Results 1 to 7 of 7
Thread: 2014 Jetta TDI, DPF Light On, Yet Car is Deleted
Hybrid View
    Dec 2019
    Hello everyone, first post here, and first week ever using VCDS. This is my second TDI as my other car is a 99.5 Jetta and I never dealt with any of this stuff with it. My new car is stock besides deleted and tuned. Have only been deleted and tuned around 1000 miles. The car runs great and great mileage, just got 700 miles on my first full tank after delete/tune. My tuner gave me some things to try like doing the SRI Reset a few times but I am still having my issue. I drove the car on a long trip, on the way home, I drove the car for around 4 hours straight then near the end of the drive the DPF light came on. No DTC's. At the time the DPF pressure sensors were plugged up because on a previous tune they were throwing DTC's when unplugged. The first thing I tried was unplugging the pressure sensors because my latest tune should have fixed the pressure sensor DTC's but the DPF light stayed on. At this point, I was driving the car with pressure sensors unplugged, DPF light still on. Then, as I was driving, probably 50 miles after the DPF light originally came on, code P2463 was thrown, then the car went into limp mode, luckily I had my laptop and cord with me. With the help of a very nice gentleman at Ross-Tech I was able to reset the DPF to make everything think that a 'new' DPF was installed. This cleared up my DTC and took me out of limp mode but the DPF light still was on as I drove home. The only other thing I knew to try and do was plug the DPF pressure sensors back up and go back through the process of resetting the DPF in VCDS. I have since drove the car after doing this and the DPF light is still on. Measuring Blocks channel 240 showed all 0's after I did my last DPF reset so the computer thinks a regen had just occurred. Now after driving the car roughly 50 miles since my last DPF reset with my pressure sensors plugged up, Measuring Blocks channel 241 shows 0 ml for oil ash volume, 2.7 g soot calculated, 0 g soot measured. I am basically wondering if there is anything else I can do in VCDS to shut off the DPF light? What all different channels throughout the ECU can actually make this DPF light come on? I appreciate any help out. Below is my Auto Scan. Thanks, Ryan.
    Wednesday,11,December,2019,17:59:01:59786
    VIN: 3VW3L7AJ6EM298639   License Plate:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
    VIN: 3VW3L7AJ6EM298639   Mileage: 51280km-31863miles
    01-Engine -- Status: Sporadic communication error 1000
    17-Instruments -- Status: Sporadic communication error 1000
    2E-Media Player 3 -- Status: Sporadic communication error 1000
    37-Navigation -- Status: Not registered 0011
    77-Telephone -- Status: Not registered 0011
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 N    HW: 03L 907 309 AA
       Component: R4 2.0l TDI G000SG  9983
       Revision: 12H16---    Serial number:
       Coding: 0050072
       Shop #: WSC 74291 008 00000
       VCID: 392F2A6505570A6FCE9-806C
    Readiness: 0 0 0 X 1
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Component: ESP MK60EC1   H46 0166
       Revision: 00H46001
       Coding: A14B400C492B0002851102E792220042A1100012
       Shop #: WSC 36314 001 1048576
       VCID: 04518B913E158787EDF-8050
                        Reset counter: 124
                        Count: 2
                        Count: 20480
                        Count: 8208
                        Count: 43008
                        Count: 256
    03391 - Coding Not Possible
                        Reset counter: 124
                        Count: 2
                        Count: 20480
                        Count: 8254
                        Count: 43520
                        Count: 256
                        Reset counter: 124
                        Count: 2
                        Count: 20480
                        Count: 8211
                        Count: 43520
                        Count: 256
                        Reset counter: 125
                        Mileage: 49127 km
                        Date: 2019.11.29
                        Time: 21:19:05
                        Count: 2
                        Count: 2
                        Count: 4096
                        Count: 8194
                        Count: 45568
                        Count: 256
                        Reset counter: 126
                        Mileage: 49127 km
                        Date: 2019.11.29
                        Time: 00:09:31
                        Count: 2
                        Count: 2
                        Count: 20480
                        Count: 16390
                        Count: 45056
                        Count: 256
    Address 08: Auto HVAC        Labels: 5C0-820-047.clb
       Part No SW: 5C0 820 047 BL    HW: 5C0 820 047 BL
       Component: J301  Klimaanlage   0204
       Revision: 2001001S    Serial number: 00000002142014
       Shop #: WSC 00066 000 00000
       VCID: 6B83C02D3F8B68FF0C5-803E
                        Reset counter: 125
                        Mileage: 49127 km
                        Date: 2019.11.29
                        Time: 21:19:05
                        Reset counter: 124
                        Mileage: 49685 km
                        Date: 2019.12.03
                        Time: 00:57:37
       Part No SW: 5C0 937 086 L    HW: 5C0 937 086 A
       Component: BCM25 JLB M3  H34 0425
       Revision: B0034001    Serial number: 06013125140398
       Coding: 7B994B1808AB0B0000302000240884C40082502E60000000300010002000
       Shop #: WSC 08571 003 1048576
       VCID: 35372655254FEE0F2A1-8060
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  006 5461
       Serial number: 14202585140328161659
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  006 5461
       Serial number: 14102584140407082653
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Component: J388__TSG_HL  006 5460
       Serial number: 14102587140402144030
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Component: J389__TSG_HR  006 5460
       Serial number: 14102586140407154919
       Coding: 800000
    03435 - Terminal 30 for Interior Light and Parking Light
                        Fault Status: 00101011
                        Reset counter: 124
                        Mileage: 49685 km
                        Date: 2019.12.03
                        Time: 00:43:06
    00532 - Supply Voltage B+
                        Reset counter: 124
       Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
       Component: AirbagVW10    102 0912
       Serial number: 003MVD049J9O
       Coding: 00004138
       Shop #: WSC 00066 790 00013
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 74B1DB516E35B707DDF-8020
       Serial number: 6940000Y1400014L1K0J
       Coding: 303039
       Serial number: 3572MSME47117E43ZZZY
       Serial number: 3582MSME570F7E43ZZZ6
       Serial number: 3516KSME5C64482CZZZ%
       Serial number: 3526KSME1942482CZZZW
       Serial number: 3556LSME510D0A2CZZZ.
