DrWife's new ride:
EDIT - Car now has +23000 miles on it, fresh maps starting at post #4
Engine map (KOEO, cold)
03:
05:
08:
09:
10:
13:
15:
17:
19:
22:
29:
2B:
39:
3C:
42:
44:
47:
4B:
52:
5F:
75:
A5:
CA:
D6:
D7:
OBDII (KOEN, cold):
Tuesday,10,December,2019,22:05:03:14741
VCDS Version: 19.10.0.0 (x64) HEX-NET CB: 0.4517.4
Data version: 20190930 DS316.0
VIN: 3VWM17AU9KM522339 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B 52
5F 75 A5 CA D6 D7
VIN: 3VWM17AU9KM522339 Mileage: 373km-231miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311900322446002F1000
Shop #: WSC 00066 790 00072
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: C6DEBD52A824F46113A7-8092
Part No SW: 5Q0 614 517 DR HW: 5Q0 614 517 BM
Component: ESC H45 0108
Revision: 00000000 Serial number: 52569000000942
Coding: 43FA6AA13022096E407A0303A0CC29C2560C9002C005943434435050F0A94B0B0040010312121212B435351919323200
Shop #: WSC 00066 790 00154
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 845A675ADE9806714D33-80D0
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0526054532
Coding: 132C0C0623
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: C5DCBA5E9522FF791AAD-8090
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 02020024200118000104000012111008
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: C8C2B36AA230E211E1CB-809C
Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C86415101903S6
Shop #: WSC 00066 790 00248
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019.rod
VCID: FBA81CA6A36679893CC9-80AE
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190804 043 0551
Serial number: 97022066190820114317
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S4Y19M07D24H20M03S21
Coding: 0008DD
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300231020190C201278
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000145451R18219
Coding: 0271167801
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: D1F49E0E516A23D9B635-8084
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2D0000C141FFC728949C810510401600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
VCID: C4DAA75A9E18C6710DB3-8090
Component: AirbagVW20 010 0830
Serial number: 003GCR0CKL8X
VCID: C7C0B056AF2EED69E8D1-8092
Occupant Detection:
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000C7O3EK
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 003 008 19
Serial number: 3570000000005D258F3N
Subsystem 3 - Part No SW: ----------- HW: 480 003 008 19
Serial number: 3580000000017918DF3U
Subsystem 4 - Part No SW: ----------- HW: 480 402 208 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B4F11238600FX
Subsystem 5 - Part No SW: ----------- HW: 480 402 108 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001B6F240022D43U
Subsystem 6 - Part No SW: ----------- HW: 480 402 409 19
Component: FrontSensor_D 005 6149
Serial number: 35500019CF2926C452DJ
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 409 19
Component: FrontSensor_P 005 6149
Serial number: 35600019CF2926C4D3BR
Part No SW: 5G1 920 840 D HW: 5G1 920 840 D
Component: KOMBI 252 2700
Coding: 0BA41015ED88CF0502886A0B5001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: A80213EA02700211018B-80FC
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 02101900841263
Coding: 0901000830085900FB00221A0A0F00000001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: EE8E25F2E0141C218B57-80BA
Component: 0-00-0d-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MDM H18 0052
Serial number: 33190001486540061439
Coding: 2CFFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: U13DCAC H27 0810
Serial number: 8004977
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00029.07.19
Coding: 0001
VCID: CCCA8F7AB6480E31C5E3-8098
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000228335011
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: B134FE8E31AA43D9D6F5-80E4
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0526884072
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: BD2CD2BEFDF2B7B9427D-80E8
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0529012329
Coding: 020111
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038927100802
Coding: 003A13200000040000000000
Shop #: WSC 01383 790 50316
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: CFF09876475E3529A001-809A
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000004352670
Coding: 011000
Part No SW: 5QM 909 144 C HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1082
Coding: 930A0000
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD0611XN
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: AE0EE5F220945C21CBD7-80FA
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 06101900840478
Coding: 000000050900211200110F01030000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: B53CCA9EC5C26FF98A0D-80E0
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46038926000574
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: CECE857240543C21AB17-809A
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000004317836
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Coding: 027312020000000041220002001808009F0508F401200505C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: B338F486CBB671C9A419-80E6
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 254 8130
Serial number: VWZ6ZMW2995930
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: C3D8A4469B16C14934B9-8096
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 18071915K24566
Coding: 000307020002020100221354C150490084000E20012000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: C0D2AB4A8A00DA51299B-8094
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804073720C
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: F5BC0A9E85422FF94A8D-80A0
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: B924C6AEE9DA8B996E25-80EC
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:48, VBatt start/end: 12.3V/12.3V)-----------
;SW:8V0-906-264-M HW:06K-907-425-B --- Engine
;Component:1.8l R4 TFSI H13 0001, Coding:311900322446002F1000
;EV_ECM18TFS0208V0906264M,001003,EV_ECM18TFS0208V0906264M.rod
;Tuesday,10,December,2019,21:33:32:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: C6DEBD52A824F46113A7-8092
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VWM17AU9KM522339,
IDE00018,Voltage terminal 15,12.129, V
IDE00019,Voltage terminal 30,12.441, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,29, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),15.3, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,15, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,42.0, °C
IDE00148,Median injection timing,0.0, ms
IDE00149,Ignition angle of current cylinder: actual value,-0.37, °
IDE00150,Pressure in brake booster,1.150, bar
IDE00151,Oil fill level,87, mm
IDE00155,Timing angle retardation cylinder 1,0.00, °
IDE00156,Timing angle retardation cylinder 2,0.00, °
IDE00157,Timing angle retardation cylinder 3,0.00, °
IDE00158,Timing angle retardation cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,11.2, °C
IDE00172,A/C compressor torque,0.00, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,0.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,0.0, °
IDE00178,Camshaft adjustment intake bank 1: specified value,0.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,0.0, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.0, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,47.6, °
IDE00186,Fuel low pressure: actual value,11.003, bar
IDE00187,Coolant temperature at engine start,31.5, °C
IDE00188,Fuel high pressure: actual value,4.9, bar
IDE00189,Activation of fuel pump electronics,10.00, %
IDE00190,Charge air pressure specified value,0.984, bar
IDE00191,Charge air pressure: actual value,0.984, bar
IDE00192,Coolant temperature at radiator outlet: actual value,17.3, °C
IDE00193,Coolant temperature at engine outlet: specified value,29.2, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,11.2, °C
IDE00196,Engine oil temperature,45.0, °C
IDE00199,Mean engine air mass,0, kg/h
IDE00200,Median vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,122.8, bar
IDE00202,Low fuel pressure: specified value,5.010, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,33, l
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,28, °C
IDE00349,Throttle valve position: normed,5, %
IDE00350,Air mass: specified value,0, kg/h
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,31.5, °C
IDE00358,Limitation: torque,290.0, Nm
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.03, %
IDE00380,Coolant fan 1: activation,10.16, %
IDE00381,Coolant fan 2: activation,0.00, %
IDE00392,Accelerator pedal: sensor voltage 1,0.762, V
IDE00393,Accelerator pedal: sensor voltage 2,0.386, V
IDE00396,Charge Pressure Actuator: acknowledgment,2.397, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,0.00, %
IDE00405,Crankshaft speed (RPM),0, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Control operation,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,01,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 acknowledgment,01,
IDE00417,Starter control: shut-off conditions 1,02 00,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,---,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,35, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00476,Fuel Metering Valve,0.00, %
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00478,Engine-drag torque,22.7, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,45.0, °C
IDE00496,Activation of oil pressure switch valve,High pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,Open,
IDE00556,Outside air temperature,12, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.000 Lambda / -128.000 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,1.275, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,5, %
IDE00584,Distance driven since erasing DTC memory,359, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,61.2, %
IDE00589,Fuel pressure,400, kPa rel
IDE00592,Oxygen sensor control status,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,-0.5, Degrees
IDE00594,Absolute intake pressure,98, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,9,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00727,Test steps still to be performed,0,
IDE00787,Cause for cancellation,0,
IDE00949-ENG98517,Hide cylinder-Cylinder 1,active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,5, H
IDE01076-MAS00110,Time since ignition off-Minutes,9, min
IDE01076-MAS00111,Time since ignition off-Seconds,12, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01377,Throttle valve adapter: actual value,6.0, °
IDE01378,High fuel pressure: control deviation,117.8, bar
IDE01385,Wear index,0.00000000,
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,After starter activation,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.557, V
IDE01649,Throttle valve position 1,0.786, V
IDE01650,Throttle valve position 2,16, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,not pressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mech. test of starter not complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation not complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line not completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection not complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch not complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch not complete,
IDE01677,Result of O2 sensor test ready bank 1 after cat. conv.,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,not active,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 not OK,
IDE01873,Test of catalytic converter: measured value,0.164,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,11.57, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.78, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.78, %
IDE01901,Lost torque adaptation: idle,-2.3, Nm
IDE01905,Average of ignition timing angle delay adjustment,0.00, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,-0.37, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,373, km
IDE01923,Control module distance driven,376, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of load shift flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,0.0, °
IDE01929,Open cam shaft angle at quantity control valve,0.0, °
IDE01931,High pressure pump injection volume control deviation,111, mg/stroke
IDE01932,High pressure pump injection volume,0, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,5,
IDE01976,Numb.of misfir.: cylinder 2,7,
IDE01977,Numb.of misfir.: cylinder 3,7,
IDE01978,Numb.of misfir.: cylinder 4,2,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,11.3, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,-1.6, %
IDE02229,Exh.gas temp.sen 1,1110.0, °C
IDE02756,Number of manual engine starts,81,
IDE02757,Number of automatic engine starts,0,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,0,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.490, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.791, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.194, V
IDE03267,Intake air temperature: unconditioned voltage,2.031, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.592, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.818, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver request torque,23.2, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status for transmission neutral position sensor,4,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3.649, V
IDE03582,Temperature sensor for engine temperature management,29.2, °C
IDE03585,System status for the start/stop function master,System malfunction,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet not complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Test of thermostat complete,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch not complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,0, kg/h
IDE03767,Engine status,Stop,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,11.57, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,0,
IDE03807,Oxygen sensor bank 1 sensor 2: status,0,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,65535, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,0.00, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,16383, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.00, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,0.557, V
IDE03918,Engine reverse rotation recognition,not recognized,
IDE03919,Oxygen regulation operability and status,OFF,
IDE03920,Oxygen adaptation status,Initializing,
IDE03921,Mixture adaptation factor at partial load,0.76, %
IDE03922,Mixture adaptation factor at idle speed,0.00, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,30.92, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.594, V
IDE03935,Charge pressure actuator: adaptation for upper stop,0.570, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.76, %
IDE03957,Throttle valve angle: specified value,6.1, °
IDE03963,Low fuel pressure adaptation value for EFP,1200, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,99.61, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04405,Mixture deviation in adapted partial load range 1,0.76, %
IDE04409,Intake manifold pressure: corrected,0.982, bar
IDE04410,Intake manifold pressure: target value,0.000, bar
IDE04412,Pressure before throttle valve: corrected,0.982, bar
IDE04415,Oxygen ctrl factor with precontrol correction,0.00, %
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04629,AVS operating condition,No enabling,
IDE04630,AVS valve stroke position: current,Standard,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,10,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature management actuator,99.75, %
IDE04638,Transmission coolant valve,Open,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,1,
IDE04680,O2 sensor 1: bank 1: voltage raw value O2 signal,1.997, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.984, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,30.92, %
IDE05312,Charge air pressure control valve uncond voltage sensor,2.3975, V
IDE05313,Charge air pressure control valve activation pulse duty factor,0.00, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0],00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.5938, V
IDE05316,Charge air pressure control valve voltage: position open,0.5701, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0],00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.983, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,0,
IDE06006,Idle speed specified value,1321, /min
IDE06192,Knock sensor: cylinder 2: voltage,2.500, V
IDE06193,Knock sensor: cylinder 3: voltage,2.500, V
IDE06194,Knock sensor: cylinder 4: voltage,2.500, V
IDE06195,Knock sensor: cylinder 1: voltage,2.500, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000000 ,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Exhaust emission control diagnosis,
IDE06307,Stop prevention history data,Auxiliary consumers power too high,
IDE06307,Stop prevention history data,Motor protection active,
IDE06307,Stop prevention history data,Driving situation,
IDE06307,Stop prevention history data,Engine hood open,
IDE06307,Stop prevention history data,Clutch protection K0,
IDE06307,Stop prevention history data,Play protection,
IDE06307,Stop prevention history data,Brake under pressure too low,
IDE06307,Stop prevention history data,Brake pedal information: plausibility,
IDE06307,Stop prevention history data,Test of thermostat not complete,
IDE06307,Stop prevention history data,Regeneration operation,
IDE06307,Stop prevention history data,Steering angle,
IDE06307,Stop prevention history data,Tighter traffic flow detected,
IDE06307,Stop prevention history data,Diagnosis of air system,
IDE06307,Stop prevention history data,Mixture adaptation,
IDE06307,Stop prevention history data,Hybrid battery power insufficient,
IDE06307,Stop prevention history data,E machine output too low,
IDE06307,Stop prevention history data,Adaptation active,
IDE06307,Stop prevention history data,Engine temperature,
IDE06307,Stop prevention history data,Steering,
IDE06307,Stop prevention history data,Event memory entry in engine control module,
IDE06307,Stop prevention history data,Sporadic function restriction,
IDE06307,Stop prevention history data,Poor start detection,
IDE06307,Stop prevention history data,Ambient air pressure,
IDE06307,Stop prevention history data,Diagnosis of exhaust system,
IDE06307,Stop prevention history data,Deceleration takeover active,
IDE06307,Stop prevention history data,Restriction in the start system,
IDE06307,Stop prevention history data,Function locked due to excessive stalling,
IDE06307,Stop prevention history data,Fuel salinization protection active,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Rolling vehicle,
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,27, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,27, mm
IDE06390,Oil level: minimum value,27, mm
IDE06391,Oil temperature sensor 2,23.0, °C
IDE06392,Oil temperature sensor 2: raw value,23.000, V
IDE06393,Oil level: dynamic average value,0, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,2.432, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,3.149, V
IDE06397,Temperature sensor for engine temp. management: target value,107.3, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,3.149, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,1.694, V
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06432,Oxygen sensor 1 bank 1 signal status,not active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.997, V
IDE06567,Start-stop function deactivation frequency counter,0,
IDE06568,Stop prevention by driver frequency counter,0,
IDE06569,Vehicle stopped frequency counter,0,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Vehicle standstill with stop frequency counter,0,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.13, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.00, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,1,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,0,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE07001,Piston-cooling jets: activation,On,
IDE07008,Tank leak: number no leak detected,11,
IDE07011,Tank leak: number communication errors to engine control,4,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,1372016,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,3.98e+008, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,85.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,88.75, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,89.25, °
IDE07550,Engine temp. management actuator: raw value,1476,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3958,
IDE07554,Engine temperature management actuator: stop open,139,
IDE07564,Required torque adjustment by idling regulator,0.0, Nm
IDE07571,Engine torque,-22.7, Nm
IDE07572,High pressure regulation: adaptation value,-8.39, mg
IDE07574,Long-term fuel trim bank 1 at idle,0.00, mg/stroke
IDE07575,Driver request torque,0.6, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,-0.3, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Setting,not activated,
IDE07598-MAS00326,Cruise control switch actuation-Activation,not activated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,not activated,
IDE07598-MAS02310,Cruise control switch actuation-Decelerate,not activated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,not activated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,not activated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,not activated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,not activated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,not activated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,Yes,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,Yes,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,No,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,not active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,not activated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,not activated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.000, counts
IDE08806,EVAP valve diag. activation condition at maximum load,0, mbar
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.592, V
IDE10380,Knock sensor average voltage bank 1,0.000, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,0,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,-48.00, °C
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,39.0, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
ENG102981,AC compressor: speed increase,00000000 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,0.00000,
ENG103474,Activation of oil pressure switching valve,00000000 ,
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,0.00, kg/h
ENG104264,Alternator load,0, W
ENG103910,Ambient temperature,11.25, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0080, cm²
ENG98377,As,none,
ENG103165,Battery voltage,12.5, V
ENG07601,Bypasstool_a2l_name,ORIGINAL A2L,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,8V0264M 0001AXAE,
ENG99697,Calibration Verification Number,10 0A D0 9E,
ENG128780,CAM_DIF_VCP[EX_1],0.000, °
ENG128781,CAM_DIF_VCP[IN_1],0.000, °
ENG102002,CAM_OFS_IVVT_IN[1],0.000, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],0.000, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],0.000, °
ENG101169,CAM_PHA_OFS_MAF[IN][1],0.000, °
ENG112542,CAM_SP_IND_VCP[EX_1],0.000, °
ENG112543,CAM_SP_IND_VCP[IN_1],0.000, °
ENG112544,CAM_VCP[EX_1],0.000, °
ENG112545,CAM_VCP[IN_1],0.000, °
ENG103849,Cat. ageing: bank 1: actual,0.164,
ENG101785,Cat. temperature: bank 1,11.2250, °C
ENG102214,CPU_LOAD,41.1, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],0,
ENG101127,CTR_CDN_OBD_RBM,10,
ENG114826,CTR_EDGE_CAM_EX[1],0,
ENG114827,CTR_EDGE_CAM_IN[1],0,
ENG100536,CTR_IGK_CYC_RBM,82,
ENG125193,CTR_LAMB_SP_PI_REQ[0],0,
ENG125194,CTR_LAMB_SP_PI_REQ[1],0,
ENG125195,CTR_LAMB_SP_PI_REQ[2],0,
ENG125196,CTR_LAMB_SP_PI_REQ[3],0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],2,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],2,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],1,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],2,
ENG112558,CTR_MIS_TOT_NVMY_SAE,181,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,0.00,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG99428,CTR_VLFT_1_SWI_NOT[0],0,
ENG103626,CTR_VLFT_1_SWI_NOT[1],0,
ENG100809,CTR_VLFT_1_SWI_NOT[2],0,
ENG99336,CTR_VLFT_1_SWI_NOT[3],0,
ENG103025,CTR_VLFT_STND_SWI_NOT[0],0,
ENG100017,CTR_VLFT_STND_SWI_NOT[1],0,
ENG100438,CTR_VLFT_STND_SWI_NOT[2],0,
ENG100736,CTR_VLFT_STND_SWI_NOT[3],0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,10,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,57,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,59,
ENG101652,Cylinder shut-off: cylinder suppression,00000001 ,
ENG102657,DIAG_INST[0],NO_ERROR,
ENG99120,DIAG_INST[1],NO_ERROR,
ENG103260,DIAG_INST[2],NO_ERROR,
ENG99710,DIAG_INST[3],NO_ERROR,
ENG102667,DIAG_INST[4],NO_ERROR,
