Results 1 to 10 of 18
Thread: A3 electrics went mental and car died
    New User
    Oct 2019
    cannot find my old thread i had problem with water in fuse box. cleeaned all up and dried out was fine.driving down road everything went mad oil warning,rev counter dash going mad car shut off. got replacement fuse box still no start
    youtube video dash https://youtu.be/4D7W7uy6ET0
    car scan. egr is because its unplugged
    Thursday,12,December,2019,18:27:39:57077
    VCDS Version: 19.6.2.0
    VIN: WAUZZZ8P84A056462   License Plate:
    Mileage: 237380km-147501mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P84A056462   Mileage: 237380km-147501miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 G    HW: 028 101 136 4
       Component: R4 2,0L EDC 0000SG  5334
       Revision: 12345678    Serial number: AUX7Z0C6FNT0DV
       Coding: 0000072
       Shop #: WSC 01286 386 08256
       VCID: 27560A959633E177C6-8072
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 000 - Signal too Low
                        RPM: 147 /min
                        Torque: 190.0 Nm
                        Voltage: 7.98 V
                        Bin. Bits: 00000000
                        Mass Air / Rev.: 850.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    Readiness: 0 0 1 1 1
       Part No: 1K0 907 379 D
       Coding: 0055942
       Shop #: WSC 06435 000 00000
       VCID: 336EEEC552EB9DD76A-8066
    6 Faults Found:
    01312 - Powertrain Data Bus
       Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
       Component: KlimavollautomatH14 0180
       Revision: 138254      Serial number: 8P0820043H
       VCID: 3162E4CDA8F7AFC718-8064
    00532 - Supply Voltage B+
                        Reset counter: 224
                        Voltage: 7.40 V
                        Fault Status: 00101001
                        Reset counter: 218
                        Temperature: -50.0°C
                        Voltage: 8.40 V
                        Load: 9.0 %
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 233
                        Reset counter: 184
                        Mileage: 223600 km
                        Date: 2017.11.11
                        Time: 03:54:00
                        Temperature: 18.5°C
    01273 - Fresh Air Blower (V2)
                        Reset counter: 224
                        Mileage: 237118 km
                        Date: 2019.11.27
                        Time: 00:01:56
                        Temperature: 5.0°C
                        Speed: 325.0 km/h
                        (no units): 202.0
                        (no units): 32.0
                        Reset counter: 184
                        Mileage: 237382 km
                        Date: 2019.12.04
                        Time: 00:11:56
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
       Component: Bordnetz-SG 1.0 H27 0401
       Revision: 00000000    Serial number: 00000000119363
       Coding: 01884F00A2141000000000000000000000
       VCID: 3B7EC6E57ABB5597B2-806E
       Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
       Component: Wischer WWS Audi350 0180
       Coding: 16711696
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
       Component: Airbag 8.4ED    H01 0130
       Coding: 0011602
       VCID: 458AA01D0C7F1367D4-8010
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 009 0030
       Coding: 0000012
       Shop #: WSC 06435 551 00000
       VCID: 3064E1C9A3FDA6CF17-8064
       Part No SW: 8P0 920 980 H    HW: 8P0 920 980 H
       Component: KOMBIINSTR. VDO H25 0080
       Revision: D05         Serial number: 2246CD05000107
       Coding: 0004403
       Shop #: WSC 00783 067 57207
       VCID: 3C7CC5F97FB552AFBB-8068
                007 - Short to Ground
                        Fault Status: 00000011
                        Reset counter: 178
                        Mileage: 237118 km
                        Date: 2019.11.27
                        Time: 00:01:33
                014 - Defective
                        Reset counter: 178
    00003 - Control Module
                014 - Defective
                        Mileage: 150981 km
                        Date: 2013.01.21
                        Time: 14:58:48
       Part No SW: 1K0 907 530 B    HW: 1K0 907 951
       Component: Gateway         H08 0090
       Revision: 08          Serial number: 2400103721A350
       Coding: 3D0F0B42070101
       VCID: 264807919139F87FFD-8072
    01304 - Radio
                        Reset counter: 184
                        Mileage: 237382 km
                        Date: 2019.12.04
