onday,16,December,2019,14:09:52:34670
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G9BN031X10 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310 Mileage: 168120km-104464miles
Address 01: Engine (J623-CGWB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 HW: 4H0 907 551
Component: 3.0l V6 TFSI H05 0007
Revision: --H05---
Coding: 0A250034052701020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551 002010
ROD: EV_ECM30TFS0214G0907551_002.rod
VCID: 6695B5FFE8EFBBD753B-8032
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 156 M HW: 0B5 927 156 F
Component: 0B5 30TFSIRdW H10 0024
Revision: --H10--- Serial number: 0000000785
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 363525BFF8CF0B5723B-8062
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Coding: 44A687002265E100DB00
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 6E85CDDFC01F73972BB-803A
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Coding: 05B82F00000000000000
VCID: 77ABE8BBBFC5325FF8D-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000097450009
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0056
Serial number: 06051100040574
Coding: 6621007824
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 270BF8FB2F6562DFA8D-8072
0378 - Coolant Circulation Pump
B10D0 04 [008] - Internal System Fault
Fault Frequency: 14
Reset counter: 96
Mileage: 167762 km
Date: 2019.12.10
Time: 10:12:42
Voltage terminal 30: 13.48 V
Outside air temperature: 32.5 °C
Interior temperature: 23.10 °C
0379 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 01 [009] - Electrical Failure
Fault Frequency: 44
Reset counter: 56
Mileage: 167382 km
Date: 2019.11.29
Time: 17:28:49
Voltage terminal 30: 12.45 V
Interior temperature: 35.37 °C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 N HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0092
Revision: 20012002 Serial number: 00000001044197
Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
VCID: 33331CABEB3D1E7F045-8066
Component: WWS57X 110404 H35 0051
Serial number: 110407090850
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11418017
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 22 04 2011 00000235
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 5228C6A5000000000001
01771 - Control Module for Headlight Range (J431)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 33
Mileage: 167382 km
Date: 2019.11.29
Time: 17:28:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55901107004778
Coding: 300306
Shop #: WSC 00097 210 98728
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 392F2E83C9D1E42FCE9-806C
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG002BRPH
Coding: 30323436313330303631554A305234473053
Serial number: 3575HRB404T0HM766GDR
Serial number: 3585HRB405H0H0LUC8R2
Serial number: 3515JRB405D0H4DU9P4N
Serial number: 3525JRB405F0G944N0G$
Serial number: 3554VRB40630GR36HOS5
Serial number: 3564VRB405D0GR36IHD.
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110505000939
Coding: 000034
VCID: 303913A71A2B2567797-8064
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 981 A HW: 4G8 920 981 A
Component: TBenGb H34 0312
Revision: 19100074 Serial number: 658020411593026
Coding: 33A709000B012600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 313F16A311A12C6F769-8064
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000141378
Coding: 00CD073000
ROD: EV_GatewUDS_AU57.rod
VCID: 303913A71AAB2567797-8064
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650387009
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11130001538021200181
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 06051100040012
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 2F3B10DB07953A9F60D-807A
0026 - Motor for Rear Left Upper Body Vent
B10D3 21 [008] - Signal Amplitude Too Low
Reset counter: 82
Mileage: 167513 km
Date: 2019.12.04
Time: 09:48:55
Voltage terminal 30: 13.32 V
Outside air temperature: 41.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 9849
Left Rear Upper Body Vent Motor-Specified value: 9849
Left Rear Upper Body Vent Motor-Stop open: 11400
Left Rear Upper Body Vent Motor-Stop closed: 10000
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006129999
Coding: 00781B0000006001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200UA850
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070AD30D99488F521-8078
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F16205E01628002080002
Shop #: WSC 02312 785 00200
VCID: 40D94367AA8BB5E7897-8014
6 Faults Found:
01482 - Motors for Central Locking
Fault Status: 00100111
Reset counter: 94
Mileage: 168023 km
Date: 2019.12.13
Time: 18:57:12
02116 - Mirror Adjusting Motor
Fault Status: 00100110
Reset counter: 94
Mileage: 168023 km
Date: 2019.12.13
Time: 18:57:12
02117 - Motor for Mirror Folding
Reset counter: 94
Mileage: 168023 km
Date: 2019.12.13
Time: 18:57:12
Reset counter: 94
Mileage: 168023 km
Date: 2019.12.13
Time: 18:57:12
Reset counter: 94
Mileage: 168023 km
Date: 2019.12.13
Time: 18:57:20
Reset counter: 94
Mileage: 168023 km
Date: 2019.12.13
Time: 18:57:20
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0010073316
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D19AF14A717770F3-8066
Revision: 00002001 Serial number: 0149428872
Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
Component: DWA-Sensor H01 0010
01134 - Alarm Horn (H12)
014 - Defective
Fault Status: 01101110
Reset counter: 33
Mileage: 167382 km
Date: 2019.11.29
Time: 17:28:50
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3FDB409BD775CA1FF0D-806A
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000070722
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D01CF3C775FB7B73-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 110502-0004-033
Coding: 1121A633F918EB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H02 0008
Coding: 1D0000
H02 0008
Coding: 1D0000
0061 - Function Restriction due to Implausible Message(s)
U1112 00 [137] - -
[Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
Fault Frequency: 54
Reset counter: 56
Mileage: 167382 km
Date: 2019.11.29
Time: 17:28:52
Part No SW: 4G0 035 056 A HW: 4G0 035 056
Component: Radio U STD H52 0050
Revision: AB001007 Serial number: 051EY0B7516476
Coding: 010003020100000001
VCID: 1F1BE01B77B5AA1FD0D-804A
Part No SW: 4G0 035 670 B HW: 4G0 035 670
Component: H-BNT-EU H46 0239
Revision: -------- Serial number: 428EX0B7514227
Coding: 050101000003E1EF45108B3E000000030000010000000000
VCID: 221DE9EF44C787F7FF3-8076
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300QPJ1
Subsystem 3 - Part No SW: 4G2 919 612 L HW: 4G2 919 612 L
Component: E380 BDT C7 H08 0120
Serial number: 90349KDT0007U
Component: CD-Database 2712
03787 - Rotation Mechanism for Display Module Front
Fault Status: 00101011
Reset counter: 93
Mileage: 168022 km
Date: 2019.12.13
Time: 18:45:38
Voltage: 12.00 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F14204001628002080002
VCID: 42DD496FA487A7F79F3-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J14F0S1
Coding: 1020004
VCID: 2517F2F359E970CF9A1-8070
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0210
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000
Coding: 64040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B2F315E9B0CF5A1-8030
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD0DBC7157A9F20D-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D3A7DA2B6567397-8024
End----------(Elapsed Time: 02:11, VBatt start/end: 12.3V/12.3V)-----------