ENG102739,DIAG_INST[5],NO_ERROR,
ENG100162,DIAG_INST[6],NO_ERROR,
ENG99103,DIAG_INST[7],NO_ERROR,
ENG99261,DIAG_INST[8],NO_ERROR,
ENG103622,DIAG_INST[9],NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,359, km
ENG103766,DIST_ENG_RUN_IN,376317.8, m
ENG100531,DIST_ST,376300, m
ENG100131,ECU_STATE,ENG_STOP,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG104044,Engine load,0.000000, %
ENG102494,Engine speed: actual,0, /min
ENG102783,Engine: operating status,ES,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,62.3750, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],0.000, %
ENG100298,FAC_LAM_CP,0.000, %
ENG100108,FAC_LAM_LIM[1],0.000, %
ENG99722,FAC_LAM_TCO_A[1],0.000, %
ENG103521,FAC_LAM_TCO_B[1],0.000, %
ENG103641,FAC_LAM_TCO_C[1],0.000, %
ENG101578,FAC_LAM_TCO_D[1],0.000, %
ENG100685,FAC_LAM_TCO_E[1],0.000, %
ENG103307,FAC_MAF_MAX,0.00000,
ENG99791,FAC_SLOP_IV[1],0.00000,
ENG102306,FAC_TPS_1_SAE,15.625000, %
ENG102292,FAC_TPS_1_SAE,16.015625, %
ENG99630,Fan control relay: fan run-on,0,
ENG101437,Fan request from air conditioner,0.0, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,61.17647159, %
ENG104248,Fuel consumption signal,0, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG100250,Fuel regulating valve: duty cycle,0.000, %
ENG101692,Fuel supply system: high-pressure regulator,117856, hPa
ENG114828,FUP_EFP_MES,11000.8, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,4940.6, hPa
ENG112563,FUP_H_SAE,400.0, kPa
ENG103368,Gearbox -CAN bus messages,94079,
ENG99170,Height correction,984.48, hPa
ENG103575,High-pressure system: regulator,119.03, mg
ENG103879,High-pressure system: regulator: mobile part,0.00, mg
ENG102603,High-pressure system: status,VCV_OPEN,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,0.5, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],-0.375, °
ENG101655,IGA_IGC[1],-0.375, °
ENG100410,IGA_IGC[2],-0.375, °
ENG100407,IGA_IGC[3],-0.375, °
ENG112564,IGA_IGC_SAE,-0.5, °
ENG101741,Intake air temperature,27.00, °C
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,10, counts
ENG125209,KNKS_ERR_REL[0],0.0000, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],-0.00287,
ENG99601,LAMB_DELTA_I_LAM_ADJ[1],0.00000,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],-0.00287,
ENG99674,Lambda controller: bank 1 (averaged value),0.000, %
ENG101381,Lambda probe 1: bank 1: status,00000000 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000000 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,11.2250, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00000,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000001 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,65535, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.997, V
ENG102763,Lambda probes actual: bank1,1.0000,
ENG104114,Lambda probes specified: bank1,0.0000,
ENG06592,LF_COSI_CTL_ERR_A,0,
ENG06593,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW[1],0,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW[2],0,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW[1],0,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW[2],0,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG112572,LF_IV_ERR_RAW_BSW[0],0,
ENG112573,LF_IV_ERR_RAW_BSW[1],0,
ENG112574,LF_IV_ERR_RAW_BSW[2],0,
ENG112575,LF_IV_ERR_RAW_BSW[3],0,
ENG112576,LF_IV_ERR_VLD_BSW[0],0,
ENG112577,LF_IV_ERR_VLD_BSW[1],0,
ENG112578,LF_IV_ERR_VLD_BSW[2],0,
ENG112579,LF_IV_ERR_VLD_BSW[3],0,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2127,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,15,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,31,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,31,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,63,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,63,
ENG127733,Life_cycle_data_system_failure,Immobilizer,
ENG127733,Life_cycle_data_system_failure,Kessy,
ENG127733,Life_cycle_data_system_failure,Convertible top control module,
ENG127733,Life_cycle_data_system_failure,Multifunction unit control module,
ENG127733,Life_cycle_data_system_failure,Parking aid,
ENG127733,Life_cycle_data_system_failure,Level control system,
ENG127733,Life_cycle_data_system_failure,12 V electrical system,
ENG127733,Life_cycle_data_system_failure,Transmission,
ENG127733,Life_cycle_data_system_failure,ACC,
ENG127733,Life_cycle_data_system_failure,Front axis lift system,
ENG127733,Life_cycle_data_system_failure,Front sensor system for driver assistance systems,
ENG127733,Life_cycle_data_system_failure,All-wheel electronics,
ENG127733,Life_cycle_data_system_failure,brakes,
ENG127733,Life_cycle_data_system_failure,Quattro Sport,
ENG127733,Life_cycle_data_system_failure,Steering,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG127733,Life_cycle_data_system_failure,A/C,
ENG122701,LMVDes_st_Mod_Out_VW,0,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,200.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,0.00000, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],0,
ENG99095,LV_CAN_HOOD_SWI,00000001 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG128788,LV_ECRAS_FB_DIAG_POS_RESP[0],00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000001 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI[1],00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI[2],00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI[3],00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI[4],00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI[1],00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI[2],00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI[3],00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI[4],00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG103773,LV_INH_STR_RLY,00000000 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000000 ,
ENG112586,LV_PWR_RLY[0],00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000000 ,
ENG102523,MAF,0.00, mg/stroke
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,98, kPa
ENG103501,MASS_SA_REL[0],0.000,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD[1],0.00, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],-0.21, mg/stroke
ENG101360,Misfire detection active,00000001 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,1321, /min
ENG103004,N_TCHA,12420.7, /min
ENG112590,N_TOOTH,0, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,154,
ENG126111,NL_PRE[0],0.00000, V
ENG126112,NL_PRE[1],0.00000, V
ENG126113,NL_PRE[2],0.00000, V
ENG126114,NL_PRE[3],0.00000, V
ENG128789,NR_CYC_AD_DC_BAL_HOM[RNG_H],0,
ENG128790,NR_CYC_AD_DC_BAL_HOM[RNG_IS],0,
ENG128791,NR_CYC_AD_DC_BAL_HOM[RNG_L],0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM[0],0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM[1],0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM[2],0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM[3],0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,4,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.47, hPa
ENG02464,PRS_UP_THR_MES,984.31, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX[1][1],0.0000, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN[1][1],1.1875, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1],0.0000, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2],0.0000, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1],1.1875, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2],0.0000, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],90.002, %
ENG112594,PWM_ACT_VCP[IN_1],90.002, %
ENG101350,PWM_ETC,0.000, %
ENG112595,PWM_HLD_VCP[EX_1],11.566, %
ENG112596,PWM_HLD_VCP[IN_1],11.566, %
ENG112597,PWM_PAS_VCP[EX_1],11.566, %
ENG112598,PWM_PAS_VCP[IN_1],11.566, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,NO_ECF,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG102377,Ready and error flags,0,
ENG112599,RVC_AV,89.25, °
ENG112601,RVC_SP,88.75, °
ENG112600,RVCPWM,0.000, %
ENG103248,SEG_AD_MMV_ER[0],0.0000, ‰
ENG101135,SEG_AD_MMV_ER[1],0.8226, ‰
ENG99078,SEG_AD_MMV_ER[2],-0.0572, ‰
ENG103257,SEG_AD_MMV_ER[3],0.8838, ‰
ENG102511,SEG_AD_MMV_ER_H[0],0.0000, ‰
ENG103258,SEG_AD_MMV_ER_H[1],0.7439, ‰
ENG99291,SEG_AD_MMV_ER_H[2],-0.0799, ‰
ENG99954,SEG_AD_MMV_ER_H[3],0.8404, ‰
ENG100568,SEG_AD_MMV_ER_L[0],0.0000, ‰
ENG100601,SEG_AD_MMV_ER_L[1],0.8226, ‰
ENG102668,SEG_AD_MMV_ER_L[2],-0.0572, ‰
ENG101232,SEG_AD_MMV_ER_L[3],0.8838, ‰
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000, ‰
ENG102964,SEG_AD_MMV_ER_MID[1],0.7010, ‰
ENG100890,SEG_AD_MMV_ER_MID[2],-0.0636, ‰
ENG99793,SEG_AD_MMV_ER_MID[3],0.7746, ‰
ENG103381,Shut-off time,12.60, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,12, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,0, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG100800,Starter: start relay 1,00000000 ,
ENG99979,Starter: start relay 2,00000000 ,
ENG102033,STATE_BPA[0],OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_PAS,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,17318976,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE[1],INI,
ENG104238,STATE_NVLD,READ_INI,
ENG112606,STATE_PWM_VCP[EX_1],HLD,
ENG112607,STATE_PWM_VCP[IN_1],HLD,
ENG101078,STATE_READY_OBD_1,7,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SC8S5010 CBS00I0,
ENG128798,STATE_T_ES_RD,0,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,passive,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_H,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,0, s
ENG104148,T_COOL_LOIL,394.6, ms
ENG112613,T_DTC_CLR_SAE,386, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,310, min
ENG112615,T_ES_CNT,0,
ENG112616,T_ES_DC,295, min
ENG99463,T_ES_H,18607, s
ENG128802,T_IGK,655.35, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG128803,T_PWL_CAN,336.9, s
ENG112636,T_SWI_VVL_ACR,0.0, ms
ENG101325,T_TEMP_SIG_LOIL,42.0, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,11.500, °C
ENG102048,Tank breather valve: duty cycle,0.000000, %
ENG101339,Tank breather valve: short trip result,0.0000, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,32, °C
ENG112611,TCO_1_ST,32, °C
ENG112612,TCO_1_SYS,29, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP[1],9.75, °C
ENG101581,TCO_C_LAM_AD_WUP[1],24.75, °C
ENG100354,TCO_D_LAM_AD_WUP[1],35.25, °C
ENG101973,TCO_E_LAM_AD_WUP[1],45.00, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],19.453, °C
ENG124460,TCO_MDL[TH],22.453, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],28.50, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],50.25, °C
ENG102279,TCS/ESP: specified torque,22.66, Nm
ENG99857,TCS: status,00000000 ,
ENG110436,TEG_DYN_LS_DOWN[1],11.2250, °C
ENG110437,TEG_DYN_LS_UP[1],11.2250, °C
ENG101941,TEMP_CAT_STAT_MDL[1],19.9750, °C
ENG112614,TEMP_CAT_UP_1_SAE,11.2, °C
ENG114837,TFPA,28, °C
ENG114838,TFU_HPP,31.50, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,6.025, °
ENG102845,Throttle valve deviation,0.000, %
ENG126115,TI_1_MES_MPI[0],0.000, ms
ENG126116,TI_1_MES_MPI[1],0.000, ms
ENG126117,TI_1_MES_MPI[2],0.000, ms
ENG126118,TI_1_MES_MPI[3],0.000, ms
ENG126119,TI_MES_4[PLS_1][0],0.000, ms
ENG126120,TI_MES_4[PLS_1][1],0.000, ms
ENG126121,TI_MES_4[PLS_1][2],0.000, ms
ENG126122,TI_MES_4[PLS_1][3],0.000, ms
ENG126123,TI_MES_4[PLS_2][0],0.000, ms
ENG126124,TI_MES_4[PLS_2][1],0.000, ms
ENG126125,TI_MES_4[PLS_2][2],0.000, ms
ENG126126,TI_MES_4[PLS_2][3],0.000, ms
ENG126127,TI_MES_4[PLS_3][0],0.000, ms
ENG126128,TI_MES_4[PLS_3][1],0.000, ms
ENG126129,TI_MES_4[PLS_3][2],0.000, ms
ENG126130,TI_MES_4[PLS_3][3],0.000, ms
ENG128801,TIA_CHA_DOWN_MV,36.773, °C
ENG125276,TIG_MES_SAE[IM],28, °C
ENG103351,Time since engine start,0.0, s
ENG112634,TLTS_MES[TCE],29.305, °C
ENG112635,TMAG_VCP,45, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG114839,TPS_ETC,6.025, °
ENG99274,TPS_SP,6.127, °
ENG103021,TQ_CONV,0.00, Nm
ENG128804,TQI_ADD_ACT,0.00000, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG102329,TTIP_MES_LS_UP[1],-2048.0000, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7617, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,64.0, V
ENG103201,VCV_CLOSE_RNG,0.0, °
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4296,
ENG122705,VLCReq_st_Dem_VW,2,
ENG112639,VLS_DOWN_SAE[1],1.275, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.000000, m³/s
ENG101929,VP_TPS_1,0.7861, V
ENG102985,VP_TPS_2,4.1992, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.5029, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.4904, V
ENG101674,VP_TPS_AD_LIH_1,0.7910, V
ENG99507,VP_TPS_AD_LIH_2,4.1943, V
Elapsed Time: 01:09
03:
;SW:5Q0-614-517-DR HW:5Q0-614-517-BM --- ABS Brakes
;Component:ESC H45 0108, Coding:43FA6AA13022096E407A0303A0CC29C2560C9002C005943434435050F0A94B0B0040010312121212B435351919323200
;EV_Brake1UDSContiMK100IPB,038007,EV_Brake1UDSContiMK100IPB_038_VW37.rod
;Tuesday,10,December,2019,21:34:49:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: 845A675ADE9806714D33-80D0
Group,Description,Actual
IDE00323,Security Access: Number of invalid keys,0,
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,ERROR,
IDE02270-IDE02713,CAN input signal(s) status-Brake Light Switch,not activated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,closed,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,not activated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,ERROR,
IDE02270-MAS01281,CAN input signal(s) status-Back-up light,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,AU22339,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,not active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency brake display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.21875, m/s²
IDE02486,Data logger triggering,not active,
IDE02492,Start-stop function: coding information,Start-stop function in control module not active,
IDE02986-IDE04431,indicator lights-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,indicator lights-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,indicator lights--AUTO HOLD- Indicator Lamp,Not available due to specific system,
IDE02986-IDE04771,indicator lights-Indicator lamp for electro-mechanical parking brake malfunction,Not available due to specific system,
IDE02986-MAS00253,indicator lights-ABS indicator lamp,OFF,
IDE02986-MAS00556,indicator lights-Electromechanical parking brake indicator lamp,Not available due to specific system,
IDE02986-MAS01206,indicator lights-Hill descent control indicator lamp,OFF,
IDE02986-MAS02925,indicator lights-Brake system indicator lamp,OFF,
IDE02986-MAS03234,indicator lights-ESP_off indicator lamp,OFF,
IDE03008-IDE04446,Stop process prevented-Hill descent control,not active,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-IDE06139,Stop process prevented-AUTO HOLD slippage recognition,not active,
IDE03008-MAS04485,Stop process prevented-ESP function deactivation,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-MAS07931,Stop process prevented-Retaining function unavailable,not active,
IDE03008-MAS07932,Stop process prevented-Inclination limit,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,3,
IDE03011-IDE04446,Number of requested start processes-Hill descent control,0,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04485,Number of requested start processes-ESP function deactivation,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2126,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,14,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,30,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,62,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,62,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start-stop conditions,System malfunction,
IDE03213,Start-stop enabling,At least one release missing,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,15,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.535, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,OFF,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-1, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.30, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake Light Switch,not activated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,65535, mm
IDE04425-IDE04436,Left front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04425-IDE04437,Left front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04425-IDE04438,Left front ABS wheel speed sensor-Average division value,Condition not met,
IDE04425-IDE04440,Left front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04425-IDE04441,Left front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Front right wheel speed,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,65535, mm
IDE04426-IDE04436,Right front ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04426-IDE04437,Right front ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04426-IDE04438,Right front ABS wheel speed sensor-Average division value,Condition not met,
IDE04426-IDE04440,Right front ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04426-IDE04441,Right front ABS wheel speed sensor-Validity of gap information,invalid,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,65535, mm
IDE04427-IDE04436,Left rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04427-IDE04437,Left rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04427-IDE04438,Left rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04427-IDE04440,Left rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04427-IDE04441,Left rear ABS wheel speed sensor-Validity of gap information,invalid,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,ERROR,
IDE04428-IDE04436,Right rear ABS wheel speed sensor-Minimum division value,Condition not met,
IDE04428-IDE04437,Right rear ABS wheel speed sensor-Maximum division value,Condition not met,
IDE04428-IDE04438,Right rear ABS wheel speed sensor-Average division value,Condition not met,
IDE04428-IDE04440,Right rear ABS wheel speed sensor-Validity of direction of rotation,invalid,
IDE04428-IDE04441,Right rear ABS wheel speed sensor-Validity of gap information,valid,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forwards,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,ÿÿÿÿÿÿÿÿÿÿ,
IDE04442-IDE00010,Vacuum sensor-Serial number,FF FF FF FF FF,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Not available due to specific system,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,65535,
IDE04442,Vacuum sensor,-1, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,65535,
IDE04443-IDE02241,Traction control system sensor-Lateral acceleration sensor 1,0.01962, m/s²
IDE04443-IDE02538,Traction control system sensor-Longitudinal acceleration sensor,0.16677, m/s²
IDE04443-IDE04429,Traction control system sensor-Lateral acceleration sensor 1: offset,-0.00000, m/s²
IDE04443-IDE04430,Traction control system sensor-Longitudinal acceleration sensor: offset,0.21875, m/s²
IDE04443-IDE04449,Traction control system sensor-Rotation rate sensor 1: Z-axis,0.000, °/s
IDE04443-IDE04460,Traction control system sensor-Steering angle sensor: offset straight line running,-28.481, °
IDE04443-MAS00815,Traction control system sensor-Steering angle sensor,-28.481, °
IDE04446-IDE01599,Hill descent control-Slope,2, %
IDE04446-IDE02955,Hill descent control-System status,Available,
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,not activated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,not activated,
IDE04452-IDE03664,Brake system button-Button for driving program,not activated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,not activated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not available due to specific system,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,0, km
IDE04456-MAS01282,Brake disk drying-Wiper,not active,
IDE04456-MAS03095,Brake disk drying-Function status,not active,
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MXARAG00015,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-IDE03659,Internal measured values-Roller test bench mode,not active,
IDE04461-MAS01481,Internal measured values-Temperature in control module,19, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAF00003,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognized,
IDE04508-IDE02955,Hydraulic brake booster-System status,Not available due to specific system,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,ERROR,
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.20, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,ERROR,
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04644-MAS03095,Roll-over protection-Function status,not active,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE03735,Counter steer support-Steering torque,0, Nm
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,299, km
IDE04765-MAS03095,Counter steer support-Function status,not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04774-MAS03095,Vehicle and trailer stabilization-Function status,not active,
IDE04939-IDE02955,Tire pressure monitoring display-System status,Available,
IDE04939-IDE04248,Tire pressure monitoring display-Left front tire pressure diffusion indicator,249,
IDE04939-IDE04249,Tire pressure monitoring display-Right front tire pressure diffusion indicator,249,
IDE04939-IDE04250,Tire pressure monitoring display-Left rear tire pressure diffusion indicator,249,
IDE04939-IDE04251,Tire pressure monitoring display-Right rear tire pressure diffusion indicator,249,
IDE04939-IDE04432,Tire pressure monitoring display-Tire Pressure Monitoring Display Button,not activated,
IDE04939-IDE04946,Tire pressure monitoring display-Odometer reading at last adaptation,0, km
IDE04939-IDE04947,Tire pressure monitoring display-Odometer reading of last warning,0, km
IDE04939-MAS04538,Tire pressure monitoring display-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire pressure monitoring display-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire pressure monitoring display-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire pressure monitoring display-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire pressure monitoring display-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire pressure monitoring display-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS04544,Tire pressure monitoring display-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire pressure monitoring display-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire pressure monitoring display-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire pressure monitoring display-Right rear flat tire indicator,255,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,5877,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,69344,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,0,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,135,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2126,
IDE07280-MAS00107,Multiple collision brake-Month,14,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,30,
IDE07280-MAS00110,Multiple collision brake-Minutes,62,
IDE07280-MAS00111,Multiple collision brake-Seconds,62,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 36 32 39 38 30 39 33 30 30 30 30 35 31 39 39 31 33 30 30 33 41 45 2F 02 28 3E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,93.744, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,94.9158, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,89.838, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,36,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,96.8688, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,57,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,92.9628, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,19,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,95.697, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,28,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,11.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,11.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,11.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,11.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake Light Switch,not activated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00121-MAS03095,Electronic Differential Lock-Function status,not active,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Available,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS01464,All Wheel Drive (AWD)-Emergency running mode,not active,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, %
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,closed,
MAS02138-MAS00988,Hill-start assistant-Reverse gear,not selected,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS00580,Text display in instrument panel insert-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument panel insert-Text,0,
MAS02672-IDE02955,Start-stop-System status,Not available due to specific system,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,2,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,2,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,2,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,2,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:12
05:
;SW:3Q0-959-435-N HW:3Q0-959-435-N --- Acc/Start Auth.
