HEX-V2 (09G Engine Basic Settings) - Kickdown Adaptation
jdreid
California, USA
C?ID=349997
Why is it that the 07K-906-055-CBT.CLB file doesn't allow the Group 63: Auto Transmission Kickdown Adaptation. But with the 06A-906-032-BGP.LBL it allows the Group 63 Adaptation.
Is there some way I can get this function enabled on the 07K-906-055-CBT.CLB file? Because everytime I refer back to the Ross-Tech webpage it says this adaptation must be done for the 09G Automatic Transmission. I can perform every other adaptation but the the Kick-Down one.
- Justin
What do you mean, "Doesn't allow"?
You don't need to do a label file to do any of this, but 07K-906-055-CBT has
B063,0,Kick-Down Alignment (Automatic Transmission only)
defined,
while 06A-906-032-BGP doesn't, which makes your request even more confusing.
jdreid
California, USA
C?ID=349997
defined,
For some reason when I go into the engine module, it doesn't allow me to perform the Kick-Down Alignment (Automatic Transmission Only). Here's a picture of what I'm getting every time I try to do the Kick-Down Alignment on VCDS.
A change to a label file isn't going to make the group appear that the ECU is refusing.
Please post an Auto-Scan so we can see the whole car.
jdreid
California, USA
C?ID=349997
Here is an auto-scan of my vehicle.
Sunday,15,December,2019,17:53:50:47916
VIN: 3VWRZ71K99M0XXXXX   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K99M0XXXXX   Mileage: 207340km-128835miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9203
   Revision: G6H02---    Serial number: VWX7Z0HN2431AD
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 38292B354E583907317-806C
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -
                    Mileage: 207331 km
                    Time: 17:23:33
                    RPM: 2190 /min
                    Load: 57.6 %
                    Speed: 60.0 km/h
                    Temperature: 93.0∞C
                    Temperature: 48.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
Address 02: Auto Trans        Labels:. User\09G-927-750.lbl
   Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
   Component: AQ 250 6F           1631
   Revision: 00H90000    Serial number:
   Coding: 0000072
   VCID: 7DA7FA2121FADC2FA21-8028
17119 - Gear 5
            P0735 - 003 - Incorrect Ratio - Intermittent - MIL ON
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B400D492A0000880E02E6921E00413400
   Shop #: WSC 36555 002 104857
   VCID: 7EA5FD2D20FCC737BBB-802A
02214 - Tire Pressure Warning
                    Reset counter: 20
                    Mileage: 206961 km
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50777
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EB350ED8F907F17-802C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001126957
   Coding: 14058E234004100007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 123 12345
   VCID: 323D191DA824D3570F3-8066
   Component: Wischer 111108 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0474413
   Coding: 0000100
   VCID: 33331C19573EDA5F045-8066
                    Reset counter: 241
                    Mileage: 207053 km
                    Time: 16:27:43
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M07MLDJ
   Coding: 0013889
   VCID: 6C81C7654A8045A705F-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME41145001U
   Subsystem 3 - Serial number: 6342MSME3F645540E
   Subsystem 4 - Serial number: 6351HSME184928504
   Subsystem 5 - Serial number: 6361HSME184970478
   Subsystem 6 - Serial number: 63727SME19085068/
   Subsystem 7 - Serial number: 63827SME19084108Z
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Component: J0527           051 0101
   Coding: 0010021
   VCID: 03538CD9471EAADFD45-8056
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0HN2431AD
   Coding: 0023203
   VCID: 3C2137257A601527D5F-8068
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 220908F2000138
   Coding: ED807F070003021002
   Shop #: WSC 11111 123 12345
   VCID: 35372201594AC46F2A1-8060
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000766589028
   Coding: 0001205
   VCID: 6FBBD0697B96BEBF20D-803A
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 0
                    Reset counter: 0
                    Mileage: 202918 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D017D80F49B97B73-807E
   Component:    KSG PQ35 RDK 052 0221
   Coding: 13900F880186083F0904058FB0880F0488D8A0
   VCID: 04518FC54210ADE7EDF-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08100814090904
   Coding: 0001204
   VCID: 70B9D31566A8A147397-8024
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2R7301947
   Coding: 1600040004000A
   Shop #: WSC 00081 790 00120
   VCID: 46D555CD38AC5FF7B3B-8012
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003626568
   Coding: 0001168
   VCID: 76B5E50D04CC8F77E3B-8022
   Component:    RDK              0450
   Coding: 0100100
                    Reset counter: 216
                    Mileage: 206618 km
                    Time: 01:48:31
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003588487
   Coding: 0001168
   VCID: 77ABE80903C6F67FF8D-8022
End----------(Elapsed Time: 01:20, VBatt start/end: 12.4V/12.4V)-----------
Sometimes control modules refuse some Basic Settings when certain fault codes are present/active and you clearly have fault codes in both Engine and Trans.
Have you tried clearing faults in both 01-Engine and 02-Transmission?
jdreid
California, USA
C?ID=349997
Yeah, I have tried clearing the codes before trying to perform the Kick-Down Alignment, and it still doesn't allow me to perform the alignment when I am free of codes. I am able to perform every other Engine - Group, but not the 063 group which allows me to reset the kick down alignment.
Does it still show not available even when there are no fault codes?
NZDubNurd
New Zealand
C?ID=230482
You're doing it with the engine off, right?
