Results 1 to 5 of 5
Thread: A1 GB 2019 Lane Assisst
    Dec 2019
    The LA can be switched off an on again by the small switch on the tip of the direction indicator switch. If on, it activates at ~65 km/h. However, on every new start of the ignition/engine, it is in state on again, activating at ~65 km/h. Is it possible to code it such that it is per default off after ignition or even remembers the last state of before turing the engine off?
    I had no success with Unit A5 (camera) -> entering access priviledge -> function 10
    -> channel "On-position of LA" (maybe worse translation of German "Einschaltzustand Suprhalteassistent") -> adjustment "menu"
    or
    -> channel "personalizing intervention momemt with terminal 15" ("Personalisierung Eingriffszeitpunkt bei Kl.15") ->
    adjustment "last known"
    Both are already stored default values, where LA is turned on automatically after ignition on and I find no respective setting within the car menu.
    My anonymized autoscan (in German) is:
    VCDS Version: AIB 19.6.1.0  HEX-NET xx: 0.xxxx.x
    Datenstand: 20190806 DS308.0
    www.vcds.de
    Fahrzeug-Ident.-Nr.: XXXXXXXXXXXXXX   KFZ-Kennzeichen:
    Kilometerstand: 830km   Reparaturauftrag:
    Fahrzeugtyp: GB-AU27 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75 A5
    Fahrzeug-Ident.-Nr.: xxxxxxxxxxxxx   Kilometerstand: 830km
    01-Motorelektronik -- Status: i.O. 0000
    02-Getriebe -- Status: i.O. 0000
    03-Bremsenelektronik -- Status: i.O. 0000
    08-Klima-/Heizungsel. -- Status: i.O. 0000
    09-Zentralelektrik -- Status: i.O. 0000
    10-Einparkhilfe 2 -- Status: i.O. 0000
    13-Distanzregelung -- Status: i.O. 0000
    15-Airbag -- Status: i.O. 0000
    17-Schalttafeleinsatz -- Status: i.O. 0000
    19-Diagnoseinterface -- Status: i.O. 0000
    42-Türelektr. Fahrer -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    52-Türelektr. Beifahr. -- Status: i.O. 0000
    5F-Informationselek. I -- Status: i.O. 0000
    75-Telematik -- Status: i.O. 0000
    A5-Front-/Vorfeldkamera -- Status: i.O. 0000
    Adresse 01: Motorelektronik (J623-DADA)       Labeldatei: Keine
       Teilenummer SW: 05E 906 018 AB    HW: 05E 907 309
       Bauteil: R4 1.5l TFS   H22 6086
       Revision: 81H22000
       Codierung: 0225003223041D0800000000000000000000000000000000
       Betriebsnr.: WSC 00049 770 00163
       ASAM Datensatz: EV_ECM15TFS01105E906018AB 003002
       ROD: EV_ECM15TFS011_AU27.rod
       VCID: E5823838E45F7B678A-80B0
    Adresse 02: Getriebe (J743)       Labeldatei: DRV\0CW-927-769.clb
       Teilenummer SW: 0CW 300 043 D    HW: 0AM 927 769 E
       Bauteil: GSG DQ200G2_M H05 1605
       Revision: 00005008    Seriennummer:
       Codierung: 0014
       ASAM Datensatz: EV_TCMDQ200021 001001
       ROD: EV_TCMDQ200021_VW27.rod
       VCID: B83CA14C036D368FE1-80EC
    Adresse 03: Bremsenelektronik (J104)       Labeldatei: Keine
       Teilenummer SW: 2Q0 614 517 AG    HW: 2Q0 614 517 N
       Bauteil: ESC_base_vFGS H23 0242
       Seriennummer:
       Codierung: 42094D4F354742AFB200AC1A37E123A649125126336A24582454285445ECC46592488A64CC56241A242A142AA24DD2423DB24B42BC
       ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 004036
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: F3A656605A8B95D714-80A6
    Adresse 08: Klima-/Heizungsel. (E87)       Labeldatei:* Keine
       Teilenummer SW: 83A 820 047 A    HW: 83A 820 047 A
       Bauteil: AC Manuell el H04 0020
       Revision: 20026000    Seriennummer:
       Codierung: 230000040000000010000000000000000000000000000000
       ASAM Datensatz: EV_AirCondiFrontManAU326 001003
       ROD: EV_AirCondiFrontManAU326_AU27.rod
       VCID: A2086324B5F14C5F2F-80F6
    Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\5Q0-937-08X-V2.clb
       Teilenummer SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
       Bauteil: BCM MQBAB M+  H38 0273
