Audi A6 2019 F2 Chassis Mising In Autoscan Options
Ashraf6119
C?ID=174194
Got this vehicle in which was involved in an accident but, NO any airbag deployed but, got this fault code which needs to be reset using basic settings but, I can't find security login code can any one please help me a login code to reset....
Car starts and drives fine but, the battery light stays ON and the charging system is only charging 11Volts which is not charging the battery as it should be...
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 291AE5FE48E28107D0-807C
40973 - Crash Shut-Down Activated
          P1609 00 [047] - -
          [Diag_F_Crash_MV_ShutOff]
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:02:10
One other thing I noticed was there is I NO F2 chassis option in Autoscan drop down menu so, I had to use F4 option to do this auto scan, please find the attached full scan for this vehicle..........
Saturday,14,December,2019,15:17:10:07075
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
VIN: WAUZZZF20KN013232   License Plate: A6 2019
Mileage: 7040km-4374mi   Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 2B 36 42 44 46 52 5F 61 6C 81 A5 AC
          BB BC C4 CC D6 D7 DE
VIN: WAUZZZF20KN013232   Mileage: 7040km-4374miles
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DDVB)       Labels: Redir Fail!
   Part No SW: 4K0 907 401     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0004
   Revision: CAH26---
   Coding: 0A2A40320526050334086000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114K0907401 001006
   ROD: EV_ECM30TDI011_AU58.rod
   VCID: 6484B4CA6F401C6F23-8030
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 4K0 927 158     HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 1001
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011.rod
   VCID: 6FAECBE6B686AF374E-803A
   Automatic Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H01 0705
   Serial number: 180618000221
   Part No SW: 4K0 907 379 M    HW: 4K0 907 379 A
   Component: ESP9 Plus     H06 0850
   Coding: 1CAA319731A30A9911A04894007FD2D2F5B9C0388C8C508812004B4BAF9D03
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 3FCE5BA6A6661FB79E-806A
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0652
   Coding: 07000143C13900CD074C57881FAF8C68130B3310000600970101080039321C810A45093242560508000001000001001A0000000000010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 76A0FE82C9DC9EFF8D-8022
   Subsystem 1 - Part No SW: 4K2 955 119     HW: 4K2 955 119
   Component: J400FRWISCH  063 0730
   Serial number: 00000001802060400892
   Coding: 7DC727
   Serial number: 21530421X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K2 941 501     HW: 4K2 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 16S08.06.1800300162
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE113041823511528
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul  H42 0413
   Serial number: C00044333
   Coding: 0D0104
   Part No SW: 4N0 959 655 J    HW: 4N0 959 655 J
   Component: AirbagVW31    H01 2710
   Serial number: 003YTM003Y2+
   Coding: AACCF0C00CC00000985400FFF08D40AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 43C65756CA8E7B57FA-8016
   Subsystem 1 - Part No SW: -----------    HW: 480 000 205 18
   Serial number: 3570000000054C718E2P
   Subsystem 2 - Part No SW: -----------    HW: 480 000 405 18
   Serial number: 35800000000067444E2E
   Subsystem 3 - Part No SW: -----------    HW: 480 032 405 18
   Serial number: 351001C10B150EE0C914
   Subsystem 4 - Part No SW: -----------    HW: 480 032 405 18
   Serial number: 352001C10B1D05C09CCD
   Subsystem 5 - Part No SW: -----------    HW: 480 031 106 18
   Component: FrontSensor_D  002 0149
   Serial number: 355001C103C9AE30C9ER
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 031 106 18
   Component: FrontSensor_P  002 0149
   Serial number: 356001C103C1A5E02B77
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 480 031 106 18
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C10391A1908EF3
   Subsystem 8 - Part No SW: -----------    HW: 480 001 206 18
   Serial number: I0M0000000072D61DDAJ
   Subsystem 9 - Part No SW: -----------    HW: 480 001 206 18
   Serial number: I0N00000000B1D61DDAN
   Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 41CA5D5ED0926947E8-8014
   Part No SW: 4K0 920 790 A    HW: 4K0 920 790 A
   Component: FBenRDWACC--- H11 0151
   Coding: A4A420C2688006000103E160B080080008001000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2B161FF6421E931722-807E
   Part No SW: 4N1 907 468 AB    HW: 4N1 907 468 AB
   Component: Gateway       H14 0036
   Revision: 8N020004    Serial number: 0488N559418614
   Coding: 02010005000486408C960000005B0132C81A000710000000097D078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 78BCF0BAC3C8E88F9F-802C
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863110018060902DD
9502727 - Databus
          [BMS_No_Component_Function]
                    Reset counter: 118
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:03:01
                    48V activation restriction-Airbag control module: active
                    48V activation restriction-Engine Electronics: not active
                    48V activation restriction-Roll stabilization: not active
                    48V activation restriction-48 V activation restriction due to open circuit: not active
                    48V activation restriction-48 V activation restriction due to deactivation: not active
                    48V activation restriction-Battery Energy Control Module 2: not active
                    48V activation restriction-DC/DC Converter Control Module: not active
                    48V activation restriction-Control module for auxiliary air heater: not active
                    48V activation restriction-Electrical Charger: not active
9502755 - 48V System
          C124E F0 [009] - Locked after Crash Active
          [Airbag_CrashTyp_Historie_Hard]