;Component:VWKESSYMQB 037 1307, Coding:132C0C0623
;EV_KessyHellaMQBAB,004052,EV_KessyHellaMQBAB.rod
;Tuesday,10,December,2019,21:35:21:14741
;VCID: C5DCBA5E9522FF791AAD-8090
IDE00019,Voltage terminal 30,12.513, V
IDE00021,Engine speed,0.0, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver door,closed,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Left rear door,closed,
IDE02408-MAS00221,Individual door locking: status-Right rear door,closed,
IDE02409,ID sensor 1 authentication: status,No response,
IDE02410,ID sensor 2 authentication: status,No response,
IDE02411,ID sensor 3 authentication: status,No response,
IDE02412,ID sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear exterior door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear exterior door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear exterior door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear exterior door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear exterior door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear exterior door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,132,
IDE02419,Proximity sensor frt.pass. door: number of triggers,56,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardwareversion,31,
IDE02422-MAS01483,Driver door handle: version information-Softwareversion,17,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,AA,
IDE02423-MAS01482,ass. door handle: version information-Hardwareversion,31,
IDE02423-MAS01483,ass. door handle: version information-Softwareversion,17,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,AA,
IDE02424-MAS01482,Left rear door handle: version information-Hardwareversion,00,
IDE02424-MAS01483,Left rear door handle: version information-Softwareversion,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardwareversion,00,
IDE02425-MAS01483,Right rear door handle: version information-Softwareversion,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,Yes,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,Yes,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,Yes,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72-hour signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72-hr signaling counter left rear door,0,
IDE02485,72-hr signaling counter right rear door,0,
IDE02495,Service key: number of activations,33,
IDE02496,Service key: number of timeouts,0,
IDE02497,Service key: number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
IDE02581,Drive train uncoupling,not decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,closed,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing message from Engine Control Module,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN signal: operation reader coil is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing message from Engine Control Module,0,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN signal: operation reader coil is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,Empty,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Empty,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Empty,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Empty,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Empty,
IDE03128,Requested start processes (ring memory),Empty,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,System malfunction,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,UID_MONITORING,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,UID_SEARCH,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,A2,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,62,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,52,
IDE05204,Manufacturing dates for driver door handle,1F 07 21 9A 51,
IDE05205,Manufacturing dates for frt.pass. door handle,1F 07 21 9A 51,
IDE05206,Manufacturing dates for left rear door handle,00 00 00 00 00,
IDE05207,Manufacturing dates for right rear door handle,00 00 00 00 00,
IDE07028,Time until shut-off terminal S,1800, s
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition not met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,100,
IDE08440,Recommendation energy management,no restriction,
IDE80258,Immobilizer status,Electronic steering locking device installed,
IDE80258-MAS00106,Immobilizer status-Year,2011,
IDE80258-MAS00107,Immobilizer status-Month,1,
IDE80258-MAS00108,Immobilizer status-Day,1,
IDE80258-MAS00109,Immobilizer status-Hours,16,
IDE80258-MAS00110,Immobilizer status-Minutes,13,
IDE80258-MAS00111,Immobilizer status-Seconds,10,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,35,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,14,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,12,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,373, km
MAS01493,Engine running,not active,
MAS03554,Clutch pedal operation,No,
MAS03607,Engine stop in start-stop mode active,not active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG29819,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG29818,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG29817,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG29816,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,12.519, V
ENG08690,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_nicht_entriegelt,
ENG114479,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,0,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,0,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,0, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,0, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,0, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,0, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,0, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG118078-MAS00111,History_low_voltage-Seconds,0, s
ENG118078-ENG118397,History_low_voltage-Function_restriction_n,No_function_restriction,
ENG118078-ENG118381,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG118078-ENG118223,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG118078-ENG118309,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG118078-ENG118280,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG118078-ENG118389,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG118078-ENG118329,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG118078-ENG118282,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG118078-ENG118267,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG118078-ENG118278,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_UNDERVOLTAGE_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,ECUEXT_RR_HPM_EOL,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_SCAN_PROCEDURE_TIMEOUTCONTROL,
ENG26926-MAS00106,lf_shutdowns-Year,2000,
ENG26926-MAS00107,lf_shutdowns-Month,0,
ENG26926-MAS00108,lf_shutdowns-Day,0,
ENG26926-MAS00109,lf_shutdowns-Hours,0,
ENG26926-MAS00110,lf_shutdowns-Minutes,0,
ENG26926-MAS00111,lf_shutdowns-Seconds,0,
ENG26926-ENG32070,lf_shutdowns-Mileage_lf_shutdown_n,0, km
ENG26926-ENG32071,lf_shutdowns-Mileage_lf_shutdown_n-1,0, km
ENG26926-ENG32072,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG26926-ENG32073,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,10,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG26348-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG26348-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG26348-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG26348-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG26348-ENG30036,Scan_cycle_data-Mileage_n,0, km
ENG26348-ENG30037,Scan_cycle_data-Mileage_n-1,0, km
ENG26348-ENG30038,Scan_cycle_data-Mileage_n-10,0, km
ENG26348-ENG30039,Scan_cycle_data-Mileage_n-11,0, km
ENG26348-ENG30040,Scan_cycle_data-Mileage_n-12,0, km
ENG26348-ENG30041,Scan_cycle_data-Mileage_n-13,0, km
ENG26348-ENG30042,Scan_cycle_data-Mileage_n-14,0, km
ENG26348-ENG30043,Scan_cycle_data-Mileage_n-15,0, km
ENG26348-ENG30044,Scan_cycle_data-Mileage_n-16,0, km
ENG26348-ENG30045,Scan_cycle_data-Mileage_n-17,0, km
ENG26348-ENG30046,Scan_cycle_data-Mileage_n-18,0, km
ENG26348-ENG30047,Scan_cycle_data-Mileage_n-19,0, km
ENG26348-ENG30048,Scan_cycle_data-Mileage_n-2,0, km
ENG26348-ENG30049,Scan_cycle_data-Mileage_n-3,0, km
ENG26348-ENG30050,Scan_cycle_data-Mileage_n-4,0, km
ENG26348-ENG30051,Scan_cycle_data-Mileage_n-5,0, km
ENG26348-ENG30052,Scan_cycle_data-Mileage_n-6,0, km
ENG26348-ENG30053,Scan_cycle_data-Mileage_n-7,0, km
ENG26348-ENG30054,Scan_cycle_data-Mileage_n-8,0, km
ENG26348-ENG30055,Scan_cycle_data-Mileage_n-9,0, km
ENG26348-ENG30076,Scan_cycle_data-Retry_count_n,0,
ENG26348-ENG30077,Scan_cycle_data-Retry_count_n -6,0,
ENG26348-ENG30078,Scan_cycle_data-Retry_count_n-1,0,
ENG26348-ENG30079,Scan_cycle_data-Retry_count_n-10,0,
ENG26348-ENG30080,Scan_cycle_data-Retry_count_n-11,0,
ENG26348-ENG30081,Scan_cycle_data-Retry_count_n-12,0,
ENG26348-ENG30082,Scan_cycle_data-Retry_count_n-13,0,
ENG26348-ENG30083,Scan_cycle_data-Retry_count_n-14,0,
ENG26348-ENG30084,Scan_cycle_data-Retry_count_n-15,0,
ENG26348-ENG30085,Scan_cycle_data-Retry_count_n-16,0,
ENG26348-ENG30086,Scan_cycle_data-Retry_count_n-17,0,
ENG26348-ENG30087,Scan_cycle_data-Retry_count_n-18,0,
ENG26348-ENG30088,Scan_cycle_data-Retry_count_n-19,0,
ENG26348-ENG30089,Scan_cycle_data-Retry_count_n-2,0,
ENG26348-ENG30090,Scan_cycle_data-Retry_count_n-3,0,
ENG26348-ENG30091,Scan_cycle_data-Retry_count_n-4,0,
ENG26348-ENG30092,Scan_cycle_data-Retry_count_n-5,0,
ENG26348-ENG30093,Scan_cycle_data-Retry_count_n-7,0,
ENG26348-ENG30094,Scan_cycle_data-Retry_count_n-8,0,
ENG26348-ENG30095,Scan_cycle_data-Retry_count_n-9,0,
ENG26348-ENG30114,Scan_cycle_data-Scan_reason_n,Initial,
ENG26348-ENG30115,Scan_cycle_data-Scan_reason_n-1,Initial,
ENG26348-ENG30116,Scan_cycle_data-Scan_reason_n-10,Initial,
ENG26348-ENG30117,Scan_cycle_data-Scan_reason_n-11,Initial,
ENG26348-ENG30118,Scan_cycle_data-Scan_reason_n-12,Initial,
ENG26348-ENG30119,Scan_cycle_data-Scan_reason_n-13,Initial,
ENG26348-ENG30120,Scan_cycle_data-Scan_reason_n-14,Initial,
ENG26348-ENG30121,Scan_cycle_data-Scan_reason_n-15,Initial,
ENG26348-ENG30122,Scan_cycle_data-Scan_reason_n-16,Initial,
ENG26348-ENG30123,Scan_cycle_data-Scan_reason_n-17,Initial,
ENG26348-ENG30124,Scan_cycle_data-Scan_reason_n-18,Initial,
ENG26348-ENG30125,Scan_cycle_data-Scan_reason_n-19,Initial,
ENG26348-ENG30126,Scan_cycle_data-Scan_reason_n-2,Initial,
ENG26348-ENG30127,Scan_cycle_data-Scan_reason_n-3,Initial,
ENG26348-ENG30128,Scan_cycle_data-Scan_reason_n-4,Initial,
ENG26348-ENG30129,Scan_cycle_data-Scan_reason_n-5,Initial,
ENG26348-ENG30130,Scan_cycle_data-Scan_reason_n-6,Initial,
ENG26348-ENG30131,Scan_cycle_data-Scan_reason_n-7,Initial,
ENG26348-ENG30132,Scan_cycle_data-Scan_reason_n-8,Initial,
ENG26348-ENG30133,Scan_cycle_data-Scan_reason_n-9,Initial,
ENG26348-ENG30134,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG26348-ENG30135,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG26348-ENG30136,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG26348-ENG30137,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG26348-ENG30138,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG26348-ENG30139,Scan_cycle_data-Scan_trigger_n-13,Set_stop_car,
ENG26348-ENG30140,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG26348-ENG30141,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG26348-ENG30142,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG26348-ENG30143,Scan_cycle_data-Scan_trigger_n-17,Set_stop_car,
ENG26348-ENG30144,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG26348-ENG30145,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG26348-ENG30146,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG26348-ENG30147,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG26348-ENG30148,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG26348-ENG30149,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG26348-ENG30150,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG26348-ENG30151,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG26348-ENG30152,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG26348-ENG30153,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2019,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,12,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00108,service_key_internal_status-Day,10,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00109,service_key_internal_status-Hours,16,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,12,
ENG129035-MAS00111,service_key_internal_status-Seconds,50,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,51,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG08630-ENG09181,WFS_key_signature-clap_15_activateing_signature,01,
ENG08630-ENG09176,WFS_key_signature-signature_key_1,02 18,
ENG08630-ENG09177,WFS_key_signature-signature_key_2,00 63,
ENG08630-ENG09178,WFS_key_signature-signature_key_3,00 00,
ENG08630-ENG09179,WFS_key_signature-signature_key_4,00 00,
ENG08630-ENG09180,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:20
08:
;SW:5GM-907-044-G HW:5GM-907-044-G --- Auto HVAC
;Component:Climatronic H04 2001, Coding:02020024200118000104000012111008
;EV_ACClimaBHBVW37X,006146,EV_ACClimaBHBVW37X_006_VW37.rod
;Tuesday,10,December,2019,21:36:37:14741
;VCID: C8C2B36AA230E211E1CB-809C
IDE00019,Voltage terminal 30,12.5, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,24, °C
IDE00075,Vehicle speed,0, km/h
IDE00198,Refrigerant pressure,4.8, bar
IDE00322,Status of basic setting,was not yet started,
IDE00767,No. of unscheduled ECU resets,3,
IDE00965,Compressor shut-off requirement,Engine running time too short: engine start not detected by CAN,
IDE00966,Compressor current: actual value,0.000, A
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,0, /min
IDE00969,Compressor load,0.5, Nm
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside air temperature,11.5, °C
IDE00974,Outside air temperature internally calculated,11.5, °C
IDE00976,Left front vent temperature,16.3, °C
IDE00977,Right front vent temperature,16.7, °C
IDE00981,Footwell vent temperature,16.3, °C
IDE00982,Temperature after evaporator,18.0, °C
IDE00983,Interior temperature,17.7, °C
IDE00984,Sun intensity left,0, W/m²
IDE00985,Sun intensity right,0, W/m²
IDE00987,Blower voltage: specified value,0.0, V
IDE00989,Blower status,not active,
IDE00994,Actual value for fresh air/recirculation air flow flap,0.0, %
IDE00994,Actual value for fresh air/recirculation air flow flap,78,
IDE00995,Specified value for fresh air/recirc air flow flap,73,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,164,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,78,
IDE00998,Left temperature flap - actual value,151,
IDE00998,Left temperature flap - actual value,59.0, %
IDE00999,Left temperature flap - specified value,240,
IDE01040,Left temperature flap: cold stop,29,
IDE01041,Left temperature flap: warm stop,235,
IDE01042,Right temperature flap: actual value,149,
IDE01042,Right temperature flap: actual value,59.5, %
IDE01043,Right temperature flap: specified value,237,
IDE01044,Right temperature flap: cold stop,25,
IDE01045,Right temperature flap: warm stop,232,
IDE01050,Front air distribution flap: actual value,131,
IDE01050,Front air distribution flap: actual value,50.0, %
IDE01051,Front air distribution flap: specified value,130,
IDE01052,Front air distribution flap: air outlet stop,235,
IDE01053,Front air distribution flap: footwell air outlet stop,25,
IDE01054,Defroster flap: actual value,157,
IDE01054,Defroster flap: actual value,65.0, %
IDE01055,Defroster flap: specified value,158,
IDE01056,Defroster flap: stop open,229,
IDE01057,Defroster flap: stop closed,21,
IDE01063,Status of recirculation air,Fresh air,
IDE01066,Convertible top status,closed,
IDE01076,Time since ignition off,240, min
IDE01088,Rear temperature flap: actual value,20,
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01089,Rear temperature flap: specified value,20,
IDE01090,Rear temperature flap: cold stop,0,
IDE01091,Rear temperature flap: warm stop,0,
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,0.0, V
IDE01227,Blower current,0.00, A
IDE01232,Supply voltage for external components,5.0, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,12,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,0,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,not activated,
IDE01442-MAS01534,Pressing a button-Recirculating air,not activated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not activated,
IDE01442-MAS01550,Pressing a button-AC,not activated,
IDE01442-MAS01554,Pressing a button-Left heated seat,not activated,
IDE01442-MAS01556,Pressing a button-Right heated seat,not activated,
IDE01442-MAS01560,Pressing a button-OFF,not activated,
IDE01442-MAS01577,Pressing a button-Parking heater,not activated,
IDE01442-MAS02015,Pressing a button-AUTO,not activated,
IDE01442-MAS02192,Pressing a button-SYNC,not activated,
IDE01442-MAS03196,Pressing a button-Menu,not activated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not activated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not activated,
IDE01442-MAS03832,Pressing a button-Air distribution up,not activated,
IDE01442-MAS04605,Pressing a button-AC MAX,not activated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE02270-IDE00002,CAN input signal(s) status-Transport mode,OFF,
IDE02270-IDE01211,CAN input signal(s) status-Static current measuring mode,OFF,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01269,CAN input signal(s) status-Wipe wash,OFF,
IDE02270-MAS01277,CAN input signal(s) status-Rear window heater actual value,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE03008-MAS01517,Stop process prevented-Defrost active,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to setting,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS04353,Stop process prevented-Fogging hazard (humidity sensor),not active,
IDE03008-MAS04354,Stop process prevented-Interior comfort humidity too high (humidity sensor),not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS05047,Stop process prevented-Maximum cooling and heating set,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to setting,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to setting,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to setting,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127,Prevented stop processes (ring memory),Measured value not available,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128,Requested start processes (ring memory),Measured value not available,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,0,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,100,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,15.1, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,15.0, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,56.0, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,6.4, °C
IDE06201,Blower reduction,No switch-off: no reduction,
IDE06235,Potentiometer for rear vent temperature,255,
IDE07159-MAS01155,Control module switch-off: counter-Control module,255,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,255,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measured value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measured value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load mgmnt.,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,33,
Elapsed Time: 00:13
09:
;SW:5Q0-937-087-BA HW:5Q0-937-087-BA --- Cent. Elect.
;Component:BCM PQ37BOSCH 036 0265, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,019001,EV_BCMBOSCH_019.rod
;Tuesday,10,December,2019,21:37:08:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: FBA81CA6A36679893CC9-80AE
Group,Description,Actual
IDE00075,Vehicle speed,0.00, km/h
IDE00323,Security Access: Number of invalid keys,0,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,Open,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside air temperature,11.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01285,Counter of component protection malfunctions,0,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,not active,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943-MAS01737,Turn signal-Diagnosis,normal,
IDE01943-MAS02248,Turn signal-Signal state,not active,
IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
IDE01943-MAS04351,Turn signal-Connector terminal number,71,
IDE01943-MAS04352,Turn signal-Connector number,Plug A,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded/not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
IDE02486,Data logger triggering,not active,
IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
IDE02515-MAS01737,Low beam-Diagnosis,normal,
IDE02515-MAS02248,Low beam-Signal state,not active,
IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
IDE02515-MAS04351,Low beam-Connector terminal number,5,
IDE02515-MAS04352,Low beam-Connector number,Plug C,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not coded/not installed,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear Window Wiper,not active,
IDE02743-MAS01737,High Beam-Diagnosis,not coded/not installed,
IDE02743-MAS02248,High Beam-Signal state,Measured value not available,
IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
IDE02743-MAS04351,High Beam-Connector terminal number,0,
IDE02743-MAS04352,High Beam-Connector number,not coded/not installed,
IDE02744-MAS01632,Steering wheel heater-Status,switched off,
IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not activated,
IDE02744-MAS09758,Steering wheel heater-Temperature sensor,254,
IDE02857-IDE03111,Activation current-Interior light,0, mA
IDE02857-IDE05533,Activation current-Spray nozzle heater,0, mA
IDE02857-IDE06012,Activation current-Search lights,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,65532, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,65532, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,0, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957-MAS01737,Ambient lighting-Diagnosis,not coded/not installed,
IDE02957-MAS02248,Ambient lighting-Signal state,NOT-DEFINED,
IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
IDE02957-MAS04351,Ambient lighting-Connector terminal number,0,
IDE02957-MAS04352,Ambient lighting-Connector number,not coded/not installed,
IDE02957-MAS06670,Ambient lighting-Channel,Not available,
IDE03111-MAS01737,Interior light-Diagnosis,normal,
IDE03111-MAS02248,Interior light-Signal state,active,
IDE03111-MAS03873,Interior light-Duty cycle,100.00, %
IDE03111-MAS04351,Interior light-Connector terminal number,12,
IDE03111-MAS04352,Interior light-Connector number,Plug C,
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,0.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,0.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,0.0, V
IDE03310-MAS01737,Brake light-Diagnosis,normal,
IDE03310-MAS02248,Brake light-Signal state,not active,
IDE03310-MAS03873,Brake light-Duty cycle,0.0, %
IDE03310-MAS04351,Brake light-Connector terminal number,71,
IDE03310-MAS04352,Brake light-Connector number,Plug A,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,12.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,12.50, °C
IDE03504-IDE02022,Personalized settings-Comfort opening,All windows,
IDE03504-IDE03679,Personalized settings-Adaptive light functions,active,
IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
IDE03504-MAS01597,Personalized settings-Sunroof,active,
IDE03504-MAS04322,Personalized settings-Masked continuous high beam,active,
IDE03504-MAS06456,Personalized settings-Autolock,active,
IDE03504-MAS06457,Personalized settings-autounlock,not active,
IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
IDE03504-MAS07014,Personalized settings-Tourist light,not active,
IDE03504-MAS07967,Personalized settings-profile,1,
IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
IDE03504-MAS07972,Personalized settings-Manual door unlock,all,
IDE03504-MAS07973,Personalized settings-Rain closure,not active,
IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
IDE03504-MAS07980,Personalized settings-Mirror lowering,not active,
IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
IDE03504-MAS07985,Personalized settings-Coming Home set point,15, s
IDE03504-MAS07986,Personalized settings-Leaving Home set point,5, s
IDE03504-MAS07987,Personalized settings-Light intensity,normal,
IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
IDE03504-MAS07993,Personalized settings-Rain light,active,
IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
IDE03638-MAS01737,static AFS light-Diagnosis,not coded/not installed,
IDE03638-MAS02248,static AFS light-Signal state,Measured value not available,
IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
IDE03638-MAS04351,static AFS light-Connector terminal number,0,
IDE03638-MAS04352,static AFS light-Connector number,not coded/not installed,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00104,Expanded environmental conditions-DTC,00 00 00,
IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE04925-MAS02248,Daytime running lights-Signal state,Measured value not available,
IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
IDE04925-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,On,
IDE05042-MAS02158,Emergency flasher button-Actuation condition,Not operated,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,22.00, %
IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
IDE05045-MAS01632,Front windshield wiper module-Status,not active,
IDE05045-MAS02282,Front windshield wiper module-Position,lower turn position,
IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,1200,
IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
IDE05323-MAS01737,Fog light-Diagnosis,normal,
IDE05323-MAS02248,Fog light-Signal state,not active,
IDE05323-MAS03873,Fog light-Duty cycle,0.0, %
IDE05323-MAS04351,Fog light-Connector terminal number,45,
IDE05323-MAS04352,Fog light-Connector number,Plug B,
IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
IDE05434-MAS02248,Rear entry light-Signal state,Measured value not available,
IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
IDE05434-MAS04150,Rear entry light-Side,NOT-DEFINED,
IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
IDE05434-MAS04352,Rear entry light-Connector number,not coded/not installed,
IDE05533,Spray nozzle heater,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02339,Window washer system-Windshield washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,Not operated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
IDE05730-MAS02248,Luggage compartment light-Signal state,Measured value not available,
IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
IDE05730-MAS04352,Luggage compartment light-Connector number,not coded/not installed,
IDE05739-MAS01737,Footwell light-Diagnosis,normal,
IDE05739-MAS02248,Footwell light-Signal state,not active,
IDE05739-MAS03873,Footwell light-Duty cycle,0.0, %
IDE05739-MAS04351,Footwell light-Connector terminal number,72,
IDE05739-MAS04352,Footwell light-Connector number,Plug C,
IDE05742-IDE02515,Light switch position-Low beam,not activated,
IDE05742-IDE05323,Light switch position-Fog light,not activated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not activated,
IDE05742-MAS03835,Light switch position-Parking light,not activated,
IDE05742-MAS03836,Light switch position-Rear fog light,not coded/not installed,
IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded/not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,0,
IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
IDE05830-MAS02282,Rear Spoiler-Position,Unknown (65534),
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00211,Driver info-Insufficient brake fluid,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00213,Driver info-Insufficient coolant,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05836-MAS03638,Rain recognition sensor-Wipe speed,0,
IDE05836-MAS04806,Rain recognition sensor-Splash,not active,
IDE05836-MAS04807,Rain recognition sensor-park position,active,
IDE05837,Activation for signal horn,not active,
IDE05838-MAS01794,Light recognition sensor-Freeway,OFF,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,0, lx
IDE05838-MAS04808,Light recognition sensor-Rain,OFF,
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839-MAS01737,Parking light-Diagnosis,normal,
IDE05839-MAS02248,Parking light-Signal state,active,
IDE05839-MAS03873,Parking light-Duty cycle,100.0, %
IDE05839-MAS04351,Parking light-Connector terminal number,39,
IDE05839-MAS04352,Parking light-Connector number,Plug B,
IDE05841-MAS06441,Central locking history data-Control-section / cause,autounlock,
IDE05841-MAS07519,Central locking history data-Command,Unlocking of entire vehicle,
IDE05841-MAS07942,Central locking history data-Additional information,Measured value not available,
IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
IDE05842-MAS00218,Comfort function history data-Driver door,not active,
IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
IDE05842-MAS06441,Comfort function history data-Control-section / cause,keine Bedienstelle,
IDE05842-MAS07560,Comfort function history data-Top,not active,
IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
IDE05842-MAS07941,Comfort function history data-Operating command,Open,
IDE06012-MAS01737,Search lights-Diagnosis,normal,
IDE06012-MAS02248,Search lights-Signal state,not active,
IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
IDE06012-MAS04351,Search lights-Connector terminal number,62,
IDE06012-MAS04352,Search lights-Connector number,Plug C,
