Results 1 to 6 of 6
Thread: Mk5 Golf MK60EC1 ABS Long Coding
    Feb 2019
    is anyone able to provide me with Long Coding for this vehicle.
    The VIN number on the windscreen is: WVWZZZ1KZ9W103390
    The Scan shows a different VIN number as the cluster has been changed.
    The advanced ID's of the Engine and Immobilizer are in the scan:
    Friday,13,December,2019,14:15:34:08713
    VIN: WVWZZZ1KZ9W047340   License Plate: KING
    Mileage: 165240km-102675mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56
    VIN: WVWZZZ1KZ9W047340   Mileage: 165240km-102675miles
    37-Navigation -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
       Component: R4 2,0L EDC  000SG  4661
       Revision: --H08---    Serial number: XXXXXXXXXXXXXX
       Coding: 0000072
       Shop #: WSC 66565 257 00032
       VCID: 7CB40AD73FC96EAFFB-8028
    008580 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2184 - 000 - Signal too Low - Intermittent
                        Mileage: 164485 km
                        Time: 04:11:20
                        RPM: 1596 /min
                        Speed: 26.0 km/h
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 00000111
                        Temperature: 72.9C
                        Temperature: 70.2C
    000386 - Fuel Temp. Sensor A (G81)
                   P0182 - 000 - Short to GND - Intermittent
                        Mileage: 164838 km
                        Time: 13:50:15
                        RPM: 1197 /min
                        Speed: 31.0 km/h
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Temperature: 17.1C
                        Temperature: 63.0C
                        Temperature: 123.3C
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 000 - Signal too Low - Intermittent
                        Fault Status: 00110000
                        Mileage: 165016 km
                        Time: 19:17:25
                        RPM: 924 /min
                        Load: 0.0 %
                        Duty Cycle: 79.7 %
                        Bin. Bits: 00000100
                        Mass Air / Rev.: 540.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       Shop #: WSC 00153 210 92361
       VCID: 74A422F7D79926EFB3-8020
    03306 - Coding Not Valid
                        Reset counter: 60
                        Mileage: 165240 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 4161
                        Count: 43008
                        Fault Status: 01100101
                        Reset counter: 60
                        Mileage: 165016 km
                        Count: 16391
                        Count: 8192
                        Count: 279
                        Count: 43008
                        Reset counter: 60
                        Mileage: 165016 km
                        Count: 16391
                        Count: 8192
                        Count: 270
                        Count: 43008
                        Reset counter: 53
                        Mileage: 165016 km
                        Count: 16391
                        Count: 8192
                        Count: 195
                        Count: 43008
                        Reset counter: 60
                        Mileage: 165016 km
                        Count: 16391
                        Count: 8192
                        Count: 320
                        Count: 43008
                        Reset counter: 53
                        Mileage: 165016 km
                        Count: 16391
                        Count: 8192
                        Count: 291
                        Count: 43008
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 77BE15FB06EF4DF796-8022
       Revision: 00H54000    Serial number: 00000008750052
       Coding: EF898F2700041500471400001400000000087F075C000100000000000000
       Shop #: WSC 80093 222 69422
       VCID: 3326E1EB521761D76A-8066
       Component: Wischer 110808 021  0501
       Coding: 00038805
       Shop #: WSC 80093
       Component: RLS     020908 054  0402
       Coding: 00209069
       Shop #: WSC 80093
    10 Faults Found:
                        Fault Status: 00101100
                        Reset counter: 76
                        Mileage: 164595 km
                        Voltage: 12.45 V
                        Reset counter: 76
                        Mileage: 164595 km
                        Voltage: 11.70 V
                        Reset counter: 76
                        Mileage: 164595 km
                        Voltage: 12.50 V
                        Reset counter: 80
                        Mileage: 164595 km
                        Voltage: 12.15 V
                        Fault Status: 01101100
                        Reset counter: 60
                        Mileage: 164339 km
                        Voltage: 12.50 V
                        Fault Status: 00101010
                        Reset counter: 76
                        Mileage: 164485 km
                        Voltage: 11.60 V
                        Reset counter: 76
                        Mileage: 164568 km
                        Voltage: 12.20 V
    02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                        Reset counter: 73
                        Mileage: 164485 km
                        Voltage: 8.90 V
    00154 - Windshield Wiper Motor;  Passenger Side (V217)
                        Reset counter: 73
                        Mileage: 164485 km
                        Voltage: 8.85 V
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 73
                        Mileage: 164485 km
                        Voltage: 8.90 V
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD266V7F
       Coding: 0013112
       VCID: 3D32C7D36453A7A78C-8068
