Results 1 to 3 of 3
Thread: 2009 JSW 2.5L 5-Speed Stock Condition-ABS, ESP Blinking Brake Light
    Dec 2019
    Good day all. I am a Ross-Tech NEWB. I am having the "ABS, ESP, Blinking Brake Light" issue. No modifications were done prior to the issue happening. I did the scan and there are three faults, as you can see below. Now I need some assistance with understanding what these faults mean and how to correct them. I am still able to drive the vehicle, but I'd like to get it fixed, as it is my teenage daughter's car. Can someone provide a newbie some guidance? Thanks.
    Brian from Kansas
    Monday,09,December,2019,18:07:58:28052
    VIN: 3VWKM71K09M284730   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWKM71K09M284730   Mileage: 262730km-163252miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9204
       Revision: G6H02---    Serial number: VWX7Z0H82410V1
       Coding: 0000071
       VCID: 3C21334A1A6D7EA7D5F-8068
       Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       Coding: 113B400D492A00FE881202E7921900413000
       Shop #: WSC 53968 001 1048576
       VCID: 76B5E16268C1E4F7E3B-8022
    16352 - Control Module - Electrical Error
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 205
                        Mileage: 262283 km
                        Count: 32768
                        Count: 4608
                        Count: 96
                        Count: 52265
                        Count: 3
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9EF5A6ED59287F17-802C
       Revision: 00H54000    Serial number: 00000001070697
       Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
       VCID: 323D1D72C829B8D70F3-8066
       Component: Wischer 021008 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 247
                        Mileage: 262289 km
                        Voltage: 12.30 V
    00927 - Terminal 30 (Right)
                        Reset counter: 247
                        Mileage: 262289 km
                        Voltage: 12.30 V
       Component: 78 AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M070AT2
       Coding: 0014136
       VCID: 6C81C30A2A8D2E2705F-8038
       Subsystem 2 - Serial number: 6332MSME3E1471629
       Subsystem 3 - Serial number: 6342MSME38302E002
       Subsystem 4 - Serial number: 6351HSME16612C689
       Subsystem 5 - Serial number: 6361HSME16723444%
       Subsystem 6 - Serial number: 63727SME173C3551/
       Subsystem 7 - Serial number: 63827SME157E043C7
       Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
       Coding: 0000022
       VCID: 73B3D87677B3F1DFC45-8026
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H82410V1
       Coding: 0007203
       Shop #: WSC 12345 067 57207
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 130808F1001314
       Coding: E9807F070002022002
       VCID: 3537266E3947AFEF2A1-8060
       Component: IMMO            3HL 1222
       Revision: 72009005    Serial number: 00000928688918
       Coding: 0001205
       VCID: 6FBBD4061B9BD53F20D-803A
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A0D0512E0F9F017B73-807E
       Coding: 139007885283281B0904058FB0880F0488DCA0
       VCID: 04518BAA221DC667EDF-8050
       Revision: 72009005    Serial number: 00000253788903
       Coding: 0001204
       VCID: 70B9D77A06A5CAC7397-8024
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       018 0021
       Revision: 00018000    Serial number: VWZ4Z7H6381199
       Coding: 0040401
       VCID: 2019E73A96C53A47E97-8074
       Revision: 12006001    Serial number: 00000003496907
       Coding: 0001168
       VCID: 76B5E16264C1E4F7E3B-8022
       Coding: 0100101
       Revision: 12006001    Serial number: 00000003466929
       Coding: 0001168
       VCID: 77ABEC6663CB9DFFF8D-8022
    End----(Elapsed Time: 01:16, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
    I'm afraid that looks like a defective ABS module.
    It may be covered by a safety recall:
    https://static.nhtsa.gov/odi/rcl/201...6V913-3524.PDF
  3. Likes N2VDUBZ liked this post
    Dec 2019
    Thanks Uwe. I checked my VIN and it doesn't show up on the recall list. Any recommendations?