       Seriennummer:
       Codierung: 000000000000000000000000000000000000000000000000000000000000
       ASAM Datensatz: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_AU27.rod
       VCID: FCB47D5C77D5DAAF45-80A8
       Sensor für Regen- und Lichterkennung:
       Subsystem 1 - Teilenummer SW: 81A 955 559 A    HW: 81A 955 559
       Bauteil: G397_RLS  H06 0002
       Seriennummer:
       Codierung: 80004D
       Lichtschalter:
       Subsystem 2 - Teilenummer SW: 4K1 941 501 D    HW: 4K1 941 501 D
       Bauteil: E1 - LTM  H05 0053
       Seriennummer:
       Lenkstockschalter:
       Subsystem 3 - Teilenummer SW: 82A 953 521 DR    HW: 5Q1 953 549
       Bauteil: J527 SMLS MQB  004 0070
       Seriennummer:
    Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\5Q0-919-294.clb
       Teilenummer SW: 5QA 919 294 C    HW: 5QA 919 294
       Bauteil: PDC 8 KanalH07 0050
       Seriennummer:
       Codierung: 0471051011
       ASAM Datensatz: EV_EPHVA18AU3700000 009039
       ROD: EV_EPHVA18AU3700000_009_VW27.rod
       VCID: CCD4ED9C67F5AA2FB5-8098
    Adresse 13: Distanzregelung (J428)       Labeldatei:| 2Q0-907-572.clb
       Teilenummer SW: 2Q0 907 572 Q    HW: 5Q3 907 572
       Bauteil: ACCCONTIMQB   H03 0342
       Codierung: 3200000208F78728747C61450050A700000000000000000000
       ASAM Datensatz: EV_ACCMRRCONTIVW376 003015
       ROD: EV_ACCMRRCONTIVW376_AU27.rod
       VCID: C2C8C3A455B16C5F4F-8096
    Adresse 15: Airbag (J234)       Labeldatei:* Keine
       Teilenummer SW: 2Q0 959 655 AM    HW: 2Q0 959 655 AM
       Bauteil: VW22Airbag    010 0351
       Revision: --------
       Codierung: 88CCC0C0000000005C5400DF000840A80065
       Betriebsnr.: WSC 00049 770 00119
       ASAM Datensatz: EV_AirbaVW22BPAVW27X 001020
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 885C118C330D860F51-80DC
       Crashsensor für Seitenairbag Fahrerseite:
       Subsystem 1 - Teilenummer SW: -----------    HW: 442 062 005 19
       Bauteil: SideSensor_Df  1E2 0887
       Seriennummer:
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag Beifahrerseite:
       Subsystem 2 - Teilenummer SW: -----------    HW: 442 062 005 19
       Bauteil: SideSensor_Pf  1E2 0887
       Seriennummer:
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Fahrerseite:
       Subsystem 3 - Teilenummer SW: -----------    HW: 442 0B1 105 19
       Bauteil: SideSensor_Dr  1C7 0148
       Seriennummer:
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Beifahrerseite:
       Subsystem 4 - Teilenummer SW: -----------    HW: 442 0B1 205 19
       Bauteil: SideSensor_Pr  1C7 0148
       Seriennummer:
       Codierung: 2D2D2D
       Crashsensor für Frontairbag Fahrerseite:
       Subsystem 5 - Teilenummer SW: -----------    HW: 442 133 003 19
       Bauteil: FrontSensor_D  290 118A
       Seriennummer:
       Codierung: 2D2D2D
    Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:* Keine-SRI3
       Teilenummer SW: 82A 920 700     HW: 82A 920 700
       Bauteil: KOMBI         H13 1712
       Codierung: 00840008618000080080A0001000000000000000
       ASAM Datensatz: EV_DashBoardVDDMQBA0 001027
       ROD: EV_DashBoardVDDMQBA0_AU27.rod
       VCID: DDF210D8CC0F33A752-8088
    Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
       Teilenummer SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Bauteil: GW MQB High   521 5366
       Seriennummer:
       Codierung: 030100F42F0857005B000248180B00000000000000000000000000000000
       ASAM Datensatz: EV_GatewNF 013025
       ROD: EV_GatewNF.rod
       VCID: EE90471431A9B83FFB-80BA
       Generator:
       Bauteil: 0-00-02-00-04
       Steuergerät für Multifunktionslenkrad:
       Subsystem 2 - Teilenummer SW: 83A 951 523     HW: 83A 951 523
       Bauteil: J453 MFL  H05 0004
       Seriennummer:
       Steuergerät für Batterieüberwachung:
       Subsystem 3 - Teilenummer SW: 2Q0 915 181     HW: 2Q0 915 181
