PASSAT B8 SW SIDE/LANE CHANGE ASSIST RETROFIT
   #61
sam1754
France
C?ID=324989
Finally you soldered 3 wires, right?
   #62
downtime
C?ID=280813
Can’t really tell as there’s no autoscan but if you can connect to 3C and CF modules then most likely connection is ok.
   #63
jrhenrique
BR
C?ID=245657
I mean, I use the right wires?
   #65
jrhenrique
BR
C?ID=245657
No coding yet! But 3C and CF active
   #66
downtime
C?ID=280813
Then coding. Register the 3C and CF to gateway and start coding them in.
   #68
sam1754
France
C?ID=324989
Finally works for me too!
But I had an issue with open circuit lamps DTC. I had to connect to ground one controller at a time and DTC gone away.
sam1754
France
C?ID=324989
Side assist also retrofitted on my Passat Sedan successfully. But I had to flash both controllers and load correct dataset this time. The seller sent me radars from an Audi A3...:rolleyes:
   #70
sam1754
France
C?ID=324989
Now I would like to learn more about how dynaimc calibration is performed??? I know it's about an angle which needs to become narrow but how... Which controllers'data are used???
   #71
karldietmann
C?ID=339222
Did anyone manage to DIY a calibration tool?
