Results 1 to 7 of 7
Thread: 1.8l engine security access (HELP)
    Dec 2019
    India
    Need Security Access for the below ECM.
    Thursday,12,December,2019,17:37:39:04642
    VCDS Version: Release 19.6.2
    Address 01: Engine
    Control Module Part Number: 6C0 906 264
    Component and/or Version: 1.8l R4 TFSI H13 0003
    Software Coding: 092500322424010B0000
    Work Shop Code: WSC 00788
    VCID: 64CDED266F499D6F23-8030
    Advanced Identification/FAZIT
    Identification: SJ8-FST
    Revision: --H13---
    Date: 27.08.16
    Manufacturer number: 1132
    Test stand number: 0223
    Flash Status
    Programming Attempts(application): 3/3/1/2/3
    Successful Attempts(application): 3/3/1/2/2
    Programming Status: 00000000
    Flash Date: 00.00.00
    Software
    HiSpd Net: 01.12.01
    Misc.
    Hardware number: 06K 907 425 B
    Workshop System Name: J623
    ASAM Dataset: EV_ECM18TFS0206C0906264
    ASAM Dataset Revision: 001004
    Car Info
    Chassis Number: WVWK166RZHY094216
    Engine code: DAJB
    VCDS Info:
    Labels: 06K-907-425-V1.clb
    Readiness: No script available
    ROD: EV_ECM18TFS0206C0906264.rod
    Regards,
    Tutu.
    What are you trying to accomplish?
    Most ECUs have several different security access codes for different purposes. Very few are known.
    Dec 2019
    India
    I have upgraded the gearbox from DQ200 7speed to DQ250 6speed, need to change the long coding in the engine ECM .
    Long coding bit 02 from 00 to 1D- that selects 6 speed transmission.
    Regards,
    Tutu.
    Quote Originally Posted by Tutu22 View Post
    Check parts catalog for your specific ECU software part number. Was it ever sold with a DQ250 6 speed transmission? Because if not, chances are it doesn't support that transmission, and the the fact that there's a coding configuration for such a transmission is not relevant.
  5. Likes PetrolDave liked this post
    Dec 2019
    India
    Hi Uwe,
    Got the Security Access - 27971
    Regards,
    Tutu.
    You probably mean, Byte 1, change coding from 25 to 1D.
    And that is accepted ?
    And if should be, you can now change the above coding ?
    I have not seen any Polo with this engine, use 6-speed DSG.
  8. Likes Uwe liked this post
    Dec 2019
    India
    You probably mean, Byte 1, change coding from 25 to 1D.th
    Yes u are correct, this engine can for india only I think.
    Regards,
    Tutu.