IDE06012-MAS15156,Search lights-terminal,Variant A,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-38.8, °C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,15.5, °C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,56.5, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,-38.9, °C
IDE06096-IDE03111,Interior lighting-Interior light,0, %
IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,100.0, %
IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,100.0, %
IDE06096-MAS01634,Interior lighting-Supply voltage,100.0, %
IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
IDE06470-MAS02248,Ambience lighting-Signal state,Measured value not available,
IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
IDE06470-MAS04352,Ambience lighting-Connector number,not coded/not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,not coded/not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded/not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not activated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,OFF,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
IDE06649-MAS05016,Radio-frequency transmitter-Receiver status,not installed,
IDE06649-MAS05048,Radio-frequency transmitter-Number of transmitters adapted,0,
IDE06649-ENG116085,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG116115,Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
IDE06695-MAS00107,Energy management: last critical state-Month,0,
IDE06695-MAS00108,Energy management: last critical state-Day,0,
IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
IDE06695-ENG99063,Energy management: last critical state-Year,2000,
IDE06864-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
IDE06864-MAS02248,Daytime running lights-Signal state,Measured value not available,
IDE06864-MAS03873,Daytime running lights-Duty cycle,0.0, %
IDE06864-MAS04351,Daytime running lights-Connector terminal number,0,
IDE06864-MAS04352,Daytime running lights-Connector number,not coded/not installed,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,54.50, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,807.7, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,4.980, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Implausible,
IDE07345,Sunroof front closed position switch,not activated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
IDE07346,Sunroof shade switches,not activated,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,Unknown (254),
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,Unknown (254),
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,Unknown (254),
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Autolock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG09185,Central locking-Load_compartment_closing,not coded/not installed,
IDE08211-MAS00106,History data control module reset-Year,2000,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,0,
IDE08211-MAS00110,History data control module reset-Minutes,0,
IDE08211-MAS03129,History data control module reset-Reset counter,6,
IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
IDE08343,Immobilizer Challenge,24 F0 0E CB,
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,0, mA
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,0, mA
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,90, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,130, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,0, mA
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,0, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,0, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,0, mA
IDE08949-MAS07885,Operating current: light driver-Conn. pin 18,0, mA
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,0, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,0, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,0, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,0, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,0, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,0, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,0, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,0, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake light,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-static AFS light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog light,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Parking light,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded/not installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
IDE11943-MAS02248,Signature light-Signal state,Measured value not available,
IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
IDE11943-MAS04351,Signature light-Connector terminal number,0,
IDE11943-MAS04352,Signature light-Connector number,not coded/not installed,
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not Present,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Intermittent operation,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not activated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not activated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not activated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not activated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not activated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not activated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not activated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 2,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not activated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not activated,
IDE12940,Lever functions of the steering column electronics,not activated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded/not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded/not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,12.45, V
MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,12.45, V
MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,12.45, V
MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,12.45, V
MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,12.35, V
MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.95, V
MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,12.40, V
MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,37,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,17,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,12,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,373, km
MAS00829-MAS00244,Access and start authorization-Awakening wire,not activated,
MAS00829-MAS01763,Access and start authorization-Signal Strength,-48,
MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,0, ms
MAS01281-MAS01737,Back-up light-Diagnosis,normal,
MAS01281-MAS02248,Back-up light-Signal state,not active,
MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
MAS01281-MAS04351,Back-up light-Connector terminal number,11,
MAS01281-MAS04352,Back-up light-Connector number,Plug C,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heater,not enabled,
MAS01490-IDE04216,Energy management-Mirror heater,not enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,not enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded/not installed,
MAS01490-MAS01564,Energy management-Windshield defogger,not coded/not installed,
MAS01490-MAS01632,Energy management-Status,active,
MAS01490-MAS02390,Energy management-Shutoff,0,
MAS01490-MAS05795,Energy management-Rear seat heater,not enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Seat heater front,No enabling,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,1,
MAS01490-MAS06560,Energy management-Short distance drive,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835-MAS01737,Parking light-Diagnosis,normal,
MAS03835-MAS02248,Parking light-Signal state,active,
MAS03835-MAS03873,Parking light-Duty cycle,100.0, %
MAS03835-MAS04351,Parking light-Connector terminal number,39,
MAS03835-MAS04352,Parking light-Connector number,Plug B,
MAS03836-MAS01737,Rear fog light-Diagnosis,not coded/not installed,
MAS03836-MAS02248,Rear fog light-Signal state,Measured value not available,
MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
MAS03836-MAS04351,Rear fog light-Connector terminal number,0,
MAS03836-MAS04352,Rear fog light-Connector number,not coded/not installed,
MAS07959-IDE00787,Remote start history data-Cause for cancellation,no reason for cancellation,
MAS07959-MAS00107,Remote start history data-Month,15,
MAS07959-MAS00108,Remote start history data-Day,31,
MAS07959-MAS00109,Remote start history data-Hours,31,
MAS07959-MAS00110,Remote start history data-Minutes,63,
MAS07959-MAS07960,Remote start history data-Stop or cancel cause,No reason for prevention,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843-MAS00106,SE references from last used digital key devices-Year,2000,
MAS18843-MAS00107,SE references from last used digital key devices-Month,0,
MAS18843-MAS00108,SE references from last used digital key devices-Day,0,
MAS18843-MAS00109,SE references from last used digital key devices-Hours,0,
MAS18843-MAS00110,SE references from last used digital key devices-Minutes,0,
MAS18843-MAS00711,SE references from last used digital key devices-Odometer reading,1048574, km
MAS18843-ENG118445,SE references from last used digital key devices-Secure_element_reference,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS18843-ENG118320,SE references from last used digital key devices-Secure_element_reference_state,Remote start function active,
ENG116910,Control unit internal measured value (supplier),31 37 30 33 30 30 30 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,0,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,0,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,keine Stoerschutzursache,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116008-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG116008-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,not coded/not installed,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG116793,Monitor 1,00 00 00 00 00 00 00 00,
ENG116802,Monitor 10,00 00 00 00 00 00 00 00,
ENG116794,Monitor 2,00 00 00 00 00 00 00 00,
ENG116795,Monitor 3,00 00 00 00 00 00 00 00,
ENG116796,Monitor 4,00 00 00 00 00 00 00 00,
ENG116797,Monitor 5,00 00 00 00 00 00 00 00,
ENG116798,Monitor 6,00 00 00 00 00 00 00 00,
ENG116799,Monitor 7,00 00 00 00 00 00 00 00,
ENG116800,Monitor 8,00 00 00 00 00 00 00 00,
ENG116801,Monitor 9,00 00 00 00 00 00 00 00,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A 86 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 32 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,12,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,7,
ENG126653-MAS00109,Personalized_Account_Key_History-Hours,11,
ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,35,
ENG126653-MAS01551,Personalized_Account_Key_History-Key number,2,
ENG126653-ENG28771,Personalized_Account_Key_History-Account,1,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,1,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,2,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,1,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,1,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,1,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,1,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,1,
ENG126654-MAS00107,Personalized_Signals-Month,0,
ENG126654-MAS00108,Personalized_Signals-Day,0,
ENG126654-MAS00109,Personalized_Signals-Hours,0,
ENG126654-MAS00110,Personalized_Signals-Minutes,0,
ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,1,
ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
ENG126654-ENG28772,Personalized_Signals-Perso_Konto,1,
ENG126654-ENG28775,Personalized_Signals-Perso_Status,1,
ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
ENG116792-ENG115817,Power up history-Funktionsanforderung,1,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,347, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.2, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,12.8, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.4, V
ENG116791,Temperatures,11.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG30013,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG30027,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG30075,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG30182,Valeo_Entwickler_MWB-WakeUp2,OFF,
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
ENG116907-IDE04639,Zusaetzliche Umgebungsdaten-Last wake-up cause,no cause for fault protection,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,11.5, °C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,not activated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,12.4, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
ENG116907-MAS14232,Zusaetzliche Umgebungsdaten-Light switch: zero setting,operated,
ENG116907-MAS19766,Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete,OFF,
ENG116907-MAS19768,Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status,OFF,
Elapsed Time: 00:43
10:
;SW:5QA-919-298-D HW:5QA-919-298-A --- Park/Steer Assist
;Component:PLA 3.0 12KH07 0050, Coding:0271167801
;EV_EPHVA2CAU3700000,009041,EV_EPHVA2CAU3700000_009_VW37.rod
;Tuesday,10,December,2019,21:40:02:14741
;VCID: D1F49E0E516A23D9B635-8084
IDE00018,Voltage terminal 15,12.1, V
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,not active,
IDE00325,Diagnostic mode,OBD-diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,39, cm
IDE00958-MAS01632,Resulting distance of rear sensors-Status,52, cm
IDE00974,Outside air temperature internally calculated,11.50, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,53, cm
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,53, cm
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,94, cm
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,118, cm
IDE01130-MAS01632,Distance of right front park assist sensors-Status,45, cm
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,ERROR,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,1.008, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,1.008, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,ERROR,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,1.056, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,1.120, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,1.104, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,1.040, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 1,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 7,
IDE01163,Sound output for park assist in selector lever position P,not installed,
IDE01164,Park assist button,not activated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,12.1, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio reduction request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,70, cm
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.944, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.976, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,40, cm
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,1.056, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,1.008, ms
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01943,Turn signal,not activated,
IDE01965,Parallel parking assistance button,not activated,
IDE01966,Cause of parallel park assist switching off,No shut-off requirement,
IDE01967,Parking side,Right,
IDE02486,Data logger triggering,not active,
IDE03683,Request power steering boost,No,
IDE03684,Vehicle stopped,Yes,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03783,Switch-on speed for parallel parking assist,37, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator position,255, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,255, bar
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2127,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,15,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,31,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,31,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,63,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,63,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,0.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,58,
MAS01426,Speaker volume for rear park assist,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 1,
MAS01428,Speaker volume for front park assist,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 7,
MAS10122,ARA operating condition,Initializing,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,10, %
ENG113996-ENG113979,Function_PLA-BS_alignement_BF,Yes,
ENG113996-ENG113982,Function_PLA-BS_alignement_driver,Yes,
ENG113996-ENG113978,Function_PLA-BS_identified_BF,Yes,
ENG113996-ENG113980,Function_PLA-BS_identified_BF_old,Yes,
ENG113996-ENG113981,Function_PLA-BS_identified_Driver,Yes,
ENG113996-ENG113983,Function_PLA-BS_identified_Driver_old,Yes,
ENG113996-ENG106720,Function_PLA-Fzgx_Max,6533.0, cm
ENG113996-ENG106721,Function_PLA-Fzgy_Max,1280.1, cm
ENG113996-ENG113974,Function_PLA-L_Rangier_Min,6553.5, cm
ENG113996-ENG107571,Function_PLA-Manual_Steering_Moment,0.0, Nm
ENG113996-ENG108155,Function_PLA-Parking_Aid_Senders_Cutoff_Time,0, s
ENG113996-ENG113977,Function_PLA-PL_Depth_BF,6553.5, cm
ENG113996-ENG113986,Function_PLA-PL_depth_BF_old,50, cm
ENG113996-ENG113988,Function_PLA-PL_Depth_Driver,6553.5, cm
ENG113996-ENG113990,Function_PLA-PL_Depth_Driver_Old,0.0, cm
ENG113996-ENG113976,Function_PLA-PL_Length_BF,6553.5, cm
ENG113996-ENG113985,Function_PLA-PL_Length_BF_old,537.5, cm
ENG113996-ENG113987,Function_PLA-PL_Length_Driver,1280.1, cm
ENG113996-ENG113989,Function_PLA-PL_Length_Driver_Old,6553.5, cm
ENG113996-ENG108329,Function_PLA-Psi0_BF,70.31, °
ENG113996-ENG108330,Function_PLA-Psi0_BF_Alt,359.99, °
ENG113996-ENG108331,Function_PLA-Psi0_Fahrer,359.99, °
ENG113996-ENG108332,Function_PLA-Psi0_Fahrer_Alt,70.59, °
ENG113996-ENG109009,Function_PLA-Speed_Limit_Power_Steering,255, km/h
ENG113996-ENG109117,Function_PLA-Steering_Angle_Actual_Value,0.0, °
ENG113996-ENG109118,Function_PLA-Steering_Angle_Nominal_Value,0.0, °
ENG113996-ENG113975,Function_PLA-T_Rangier_Min,6530.0, cm
ENG113996-ENG113984,Function_PLA-Visual_Indication,Yes,
ENG113996-ENG110295,Function_PLA-X0_BF,256.0, cm
ENG113996-ENG110296,Function_PLA-X0_BF_Alt,2024.5, cm
ENG113996-ENG110297,Function_PLA-X0_Fahrer,1280.1, cm
ENG113996-ENG110298,Function_PLA-X0_Fahrer_Alt,-0.1, cm
ENG113996-ENG110299,Function_PLA-Xa_BF_Alt,-23.6, cm
ENG113996-ENG110300,Function_PLA-Xa_Fahrer_Alt,51.1, cm
ENG113996-ENG110301,Function_PLA-Y0_BF,37.3, cm
ENG113996-ENG110302,Function_PLA-Y0_BF_Alt,2303.4, cm
ENG113996-ENG110303,Function_PLA-Y0_Fahrer,-0.1, cm
ENG113996-ENG110304,Function_PLA-Y0_Fahrer_Alt,537.5, cm
ENG113996-ENG113973,Function_PLA-Ya_Alt,-20.6, cm
ENG113996-ENG110306,Function_PLA-Ya_Fahrer_Alt,-0.1, cm
Elapsed Time: 00:14
13:
;SW:5Q0-907-572-P HW:3QF-907-572-A --- Auto Dist. Reg
;Component:ACC BOSCH MQB H11 0682, Coding:2D0000C141FFC728949C810510401600000000000000000004
;EV_ACCBOSCHVW416,002008,EV_ACCBOSCHVW416_002_VW37.rod
;Tuesday,10,December,2019,21:40:28:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: C4DAA75A9E18C6710DB3-8090
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,12.4, V
IDE00102,Control Module temperature,33, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01788,Heated lens control signal,0.00, %
IDE01794,ACC operating lever signal,00000000 10101000 ,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,8C 87 2B E7,
IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 90 01,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 F7 2F 35 53 5E E2 17 A5 77 DB 79 FD 19 AF 44 A3 60 AB 15 CA A5 5E F9 45 CD 6F 1E F6 A2 BE 4E 8D 28 64 CF 1C 34 C7 C9 16 DE DE 67 B5 57 39 00 C2 53 57 B6 FB 19 A1 41 40 A0 F5 B2 60 C0 18 01 6D C7 8E B5 02 83 63 E2 BA D4 28 DD 96 22 FD D1 F4 87 8B 5F EC EC 1D 9D 62 41 0B 2B 9F 3C 6B 2B AE 87 95 D3 A9 B9 72 54 56 6C 80 1C 53 40 5F 4E CE C1 CD 32 AD 83 5B 53 DE BA EF E3 D0 D0 B8 A7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE05814,Individualization characteristic,C8 4E D2 18 59,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06308,Start request history data,not active,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,24.464, °
IDE08769,Mirror deviation: vertical,-24.464, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.207, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.134, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,19,
IDE09380-MAS00107,Performed adjustment-Month,11,
IDE09380-MAS00108,Performed adjustment-Day,07,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,-0.10, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,2.30, °
IDE09906,Vertical deadjustment,1.243, °
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.130, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,1.240, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,-0.100, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,2.300, °
ENG107409,Longitudinal_acceleration_vehicle_reference,0.00, m/s²
ENG107860,Number_of_ANB_partial_bracings,0,
ENG107861,Number_of_ANB_target_bracings,0,
ENG107862,Number_of_ANB-CM,0,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00915,Number_of_fully_developed_deceleration_1,0,
ENG00916,Number_of_fully_developed_deceleration_2,0,
ENG06681,Number_of_mainwarnings,0,
ENG03998,number_of_prewarnings,0,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,14, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,1, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,13, min
ENG00921,Operating_time_ACC_active_timegap_1,0, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,1, min
ENG00924,Operating_time_ACC_active_timegap_4,10, min
ENG00925,Operating_time_ACC_active_timegap_5,2, min
ENG00929,Operating_time_ACC_active_v-delta_0,14, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG00933,Operating_time_STA_active,0, min
ENG00934,Operating_time_STA_off_activation_possible,0, min
ENG00935,Status_ACC_System,ACC_StandBy,
ENG08760,Sw_version_supplier,1037604546;PF_R28.9.0_VW.MQB_371_JETTA.0682_I1.0;0;Compiled by bor7htv on Wed Nov 29 18:39:27 2017$!,
ENG109878,Velocity_vehicle_reference,0.00, m/s
Elapsed Time: 00:14
15:
;SW:5Q0-959-655-J HW:5Q0-959-655-J --- Airbags
;Component:AirbagVW20 010 0830, Coding:8CCCFC00000000005000001AC24800000065
;EV_AirbaVW20SMEVW37X,002144,EV_AirbaVW20SMEVW37X_VW37.rod
;Tuesday,10,December,2019,21:40:50:14741
;VCID: C7C0B056AF2EED69E8D1-8092
IDE00821,Safety belt switch 2nd row driver side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Safety belt switch 2nd row center,not installed,
IDE00824,Driver side 3rd row seat belt switch,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.9, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.2, Ohm
IDE01102,Driver's side airbag igniter ohm value,2.5, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.2, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.2, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.3, Ohm
IDE01115,side belt force limiter igniter ohm value,2.3, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,no measured value present,
IDE01117,Passenger side rear belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,too Low,
IDE01194,Frt.pass. belt tensioner ohm value,too Low,
IDE01195,Front passenger side seat occupancy detection: Ohm value,no measured value present,
IDE01197,Key switch contact 1 ohm value,too High,
IDE01198,Key switch contact 2 ohm value,too High,
IDE01200,Driver seat position sensor current value,5.9, mA
IDE01201,Frt.pass. seat position sensor current value,6.1, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01285,Counter of component protection malfunctions,0,
IDE01555,Number of frontal crashes,0,
IDE01556,Number of side crashes driver side,0,
IDE01557,Number of side crashes frt.pass. side,0,
IDE01558,Number of rear crashes,0,
IDE01559,Number of rollover crashes,0,
IDE02246,Number of activations of pedestrian protection,0,
IDE02852,Igniter for battery interrupt: high voltage battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,00,
IDE06959,Seat occupant detection: diagnosis signal,31.0, %
IDE06960,Seat occupant detection: msmt. signal,1.0, %
IDE06961,Seat occupant detection: ref. signal,0.5, %
MAS00001,Driver airbag igniter,correct,
MAS00003,Passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,cannot be measured currently,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
MAS00017,Driver side belt force limiter igniter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,cannot be measured currently,
MAS00020,Passenger side rear safety belt tension igniter,cannot be measured currently,
MAS00022,Igniter for battery interrupt,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00044,Supply voltage: Terminal 15,12.4, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:11
17:
;SW:5G1-920-840-D HW:5G1-920-840-D --- Instruments
;Component:KOMBI 252 2700, Coding:0BA41015ED88CF0502886A0B5001000080000000
;EV_DashBoardVDDMQBAB,009068,EV_DashBoardVDDMQBAB_009_VW37.rod
;Tuesday,10,December,2019,21:31:25:14741
;VCID: A80213EA02700211018B-80FC
IDE00019,Voltage terminal 30,12.4, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,24.00, °C
IDE00075,Vehicle speed,0, km/h
IDE00196,Engine oil temperature,23, °C
IDE00301,Distance,373, km
IDE00310,Outside air temperature,11.5, °C
IDE00316-IDE00500,Time-Hour,21, H
IDE00316-IDE00501,Time-Minute,31, min
IDE00316-MAS00111,Time-Seconds,10, s
IDE00317-IDE00502,Date-Year,2019, yr
IDE00317-IDE00503,Date-Month,12, mon
IDE00317-IDE00504,Date-Day,10, d
IDE00510,ESI: distance driven from inspection,373, km
IDE00511,ESI: time from inspection,34, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,900, km
IDE00520,Phototransistor,0,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,15730, km
IDE00698,ESI: remaining running time,331, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,34, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1976, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,1976, mm
IDE00935,ESI: Theoretical service interval,15000, km
IDE01076,Time since ignition off,18454, s
IDE01153,SIA: maximum value of distance to service,16100, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01985-MAS06854,FAZIT identification test sum-Version,02,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,69 9C F5 D3,
IDE02307,Parking brake status,operated,
IDE02642,Outside temp.: displayed value,11.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,64,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,4095,
IDE03349,FIX: Max. distance until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,300, km
IDE03352,FIX: Time since last time-dependent inspection,34, d
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,4.6, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,54.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,57.5, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,4.3, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,4.0, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,17.6, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,16.4, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,2.8, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,8.8, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,8.8, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.0, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,100,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,0,
IDE03472-MAS06155,Volume after refueling-Third to last distance,0,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,89, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,201, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,1, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,1, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,1271,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,2291,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,2061,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,1702,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,33.3, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,88, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,199, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,21.3, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,11.7, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,21.3, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,11.7, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,33.0, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,33.0, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,33.0, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.21875, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,32.5, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,111,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,21, H
IDE03477-IDE00501,GPS time-Minute,31, min
IDE03477-IDE00501,GPS time-Minute,20, min
IDE03477-IDE00502,GPS time-Year,2019, yr
IDE03477-IDE00503,GPS time-Month,12, mon
IDE03477-IDE00504,GPS time-Day,10, d
IDE03477-MAS00111,GPS time-Seconds,15, s
IDE03477-MAS00111,GPS time-Seconds,0, s
IDE03477-MAS03493,GPS time-last synchronization year,2019, yr
IDE03506,Distance: high resolution,00 05 B1 FD,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,FF FF FF FF,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,FF FF FF FF,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,FF FF FF FF,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,FF FF FF FF,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,730, d
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
ENG124477-MAS06854,Adapted_transponders_checksum-Version,01,
ENG124477-MAS06855,Adapted_transponders_checksum-Test sum,9E 23 44 E8,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,8, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,29, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,22, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,13, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,100, km