       Subsystem 1 - Serial number: 6332MSME3F36226DL
       Subsystem 2 - Serial number: 6342MSME3F532C76P
       Subsystem 3 - Serial number: 6352QSME79085814J
       Subsystem 4 - Serial number: 6362QSME6508233CH
    00532 - Supply Voltage B+
       Part No SW: 1K0 953 549 CB    HW: 1K0 953 549 CB
       Component: J0527           051 0101
       Coding: 0002002
       VCID: 74A422F7179926EFB3-8020
    01426 - Controls in Steering Wheel (E221)
    00576 - Terminal 15
       Part No SW: 1K0 920 964 B    HW: 1K0 920 964 B
       Component: KOMBIINSTRUMENT VDD 1212
       Revision: V0002000    Serial number: VWX7Z0H63N18TG
       Coding: 0003403
       Shop #: WSC 00867 210 91890
       VCID: 2C14FA978F293E2F2B-8078
                        Fault Frequency: 14
                        Reset counter: 73
                        Mileage: 164484 km
                        Time: 06:48:15
       Component: J533__Gateway   a 0202
       Revision:   a       Serial number: 2700
       Coding: E9801F064002020003
       VCID: 3522DFF35C637FE744-8060
                        Reset counter: 30
                        Mileage: 164436 km
                        Time: 13:41:00
       Component: IMMO            VDD 1212
    01176 - Key
                008 - Implausible Signal
                        Fault Status: 01101000
                        Mileage: 164359 km
                        Time: 14:39:56
    Address 37: Navigation
       Component: Tuer-SG         006 1208
       Coding: 0000564
       VCID: 383CD6C74B71828F5F-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       Shop #: WSC 01324 785 00200
       VCID: 2A18FC8F85DD201FD9-807E
                        Fault Status: 11100101
                        Mileage: 164359 km
                        Time: 14:40:01
                        Battery Volts: 12.0 V
                            DD
                        Temperature: 22.0C
                        Count: 3
                        Steering Angle: 0.00
                            SteerAng n.Init
       Coding: 819002085103087F2D04840570085AC690BC00
       Shop #: WSC 00000 785 00200
       VCID: 0346712B42371157BA-8056
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
    01134 - Alarm Horn (H12)
                        Fault Frequency: 6
                        Reset counter: 33
                        Mileage: 164359 km
                        Time: 14:40:04
       Coding: 0000564
       VCID: 393AD3C3707B9B87A0-806C
       Part No: 1K0 035 186 T
       Component: Radio GR0       020 0023
       Revision: 0002006S    Serial number: VWZ2Z2G2281248
       Coding: 0040402
       Shop #: WSC 00028 028 00001
       VCID: 373ED5FB466F8DF756-8062
    00857 - CD Changer Unit (R41)
    00856 - Radio Antenna
    End----(Elapsed Time: 01:03, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
                    Address 01: Engine
    Control Module Part Number: 03G 906 021 PP
      Component and/or Version: R4 2,0L EDC  000SG  4661
               Software Coding: 0000072
                Work Shop Code: WSC 66565
    Advanced Identification
         Identification: BPG-810
         Revision: --H08---
         Date: 16.08.08
         Test stand number: 1349
         Manufacturer number: 0002
    Flash Status
         Programming Attempts: 2
         Successful Attempts: 2
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 00032 257 66565
         Flash Date: 00.00.00
    Software
         P0101
         HAXN
    Misc.
         Hardware number: 03G 906 021 AN
         Immo Challenge: 5A 10 74 FF
    Car Info
         Chassis Number: XXXXXXXXXXXXXXXXX
    VCDS Info:
           Readiness: No script available
    Control Module Part Number: 1K0 920 964 B
      Component and/or Version: IMMO            VDD 1212
               Software Coding:
                Work Shop Code: WSC 00000
         Identification: VDD-024
         Revision: V0002000
         Date: 01.07.08
         Test stand number: 7702
         Manufacturer number: 1428
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Required Conditions: 00000001
         Flash Tool Code: 00000 000 00000
         Flash Date: --.--.--
    Software
         DKBI339
         Y012
         Z0012
    Misc.
         Hardware number: 1K0 920 964 B
         Lot Number: 000
         Type Lock: 0000
    Car Info
         Chassis Number: WVWZZZ1KZ9W047340
    VCDS Info:
    Gateway Installation List:  1K0 907 530 Q
    Address 19,1K0 907 530 Q,recoded (Installation List),from,E9801F064002020003,to,E9801F060002020003,,
    Did you know the cluster will have to have the correct VIN input and engine ECU + all proper power classes demonstrated on CAN broadcast for CP + MAC data & is to be consistent in order to process a proper coding request?
    FOD
    Feb 2019
    FOD
    Hello Jack,
    I will sort it with ODIS Online first.
    Thanks
  4. Likes Dana liked this post
    United States
    The OP contacted us via email as well and I agree with Jack. That Advanced ID in 01-Engine (Chassis Number: XXXXXXXXXXXXXXXXX) is likely a deal breaker. I suspect valid ABS coding is going to be rejected or zero upon a key cycle with the engine in this condition.
    Either way, I'll try to build coding for WVWZZZ1KZ9W103390 and report back.
    -Dana
  6. Likes Uwe, Jack@European_Parts, m3nt4l liked this post
    United States
    I believe the factory condition 03-ABS coding of WVWZZZ1KZ9W103390 was:
    133B400D092200FDC80E02ED901900823000
    Even if you configure this car with ODIS, please try to post a final VCDS scan with ABS coding.
  8. Likes Jack@European_Parts, m3nt4l liked this post
  9. #6
    Feb 2019
    Thank you.
    Once i have the car back and all relevant repairs have been done i will update this thread.
    Thanks again.
  10. Likes Dana, Uwe, myounus liked this post
