Results 1 to 8 of 8
Thread: Mk 5 R32 Golf Steering angle G85 mechanical fault.
    Dec 2019
    New Zealand
    Hi Guys, need a bit of help with this one.
    R32 Golf presented from the Panel shop after loosing a left front wheel.
    We replaced the damaged hub, headlight height sensor, brake rotor etc then it went for an alignment before we attempted to deal with the 778 G85 steering angle sensor mechanical fault code that was present.
    Vehicle drives well- steering wheel is straight.
    We have malfunctions in the ABS, CAN gateway and convenience modules.
    I have intermittent communication issues with this vehicle using my Autel and Autologic and it appears to be something to do with the audio coding. This vehicle is a Japanese import and its had a (likely Chinese replica) head unit fitted that works fine.
    We attempted to do a basic setting for the steering angle sensor but it was unsuccessful. We now also get codes for 778 G85 no or incorrect basic setting. When i look at group 60 it is empty or void and not available.
    We removed the steering wheel- marks on shaft and wheel align OK. Checked tie rod ends- 10mm exposed thread on the left and 17mm on the right- Not sure if this may be part of the issue?
    I tried another known good steering angle sensor and checked all the cutter windows for the optical sensor in the back of the clock spring but no problem was found.
    Autel and autologic were both unable to pick up a software code for the ABS module. But the VCDS does show a code.
    At this stage i think we either have a module issue (steering wheel module or brake module?) or the tie rod lenghts messing with it?
    Can any one shed some more light on this issue please.
    Hi and welcome.
    Please post a complete Auto-Scan for context.
    Dec 2019
    New Zealand
    Saturday,14,December,2019,11:56:05:20137
    VIN: WVWZZZ1KZ6W077336   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 62 72
    VIN: WVWZZZ1KZ6W077336   Mileage: 131590km-81766miles
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 CE    HW: 000 000 000 00
       Component: MOTRONIC ME7.1.1G   6733
       Revision: --H01---    Serial number: VWZ7Z0E2907931
       Coding: 0000178
       Shop #: WSC 01279 785 00200
       VCID: 50F97033C6E7D917197-8004
    004949 - Cylinder 1 Ignition Circuit
                   P1355 - 004 - Open Circuit - Intermittent - MIL ON
    Readiness: 0110 1001
       Part No SW: 02E 300 047 F    HW: 02E 927 770 AE
       Component: GSG DSG         070 1121
       Revision: 04507000    Serial number: 00000511171308
       Shop #: WSC 60310 981 60724
       VCID: 1B63D71FDFA12A4F3C5-804E
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 1K0 614 517 S    HW: 1K0 614 517 S
       Component: ESP 4MOTION MK60-AT 0102
       Revision: 00T12001
       Coding: 0004744
       VCID: 372B2BAF43496E2F38D-8062
                003 - Mechanical Failure
       Part No: 1K0 907 044 BA
       Component: ClimatronicPQ35 066 0606
       VCID: 678BBBEF53693EAF68D-8032
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000005136199
       Coding: E68F8F2700041800001400001400000000087B075C
       Shop #: WSC 01392 785 00200
       VCID: 2B0307DF8F01DACF4C5-807E
       Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00065493
       Shop #: WSC 01392
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00207646
       Shop #: WSC 01392
                        Fault Status: 00101100
                        Reset counter: 204
                        Mileage: 131582 km
                        Voltage: 13.50 V
                        Reset counter: 203
                        Mileage: 131582 km
                        Voltage: 11.35 V
                        Fault Status: 00101010
                        Reset counter: 203
                        Mileage: 131582 km
                        Voltage: 13.65 V
                        Reset counter: 206
                        Mileage: 131596 km
                        Voltage: 12.00 V
                        Reset counter: 189
                        Mileage: 130371 km
                        Voltage: 8.25 V
       Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
       Component: 5E AIRBAG VW8R  032 6800
       Revision: 02032000    Serial number: 0038FD029CYA
       Coding: 0013637
       Shop #: WSC 01269 785 00200
       VCID: 392F2D97755D785FCE9-806C
       Subsystem 1 - Serial number: 6332MSME0C224E34C
       Subsystem 2 - Serial number: 6342MSME0C173A1FL
       Subsystem 3 - Serial number: 6352QSME0672122FC
       Subsystem 4 - Serial number: 6362QSME04343B7FP
       Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
       Component: J0527           634 0070
       Coding: 0012122
       VCID: 77ABEBAF03C9AE2FF8D-8022
       Part No: 1K6 920 862 F
       Component: KOMBIINSTRUMENT VDD 4316
       Coding: 0007503
       Shop #: WSC 52167 001 1048576
       VCID: 33331FBF5731820F045-8066
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 2800105A150DE9
       Coding: FF3F0300070003
       Shop #: WSC 33408 210 01865
       VCID: 2A0D02DB80FBC3C7B73-807E
                        Reset counter: 206
                        Mileage: 131596 km
                        Time: 03:47:19
    01304 - Radio
                        Reset counter: 206
                        Mileage: 131596 km
                        Time: 03:47:23
                        Reset counter: 206
                        Mileage: 131597 km
                        Time: 04:50:34
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 B
       Component: HALDEX 4Motion      0107
       VCID: 2C0104C38A0FDDF745F-8078
       Component: IMMO            VDD 4316
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2468
       Coding: 0000694
       Shop #: WSC 60310 981 91232
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.141 H07 1806
       VCID: 353721A759459C3F2A1-8060
    Address 46: Central Conv.        Labels: None
       Part No: 1K0 959 433 CQ
       Coding: 81C802087F2D8405485FC6F010CC
       VCID: 015F85775D0DE09FC69-8054
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1K0 951 177 A
       Component: Innenraumueberw.005 0202
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1K0 959 702 L
       Coding: 0000694
       VCID: 382928934E576157317-806C
       Part No: 1T0 907 357
       Coding: 0000004
       Shop #: WSC 01287 785 00200
       VCID: 74B1DCA312BFC537DDF-8020
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2429
       Coding: 0000144
       Part No: 1K0 959 704 F
       Coding: 0000144
       VCID: 34311CA3523F85371DF-8060
    End----(Elapsed Time: 01:08, VBatt start/end: 12.2V/12.0V. VIgn 12.0V)-----
    Ignore the steering wheel fault as i have the air bag out currently.
    Quote Originally Posted by NorthernAuto View Post
    Wait, isn't the steering angle sensor right there with that on this car?
    Dec 2019
    New Zealand
    Its in behind the clock spring above the steering wheel module. Currently i have the air bag itself out as i went back and rechecked the clock spring and steering wheel location marks. I can refit the air bag and retest. But all testing previously has been done with the air bag in and fault codes cleared
    What do you see in MVB 004.1 of the ABS?
    Also look in MVB 007.1 of the Steering assist.
    Both should show something close to 0 degrees with the steering wheel centered and the front wheels pointed straight ahead, and should go positive when the steering wheel is turned in one direction, and negative when it is turned in the other direction.
  7. #7
    Dec 2019
    New Zealand
    ABS MVB 004 is -1.40 and goes positive and negative when turned.
    Steering assist MVB 7 is identical.
  8. #8
    OK, that is as it should be. I am now scratching my head.