ENG106922,Immobilizer - Challenge,F4 A2 DB 00,
ENG99439,Instrument_recorder,03 03 81 00 4D 51 42 56 57 31 38 53 31 4D 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 01 E0 00 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7F FB,
ENG107920-ENG100914,onboard_computer-current_consumption,0.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,8.3, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,8.3, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,8.7, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,362, km
ENG107920-ENG119792,onboard_computer-range_R,363,
ENG107920-ENG112418,onboard_computer-total_range_gas,362, km
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,123,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG103405,read_out_measured_value_block,0,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,34,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,0,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,0,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,0,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 6A 02 00 00 00 01 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,F8,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,00,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,1C,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,00,
ENG103284-ENG20775,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG20776,State of Immobilizer Slaves-VTS_state,00,
ENG109576,Transponder ID Key 1,0A F9 08 E1,
ENG109577,Transponder ID Key 2,0A F9 22 9A,
Elapsed Time: 00:12
19:
;SW:3Q0-907-530-AA HW:3Q0-907-530-C --- CAN Gateway
;Component:GW MQB High 521 5366, Coding:0901000830085900FB00221A0A0F00000001070000000000000000000000
;EV_GatewNF,013025,EV_GatewNF_VW37.rod
;Tuesday,10,December,2019,21:32:11:14741
;VCID: EE8E25F2E0141C218B57-80BA
IDE00019,Voltage terminal 30,12.5, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056-ENG20489,History data 1-Life Cycle Data String,-------------:--*--.-*--*-----***
IDE00057-ENG20489,History data 2-Life Cycle Data String,-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489,History data 3-Life Cycle Data String, 0000017km*T*0*050*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000017km*T*0*100*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000016km*T*0*050*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000016km*T*0*060*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000016km*T*0*070*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000016km*T*0*080*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000016km*T*0*100*100*0-0-0-0-0-0-0*-*0*00.0*00.0**
0000016km*T*0*060*100*0-0-0-0-0-0-0*-*0*00.0*00.0**,
IDE00059-ENG20489,History data 4-Life Cycle Data String, 0000000km*01*060*JCB*1111111111*10000*00000*000.0*000.0*000.0**
IDE00060-ENG20489,History data 5-Life Cycle Data String,-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061-ENG20489,History data 6-Life Cycle Data String,2019-12-10-15:48*100*-40*+000.0*00.50*0.00*000**
2019-12-10-06:26*100*-40*+000.0*00.50*0.00*000**
2019-12-09-16:33*100*-40*+000.0*00.10*0.00*000**
2019-12-09-15:56*100*-40*+000.0*00.40*0.00*000**
2019-12-09-06:28*100*-40*+000.0*00.40*0.00*000**
2019-12-08-16:01*100*-40*+000.0*00.60*0.00*000**
2019-12-08-13:30*100*-40*+000.0*00.20*0.00*000**
2019-12-08-12:38*100*-40*+000.0*00.20*0.00*000**
2019-12-08-11:42*100*-40*+000.0*00.60*0.00*000**
2019-12-08-10:55*100*-40*+000.0*00.10*0.00*000**,
IDE00062-ENG20489,History data 7-Life Cycle Data String,-------------:--*---*----.-*---.-*--.-*--.-**
IDE00063-ENG20489,History data 8-Life Cycle Data String,2019-12-06-16:30*4*00*00*00*01*2011-01-31-01:29*01**
IDE00064-ENG20489,History data 9-Life Cycle Data String, 0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
IDE00065-ENG20489,History data 10-Life Cycle Data String,-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066-ENG20489,History data 11-Life Cycle Data String,-------------:--*---*---*---*---*----*---*--.-*--.-*---*---*---*---*--*-----*-----*-----*-----*-----**
IDE00067-ENG20489,History data 12-Life Cycle Data String,-------------:--*---------------**
IDE00068-ENG20489,History data 13-Life Cycle Data String,-------------:--*---------*---.-*-----**
IDE00069-ENG20489,History data 14-Life Cycle Data String,2019-12-10-15:48*3*02075*0000*0003*00.50*038045*-40*0003.3*0000.0*0000.0**
2019-12-10-06:26*3*01875*0000*0003*00.50*038045*-40**
2019-12-09-22:23*3*00025*0000*0003*00.00*038045*-40**
2019-12-09-18:08*3*00060*0000*0003*00.00*038045*-40**
2019-12-09-16:33*3*00597*0000*0003*00.10*038045*-40**
00138*00034*00007*00000*00000**
IDE00071-ENG20489,History data 16-Life Cycle Data String, 0000373km**
00000*00000*00000*00000*00000**
00068*00016*00001*00001**
00571*00004*00000*00000**
00052*00013*00003*00013**
00063*00013*00005**
00034*00000*00000**
00000*00000*00000**
00004*00000*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not activated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,8,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,196,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,0,
IDE00773,Terminal 15 status via CAN,On,
IDE01459,Energy management heat output control status,not active,
IDE01805-ENG20489,History data 19-Life Cycle Data String,-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Databus drivetrain,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Databus extended,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Databus Infotainment,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.1, H
IDE01810-MAS00106,History data 24-Year,2019,
IDE01810-MAS00107,History data 24-Month,12,
IDE01810-MAS00108,History data 24-Day,7,
IDE01810-MAS00109,History data 24-Hours,13, H
IDE01810-MAS00110,History data 24-Minutes,59, min
IDE01810-MAS14375,History data 24-Cycle counter,80,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,1,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,80,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,1B 00 00 09,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,9,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Databus extended,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,1B FC 72 0A,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,5,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,17 F0 00 09,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,5,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Databus extended,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,1B 00 00 4B,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,2,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Comfort data bus,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 05 A0,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,2,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Comfort data bus,
IDE01812-MAS01468,History data 26-Terminal 15,109,
IDE01812-MAS03173,History data 26-Databus drivetrain,1,
IDE01812-MAS03174,History data 26-Comfort data bus,508,
IDE01812-MAS03175,History data 26-Databus extended,465,
IDE01812-MAS03177,History data 26-Databus Infotainment,0,
IDE01812-MAS03178,History data 26-Suspension data bus,2,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,976,
IDE01813-MAS03173,History data 27-Databus drivetrain,27,
IDE01813-MAS03174,History data 27-Comfort data bus,543,
IDE01813-MAS03175,History data 27-Databus extended,162,
IDE01813-MAS03177,History data 27-Databus Infotainment,39,
IDE01813-MAS03178,History data 27-Suspension data bus,92,
IDE01813-MAS14374,History data 27-Totals,863,
IDE01814-MAS03173,History data 28-Databus drivetrain,0,
IDE01814-MAS03174,History data 28-Comfort data bus,1040,
IDE01814-MAS03175,History data 28-Databus extended,0,
IDE01814-MAS03177,History data 28-Databus Infotainment,0,
IDE01814-MAS03178,History data 28-Suspension data bus,0,
IDE01814-MAS14374,History data 28-Totals,1048,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.4, H
IDE01816-MAS00106,History data 30-Year,2011,
IDE01816-MAS00107,History data 30-Month,1,
IDE01816-MAS00108,History data 30-Day,1,
IDE01816-MAS00109,History data 30-Hours,18, H
IDE01816-MAS00110,History data 30-Minutes,23, min
IDE01816-MAS14375,History data 30-Cycle counter,31,
IDE01816-ENG20570,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG20572,History data 30-Bus_2,Databus extended,
IDE01816-ENG20574,History data 30-Bus_3,Unknown,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,0.1, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.1, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.0, H
IDE01817-MAS00106,History data 31-Year,2000,
IDE01817-MAS00107,History data 31-Month,1,
IDE01817-MAS00108,History data 31-Day,1,
IDE01817-MAS00109,History data 31-Hours,0, H
IDE01817-MAS00110,History data 31-Minutes,0, min
IDE01817-MAS14375,History data 31-Cycle counter,0,
IDE01817-MAS14376,History data 31-ECU 1,Node_0x-- $-- (empty entry),
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,Node_0x-- $-- (empty entry),
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.1, H
IDE01819-MAS00106,History data 33-Year,2019,
IDE01819-MAS00107,History data 33-Month,12,
IDE01819-MAS00108,History data 33-Day,7,
IDE01819-MAS00109,History data 33-Hours,13, H
IDE01819-MAS00110,History data 33-Minutes,59, min
IDE01819-MAS14375,History data 33-Cycle counter,80,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B FC 72 0A,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,4.9, H
IDE01820-MAS00106,History data 34-Year,2019,
IDE01820-MAS00107,History data 34-Month,12,
IDE01820-MAS00108,History data 34-Day,10,
IDE01820-MAS00109,History data 34-Hours,21, H
IDE01820-MAS00110,History data 34-Minutes,19, min
IDE01820-MAS14375,History data 34-Cycle counter,109,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,2, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,110,
IDE01823-MAS14429,History data 37-Time in current cycle,0.2, H
IDE01827,Generator specified voltage value,10.6, V
IDE01828,Generator DF Signal,0.025, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,110A - 150A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,0,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,12.430, V
IDE01836,Battery current,0.000, A
IDE01837,Temperature of battery sensor,-40, °C
IDE01838,Battery temperature,-40, °C
IDE01839,Battery charge condition,90, %
IDE01841,Battery internal resistance,2.0, mOhm
IDE01842,Usable battery charge,100, Ah
IDE01843,Battery voltage at rest,15.0, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shutdown level,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,ERROR,
IDE01848,Previous journey energy summary,0.0, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,Initializing,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,0.0, A
IDE01948,Battery internal resistance not normed,2.0, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,87 0D 8D D6,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG06041,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG06043,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG06044,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG06045,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG06046,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG06047,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG06048,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG06049,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG06042,Play protection status-function_calls_counter_1,0,
IDE02578-ENG06050,Play protection status-function_calls_counter_2,0,
IDE02578-ENG06051,Play protection status-function_calls_counter_3,0,
IDE02578-ENG06052,Play protection status-function_calls_counter_4,0,
IDE02578-ENG06053,Play protection status-function_calls_counter_5,0,
IDE02578-ENG06054,Play protection status-function_calls_counter_6,0,
IDE02578-ENG06055,Play protection status-function_calls_counter_7,0,
IDE02578-ENG06056,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside air temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer current too high,not active,
IDE03008-MAS04055,Stop process prevented-Usable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery charge condition too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible service life too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-Insuff. voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer current too high,not active,
IDE03009-MAS04055,Start process requested-Usable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery charge condition too low,not active,
IDE03009-MAS04058,Start process requested-Service life expired,not active,
IDE03009-MAS06003,Start process requested-Charging contingent,not active,
IDE03009-MAS06004,Start process requested-Special start requirements,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside air temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Usable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery charge condition too low,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible service life too short,0,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-Insuff. voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer current too high,0,
IDE03011-MAS04055,Number of requested start processes-Usable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery charge condition too low,0,
IDE03011-MAS04058,Number of requested start processes-Service life expired,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,no measured value present,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,no measured value present,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,no measured value present,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,no measured value present,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,System malfunction,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,60, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,Wet,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery malfunction,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04186,Battery terminal recognition,connected,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,present,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,invalid,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,not activated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,not activated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,not activated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,not activated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,not activated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,not activated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,not activated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,not activated,
IDE05583-IDE02766,Pause recommendation-Malfunction status,not installed,
IDE05583-MAS03095,Pause recommendation-Function status,not installed,
IDE05583-MAS04622,Pause recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Pause recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,56 23 1E BB A7,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initializing,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initializing,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initializing,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module (ECM),
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initializing,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,AUTO,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,468,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,65,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,106,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2000,
IDE06230-MAS00107,Break recommend.: last message-Month,0,
IDE06230-MAS00108,Break recommend.: last message-Day,0,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initializing,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,not activated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,76,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,44,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,36,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,Timeout,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,0,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,no request,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop - operation,ERROR,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stoppage time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,155, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,15.0, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,blocked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,Enabled,
IDE07628-MAS06332,Status power receptacle-Status function readiness,Enabled,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in permissible range,
IDE07637,Current charge contingent for feedback,0.0, As
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,active,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,14.65,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognized,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognized,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.00, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,1, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,1, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,0.0, Ah
IDE07681-MAS06087,Battery total charging throughput-Total energy throughput,0.0, Ah
IDE07873-MAS06193,FPA enabled profiles-Profile 1,Not Used,
IDE07873-MAS06194,FPA enabled profiles-Profile 2,AUTO,
IDE07873-MAS06195,FPA enabled profiles-Profile 3,Dynamic,
IDE07873-MAS06196,FPA enabled profiles-Profile 4,Offroad,
IDE07873-MAS06197,FPA enabled profiles-Profile 5,Not Used,
IDE07873-MAS06198,FPA enabled profiles-Profile 6,Not Used,
IDE07873-MAS06199,FPA enabled profiles-Profile 7,Not Used,
IDE07873-MAS06200,FPA enabled profiles-Profile 8,Not Used,
IDE07873-MAS08875,FPA enabled profiles-Profile 9,Not Used,
IDE07873-MAS08876,FPA enabled profiles-Profile 10,Not Used,
IDE07873-MAS08877,FPA enabled profiles-Profile 11,Not Used,
IDE07873-MAS08878,FPA enabled profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,A4 59 72 D3,
IDE08346-MAS06117,Generator Analysis-Rated voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.5, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.1, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,32, °C
IDE08347,adapted battery capacity,254, Ah
IDE08680-MAS03173,Allocation data bus identifier-Databus drivetrain,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Databus extended,15,
IDE08680-MAS03177,Allocation data bus identifier-Databus Infotainment,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Databus drivetrain,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Databus extended,OK,
IDE08681-MAS03177,Data bus defect error-Databus Infotainment,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Databus drivetrain,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Databus extended,OK,
IDE08682-MAS03177,Data bus single wire err.-Databus Infotainment,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Databus drivetrain,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Databus extended,OK,
IDE08683-MAS03177,Data bus TimeOut error-Databus Infotainment,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT09757,Allocation LIN system number-Alternator,00 1D,
IDE08684-SFT09777,Allocation LIN system number-Multi Function Steering Wheel Control Module,00 31,
IDE08684-SFT09783,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT09833,Allocation LIN system number-Power Converter DC AC,00 69,
IDE08684-SFT09842,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT10031,Allocation LIN system number-Operating Unit Drive Mode Selection,01 2F,
IDE08684-SFT10046,Allocation LIN system number-Control module for steering wheel touch recognition,01 3E,
IDE08685-SFT09757,Status LIN user-Alternator,active,
IDE08685-SFT09777,Status LIN user-Multi Function Steering Wheel Control Module,active,
IDE08685-SFT09783,Status LIN user-Battery Monitoring Control Module,not active,
IDE08685-SFT09833,Status LIN user-Power Converter DC AC,active,
IDE08685-SFT09842,Status LIN user-Analog clock,not active,
IDE08685-SFT10031,Status LIN user-Operating Unit Drive Mode Selection,not active,
IDE08685-SFT10046,Status LIN user-Control module for steering wheel touch recognition,not active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initializing,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Closed-circuit current of last LIN sleep phase,0.000, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,7,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initializing,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initializing,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initializing,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initializing,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery Energy Control Module 2,not active,
IDE11911-SFT00196,48V activation restriction-DC/DC Converter Control Module,not active,
IDE11911-SFT09769,48V activation restriction-Control module for auxiliary air heater,not active,
IDE11911-SFT09997,48V activation restriction-Electrical Charger,not active,
IDE12084,Status of component protection slaves,00 14 19 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 6F 21 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00 00 7B 20 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,155, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,No enabling,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12135-MAS14363,Belt driven starter generator 12V-Specified voltage: lower limit,10.60, V
IDE12135-MAS14364,Belt driven starter generator 12V-Specified voltage limit,10.60, V
IDE12135-MAS14365,Belt driven starter generator 12V-Recommended specified voltage,10.6, V
IDE12135-MAS14366,Belt driven starter generator 12V-Maximum ramp time,0, s
IDE12135-MAS14367,Belt driven starter generator 12V-Minimum voltage for start,7.0, V
IDE12135-MAS14368,Belt driven starter generator 12V-Specified voltage of the belt driven starter generator,9.0, V
IDE12135-MAS14369,Belt driven starter generator 12V-Actual mode belt driven starter generator,Unknown (14),
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initializing,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*0000-01-01-00-00-00*0**,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0000000*0000-01-01-00-00-00*0**,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,32,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,32,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,12,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,373, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,not activated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,not activated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Signal horn,not activated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,11,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,not activated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine off,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT09757,Alternator,-,
SFT09757-ENG119789,Alternator-alternator_family,30,
SFT09757-ENG114913,Alternator-asic_manufacturer,30 30,
SFT09757-ENG119379,Alternator-asic_variant,30 34,
SFT09757-ENG40398,Alternator-Manufacturer,30 30,
SFT09757-ENG99001,Alternator-Variant,30 64,
ENG118785-ENG118741,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication,0,
ENG118785-ENG118742,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State,0,
ENG118785-ENG118743,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State,0,
ENG118785-ENG118744,Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value,0,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG06039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG06040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG20970,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG06038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG06036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognized,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognized,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG06004-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.039, V
ENG06004-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,12.4, V
ENG06004-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG06004-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG06004-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,12.4, V
ENG06004-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.35, V
ENG106123,EM_blAlternator On,OFF,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,not active,
ENG20108,EM_electrical_system_current,0.000, A
ENG118437,EM_IAlternatorReserve,0.0, A
ENG118434,EM_LoadResponse Time,6, s
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,100, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,100, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG115189,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,0,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,0,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,0,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,0,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,0,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,0,
ENG118780-ENG36229,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,0,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,0,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,0,
ENG118780-ENG36251,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,0,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,0,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG121521,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,1,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG36309,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG36310,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,1005,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG06026,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,2407,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9070,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG32644,Gateway app. software identification-software_version_mv-em,0300,
ENG118782-ENG32645,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7200,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG20113-ENG09375,MV-EM_48V_electrical_system_components-48V_Ptc_installed,not installed,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09372,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG20113-ENG09373,MV-EM_48V_electrical_system_components-eAv_installed,not installed,
ENG20113-ENG09371,MV-EM_48V_electrical_system_components-eAws_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initializing,
ENG20115-ENG09356,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG20115-ENG09355,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG20115-ENG09357,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG20115-ENG09354,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG20115-ENG09353,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG20115-ENG09358,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initializing,
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0.00, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initializing,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,-204.0, A
ENG20120,MV-EM_dc_power_desired,-6325, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,-511, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
ENG119298-ENG119462,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
Elapsed Time: 00:47
22:
;SW:0CQ-907-554-J HW:0CQ-525-130 --- AWD
;Component:Haldex4Motion H55 7084, Coding:0001
;EV_AllWheelContrHA1VW37X,004013,EV_AllWheelContrHA1VW37X_004.rod
;Tuesday,10,December,2019,21:41:08:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: CCCA8F7AB6480E31C5E3-8098
Group,Description,Actual
IDE00019,Voltage terminal 30,12.4, V
IDE00030,Status of actuator test,not active,
IDE00102,Control Module temperature,17, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00920,Front left wheel speed,0.0, km/h
IDE00921,Front right wheel speed,0.0, km/h
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE01617,Clutch temperature,17.30, °C
IDE02271-IDE02384,CAN output signal(s) status-Status of event memory,not active,
IDE02271-MAS01464,CAN output signal(s) status-Emergency running mode,not active,
IDE02271-MAS01480,CAN output signal(s) status-Excess temp.,not active,
IDE02404,Checksum calculation,DA BD 2A 9E,
IDE02486,Data logger triggering,not active,
IDE04502-MAS04730,Haldex clutch status-Degree of blockage,0.00, %
IDE05609,Cooling fin temperature,14.90, °C
IDE05610,Duration of overtemperature,0, min
IDE05707,Haldex clutch pump current,0.005, A
IDE05708,Haldex clutch pump PWM signal,0, %
IDE05710,Haldex clutch pump voltage,0.0, V
IDE06111,Axle speed deltas,0.0, km/h
IDE12115,Pumps diagnostic: number of tests during service life,9,
IDE12116,Pumps diagnostic: anomalies during service life,7,
IDE12117,Pump diagnostic: anomalies in current driving cycle,0,
IDE12118,Pump diagnostic: total of defined anomalies,0,
IDE80003-ENG119372,Analysis 3-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80003-ENG119373,Analysis 3-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80003-ENG119374,Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed,0,
IDE80004-ENG119372,Analysis 4-Exeedance_Intergral_1_traction_slip_controller,0,
IDE80004-ENG119373,Analysis 4-Exeedance_Intergral_2_extreme_slip_event,0,