       Serial number: 3566LSME510A0A2CZZZZ
       Part No SW: 5C6 920 953 A    HW: 5C6 920 953 A
       Component: KOMBI         H04 0809
       Coding: 270A01
       VCID: 2B03002DF38BA8FF4C5-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 086 A
       Component: GW-K-CAN TP20 H34 0425
       Revision: B0034001
       Coding: 102200
       VCID: 70B9D7411AAD8B27397-8024
                        Reset counter: 125
                        Mileage: 49127 km
                        Date: 2019.11.29
                        Time: 21:19:06
                        Reset counter: 124
    01304 - Radio
                        Reset counter: 125
                        Mileage: 49685 km
                        Date: 2019.12.03
                        Time: 00:00:03
                        Reset counter: 124
    02078 - Media Player Position 3 (R120)
                        Reset counter: 125
                        Mileage: 49685 km
                        Date: 2019.12.03
                        Time: 00:00:03
       Component: IMMO          H04 0809
       VCID: 6A8DC5293CF171F7773-803E
       Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Revision: A1001003    Serial number: 7665927860
       Coding: 010100
       VCID: 2B03002DF30BA8FF4C5-807E
       Part No SW: 3C0 035 684 J    HW: 3C8 035 684 E
       Component: RNS-MID       H61 4366
       Revision: AB001001    Serial number: VWZ6Z7M9044008
       Coding: 04000440040000A40000
       Shop #: WSC 01234 444 00007
       VCID: 2A0D0529FCF1B1F7B73-807E
       Component: NAR V12  8534
    00877 - Treble Speaker Rear Right (R16)
                        Reset counter: 145
                        Mileage: 49696 km
    00876 - Treble Speaker Rear Left (R14)
                        Reset counter: 145
                        Mileage: 49696 km
                        Reset counter: 231
                        Reset counter: 149
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 70     3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
                        Reset counter: 125
                        Mileage: 49700 km
                        Date: 2019.12.03
                        Time: 22:00:18
                        Voltage: 13.13 V
                            DU
                        Temperature: 19.0C
                        RPM: 1498 /min
                        Reset counter: 124
                        Voltage: 12.00 V
                            DD
                        Temperature: 17.0C
                        Reset counter: 145
                        Mileage: 49696 km
                        Reset counter: 145
                        Mileage: 49696 km
                        Reset counter: 231
                        Reset counter: 149
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007663611823
       Coding: 0A10040000010110
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A2D35690CD10177C73-806E
    9455635 - Telephone Microphone
              B1048 13 [008] - Open Circuit
                        Reset counter: 125
    End----------(Elapsed Time: 01:16, VBatt start/end: 12.5V/12.4V)-----------
    With Tuna software and deletes, there's really no telling what's going on in your ECU.
    Dec 2019
    There's gotta be something else to check besides the readouts from measuring block 241 and possibly something else to 'reset' that is DPF related.
    Jan 2015
    Bosnia and Herzegovina
    there is nothing vcds can do in your situation, DPF, EGR tune is bad since it's trowing dtc's
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  6. Likes Uwe liked this post
    Dec 2019
    Just because it deleted and tuned doesn't mean vcds could possibly be used in this situation. The car had a DPF on there and there were still old stored oil ash volume, soot calculated & soot measured values in there that had to be reset using vcds which cleared up the DTC. Now there is still another DPF related value in there somewhere that is throwing the DPF light. Something besides oil ash volume, soot calculated & soot measured. Whatever this may be could be a value stored in there from when the DPF used to be on the car that needs to be reset.
    Quote Originally Posted by shumie7 View Post
    That's may well be true, but how are we supposed to know what it is since the tuna software in your ECU is refusing to report a DTC?
  9. Likes PetrolDave liked this post
  10. #7
    Jan 2015
    car had a DPF on there and there were still old stored oil ash volume, soot calculated & soot measured values in there that had to be reset...
    When done correctly this is done automatically via map or ecu tool, only when it's shady you need to reset these values, hence there is nothing vcds can do, check tuning file because if it were ok it couldn't report DPF....
    GOOD CHEAP FAST
  11. Likes NZDubNurd, PetrolDave liked this post