       Bauteil: J367-BDMBOSCH  H02 2011
       Seriennummer:
    Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:| 5QX-959-X93-42.clb
       Teilenummer SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
       Bauteil: TSG FS        006 0246
       Seriennummer:
       Codierung: 00100320E100020000001000
       ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
       ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
       VCID: C6C0DFB47999507F63-8092
       Türsteuergerät Fahrerseite hinten:
       Subsystem 1 - Teilenummer SW: 5Q0 959 407     HW: 5Q0 959 163
       Bauteil: FOND_FHSG_DRV  007 0010
       Seriennummer:
       Codierung: 310000
    Adresse 44: Lenkhilfe (J792)       Labeldatei:* Keine
       Teilenummer SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
       Bauteil: TRW_G4L_MQBA0 611 6041
       Seriennummer:
       Codierung: 010000000100000001010201010001010000010101
       ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
       ROD: EV_SteerAssisTRWG4LMQBA0.rod
       VCID: BC34BD5C37551AAF05-80E8
    Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:| 5QX-959-X92-52.clb
       Teilenummer SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
       Bauteil: TSG BFS       006 0246
       Seriennummer:
       Codierung: 00100120E100020000001000
       ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
       ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
       VCID: C5C2D8B8449F5B676A-8090
       Türsteuergerät Beifahrerseite hinten:
       Subsystem 1 - Teilenummer SW: 5Q0 959 408     HW: 5Q0 959 164
       Bauteil: FOND_FHSG_PSG  007 0010
       Seriennummer:
       Codierung: 290000
    Adresse 5F: Informationselek. I (J794)       Labeldatei:* Keine
       Teilenummer SW: 83A 035 842     HW: 83A 035 842
       Bauteil: MU-S-D-ER     742 0051
       Seriennummer:
       Codierung: 01720000BE00000041111101C00800002F0007E40170000002
       ASAM Datensatz: EV_MUStdGen2pDELP 001001
       ROD: EV_MUStdGen2pDELP.rod
       VCID: E2882324F5710C5F6F-80B6
       Anzeigeeinheit 1 für Multimediasystem:
       Subsystem 1 - Teilenummer SW: 82A 919 604 A    HW: 82A 919 604 A
       Bauteil: DU AU270 Std  H42 0133
       Seriennummer:
       Lautstärkeregler 1:
       Subsystem 2 - Teilenummer SW: 82A 919 616     HW: 82A 919 616
       Bauteil: LSR-D5/C8  H33 0108
       Seriennummer:
    Adresse 75: Telematik (J949)       Labeldatei:| 5QE-035-285.clb
       Teilenummer SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Bauteil: OCULowMQBLGE  H19 0825
       Revision: --------
       Codierung: 01720601EA370A0F05109C0000354003804651
       ASAM Datensatz: EV_OCULowMQBLGE 004049
       ROD: EV_OCULowMQBLGE_004_VW27.rod
       VCID: BD32B0582C4F13A732-80E8
    Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
       Teilenummer SW: 3Q0 980 654 M    HW: 3Q0 980 654 A
       Bauteil: MQB_B_MFK     H09 0451
       Seriennummer:
       Codierung: 0402070000000401002200448146440084000E00000000
       ASAM Datensatz: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB_VW12.rod
       VCID: C1CACCA850B7774756-8094
    Thank you,
    Chris
    Feb 2018
    As Iam right here's actually no known solution. @hadez16 or is there anything NEW?
    Dec 2016
    DE
    You need to change the A5 module's coding: Byte 14 Bit 2-3 to "08 (Perso_HC,Last_setting)"
    Disclaimer: I am not sure, if this works with the Audi A1.
  4. Likes Uwe, chb liked this post
    Dec 2019
    @TBAx Thanks, works like a charm on my A1. You are the best.
  6. Likes Uwe liked this post
    Jun 2017
    This coding applies to all bothering new MY19 cars on MQB or MQB-A0 Platform where Lane Assist is on by ignition.
    MLBevo cars (Touareg 3, A6 4K, ...) have an adaptation channel in unit A5 instead of coding to change the ignition behaviour.
  8. Likes Uwe liked this post