IDE80004-ENG119374,Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,40,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS03129,Reset counter,4,
ENG119394-ENG119379,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM,1422,
ENG119394-ENG119380,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement,0,
ENG119394-ENG119378,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM,0,
ENG119394-ENG119381,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM,2270,
ENG119394-ENG119382,Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119384,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM,5088,
ENG119394-ENG119385,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation,0,
ENG119394-ENG119383,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM,15,
ENG119394-ENG119386,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM,4999,
ENG119394-ENG119387,Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation,0,
ENG119394-ENG119389,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM,9881,
ENG119394-ENG119390,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement,0,
ENG119394-ENG119388,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM,35,
ENG119394-ENG119391,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM,7604,
ENG119394-ENG119392,Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement,0,
ENG119394-ENG119377,Pump_Calibration_Values-Series_Number_Pump,12412123,
ENG119394-ENG119376,Pump_Calibration_Values-Temperature_Value_at_Calibration,31, °C
ENG119375,Upper Limit of Temperature Duration,0, min
Elapsed Time: 00:04
29:
;SW:8V0-907-399-D HW:8V0-907-399-D --- Left Light
;Component:LCM_MLBevoH08 0014, Coding:
;EV_LCMLeftHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW37.rod
;Tuesday,10,December,2019,21:41:19:14741
;VCID: C7C0B056AF2EED69E8D1-8092
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE00773,Terminal 15 status via CAN,On,
IDE03680-MAS01468,Supply voltages-Terminal 15,12.30, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,12.40, V
IDE06876-MAS01482,Signature light bulb-Hardwareversion,Not available,
IDE06876-MAS01483,Signature light bulb-Softwareversion,Not available,
IDE06876-MAS12381,Signature light bulb-Software subversion,0F,
IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,Not available,
IDE06926-IDE02068,History memory: reset counter-Time stamp,F0 4D 5F 4D 4C,
IDE06926-MAS09176,History memory: reset counter-Reset reason,Unknown (0),
IDE08742-MAS01155,Operating time-Control module,11.41, H
IDE08742-MAS03835,Operating time-Parking light,4.11, H
IDE08742-MAS09325,Operating time-Daytime running lights,3.65, H
IDE08742-MAS09330,Operating time-Cover for low beam headlight,0.00, H
IDE08742-MAS09332,Operating time-Turn signal,0.20, H
IDE08742-MAS09333,Operating time-Side-marker light,0.00, H
IDE08742-MAS09334,Operating time-Parking light,0.00, H
IDE09492-MAS01155,Temperatures-Control module,37.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,19.00, °C
IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,not installed,
IDE09768-MAS04121,LED channel 1-Voltage,0.00, V
IDE09768-MAS04136,LED channel 1-Current,0, mA
IDE09768-MAS09022,LED channel 1-PWM value,0.00, %
IDE09768-MAS09327,LED channel 1-LED brightness class,4,
IDE09768-MAS09328,LED channel 1-Primary function,Turn signal,
IDE09768-MAS09329,LED channel 1-Secondary function,no function,
IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
IDE09769-MAS04136,LED channel 2-Current,0, mA
IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
IDE09769-MAS09327,LED channel 2-LED brightness class,1,
IDE09769-MAS09328,LED channel 2-Primary function,Turn signal,
IDE09769-MAS09329,LED channel 2-Secondary function,no function,
IDE09770-MAS04136,High side channel 1-Current,0, mA
IDE09770-MAS09022,High side channel 1-PWM value,0.00, %
IDE09770-MAS09326,High side channel 1-Function,no function,
IDE09771-MAS04136,High side channel 2-Current,0, mA
IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
IDE09771-MAS09326,High side channel 2-Function,Turn signal,
IDE09772-MAS04136,High side channel 3-Current,0, mA
IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
IDE09772-MAS09326,High side channel 3-Function,Parking light,
IDE09774-MAS03835,Number of activations-Parking light,90,
IDE09774-MAS09325,Number of activations-Daytime running lights,130,
IDE09774-MAS09330,Number of activations-Cover for low beam headlight,0,
IDE09774-MAS09332,Number of activations-Turn signal,2184,
IDE09774-MAS09333,Number of activations-Side-marker light,0,
IDE09774-MAS09334,Number of activations-Parking light,0,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.00, H
IDE09775-MAS09337,High temperature operating times for control unit-between 105°C and 115°C,0.00, H
IDE09775-MAS09338,High temperature operating times for control unit-over 115°C,0.00, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,82.04, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,17.03, %
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.54, %
IDE09828-MAS00890,Head lamp variant-via CAN,E0 76,
IDE09828-MAS01155,Head lamp variant-Control module,E0 76,
IDE09916-MAS09563,Data set names-Number of data set names,01,
IDE09916-MAS09564,Data set names-Data set ID,28928,
IDE09916-MAS09565,Data set names-Data set name,VMAV28iXK001,
IDE10175,Capturing statistic data: status,active,
IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,0,
IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,0,
IDE11123-MAS04136,High side channel 4-Current,0, mA
IDE11123-MAS09022,High side channel 4-PWM value,0.00, %
IDE11123-MAS09326,High side channel 4-Function,no function,
IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,performed,
IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),63.60, %
IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-33.00, mm
IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,performed,
IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),36.80, %
IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,0.03, °
IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,Not available,
IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,Not available,
IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
Elapsed Time: 00:03
2B:
;SW:2Q0-905-861-A HW:2Q0-905-861-A --- Steer. Col. Lock
;Component:ELV-MQBB H08 0021, Coding:0000000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW37.rod
;Tuesday,10,December,2019,21:41:25:14741
;VCID: B134FE8E31AA43D9D6F5-80E4
IDE00021,Engine speed,0.00, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-obsolete,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075,Vehicle speed,0.00, km/h
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-obsolete,Yes,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,Not available,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,1,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,13,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,not activated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,not locked,
IDE02580,Number of unlocks,78,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,closed,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Not adapted,
IDE06746-MAS08251,Locking requirements-Communication status signal ESP_21,Condition met,
IDE06746-MAS08252,Locking requirements-Communication status signal Klemmenstatus_01,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Cyclical Reception Signal ESP_21,Condition met,
IDE06746-MAS08792,Locking requirements-Cyclical Reception Signal ESP_10,Condition met,
IDE06746-MAS08794,Locking requirements-Cyclical Reception Signal Terminal Status_01,Condition met,
IDE06746-MAS11697,Locking requirements-Communication status signal ESP_10,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,41,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,11,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG31613,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG31614,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG124678,functional_check-Functional_Check_VW_EOL,Not confirmed,
Elapsed Time: 00:04
39:
;SW:8V0-907-399-D HW:8V0-907-399-D --- Right Light
;EV_LCMRightHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW37.rod
;Tuesday,10,December,2019,21:41:33:14741
IDE03680-MAS01468,Supply voltages-Terminal 15,12.40, V
IDE08742-MAS01155,Operating time-Control module,11.42, H
IDE08742-MAS03835,Operating time-Parking light,4.20, H
IDE08742-MAS09325,Operating time-Daytime running lights,3.67, H
IDE08742-MAS09332,Operating time-Turn signal,0.15, H
IDE09492-MAS01155,Temperatures-Control module,38.00, °C
IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,18.00, °C
IDE09774-MAS03835,Number of activations-Parking light,97,
IDE09774-MAS09325,Number of activations-Daytime running lights,138,
IDE09774-MAS09332,Number of activations-Turn signal,1693,
IDE09775-MAS09336,High temperature operating times for control unit-°C,0.03, H
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,82.65, %
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,16.42, %
IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),63.20, %
IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,0.06, °
Elapsed Time: 00:03
3C:
;SW:5Q0-907-686-C HW:5Q0-907-686-C --- Lane Change
;Component:HRE_Master H12 0081, Coding:02011103
;EV_HREntryHella,001028,EV_HREntryHella_VW37.rod
;Tuesday,10,December,2019,21:41:40:14741
;VCID: BD2CD2BEFDF2B7B9427D-80E8
IDE00018,Voltage terminal 15,12.16, V
IDE00102,Control Module temperature,32.0, °C
IDE00925,Yaw rate,-0.01, °/s
IDE01441,Back-up light,OFF,
IDE01766-MAS01853,Distance impulses-Left front,0,
IDE01766-MAS01854,Distance impulses-Right front,1,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,13,
IDE02049,Trailer detected,not defined,
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,129.00, km
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057-MAS10065,Dynamic calibration: status-Distance of object 4,100, %
IDE02057,Dynamic calibration: status,is running,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,25.60,
IDE03619,System status,On,
IDE05064,lane change assist. 2: supply voltage,12.40, V
IDE05065,lane change assist. 2: temperature,31.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,On,
IDE05070,Curve radius,4480, m
IDE05072,Status of lane change assist. indicator lamp,active,
IDE05077-IDE02389,Rain/light recognition sensor via data bus-Ambient brightness,0,
IDE05077,Rain/light recognition sensor via data bus,not defined,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,-120.00, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,0.00, m
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,0.00, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,-120.00, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,0.00, m
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,0.00, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,-120.00, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,0.00, m
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,0.00, m/s
IDE05084,Closest object left lane,No object recognized,
IDE05085,Closest object right lane,No object recognized,
IDE05086,Closest object lane used,No object recognized,
IDE05087,Dynamic angle offset lane change assist. 1,0.58, °
IDE05088,Dynamic angle offset lane change assist. 2,1.50, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,20.32, °
IDE05093,Measured angle lane change assist. 2,20.32, °
IDE05094,Static angle offset lane change assist. 1,0.00, °
IDE05095,Static angle offset lane change assist. 2,0.00, °
IDE05100,Spray counter,0,
IDE10101,Dimming value of left warning light,0, %
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10105,Dimming value of right warning light,0, %
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,0,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,0,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane holding warn. syst.-LED,yellow,
IDE10236-MAS10041,Lane holding warn. syst.-Distance to lane,1.25, m
IDE10236-MAS10042,Lane holding warn. syst.-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane holding warn. syst.-Vehicle side,Right,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System status,System off,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,-120.00, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,0.00, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,-120.00, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,0.00, m
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,0.00, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,0.00, m/s
Elapsed Time: 00:08
42:
;SW:5Q4-959-593-M HW:5Q4-959-593-F --- Door Elect, Driver
;Component:TSG FS 006 0247, Coding:003A13200000040000000000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHKLO.rod
;Tuesday,10,December,2019,21:41:52:14741
;VCID: CFF09876475E3529A001-809A
IDE00310,Outside air temperature,11.50, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Driver side rear door control module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.10, V
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.40, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE02668,Central window regulator switch,not installed,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
IDE04220,Driver power window button,not activated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Busmaster,
IDE04411,Child Safety Lock Switch,not activated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-install,not installed,
IDE04540,Mirror adjustment (X/Y-direction),Position center,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not installed,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,10, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,96.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position bottom,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Power window control standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,not activated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,4820,
IDE06933,Front window regulator relay: driver side,Open,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,14.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07222,Window regulator child lock: driver side,Not available,
IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,21, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,34, °C
IDE07413,Comfort function for front window regulator: driver side,not active,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,Not available,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,automatic day/night exterior mirror-Status,not installed,
IDE10164-MAS03691,automatic day/night exterior mirror-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initializing,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS01872,Rear lid remote release button,not installed,
MAS02099,Switch for inside door handle,not installed,
MAS02100,Switch for outside door handle,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,0, %
ENG117315-ENG32834,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:08
44:
;SW:5QM-909-144-C HW:5QM-909-144-B --- Steering Assist
;Component:EPS_MQB_ZFLS 173 1082, Coding:930A0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Tuesday,10,December,2019,21:42:11:14741
;VCID: D1F49E0E516A23D9B635-8084
IDE00018,Voltage terminal 15,12.47, V
IDE00019,Voltage terminal 30,12.54, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,0, /min
IDE00102,Control Module temperature,26.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,04,
IDE00550-MAS01078,Identification of parameterization-Vehicle type,A0,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,42,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assistant-System status,Marginal conditions have not been met,
IDE02006-IDE04227,Lane assistant-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assistant-Function status,activated,
IDE02006-MAS03368,Lane assistant-Steering wheel vibration,not active,
IDE02202,End stage temperature,18.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Waiting for start request,
IDE03682-IDE04457,Sensor for motor position-Electric motor speed,0, /min
IDE03682-MAS02961,Sensor for motor position-Engine angle,161.1, °
IDE03682-MAS03083,Sensor for motor position-Cosine signal,2.235, V
IDE03682-MAS03211,Sensor for motor position-Sine signal,2.589, V
IDE03682-MAS05053,Sensor for motor position-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,0, %
IDE03725-MAS03001,Steering Assistance-Mode,Unknown (3),
IDE03725-MAS03095,Steering Assistance-Function status,not activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,Initializing,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,-35.6, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,activated,
IDE03735,Steering torque,0.038, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,0.038, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-2.3, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-2.3, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active reset-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,0.000, Nm
IDE04184,Steering assistance: engine output,0.000, %
IDE04185,Terminal 30 voltage filtered,12.41, V
IDE04186,Battery terminal recognition,connected,
IDE04187,Steering torque: raw value 1,89.746, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-9.863, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,89.746, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-9.863, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.39, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.39, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,-0.3, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.1, A
IDE04194,Steering assistance: electromotor power,-0.77, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-28.5, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-0.8, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.75, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical center,0.18, mm
IDE04460,Steering angle sensor: offset straight line running,-0.7, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not recognized,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not recognized,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not recognized,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not recognized,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04511,Steering angle sensor external via CAN: angle,Measured value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measured value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.55, mm
IDE05162-MAS01850,Software end stop-Right,-80.20, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,1758,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,1862,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG08146,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG08147,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG30242,Engine specified torque load-above_11_kilo_newton,439,
IDE05994-ENG30407,Engine specified torque load-below_-11_kilo_newton,439,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,44187,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,0,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,1,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,4,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,213,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adapt. value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,0,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Regulation active,Condition not met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,42,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,12,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,373, km
MAS00976-IDE80003,Counter-Analysis 3,381600249,
MAS00976-IDE80004,Counter-Analysis 4,90751,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG37819-ENG37964,Strain_detection-Calculated_worm_gear_temperature,0.0, °C
ENG37819-ENG38046,Strain_detection-High_count_worm_gear_alt,90751,
ENG37819-ENG38061,Strain_detection-KlimaSensor02_alt,0,
ENG37819-ENG38097,Strain_detection-Low_count_worm_gear_alt,381600249,
ENG37819-ENG38105,Strain_detection-Mileage_counter,0, km
ENG37819-ENG38117,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG37819-ENG102605,Strain_detection-outside_temperature,11.5, °C
ENG37819-ENG37918,Strain_detection-revolutions_per_minute_electric_motor,-2, /min
ENG37819-ENG26208,Strain_detection-Steering_angle,-28.5, °
ENG37819-ENG37919,Strain_detection-steering_moment,0.038, Nm
ENG37819-ENG37920,Strain_detection-Steering_Support_Engine_Commanded_Torque,0.000, Nm
ENG37819-ENG38151,Strain_detection-Strain_detection_per_cent,0.0000006816, %
Elapsed Time: 00:07
47:
;SW:5Q0-035-456-A HW:5Q0-035-456-A --- Sound System
;Component:MIB2_lite_amp H40 0200, Coding:2200000000AAAAAA000000000000
;EV_AMPMst12C1Gen2ALPI,001003,EV_AMPMst12C1Gen2ALPI.rod
;Tuesday,10,December,2019,21:42:23:14741
;VCID: AE0EE5F220945C21CBD7-80FA
IDE00020,Terminal 15 status,On,
IDE00767,No. of unscheduled ECU resets,0, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01715,Status terminal S,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,13, min
IDE04317-MAS00108,Total system run time-Day,0, d
IDE04317-MAS00109,Total system run time-Hours,8, H
IDE04317-MAS00110,Total system run time-Minutes,16, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,OFF,
IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,Mute,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,Mute,
IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,2,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,60,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),00,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,69, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-2, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,22, °C
IDE10545-MAS01190,Speaker status-Left front treble speaker,OK,
IDE10545-MAS01193,Speaker status-Right front treble speaker,OK,
IDE10545-MAS01194,Speaker status-Left rear bass speaker,OK,
IDE10545-MAS01195,Speaker status-Left rear treble speaker,OK,
IDE10545-MAS01196,Speaker status-Right rear bass speaker,OK,
IDE10545-MAS01197,Speaker status-Right rear treble speaker,OK,
IDE10545-MAS04506,Speaker status-Double subwoofer speaker 1,OK,
IDE10545-MAS04507,Speaker status-Double subwoofer speaker 2,OK,
IDE10545-MAS12334,Speaker status-Double bass speaker 1: left front,OK,
IDE10545-MAS12335,Speaker status-Double bass speaker 1: right front,OK,
IDE10545-MAS12336,Speaker status-Double bass speaker 2: left front,OK,
IDE10545-MAS12337,Speaker status-Double bass speaker 2: right front,OK,
IDE10545,Speaker status,Measured value not available,
IDE10657-MAS01424,Temperature switching power supply-max.value,205, °C
IDE10657-MAS01425,Temperature switching power supply-min.value,205, °C
IDE10657-MAS02238,Temperature switching power supply-Current,205, °C
IDE10659-MAS01424,Temperature switching power supply 2-max.value,63, °C
IDE10659-MAS01425,Temperature switching power supply 2-min.value,5, °C
IDE10659-MAS02238,Temperature switching power supply 2-Current,25, °C
MAS00464-MAS00111,Standard - ambient data 1-Seconds,13,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,19, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,12, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,10, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,21, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,28, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,53, s
Elapsed Time: 00:07
4B:
;SW:3Q0-907-338-C HW:3Q0-907-338-C --- Multifunc. Module
;Component:FCM MQB Low 002 0345, Coding:000000050900211200110F01030000000000000000000000000000000000
;EV_MultiModulContiVW48X,002006,EV_MultiModulContiVW48X_002_VW37.rod
;Tuesday,10,December,2019,21:42:35:14741
;VCID: B53CCA9EC5C26FF98A0D-80E0
IDE00075,Vehicle speed,0.0, km/h
IDE00322,Status of basic setting,not active,
IDE00326,Steering wheel angle,-28.50, °
IDE01714,Status reverse gear,OFF,
IDE01717-ENG30211,Processor load-Software_component_AFS_MXB,9, %
IDE01717-ENG30223,Processor load-Total_system_FCM,23, %
IDE01943,Turn signal,not activated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,0, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,53.60, %
IDE03616,Motor status,OFF,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-8.4, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03624,Left dynamic AFS light motor: specified value,0.000000, °
IDE03625,Right dynamic AFS light motor: specified value,0.000000, °
IDE03626,Left dynamic AFS light motor: status,no error,
IDE03627,Right dynamic AFS light motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,no error,
IDE03629,Adjusting motor for variable right front lighting: status,no error,
IDE03630,Left headlight beam adjusting motor: specified value,-33.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,-33.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,0.0, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,0.0, %
IDE03640,Dynamic AFS light,On,
IDE03669,Light distribution status,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),56.40, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,both sides,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,-500.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-500.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-15.00, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,-120.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,-120.0, '
IDE08706-MAS17333,Actual angle of ref. segments-Vertical angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17334,Actual angle of ref. segments-Vertical angle reference segment right: as a percentage,-15.00, %
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,-5.00, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,-9.00, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-5.00, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-9.00, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-5.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-9.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-5.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-9.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of first warning,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of second warning,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of third warning,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,0,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2019,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,12,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,11,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,10,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,19,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,41,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,107,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2019,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,12,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,11,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,10,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,19,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,41,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,107,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2019,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,12,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,11,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,10,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,19,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,41,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,107,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2019,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,12,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,3,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,21,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,50,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,13,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,2,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,0,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,0,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,0.031250, °
ENG26446-ENG30212,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0162,
ENG26446-ENG30225,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7190,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,0.062500, °
Elapsed Time: 00:09
52:
;SW:5Q4-959-592-M HW:5Q4-959-592-F --- Door Elect, Pass.
;Component:TSG BFS 006 0247, Coding:003A13200000040000000000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHKLO.rod
;Tuesday,10,December,2019,21:42:57:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: CECE857240543C21AB17-809A
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE01993-MAS12276,Control module reference number-Front door control module,Frt.pass. side door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear passenger side door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.10, V
IDE02266,Passenger side rear power window button,not activated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.50, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y-direction),not installed,
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not activated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,not activated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,4820,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,21, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,34, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,14.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
ENG117316-ENG32834,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:07
5F:
;SW:3Q0-035-876-B HW:3Q0-035-876-B --- Information Electr.