                    Reset counter: 118
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:03:01
8526354 - Generator
          P1B01 00 [009] - Electrical Malfunction
                    Reset counter: 118
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:03:01
                    Generator voltage: 10.6 V
                    Battery voltage: 11.455 V
8519684 - 12V Electrical System
          C11CB 01 [009] - Electrical Failure
                    Reset counter: 118
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:03:01
                    12 V elec. system: error status: Stage 1
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 17000234825009
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3424048A9F20CCEF73-8060
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0042
   Serial number: 00000327275757
   Coding: 007812400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   VCID: 79BAF5BEF8C2F187E0-802C
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS001 0188
   Serial number: YE007RFD18596
   Coding: 001DDA0052010400A000B002
   VCID: 3E3026A2A16C16BF95-806A
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H20 0504
   Coding: 94002101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 312A0D9E6032F9C718-8064
   Part No SW: 4N0 907 064 BB    HW: 4N0 907 064 B
   Component: BCM2 MLBevo H14 0145
   Coding: 013500002FB000406309A0000400000203030000804302502F04000000040030001F0100000001
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008.rod
   VCID: 70ACC89AABB8B0CF57-8024
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1814535CV
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099464755
   Rear Spoiler Adjustment:
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS001 0188
   Serial number: YE007RFD21026
   Coding: 001DDA005E010400A000B000
   VCID: 3D3221AEAC6A0DA78C-8068
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 A    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   046 2470
   Coding: 01850101FF0A000043111101C00800302F0001E601F00800CE
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 210AFDDE30D2494788-8074
   Subsystem 1 - Part No: V03 959 804 BB
   Component: MIB2P_EU_Q317  0240
   Subsystem 2 - Part No SW: 4K0 919 605 A    HW: 4K0 919 605 A
   Component: DU AU58x High  H42 0144
   Serial number: INX00113051800060128
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004418000100520059
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K2 919 603 A    HW: 4K2 919 603
   Component: DU AU58x Bot  H41 0144
   Serial number: INX00123041800090153
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800378671013
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 118
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:04:14
                    Voltage terminal 30: 11.3 V
          P1609 00 [047] - -
                    Mileage: 7040 km
                    Date: 2019.12.14
                    Time: 15:02:10
Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H12 0250
   Coding: 0285010102002001C20040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 332607969A2ECBD76A-8066
   Part No SW: 4K2 713 041 G    HW: 4K2 713 041 H
   Component: GSM-LL H14 0050
   Serial number: 18.157 40199
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 281CE0FA53E8B80FCF-807C
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 A    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0290
   Coding: 04C18600000000000000060000400424189D5600000000000000000000000000001900000000000000000000000000000000000000000000000080000000000000007818008000B000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001_AU58.rod
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0004
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   VCID: 2C141CEA4710942F2B-8078
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS003 0188
   Serial number: YE007RFC15926
   Coding: 000DD80000010400A000B000
   VCID: 40CC585ADB98604FE7-8014
   Component: TSG HBFS003 0188
   Serial number: YE007RFC15927
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A382AB2BD443A9FA9-806E
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 21061800020040
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 302C089A6B38F0CF17-8064
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H05 0030
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
   VCID: 72A8C292A5B482DFA1-8026
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 502 A    HW: 4K0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 400000
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 1F0EFB2606A67FB7BE-804A
End----(Elapsed Time: 01:44, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
Thanks
Hopefully someone knows it, but data for these cars has been hard to find.
One other thing is I could not find F2 chassis option in Autoscan drop down menu so, I had to use F4 option to do this autoscan.........
You don't need to select a chassis on any modern car. Just use Auto-Detect.
Ashraf6119
C?ID=174194
Thanks for the reply so, any idea how do i reset theses fault codes as it needs a security login code with out login do any thing any help would be great....
NEtech
C?ID=56995
What do you do, when VCDS show a message that security access is needed ?
Try if maybe 20103 is accepted as security access.
Measurement "Security Access: Number of invalid keys" must be 0
F2 is: 4K - Audi A7 (2019>)
Ashraf6119
C?ID=174194
Thanks for the reply......What do you mean by (Security Access: Number of invalid keys" must be 0)
NEtech
C?ID=56995
Look in Measurement values "Security Access: Number of invalid keys"
Ashraf6119
C?ID=174194
Well this post can now be marked as Fixed and Thanks to all for the help.............
NEtec, Thanks the Measurement values "Security Access: Number of invalid keys was indeed ''0'' and the Basic Settings is bit tricky as there are few options to reset for that fault code but, thanks to you all I did managed to sort the problem..........