                        Time: 00:15:39
       Revision: D05         Serial number: AUX7Z0C6FNT0DV
       Shop #: WSC 00762 210 91493
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 A
       Component: Tuersteuerger.  H10 0010
       Coding: 0000048
       VCID: 3972DCED70876787A0-806C
    Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
       Part No: 1K1 909 143 L
       Component: EPS_ZFLS Kl.7       0402
    00573 - Steering Torque Sensor (G269)
                        Torque: 0.0 Nm
                012 - Electrical Fault in Circuit - Intermittent - MIL ON
                        Temperature: 9.0°C
                        Voltage: 11.30 V
                        Voltage: 12.40 V
                        Mileage: 7360 km
                        Temperature: 14.0°C
                        Voltage: 6.00 V
                        Voltage: 6.00 V
                        Mileage: 7360 km
                        Temperature: 9.0°C
                        Voltage: 8.20 V
                        Voltage: 12.10 V
       Part No: 8P0 959 433
       Component:    KSG          H02 0040
       Coding: 188800186D288505485AC63000
       Shop #: WSC 00186 785 00200
       VCID: 79F21CED3007A787E0-802C
       Subsystem 2 - Component:       NGS No Answer
       Subsystem 3 - Component:      IRUE No Answer
    00323 - Vehicle Inclination Sensor (G384)
    01134 - Alarm Horn (H12)
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH23 0100
       Revision: 00001       Serial number: 10000001041884
       VCID: 70E421C9637DE6CF57-8024
                        Reset counter: 218
                        Mileage: 237082 km
                        Date: 2063.15.31
                        Time: 31:63:63
                        Temperature: 4.0°C
                        Raw, Form. N/A: 000 000 000
                        Reset counter: 218
                        Mileage: 237082 km
                        Date: 2063.15.31
                        Time: 31:63:63
                        Temperature: 4.0°C
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 A
       Coding: 0000048
       VCID: 3A70C3E175816C9FA9-806E
    Address 56: Radio
       Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
       Revision: 00600000    Serial number:
       VCID: 2B5EF6A58ADBC51722-807E
                014 - Defective
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Address 03: DTCs cleared
    Several (but by no means all) modules report really low voltage in their freeeze-frame data. Look for a common voltage supply to those modules. You problem will likely be there.
  3. Likes AIB Wolfgang liked this post
    New User
    Oct 2019
    The low voltage is where I kept unplugging things 1 by one and tryin to start. Then clearing all codes and doing scan after battery bit low. All this bloody started from a puddle not even a big one.
    Quote Originally Posted by Stuartwhite1989 View Post
    Sounds like you need to check for water ingress in more places than just the fuse box.
    New User
    Oct 2019
    I’m going to cut cover off ecu tomo and check there for water in plugs. I keep thinking engine loom as the Rev counter speedo and oil level was going crazy
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    Here is the reason:
    Freeze Frame: RPM: 147 /min >> needs up to 300 and
    more than 10,5V battery voltage while starting.
    -Wolfgang
    Drive more talk less
  8. Likes Mats@MFT liked this post
    New User
    Oct 2019
    The low voltage is because I had been trying to keep starting and unplugging bits then cranking. I could put a fully charged battery on or jump leads and it still won’t start. It jut cranks and dash beeps
  10. #8
    Sep 2014
    so it seems there are no electrical failures who blocks the starting.
    Now it's necessary to switch looking for mechanical failures.
    -Wolfgang
  11. #9
    New User
    Oct 2019
    The problem is mechanicaly it ran fine. Engine bay got bit wet then the problems started. When I switch the ignition on even with charged battery I get traction control light on permanently steering one and beeps. Only other thing I can think is I washed the car day before it broke down. It was parked for day after then it started and cut out few times like immo. Then it started after I sprayed wd40 into engine fuse box then had all the crazy light on dash in video I posted while driving. Then is cut in and out with power then died.
  12. #10
    Sounds like a good start would be to thoroughly clean the residue of the WD40 from the fuse box.
  13. Likes Uwe liked this post