;Component:MU-S-NS-US 853 0890, Coding:027312020000000041220002001808009F0508F401200505C6
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Tuesday,10,December,2019,21:43:15:14741
;VCID: B338F486CBB671C9A419-80E6
IDE00019,Voltage terminal 30,12.5, V
IDE00021,Engine speed,0.00, /min
IDE00075,Vehicle speed,0.00, km/h
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.80, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00916-IDE02127,Speaker status-Left front speaker,Measured value not available,
IDE00916-IDE02128,Speaker status-Right front speaker,Measured value not available,
IDE00916-IDE02129,Speaker status-Left rear speaker,Measured value not available,
IDE00916-IDE02130,Speaker status-Right rear speaker,Measured value not available,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01712-MAS01779,GPS Position-Length,[Redacted]"W,
IDE01712-MAS01780,GPS Position-Width,[Redacted]"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,12,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,62, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,56, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,51, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,56, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG20557,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG20556,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG20933,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG20932,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG20931,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG20930,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG20929,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG20950,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG20555,Installation list: current installations-ECU present Bit 2 Sound_System,installed,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG20554,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG20553,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG20552,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG20919,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,not installed,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG20918,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG20935,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG20934,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,7,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,17,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,28,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,8,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,44, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,41, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,40, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,36, dBµV
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG20563,Status of event memory-ECU Dtc Bit 0 Main_Unit,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG20562,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG20924,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG20923,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG20922,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG20921,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG20920,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG20949,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG20561,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG20560,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG20559,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG20558,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG20945,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG20944,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG20926,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG20925,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02486,Data logger triggering,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,FF FB,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,Sleep mode,
IDE03150-ENG20569,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,Sleep mode,
IDE03150-ENG20568,Readiness for bus sleep mode-Sleep Bit 1 reserved,Sleep mode,
IDE03150-ENG20941,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Sleep mode,
IDE03150-ENG20940,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Sleep mode,
IDE03150-ENG20939,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Sleep mode,
IDE03150-ENG20938,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Sleep mode,
IDE03150-ENG20937,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Sleep mode,
IDE03150-ENG20936,Readiness for bus sleep mode-Sleep Bit 15,Sleep mode,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,Sleep mode,
IDE03150-ENG20567,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,End busstat,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,Sleep mode,
IDE03150-ENG20566,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Sleep mode,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,Sleep mode,
IDE03150-ENG20565,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Sleep mode,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,Sleep mode,
IDE03150-ENG20564,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Sleep mode,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,Sleep mode,
IDE03150-ENG20928,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,Sleep mode,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,Sleep mode,
IDE03150-ENG20927,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Sleep mode,
IDE03150-ENG20943,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Sleep mode,
IDE03150-ENG20942,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Sleep mode,
IDE03151-ENG20551,TP CAN identifier-ECU TP-CAN-Identifier-Request Bit 0,1907,
IDE03151-ENG20550,TP CAN identifier-ECU TP-CAN-Identifier-Response Bit 0,2013,
IDE03477-MAS00106,GPS time-Year,2019,
IDE03477-MAS00107,GPS time-Month,12,
IDE03477-MAS00108,GPS time-Day,11,
IDE03477-MAS00109,GPS time-Hours,2,
IDE03477-MAS00110,GPS time-Minutes,43,
IDE03477-MAS00111,GPS time-Seconds,5,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00110,System run time-Minutes,23, min
IDE04317-MAS00109,Total system run time-Hours,12, H
IDE04317-MAS00110,Total system run time-Minutes,28, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG20542,Bus identification-Bus Identifier,Busmaster,
IDE04344-ENG20451,Control module assignment-ECU ID,5F,
IDE04344-ENG20480,Control module assignment-ECU Name,Information Control Unit 1,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.470, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,084°08'33.76"W,
IDE04605-MAS01780,Navigation: Corrected position-Width,035°59'24.64"N,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,0.0, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,4020, /min
IDE04748,Microphone override meter,0,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,58 16 D7 47 A7 4C,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05536-MAS01632,GPS almanac-Status,valid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2019,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,12,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,11,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,2,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,19,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,59,
IDE05596-MAS00106,Last time GPS position outside map-Year,2000,
IDE05596-MAS00107,Last time GPS position outside map-Month,0,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,0,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,0,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,0,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,½E=ˆ
Galaxy S9+samsung SM-G965U1--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,88 BD 45 3D 88 20,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,½E=ˆ
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),88 BD,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),88 BD,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,½E=ˆ
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Galaxy S9+
samsung
SM-G965U1
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,88 BD,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,88 BD,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,88 BD,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,88 BD,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,88 BD,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,88 BD,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,88 BD,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,88 BD,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,88 BD,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,88 BD,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,88 BD,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,88 BD,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,88 BD,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,88 BD,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,88 BD,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,88 BD,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,88 BD,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,“Ù"ÓÁ
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,C4 93 D9 22 D3 C1,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,“Ù"ÓÁ
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),C4 93,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),C4 93,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,“Ù"ÓÁ
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,Galaxy S9+
samsung
SM-G965U1
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,C4 93,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,C4 93,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,C4 93,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,C4 93,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,C4 93,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,C4 93,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,C4 93,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,C4 93,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,C4 93,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,C4 93,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,C4 93,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,C4 93,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,C4 93,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,C4 93,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,C4 93,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,C4 93,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,C4 93,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,39.50, %
IDE05814,Individualization characteristic,CD 96 95 19 A8,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06425,Roller test bench mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,---,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,100,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
IDE11034-MAS01482,Satellite radio: module information-Hardwareversion,01-00-01---,
IDE11034-MAS11961,Satellite radio: module information-Serial number,Q34KUAR1,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 08 00 51 33 34 4B 55 41 52 31 00 02 98 07 8A 38 64 68 F5 31 71 89 46 FF 18 07 D5 07 7A 91 19 4A 69 40 78 B2 00 08 00 66 03 41 00 09 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,0b-26-00---,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,02-04-04---,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,03-05-00---,
IDE11034-MAS11966,Satellite radio: module information-Database Version,02-04-04--A,
IDE11504-ENG127677,Satellite radio tuner: pre-activated subscription-SDARS_preactivation_coding status,Yes,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,43,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,19,
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,8, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,8, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,12.6, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,62, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,16, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,2,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,96.7, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,55, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,56, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,1,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,56, dBµV
MAS01991-IDE00010,Card reader-Serial number,3B 08 1A A7,
MAS01991-IDE01001,Card reader-Application,SD,
MAS01991-MAS01632,Card reader-Status,connected,
MAS01991-MAS03159,Card reader-Manufacturer,03,
MAS01991-MAS03375,Card reader-Major version,0,
MAS01991-MAS03376,Card reader-Minor version,8,
MAS01991-MAS03959,Card reader-Write-protection,not activated,
MAS01991-MAS04388,Card reader-Card type,SC32G,
MAS01991-MAS13476,Card reader-Manufacturing date: month,2, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2018, yr
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,20091841466104096,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,9,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,13,
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,16, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,24, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,56, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,128, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG122217-ENG122284,SDARS_service-audio_service,subscribed,
ENG122217-ENG122285,SDARS_service-traffic_service,subscribed,
ENG122217-ENG122286,SDARS_service-travel_link_service,subscribed,
ENG122216-MAS00106,SDARS_subscription_status-Year,2034,
ENG122216-MAS00107,SDARS_subscription_status-Month,1,
ENG122216-MAS00108,SDARS_subscription_status-Day,1,
ENG122216-MAS00109,SDARS_subscription_status-Hours,31,
ENG122216-MAS00110,SDARS_subscription_status-Minutes,63,
ENG122216-MAS00111,SDARS_subscription_status-Seconds,63,
ENG122216-ENG122279,SDARS_subscription_status-SDARS_subscription,subscribed,
ENG122216-ENG125804,SDARS_subscription_status-SDARS_suspend_alert,0,
ENG122216-ENG122280,SDARS_subscription_status-SDARS_suspension,not_suspended,
ENG127487-IDE02451,SDARS_tuner_status_2-Satellite radio antenna status,Electrical OK,
ENG127487-IDE02453,SDARS_tuner_status_2-Channel selection for satellite radio,9,
ENG127487-MAS01765,SDARS_tuner_status_2-Audio Signal,Available,
ENG127487-MAS01808,SDARS_tuner_status_2-Antenna current,107, mA
ENG127487-MAS02573,SDARS_tuner_status_2-Reception quality,good_signal,
ENG127487-MAS13343,SDARS_tuner_status_2-Satellite radio tuner: pre-activation status,07,
ENG127487-MAS13344,SDARS_tuner_status_2-Satellite radio tuner: pre-activation value,07,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not available,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,65535,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,65535,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,54, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,0, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,38, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,46, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,0, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,27, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,53, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,0, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,34, °C
Elapsed Time: 00:24
75:
;SW:5QE-035-285-A HW:5QE-035-285-A --- Telematics
;Component:OCULowMQBUS 009 0570, Coding:02730202C2823A017F1E06020000
;EV_OCULowMQB,001006,EV_OCULowMQB.rod
;Tuesday,10,December,2019,21:44:21:14741
;VCID: C3D8A4469B16C14934B9-8096
IDE00019,Voltage terminal 30,12.1, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,33, °C
IDE00608,Type of fuel,Petrol,
IDE00667,Microphone status,Electrical OK,
IDE00668,Microphone current consumption,5.0, mA
IDE00672,Roadside Assistance Button,not activated,
IDE00673,Information Service Button,not activated,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Terminal 58d dimmer,3.97, %
IDE01625,Muting of radio/radio navigation system via control wire,Measured value not available,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,[Redacted]",
IDE01712-MAS01780,GPS Position-Width,[Redacted]",
IDE01712-MAS02230,GPS Position-Height,352, m
IDE01713-MAS01632,Status GPS reception-Status,No GPS reception,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,10,
IDE01715,Status terminal S,On,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01971,Lowest recorded control module temperature,5, °C
IDE01972,Highest recorded control module temperature,61, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,Electrical OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,1, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100.0, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,0,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02486,Data logger triggering,Measured value not available,
IDE03348-MAS01586,Speed warning-Alarm,0,
IDE03348,Speed warning,655.33, km/h
IDE03348-MAS08775,Speed warning-Calculation frequency,5, s
IDE03348-MAS08776,Speed warning-tolerance,5, m
IDE03348-MAS08777,Speed warning-Contact bounce suppression,5, s
IDE03477-MAS00110,GPS time-Minutes,44,
IDE03477-MAS00111,GPS time-Seconds,9,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,84142638,
IDE04605-MAS01780,Navigation: Corrected position-Width,35990111,
IDE04605-ENG123297,Navigation: Corrected position-error_value,0, m
IDE04750-MAS03876,SIM cards-active SIM card,internal,
IDE04750-MAS03877,SIM cards-SIM ID,89011702258374288161,
IDE04750-MAS03878,SIM cards-SIM IMSI,310170837428816,
IDE04750-MAS04226,SIM cards-Telephone number, ,
IDE04750-MAS08401,SIM cards-SIM intern,Available,
IDE04750-MAS08402,SIM cards-SIM extern,Not available,
IDE04790,Call for help button,not activated,
IDE05430,Telephone serial number,358895056242804,
IDE06644,Vehicle positioning system,Measured value not available,
IDE07007-IDE00983,A/C heater function via remote control-Interior temperature,255, °C
IDE07007-IDE04927,A/C heater function via remote control-Window heater,On,
IDE07007-MAS01118,A/C heater function via remote control-Climate control,Measured value not available,
IDE07007-MAS02289,A/C heater function via remote control-Outside air temperature,255, °C
IDE07007-MAS05945,A/C heater function via remote control-Specified temperature,25.7, °C
IDE07007-MAS08947,A/C heater function via remote control-After-run time for power supply,255, min
IDE07007-MAS08948,A/C heater function via remote control-After-run time for battery,255, min
IDE07007-MAS08949,A/C heater function via remote control-Climate control without power supply,On,
IDE07007-MAS08957,A/C heater function via remote control-A/C window heater,On,
IDE07007-MAS08958,A/C heater function via remote control-reason for last climate control,Measured value not available,
IDE07543,Vehicle speed,0.00, km/h
IDE07940-IDE07007,Status of enabling for online services-A/C heater function via remote control,not activated,
IDE07940-IDE07909,Status of enabling for online services-Remote control for vehicle locking,activated,
IDE07940,Status of enabling for online services,activated,
IDE07940-IDE07974,Status of enabling for online services-Transmission of navigation targets,activated,
IDE07940-IDE07975,Status of enabling for online services-Remote control for charge function of H-V battery,not activated,
IDE07940-IDE07976,Status of enabling for online services-Info call,activated,
IDE07940-IDE08155,Status of enabling for online services-Vehicle state report,activated,
IDE07940-IDE08158,Status of enabling for online services-Roadside assistance / schedule agreement for service,activated,
IDE07940-MAS08370,Status of enabling for online services-Position monitoring (Geofencing),activated,
IDE07940-MAS08371,Status of enabling for online services-Remote control for speed warning,activated,
IDE07940-MAS08372,Status of enabling for online services-Remote control for vehicle shutdown,not activated,
IDE07940-MAS08373,Status of enabling for online services-Remote control for vehicle location,activated,
IDE07940-MAS08374,Status of enabling for online services-Remote control for lights and horn,activated,
IDE07940-MAS08375,Status of enabling for online services-Distance statistics display,activated,
IDE07940-MAS08376,Status of enabling for online services-Display vehicle state,activated,
IDE07940-MAS08377,Status of enabling for online services-Remote control for departure time programming,not activated,
IDE07940-MAS08448,Status of enabling for online services-Manual roadside assistance,activated,
IDE07940-MAS08449,Status of enabling for online services-Automatic roadside assistance,activated,
IDE07975-IDE00704,Remote control for charge function of H-V battery-Charge level,Measured value not available,
IDE07975-IDE01839,Remote control for charge function of H-V battery-Battery charge condition,255, %
IDE07975-IDE05431,Remote control for charge function of H-V battery-Locking for H-V charge plug,Measured value not available,
IDE07975-IDE06986,Remote control for charge function of H-V battery-H-V battery charge current: maximum value,63, A
IDE07975-MAS01002,Remote control for charge function of H-V battery-Remaining operating range,65535, km
IDE07975-MAS01118,Remote control for charge function of H-V battery-Climate control,Measured value not available,
IDE07975-MAS05682,Remote control for charge function of H-V battery-External Charging,Not available,
IDE07975-MAS08781,Remote control for charge function of H-V battery-Connection state of charging plug,Measured value not available,
IDE07975-MAS08782,Remote control for charge function of H-V battery-Remaining charge time,255, min
IDE07975-MAS08783,Remote control for charge function of H-V battery-Reason for last battery charge,Measured value not available,
IDE07975-MAS08784,Remote control for charge function of H-V battery-Charging current type,Measured value not available,
IDE08077-MAS01240,Timer 1 for programming of departure time-Programming status,Measured value not available,
IDE08077-MAS01635,Timer 1 for programming of departure time-Monday,not programmed,
IDE08077-MAS01636,Timer 1 for programming of departure time-Tuesday,not programmed,
IDE08077-MAS01637,Timer 1 for programming of departure time-Wednesday,not programmed,
IDE08077-MAS01638,Timer 1 for programming of departure time-Thursday,not programmed,
IDE08077-MAS01639,Timer 1 for programming of departure time-Friday,not programmed,
IDE08077-MAS01640,Timer 1 for programming of departure time-Saturday,not programmed,
IDE08077-MAS01641,Timer 1 for programming of departure time-Sunday,not programmed,
IDE08077-MAS08963,Timer 1 for programming of departure time-Condition of timer,Measured value not available,
IDE08077-ENG123310,Timer 1 for programming of departure time-Timer_Mode,Measured value not available,
IDE08077-ENG123309,Timer 1 for programming of departure time-Timer_Type,Measured value not available,
IDE08078-MAS01240,Timer 2 for programming of departure time-Programming status,Measured value not available,
IDE08078-MAS01635,Timer 2 for programming of departure time-Monday,not programmed,
IDE08078-MAS01636,Timer 2 for programming of departure time-Tuesday,not programmed,
IDE08078-MAS01637,Timer 2 for programming of departure time-Wednesday,not programmed,
IDE08078-MAS01638,Timer 2 for programming of departure time-Thursday,not programmed,
IDE08078-MAS01639,Timer 2 for programming of departure time-Friday,not programmed,
IDE08078-MAS01640,Timer 2 for programming of departure time-Saturday,not programmed,
IDE08078-MAS01641,Timer 2 for programming of departure time-Sunday,not programmed,
IDE08078-MAS08963,Timer 2 for programming of departure time-Condition of timer,Measured value not available,
IDE08078-ENG123310,Timer 2 for programming of departure time-Timer_Mode,Measured value not available,
IDE08078-ENG123309,Timer 2 for programming of departure time-Timer_Type,Measured value not available,
IDE08079-MAS01240,Timer 3 for programming of departure time-Programming status,Measured value not available,
IDE08079-MAS01635,Timer 3 for programming of departure time-Monday,not programmed,
IDE08079-MAS01636,Timer 3 for programming of departure time-Tuesday,not programmed,
IDE08079-MAS01637,Timer 3 for programming of departure time-Wednesday,not programmed,
IDE08079-MAS01638,Timer 3 for programming of departure time-Thursday,not programmed,
IDE08079-MAS01639,Timer 3 for programming of departure time-Friday,not programmed,
IDE08079-MAS01640,Timer 3 for programming of departure time-Saturday,not programmed,
IDE08079-MAS01641,Timer 3 for programming of departure time-Sunday,not programmed,
IDE08079-MAS08963,Timer 3 for programming of departure time-Condition of timer,Measured value not available,
IDE08079-ENG123310,Timer 3 for programming of departure time-Timer_Mode,Measured value not available,
IDE08079-ENG123309,Timer 3 for programming of departure time-Timer_Type,Measured value not available,
IDE08159-IDE07007,Status of online services-A/C heater function via remote control,not active,
IDE08159-IDE07975,Status of online services-Remote control for charge function of H-V battery,not active,
IDE08159-IDE08158,Status of online services-Roadside assistance / schedule agreement for service,not active,
IDE08159-MAS08370,Status of online services-Position monitoring (Geofencing),not active,
IDE08159-MAS08371,Status of online services-Remote control for speed warning,not active,
IDE08159-MAS08372,Status of online services-Remote control for vehicle shutdown,not active,
IDE08159-MAS08373,Status of online services-Remote control for vehicle location,not active,
IDE08159-MAS08374,Status of online services-Remote control for lights and horn,not active,
IDE08159-MAS08377,Status of online services-Remote control for departure time programming,not active,
IDE08159-MAS08448,Status of online services-Manual roadside assistance,not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,00,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,04,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status GSG,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ELV,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,10,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,44,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,12,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,12,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,373, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,961, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,4,
MAS04394-IDE03580,Connection status-Country code for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,410,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100.0, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,HSPA,
MAS04394-MAS08407,Connection status-Data connection,not active,
MAS04394-MAS08408,Connection status-Number of hours to next event,21,
MAS04394-MAS08409,Connection status-Number of minutes to next event,25,
MAS04394-MAS08410,Connection status-Number of seconds to next event,29,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,204684237,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06193-IDE06986,Profile 1-H-V battery charge current: maximum value,0, A
MAS06193-MAS04721,Profile 1-Minimum charge level,0, %
MAS06193-MAS04722,Profile 1-Maximum charge level,0, %
MAS06193-MAS08967,Profile 1-Start high voltage charging:Hour,0,
MAS06193-MAS08968,Profile 1-Start high voltage charging:Minute,0,
MAS06193-MAS08969,Profile 1-End of high voltage charging:Hour,0,
MAS06193-MAS08970,Profile 1-End of high voltage charging:Minute,0,
MAS06194-IDE06986,Profile 2-H-V battery charge current: maximum value,0, A
MAS06194-MAS04721,Profile 2-Minimum charge level,0, %
MAS06194-MAS04722,Profile 2-Maximum charge level,0, %
MAS06194-MAS08967,Profile 2-Start high voltage charging:Hour,0,
MAS06194-MAS08968,Profile 2-Start high voltage charging:Minute,0,
MAS06194-MAS08969,Profile 2-End of high voltage charging:Hour,0,
MAS06194-MAS08970,Profile 2-End of high voltage charging:Minute,0,
MAS06195-IDE06986,Profile 3-H-V battery charge current: maximum value,0, A
MAS06195-MAS04721,Profile 3-Minimum charge level,0, %
MAS06195-MAS04722,Profile 3-Maximum charge level,0, %
MAS06195-MAS08967,Profile 3-Start high voltage charging:Hour,0,
MAS06195-MAS08968,Profile 3-Start high voltage charging:Minute,0,
MAS06195-MAS08969,Profile 3-End of high voltage charging:Hour,0,
MAS06195-MAS08970,Profile 3-End of high voltage charging:Minute,0,
MAS06413,Audio signal output,Electrical OK,
MAS08178-IDE02493,Crash information-Automatic door unlocking,No,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,No,
MAS08179,List of last telephone numbers,,
MAS08180,Remote-controlled horn and lights,0, s
MAS08181-MAS01779,Area restriction configuration-Length,0, m
MAS08181-MAS01780,Area restriction configuration-Width,0, m
MAS08181-MAS08775,Area restriction configuration-Calculation frequency,65535, s
MAS08181-MAS08776,Area restriction configuration-tolerance,65535, m
