Stuartwhite1989
cannot find my old thread i had problem with water in fuse box. cleeaned all up and dried out was fine.driving down road everything went mad oil warning,rev counter dash going mad car shut off. got replacement fuse box still no start
youtube video dash https://youtu.be/4D7W7uy6ET0
car scan. egr is because its unplugged
Thursday,12,December,2019,18:27:39:57077
VCDS Version: 19.6.2.0
VIN: WAUZZZ8P84A056462 License Plate:
Mileage: 237380km-147501mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P84A056462 Mileage: 237380km-147501miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5334
Revision: 12345678 Serial number: AUX7Z0C6FNT0DV
Coding: 0000072
Shop #: WSC 01286 386 08256
VCID: 27560A959633E177C6-8072
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
RPM: 147 /min
Torque: 190.0 Nm
Voltage: 7.98 V
Bin. Bits: 00000000
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 0 0 1 1 1
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
Shop #: WSC 06435 000 00000
VCID: 336EEEC552EB9DD76A-8066
6 Faults Found:
01312 - Powertrain Data Bus
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH14 0180
Revision: 138254 Serial number: 8P0820043H
VCID: 3162E4CDA8F7AFC718-8064
00532 - Supply Voltage B+
Reset counter: 224
Voltage: 7.40 V
Fault Status: 00101001
Reset counter: 218
Temperature: -50.0°C
Voltage: 8.40 V
Load: 9.0 %
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 233
Reset counter: 184
Mileage: 223600 km
Date: 2017.11.11
Time: 03:54:00
Temperature: 18.5°C
01273 - Fresh Air Blower (V2)
Reset counter: 224
Mileage: 237118 km
Date: 2019.11.27
Time: 00:01:56
Temperature: 5.0°C
Speed: 325.0 km/h
(no units): 202.0
(no units): 32.0
Reset counter: 184
Mileage: 237382 km
Date: 2019.12.04
Time: 00:11:56
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000119363
Coding: 01884F00A2141000000000000000000000
VCID: 3B7EC6E57ABB5597B2-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 458AA01D0C7F1367D4-8010
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
Shop #: WSC 06435 551 00000
VCID: 3064E1C9A3FDA6CF17-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0080
Revision: D05 Serial number: 2246CD05000107
Coding: 0004403
Shop #: WSC 00783 067 57207
VCID: 3C7CC5F97FB552AFBB-8068
007 - Short to Ground
Fault Status: 00000011
Reset counter: 178
Mileage: 237118 km
Date: 2019.11.27
Time: 00:01:33
014 - Defective
Reset counter: 178
00003 - Control Module
014 - Defective
Mileage: 150981 km
Date: 2013.01.21
Time: 14:58:48
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103721A350
Coding: 3D0F0B42070101
VCID: 264807919139F87FFD-8072
01304 - Radio
Reset counter: 184
Mileage: 237382 km
Date: 2019.12.04
Time: 00:15:39
Revision: D05 Serial number: AUX7Z0C6FNT0DV
Shop #: WSC 00762 210 91493
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 3972DCED70876787A0-806C
Address 44: Steering Assist Labels: 1Kx-909-143-GEN1.clb
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.7 0402
00573 - Steering Torque Sensor (G269)
Torque: 0.0 Nm
012 - Electrical Fault in Circuit - Intermittent - MIL ON
Temperature: 9.0°C
Voltage: 11.30 V
Voltage: 12.40 V
Mileage: 7360 km
Temperature: 14.0°C
Voltage: 6.00 V
Voltage: 6.00 V
Mileage: 7360 km
Temperature: 9.0°C
Voltage: 8.20 V
Voltage: 12.10 V
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 188800186D288505485AC63000
Shop #: WSC 00186 785 00200
VCID: 79F21CED3007A787E0-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001041884
VCID: 70E421C9637DE6CF57-8024
Reset counter: 218
Mileage: 237082 km
Date: 2063.15.31
Time: 31:63:63
Temperature: 4.0°C
Raw, Form. N/A: 000 000 000
Reset counter: 218
Mileage: 237082 km
Date: 2063.15.31
Time: 31:63:63
Temperature: 4.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A70C3E175816C9FA9-806E
Address 56: Radio
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
VCID: 2B5EF6A58ADBC51722-807E
014 - Defective
End-------------------------(Elapsed Time: 01:50)--------------------------
Address 03: DTCs cleared
