01286 386 08256
VCID: 02489F3B957DAE5FB1-8056
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Serial number: 2175034
Coding: 820000
14 Faults Found:
147462 - Terminal 15
B1148 12 [009] - Short to Plus
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
226838 - Turn Signal Switch
B1144 12 [008] - Short to Plus
Fault Frequency: 10
Reset counter: 102
Mileage: 222688 km
Date: 2019.11.15
Time: 07:24:57
226839 - Turn Signal Switch
B1144 11 [008] - Short to Ground
Reset counter: 77
227339 - Windshield Wiper Switch
B1145 13 [008] - Open Circuit
B1149 13 [009] - Open Circuit
Reset counter: 65
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Fault Frequency: 84
Reset counter: 64
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Fault Frequency: 134
Reset counter: 65
332660 - Databus
335876 - Powertrain Databus
U0002 00 [009] - No Communications
Reset counter: 37
Mileage: 221657 km
Date: 2019.11.07
Time: 19:49:25
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
365080 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 77
617736 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
1140738 - Steering angle sensor
UBat: 13.70 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Part No SW: 5L0 920 840 K HW: 5L0 920 840 K
Component: KOMBI H05 0607
Coding: 120A00
ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
VCID: 33260AFF9A47D7D76A-8066
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Lenksäulenelektronik: keine Kommunikation]
Reset counter: 77
Mileage: 221657 km
Date: 2019.11.07
Time: 19:33:43
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 010811F1003437
Coding: 356303
VCID: 352234E79C33C9E744-8060
Fault Status: 00110100
Reset counter: 77
Mileage: 221657 km
Date: 2014.03.30
Time: 19:33:42
Mileage: 4801 km
Date: 2012.03.22
Time: 01:06:20
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 45C244270CD35967D4-8010
Component: IMMO H05 0607
VCID: 6A98D79B8D0D561F19-803E
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 D HW: 7N0 959 793
Component: TSG FA H04 0400
Revision: Serial number: 0000118943811
Coding: 011402208001231004
VCID: 43C65A3FC2E76757FA-8016
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 71 3201
Revision: 00H20000
VCID: 342409E35749D0EF73-8060
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 D HW: 7N0 959 792
Component: TSG BF H04 0400
Revision: Serial number: 0000118833144
Coding: 011400208001231004
VCID: 42C85F3BDDFD6E5FF1-8016
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 011 0062
Revision: 0A001001 Serial number: SKZ1Z3L9538607
Coding: 0D0004000001
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-795.clb
Part No SW: 7N0 959 795 D HW: 7N0 959 795
Component: TSG HL H03 0400
Revision: Serial number: 0000118714532
Coding: 010000200001531004
VCID: 45C24427CCD35967D4-8010
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000153940311
Coding: 0100000100000000
VCID: 302C05F36351ECCF17-8064
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-795.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000118714535
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660623446
Coding: 0200000000010110
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 352234E79433C9E744-8060
13635840 - Supply voltage
U1011 00 [000] - Voltage too Low
[Klemme 30: unterer Grenzwert unterschritten]
U1400 00 [000] - -
End----(Elapsed Time: 01:22, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)
