Hello everyone, first post here, and first week ever using VCDS. This is my second TDI as my other car is a 99.5 Jetta and I never dealt with any of this stuff with it. My new car is stock besides deleted and tuned. Have only been deleted and tuned around 1000 miles. The car runs great and great mileage, just got 700 miles on my first full tank after delete/tune. My tuner gave me some things to try like doing the SRI Reset a few times but I am still having my issue. I drove the car on a long trip, on the way home, I drove the car for around 4 hours straight then near the end of the drive the DPF light came on. No DTC's. At the time the DPF pressure sensors were plugged up because on a previous tune they were throwing DTC's when unplugged. The first thing I tried was unplugging the pressure sensors because my latest tune should have fixed the pressure sensor DTC's but the DPF light stayed on. At this point, I was driving the car with pressure sensors unplugged, DPF light still on. Then, as I was driving, probably 50 miles after the DPF light originally came on, code P2463 was thrown, then the car went into limp mode, luckily I had my laptop and cord with me. With the help of a very nice gentleman at Ross-Tech I was able to reset the DPF to make everything think that a 'new' DPF was installed. This cleared up my DTC and took me out of limp mode but the DPF light still was on as I drove home. The only other thing I knew to try and do was plug the DPF pressure sensors back up and go back through the process of resetting the DPF in VCDS. I have since drove the car after doing this and the DPF light is still on. Measuring Blocks channel 240 showed all 0's after I did my last DPF reset so the computer thinks a regen had just occurred. Now after driving the car roughly 50 miles since my last DPF reset with my pressure sensors plugged up, Measuring Blocks channel 241 shows 0 ml for oil ash volume, 2.7 g soot calculated, 0 g soot measured. I am basically wondering if there is anything else I can do in VCDS to shut off the DPF light? What all different channels throughout the ECU can actually make this DPF light come on? I appreciate any help out. Below is my Auto Scan. Thanks, Ryan.
Wednesday,11,December,2019,17:59:01:59786
VIN: 3VW3L7AJ6EM298639 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
VIN: 3VW3L7AJ6EM298639 Mileage: 51280km-31863miles
01-Engine -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
2E-Media Player 3 -- Status: Sporadic communication error 1000
37-Navigation -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0011
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 N HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H16--- Serial number:
Coding: 0050072
Shop #: WSC 74291 008 00000
VCID: 392F2A6505570A6FCE9-806C
Readiness: 0 0 0 X 1
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492B0002851102E792220042A1100012
Shop #: WSC 36314 001 1048576
VCID: 04518B913E158787EDF-8050
Reset counter: 124
Count: 2
Count: 20480
Count: 8208
Count: 43008
Count: 256
03391 - Coding Not Possible
Reset counter: 124
Count: 2
Count: 20480
Count: 8254
Count: 43520
Count: 256
Reset counter: 124
Count: 2
Count: 20480
Count: 8211
Count: 43520
Count: 256
Reset counter: 125
Mileage: 49127 km
Date: 2019.11.29
Time: 21:19:05
Count: 2
Count: 2
Count: 4096
Count: 8194
Count: 45568
Count: 256
Reset counter: 126
Mileage: 49127 km
Date: 2019.11.29
Time: 00:09:31
Count: 2
Count: 2
Count: 20480
Count: 16390
Count: 45056
Count: 256
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BL HW: 5C0 820 047 BL
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000002142014
Shop #: WSC 00066 000 00000
VCID: 6B83C02D3F8B68FF0C5-803E
Reset counter: 125
Mileage: 49127 km
Date: 2019.11.29
Time: 21:19:05
Reset counter: 124
Mileage: 49685 km
Date: 2019.12.03
Time: 00:57:37
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 086 L HW: 5C0 937 086 A
Component: BCM25 JLB M3 H34 0425
Revision: B0034001 Serial number: 06013125140398
Coding: 7B994B1808AB0B0000302000240884C40082502E60000000300010002000
Shop #: WSC 08571 003 1048576
VCID: 35372655254FEE0F2A1-8060
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14202585140328161659
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140407082653
Coding: 820000
Subsystem 3 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587140402144030
Coding: 800000
Subsystem 4 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586140407154919
Coding: 800000
03435 - Terminal 30 for Interior Light and Parking Light
Fault Status: 00101011
Reset counter: 124
Mileage: 49685 km
Date: 2019.12.03
Time: 00:43:06
00532 - Supply Voltage B+
Reset counter: 124
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD049J9O
Coding: 00004138
Shop #: WSC 00066 790 00013
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74B1DB516E35B707DDF-8020
Serial number: 6940000Y1400014L1K0J
Coding: 303039
Serial number: 3572MSME47117E43ZZZY
Serial number: 3582MSME570F7E43ZZZ6
Serial number: 3516KSME5C64482CZZZ%
Serial number: 3526KSME1942482CZZZW
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME510D0A2CZZZ.
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME510A0A2CZZZZ
Part No SW: 5C6 920 953 A HW: 5C6 920 953 A
Component: KOMBI H04 0809
Coding: 270A01
VCID: 2B03002DF38BA8FF4C5-807E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 086 A
Component: GW-K-CAN TP20 H34 0425
Revision: B0034001
Coding: 102200
VCID: 70B9D7411AAD8B27397-8024
Reset counter: 125
Mileage: 49127 km
Date: 2019.11.29
Time: 21:19:06
Reset counter: 124
01304 - Radio
Reset counter: 125
Mileage: 49685 km
Date: 2019.12.03
Time: 00:00:03
Reset counter: 124
02078 - Media Player Position 3 (R120)
Reset counter: 125
Mileage: 49685 km
Date: 2019.12.03
Time: 00:00:03
Component: IMMO H04 0809
VCID: 6A8DC5293CF171F7773-803E
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7665927860
Coding: 010100
VCID: 2B03002DF30BA8FF4C5-807E
Part No SW: 3C0 035 684 J HW: 3C8 035 684 E
Component: RNS-MID H61 4366
Revision: AB001001 Serial number: VWZ6Z7M9044008
Coding: 04000440040000A40000
Shop #: WSC 01234 444 00007
VCID: 2A0D0529FCF1B1F7B73-807E
Component: NAR V12 8534
00877 - Treble Speaker Rear Right (R16)
Reset counter: 145
Mileage: 49696 km
00876 - Treble Speaker Rear Left (R14)
Reset counter: 145
Mileage: 49696 km
Reset counter: 231
Reset counter: 149
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
Reset counter: 125
Mileage: 49700 km
Date: 2019.12.03
Time: 22:00:18
Voltage: 13.13 V
DU
Temperature: 19.0°C
RPM: 1498 /min
Reset counter: 124
Voltage: 12.00 V
DD
Temperature: 17.0°C
Reset counter: 145
Mileage: 49696 km
Reset counter: 145
Mileage: 49696 km
Reset counter: 231
Reset counter: 149
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663611823
Coding: 0A10040000010110
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2D35690CD10177C73-806E
9455635 - Telephone Microphone
B1048 13 [008] - Open Circuit
Reset counter: 125
End----------(Elapsed Time: 01:16, VBatt start/end: 12.5V/12.4V)-----------