MAS08181-MAS08777,Area restriction configuration-Contact bounce suppression,65535, s
MAS08181-MAS08778,Area restriction configuration-Rotation angle,65535, °
MAS08181-MAS08779,Area restriction configuration-Zone type,Not available,
MAS08181-MAS08780,Area restriction configuration-Area type,rectangle,
MAS08183-IDE02068,Event list: horn and lights (ring memory)-Time stamp,Write only channel,
MAS08183-MAS08552,Event list: horn and lights (ring memory)-Event generated,Write only channel,
MAS08184-IDE02068,Event list: emergency call(ring memory)-Time stamp,Write only channel,
MAS08184-MAS08552,Event list: emergency call(ring memory)-Event generated,Write only channel,
MAS08185-IDE02068,Event list: vehicle shut-down (ring memory)-Time stamp,Write only channel,
MAS08185-MAS08552,Event list: vehicle shut-down (ring memory)-Event generated,Write only channel,
MAS08186-IDE02068,Event list: vehicle location (ring memory)-Time stamp,Write only channel,
MAS08186-MAS08552,Event list: vehicle location (ring memory)-Event generated,Write only channel,
MAS08187-IDE02068,Event list area restriction (ring memory)-Time stamp,Write only channel,
MAS08187-MAS08552,Event list area restriction (ring memory)-Event generated,Write only channel,
MAS08188-IDE02068,Event list: Mobile Online services (ring memory)-Time stamp,Write only channel,
MAS08188-MAS08552,Event list: Mobile Online services (ring memory)-Event generated,Write only channel,
MAS08189-IDE02068,Event list: speed warning (ring memory)-Time stamp,Write only channel,
MAS08189-MAS08552,Event list: speed warning (ring memory)-Event generated,Write only channel,
MAS08190-IDE02068,Event list: distance statistics (ring memory)-Time stamp,Write only channel,
MAS08190-MAS08552,Event list: distance statistics (ring memory)-Event generated,Write only channel,
MAS08191-IDE02068,Event list: vehicle state (ring memory)-Time stamp,Write only channel,
MAS08191-MAS08552,Event list: vehicle state (ring memory)-Event generated,Write only channel,
MAS08192-IDE02068,Event list: info call (ring memory)-Time stamp,Write only channel,
MAS08192-MAS08552,Event list: info call (ring memory)-Event generated,Write only channel,
MAS08193-IDE02068,Event list: battery charge management (ring memory)-Time stamp,Write only channel,
MAS08193-MAS08552,Event list: battery charge management (ring memory)-Event generated,Write only channel,
MAS08194-IDE02068,Event list: A/C (ring memory)-Time stamp,Write only channel,
MAS08194-MAS08552,Event list: A/C (ring memory)-Event generated,Write only channel,
MAS08195-IDE02068,Event list: departure time (ring memory)-Time stamp,Write only channel,
MAS08195-MAS08552,Event list: departure time (ring memory)-Event generated,Write only channel,
MAS08196-IDE02068,Event list: vehicle status report (ring memory)-Time stamp,Write only channel,
MAS08196-MAS08552,Event list: vehicle status report (ring memory)-Event generated,Write only channel,
MAS08197-IDE02068,Event list:roadside assist and maint. schedule(ring memory)-Time stamp,Write only channel,
MAS08197-MAS08552,Event list:roadside assist and maint. schedule(ring memory)-Event generated,Write only channel,
MAS08198-IDE02068,Event lists: imported navigation destinations (bring memory)-Time stamp,Write only channel,
MAS08198-MAS08552,Event lists: imported navigation destinations (bring memory)-Event generated,Write only channel,
MAS08199-IDE02068,Event list: vehicle locking (ring memory)-Time stamp,Write only channel,
MAS08199-MAS08552,Event list: vehicle locking (ring memory)-Event generated,Write only channel,
ENG123206-ENG123337,Antenna_Switch-GPS_Antenna_Switch,external,
ENG123206-ENG123336,Antenna_Switch-GSM_Antenna_Switch,external,
ENG123207-IDE01588,Calculated_Position_And_Direction_Areal_Update-Driving direction,0, °
ENG123207-MAS01632,Calculated_Position_And_Direction_Areal_Update-Status,Not available,
ENG123207-MAS01779,Calculated_Position_And_Direction_Areal_Update-Length,,
ENG123207-MAS01780,Calculated_Position_And_Direction_Areal_Update-Width,,
ENG123207-ENG123297,Calculated_Position_And_Direction_Areal_Update-error_value,0, m
ENG123208-MAS00106,Geofencing_schedule_start_time-Year,2000,
ENG123208-MAS00107,Geofencing_schedule_start_time-Month,0,
ENG123208-MAS00108,Geofencing_schedule_start_time-Day,0,
ENG123208-MAS00109,Geofencing_schedule_start_time-Hours,0,
ENG123208-MAS00110,Geofencing_schedule_start_time-Minutes,0,
ENG123208-MAS00111,Geofencing_schedule_start_time-Seconds,0,
ENG123209-MAS00106,Geofencing_schedule_stop_time-Year,2000,
ENG123209-MAS00107,Geofencing_schedule_stop_time-Month,0,
ENG123209-MAS00108,Geofencing_schedule_stop_time-Day,0,
ENG123209-MAS00109,Geofencing_schedule_stop_time-Hours,0,
ENG123209-MAS00110,Geofencing_schedule_stop_time-Minutes,0,
ENG123209-MAS00111,Geofencing_schedule_stop_time-Seconds,0,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,0,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,126,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,2,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,514,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,516,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,187,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,0,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG117422,IP_Address,10.101.127.155,
ENG117869-IDE01588,Nav._Calculated_Direction-Driving direction,0, °
ENG117869-MAS01632,Nav._Calculated_Direction-Status,Available,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,0,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,47,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,no error,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,0, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,18,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,no error,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,0,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,no error,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,23,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,0,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,0,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,0,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,0,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,0,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,6,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,0,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,6,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,0,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,no error,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,0,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,1, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,no error,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,4280, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,0,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,122057, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,no error,
ENG123204,Outgoing_call_line_state,Idle,
ENG123202,Phone_Register_State,registerstate_registered,
ENG129162-ENG98933,Serial_Tracing-Status,not activated,
ENG123210-MAS00106,Speed_alert_schedule_start_time-Year,2000,
ENG123210-MAS00107,Speed_alert_schedule_start_time-Month,0,
ENG123210-MAS00108,Speed_alert_schedule_start_time-Day,0,
ENG123210-MAS00109,Speed_alert_schedule_start_time-Hours,0,
ENG123210-MAS00110,Speed_alert_schedule_start_time-Minutes,0,
ENG123210-MAS00111,Speed_alert_schedule_start_time-Seconds,0,
ENG123211-MAS00106,Speed_alert_schedule_stop_time-Year,2000,
ENG123211-MAS00107,Speed_alert_schedule_stop_time-Month,0,
ENG123211-MAS00108,Speed_alert_schedule_stop_time-Day,0,
ENG123211-MAS00109,Speed_alert_schedule_stop_time-Hours,0,
ENG123211-MAS00110,Speed_alert_schedule_stop_time-Minutes,0,
ENG123211-MAS00111,Speed_alert_schedule_stop_time-Seconds,0,
ENG123193-ENG123341,Vehicle_Health_Report-Collection_Period,Deactivated,
ENG123193-ENG123342,Vehicle_Health_Report-Day_at_month_for_report,0,
ENG123193-ENG123343,Vehicle_Health_Report-Day_at_week_for_report,Not available,
ENG123193-ENG123339,Vehicle_Health_Report-Distance_Based_Distance,0, km
ENG123193-ENG123338,Vehicle_Health_Report-Distance_Based_Start_Mileage,0, km
ENG123193-ENG123340,Vehicle_Health_Report-Maintenance_Based_Distance,0, km
Elapsed Time: 00:18
A5:
;SW:3Q0-980-654-L HW:3Q0-980-654-A --- Frt Sens. Drv. Assist
;Component:MQB_B_MFK H12 0610, Coding:000307020002020100221354C150490084000E20012000
;EV_MFKBoschMQBB,002041,EV_MFKBoschMQBB_002.rod
;Tuesday,10,December,2019,21:45:05:14741
;VCDS Version: Beta 19.10.0 (x64) Data version: 20190930 DS316.0
;VCID: C0D2AB4A8A00DA51299B-8094
Group,Description,Actual
IDE00018,Voltage terminal 15,12.3, V
IDE00030,Status of actuator test,not active,
IDE00102,Control Module temperature,29, °C
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,28.5, °
IDE00925-MAS02471,Yaw rate-Sign,Positive,
IDE00925,Yaw rate,0.01, °/s
IDE00973,Outside air temperature,11.5, °C
IDE01968,Dynamic calibration: yaw angle offset,0.228, °
IDE01969,Dynamic calibration: pitch angle offset,0.131, °
IDE01970,Dynamic calibration: roll angle offset,-0.127, °
IDE01971,Lowest recorded control module temperature,3, °C
IDE01972,Highest recorded control module temperature,70, °C
IDE02057,Dynamic calibration: status,Passive values stored,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Fuzziness/Diffusion,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,Yes,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,56, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,4,
IDE04125,Visibility,Not Used,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,Unknown (384),
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,Unknown (384),
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,Unknown (896),
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,Unknown (896),
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,Unknown (0),
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,Unknown (0),
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.266, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-0.106, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.085, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1377, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2011,
IDE10664-MAS00107,Current initial calibration: details-Month,1,
IDE10664-MAS00108,Current initial calibration: details-Day,1,
IDE10664-MAS00109,Current initial calibration: details-Hours,17,
IDE10664-MAS00110,Current initial calibration: details-Minutes,41,
IDE10664-MAS00111,Current initial calibration: details-Seconds,23,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,3VWM17AU9KM522339,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1386,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,633,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,361,
IDE10664,Current initial calibration: details,00110000 ,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,Yes,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,no error,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,active,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:36
CA:
;SW:4K0-907-594-AC HW:4K0-907-594 --- Sunroof
;Component:SAD_STG_1 006 0002, Coding:00804073720C
;EV_SunRoofCONTIAU736,009011,EV_SunRoofCONTIAU736_009_VW37.rod
;Tuesday,10,December,2019,21:45:51:14741
;VCID: F5BC0A9E85422FF94A8D-80A0
IDE00322,Status of basic setting,was not yet started,
IDE03114-MAS02447,Comfort function-Release,Not Present,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,not active,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,not active,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,Not operated,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,operated,
IDE09422-MAS02282,Roof Blind-Position,0, %
IDE09422-MAS05370,Roof Blind-Direction of movement,Not moving,
IDE09422-MAS05563,Roof Blind-Norming,normed,
IDE09422-MAS08536,Roof Blind-Excessive temperature protection,not active,
IDE09422-MAS08862,Roof Blind-Reversing,not active,
IDE09422-MAS08866,Roof Blind-Adaption depth,not installed,
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Norming,normed,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,not installed,
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,12,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,3,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Norming,3,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,2,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,10,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,2,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,11,
IDE09429-MAS05563,Sunroof shade counter readings-Norming,2,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,0,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,1,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,10,
IDE09430-MAS00106,History data sunroof reversing-Year,2127,
IDE09430-MAS00107,History data sunroof reversing-Month,15,
IDE09430-MAS00108,History data sunroof reversing-Day,31,
IDE09430-MAS00109,History data sunroof reversing-Hours,0,
IDE09430-MAS00110,History data sunroof reversing-Minutes,0,
IDE09430-MAS00111,History data sunroof reversing-Seconds,0,
IDE09430-MAS00370,History data sunroof reversing-Vehicle speed,0.00, km/h
IDE09430-MAS01453,History data sunroof reversing-Blocking detection,not active,
IDE09430-MAS01634,History data sunroof reversing-Supply voltage,13.00, V
IDE09430-MAS02282,History data sunroof reversing-Position,56, %
IDE09430-MAS02289,History data sunroof reversing-Outside air temperature,25.00, °C
IDE09430-MAS05622,History data sunroof reversing-Cold start,not active,
IDE09430-MAS05737,History data sunroof reversing-Position,Tilt out posi.,
IDE09430-MAS09456,History data sunroof reversing-Counter reading sunroof reversals,2,
IDE09430-MAS10923,History data sunroof reversing-Absolute Position,424,
IDE09430-MAS10991,History data sunroof reversing-Restart,not active,
IDE09430-MAS10992,History data sunroof reversing-Absolute start position,708,
IDE09431-MAS00106,History data sunroof shade reversing-Year,2127,
IDE09431-MAS00107,History data sunroof shade reversing-Month,15,
IDE09431-MAS00108,History data sunroof shade reversing-Day,31,
IDE09431-MAS00109,History data sunroof shade reversing-Hours,0,
IDE09431-MAS00110,History data sunroof shade reversing-Minutes,0,
IDE09431-MAS00111,History data sunroof shade reversing-Seconds,0,
IDE09431-MAS01453,History data sunroof shade reversing-Blocking detection,not active,
IDE09431-MAS01634,History data sunroof shade reversing-Supply voltage,13.10, V
IDE09431-MAS02282,History data sunroof shade reversing-Position,13, %
IDE09431-MAS02289,History data sunroof shade reversing-Outside air temperature,25.00, °C
IDE09431-MAS05622,History data sunroof shade reversing-Cold start,not active,
IDE09431-MAS09457,History data sunroof shade reversing-Counter readings roof blind reversals,1,
IDE09431-MAS10923,History data sunroof shade reversing-Absolute Position,1772,
IDE09431-MAS10991,History data sunroof shade reversing-Restart,not active,
IDE09431-MAS10992,History data sunroof shade reversing-Absolute start position,4388,
IDE09492-MAS01155,Temperatures-Control module,7.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,11.50, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,7.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,7.00, °C
IDE09515-MAS08884,Controls-Sunroof button,not activated,
IDE09515-MAS08932,Controls-Sunroof shade button,not activated,
IDE09515-MAS08992,Controls-Button for sliding roof,not activated,
IDE09515-MAS12701,Controls-Search lights,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,not active,
IDE09516-MAS04195,Status of child safety-Frt. pass. side,not active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Release,present,
IDE09517-MAS07376,Control module-Terminal 58xd,Not available,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Panel lighting for controls,0, %
IDE09517-MAS11499,Control module-Rear indicator light for tilting sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,12.30, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,0.00, A
IDE09844-MAS00106,History data sunroof standardization-Year,2011,
IDE09844-MAS00107,History data sunroof standardization-Month,1,
IDE09844-MAS00108,History data sunroof standardization-Day,1,
IDE09844-MAS00109,History data sunroof standardization-Hours,17,
IDE09844-MAS00110,History data sunroof standardization-Minutes,5,
IDE09844-MAS00111,History data sunroof standardization-Seconds,22,
IDE09844-MAS00370,History data sunroof standardization-Vehicle speed,0.00, km/h
IDE09844-MAS01155,History data sunroof standardization-Control module,11.00, °C
IDE09844-MAS01634,History data sunroof standardization-Supply voltage,14.00, V
IDE09844-MAS02289,History data sunroof standardization-Outside air temperature,18.00, °C
IDE09844-MAS04447,History data sunroof standardization-Engine running status,Motor not running,
IDE09844-MAS09458,History data sunroof standardization-Counter reading sunroof calibrations,3,
IDE09845-MAS00106,History data roof blind standardization-Year,2011,
IDE09845-MAS00107,History data roof blind standardization-Month,1,
IDE09845-MAS00108,History data roof blind standardization-Day,1,
IDE09845-MAS00109,History data roof blind standardization-Hours,17,
IDE09845-MAS00110,History data roof blind standardization-Minutes,6,
IDE09845-MAS00111,History data roof blind standardization-Seconds,12,
IDE09845-MAS00370,History data roof blind standardization-Vehicle speed,0.00, km/h
IDE09845-MAS01155,History data roof blind standardization-Control module,12.00, °C
IDE09845-MAS01634,History data roof blind standardization-Supply voltage,13.90, V
IDE09845-MAS02289,History data roof blind standardization-Outside air temperature,18.00, °C
IDE09845-MAS04447,History data roof blind standardization-Engine running status,Motor not running,
IDE09845-MAS09459,History data roof blind standardization-Counter read. roof blind calibrations,2,
IDE09846-MAS00106,History data sunroof control point-Year,2000,
IDE09846-MAS00107,History data sunroof control point-Month,0,
IDE09846-MAS00108,History data sunroof control point-Day,0,
IDE09846-MAS00109,History data sunroof control point-Hours,0,
IDE09846-MAS00110,History data sunroof control point-Minutes,0,
IDE09846-MAS00111,History data sunroof control point-Seconds,0,
IDE09846-MAS02282,History data sunroof control point-Position,0, %
IDE09846-MAS05737,History data sunroof control point-Position,Tilt out posi.,
IDE09846-MAS09430,History data sunroof control point-Operating pts.,Button for sliding roof,
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Unknown (255),
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255),
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Unknown (255),
IDE12985-MAS15419,Operating signals: rear door control modules-Operating signal: rear: driver side sliding/tilting sunroof,not activated,
IDE12985-MAS15420,Operating signals: rear door control modules-Operating signal: rear: passenger side sliding/tilting sunroof,not activated,
IDE12985-MAS15421,Operating signals: rear door control modules-Operating signal: rear: driver side roof shade,not activated,
IDE12985-MAS15422,Operating signals: rear door control modules-Operating signal: rear: passenger side roof shade,not activated,
IDE14139-MAS01161,Wind deflector control module: status-Communication error,not installed,
IDE14139-MAS02282,Wind deflector control module: status-Position,not installed,
IDE14139-MAS04183,Wind deflector control module: status-Position error,not installed,
IDE14139-MAS08536,Wind deflector control module: status-Excessive temperature protection,not installed,
IDE14139-MAS17855,Wind deflector control module: status-Wagon message,Not available,
IDE14139-MAS17856,Wind deflector control module: status-Forced connection requirement,Not available,
IDE14139-MAS17857,Wind deflector control module: status-Position,not installed,
IDE14139-MAS17858,Wind deflector control module: status-Drive initializing,not installed,
IDE14139-MAS17859,Wind deflector control module: status-Adaptation run successful,not installed,
IDE14139-MAS17860,Wind deflector control module: status-Cancel function,not installed,
IDE14140-IDE02021,Wind deflector control module: reception signal-Comfort closing,Not available,
IDE14140-IDE02022,Wind deflector control module: reception signal-Comfort opening,Not available,
IDE14140-IDE14099,Wind deflector control module: reception signal-Wind deflector: denormalization,Not available,
IDE14140-MAS00370,Wind deflector control module: reception signal-Vehicle speed,Not available,
IDE14140-MAS01468,Wind deflector control module: reception signal-Terminal 15,Not available,
IDE14140-MAS02447,Wind deflector control module: reception signal-Release,Not available,
IDE14140-MAS05563,Wind deflector control module: reception signal-Norming,Not available,
IDE14140-MAS05737,Wind deflector control module: reception signal-Position,Not available,
IDE14140-MAS17871,Wind deflector control module: reception signal-Teaching-in run,Not available,
IDE14231-IDE09422,Power sunroof control module: absolute position values-Roof Blind,96,
IDE14231-IDE09423,Power sunroof control module: absolute position values-Sunroof,64,
Elapsed Time: 00:05
D6:
;SW:7P5-941-572-A HW:7P5-941-572-A --- Light Ctrl Left 2
;Component:LED1L H06 0002, Coding:
;EV_LEDMinMaxL_KEBODAVW481,001003,EV_LEDMinMaxL_KEBODAVW481.rod
;Tuesday,10,December,2019,21:46:01:14741
;VCID: B924C6AEE9DA8B996E25-80EC
IDE00325,Diagnostic mode,Extended Session,
IDE00767-ENG14124,No. of unscheduled ECU resets-Test_Program_Watchdog_reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,12.3, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.5, V
IDE03680-MAS09375,Supply voltages-Terminal 56a,0.0, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,0.0, V
IDE03680-ENG35973,Supply voltages-Supply_for_daytime_running_light,0.0, V
IDE03680-ENG35974,Supply voltages-Supply_for_logic,12.3, V
IDE06926-ENG28625,History memory: reset counter-reset_reason,Unknown (1),
IDE06926-ENG08623,History memory: reset counter-Timestamp,13 0C 0A 15 2D,
IDE08742-MAS02946,Operating time-static AFS light,0.00, H
IDE08742-MAS07243,Operating time-Low beam,3.00, H
IDE08742-MAS07249,Operating time-High Beam,0.08, H
IDE08742-MAS09325,Operating time-Daytime running lights,0.00, H
IDE08742-ENG28624,Operating time-all_weather_light,0.00, H
IDE08742-ENG28616,Operating time-Control_module,9.67, H
IDE08742-ENG28502,Operating time-Motorway_light,9.43, H
IDE08742-ENG28679,Operating time-Tourist_light,0.00, H
IDE09774-MAS02946,Number of activations-static AFS light,68,
IDE09774-MAS07243,Number of activations-Low beam,32,
IDE09774-MAS07249,Number of activations-High Beam,12,
IDE09774-MAS09325,Number of activations-Daytime running lights,0,
IDE09774-ENG28624,Number of activations-all_weather_light,0,
IDE09774-ENG28914,Number of activations-High_beam_excess_temperature,0,
IDE09774-ENG28912,Number of activations-High_beam_excess_temperature_protection,0,
IDE09774-ENG28913,Number of activations-Low_beam_excess_temperature,0,
IDE09774-ENG28911,Number of activations-Low_beam_excess_temperature_protection,0,
IDE09774-ENG28502,Number of activations-Motorway_light,6,
IDE09774-ENG28679,Number of activations-Tourist_light,0,
IDE09828-ENG28616,Head lamp variant-Control_module,E0 76,
IDE09828-ENG11304,Head lamp variant-via_CAN,E0 76,
IDE10048-IDE09768,Supply information-LED channel 1,Not Used,
IDE10048-IDE09769,Supply information-LED channel 2,Terminal 15,
IDE10048-MAS01968,Supply information-Fan,Terminal 15,
IDE10048-MAS09754,Supply information-LED channel 3,Not Used,
IDE10048-MAS09754,Supply information-LED channel 3,Terminal 15,
IDE10048-MAS09755,Supply information-Matrixbeam channels,Not Used,
IDE10048-ENG30205,Supply information-Highside_channel 1,Terminal 15,
IDE10048-ENG30206,Supply information-Highside_channel 2,Not Used,
IDE10048-ENG30207,Supply information-Highside_channel 3,Terminal 15,
IDE10048-ENG30208,Supply information-Highside_channel 4,Terminal 15,
IDE10165-IDE10205,LED channel 1: Master 1-Control module version,Max,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,22, °C
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,100.0, %
IDE10165-ENG35975,LED channel 1: Master 1-LED_brightness_class,1,
IDE10167-IDE10205,LED channel 1: Slave-Control module version,not defined,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,-50, °C
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS09022,LED channel 1: Slave-PWM value,100.0, %
IDE10167-ENG35975,LED channel 1: Slave-LED_brightness_class,4,
IDE10168-IDE10205,LED channel 2: Master-Control module version,MXB 8,
IDE10168-MAS02201,LED channel 2: Master-Temperature,21, °C
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS09022,LED channel 2: Master-PWM value,100.0, %
IDE10168-ENG35975,LED channel 2: Master-LED_brightness_class,1,
IDE10169-IDE10205,LED channel 2: Slave-Control module version,not defined,
IDE10169-MAS02201,LED channel 2: Slave-Temperature,-50, °C
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS09022,LED channel 2: Slave-PWM value,100.0, %
IDE10169-ENG35975,LED channel 2: Slave-LED_brightness_class,4,
IDE10170-IDE10205,LED channel 3: Master-Control module version,MXB Mid,
IDE10170-MAS02201,LED channel 3: Master-Temperature,21, °C
IDE10170-MAS04136,LED channel 3: Master-Current,0, mA
IDE10170-MAS09022,LED channel 3: Master-PWM value,100.0, %
IDE10170-ENG35975,LED channel 3: Master-LED_brightness_class,2,
IDE10171-IDE10205,LED channel 3: Slave-Control module version,MXB Mid,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,22, °C
IDE10171-MAS04136,LED channel 3: Slave-Current,0, mA
IDE10171-MAS09022,LED channel 3: Slave-PWM value,100.0, %
IDE10171-ENG35975,LED channel 3: Slave-LED_brightness_class,1,
IDE10173-ENG28909,Operating times in temperature ranges-Between_105C_and_115C,0.00, H
IDE10173-ENG28915,Operating times in temperature ranges-Between_-40C_and_95C,7.00, H
IDE10173-ENG28908,Operating times in temperature ranges-Between_95C_and_105C,0.00, H
IDE10173-ENG28910,Operating times in temperature ranges-Over_115C,0.00, H
IDE10205,Control module version,Max,
IDE10206-IDE10205,Fan for headlight-Control module version,MXB 8,
IDE10282-ENG36147,LED channels: voltages-Channel_1_Master,0.00, V
IDE10282-ENG36226,LED channels: voltages-Channel_1_Slave,0.00, V
IDE10282-ENG36148,LED channels: voltages-Channel_2_Master,0.00, V
IDE10282-ENG36227,LED channels: voltages-Channel_2_Slave,0.00, V
IDE10282-ENG36149,LED channels: voltages-Channel_3_Master,0.00, V
IDE10282-ENG36228,LED channels: voltages-Channel_3_Slave,0.00, V
IDE10864-MAS11562,Control mod. temperatures-Matrix light power output stage,0, °C
IDE10864-ENG35976,Control mod. temperatures-LED_headlamp_power_module,21, °C
MAS00468,Unlearning counter,12,
MAS09756-IDE10205,High side channel-Control module version,not defined,
MAS09756-MAS02526,High side channel-Activation,Channel not used,
MAS09756-MAS09022,High side channel-PWM value,0.0, %
SER00010,Read data,not active,
Elapsed Time: 00:03
D7:
;SW:7P5-941-572-A HW:7P5-941-572-A --- Light Ctrl Right 2
;Component:LED1R H06 0002, Coding:
;EV_LEDMinMaxR_KEBODAVW481,001003,EV_LEDMinMaxL_KEBODAVW481.rod
;Tuesday,10,December,2019,21:46:08:14741
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.6, V
IDE09774-MAS02946,Number of activations-static AFS light,64,
IDE09774-MAS07243,Number of activations-Low beam,37,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,23, °C
IDE10165-ENG35975,LED channel 1: Master 1-LED_brightness_class,2,
IDE10168-ENG35975,LED channel 2: Master-LED_brightness_class,2,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,23, °C
IDE10171-ENG35975,LED channel 3: Slave-LED_brightness_class,2,
IDE10864-ENG35976,Control mod. temperatures-LED_headlamp_power_module,20, °C
Elapsed Time: 00:03
OBDII (KOEN, cold):
;33-OBD2
;Tuesday,10,December,2019,21:46:15:14741
03,Fuel system 1/2 status,Engine off,Engine off
04,Calculated load value,0.0 %
05,Engine coolant temperature,28 °C
06,Short Term Trim - Bank 1,0.0 %
07,Long Term Trim - Bank 1,-1.6 %
0B,Intake Manifold Absolute Pressure,98 kPa abs
0C,Engine RPM,0 /min
0D,Vehicle speed,0 km/h
0E,Ignition timing advance for cyl #1,-0.5 Degrees
0F,Intake air temperature,26 °C
11,Throttle position sensor,15.3 %
12,Secondary Air Status,Atmosphere/off
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,1.275 V
1C,OBD Requirements Met,OBD + OBD II
1F,Time since engine start,0 s
21,Distance travelled with MIL on,0 km
23,Fuel Rail Press (rel),330 kPa rel
2E,Commanded Evaporative Purge,0.0 %
2F,Fuel Level Input,61.2 %
30,Warm-ups since DTC cleared,9
31,Distance since DTC cleared,359 km
33,Barometric pressure,98 kPa abs
34,Bank 1 Sensor 1 Status,0.000 Lambda,-128.000 mA
3C,B1S1 Cat. Temp.,11.2 °C
42,Control module voltage,12.421 V
43,Absolute Load Value,0 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,5 %
46,Ambient Air Temp,12 °C
47,Absolute Throttle Position B,15 %
49,Accelerator Pedal Position D,15 %
4A,Accelerator Pedal Position E,15 %
4C,Commanded Throttle Actuator Control,5 %
51,Fuel type,Gasoline
56,Long term sec. O2 trim bank 1/3,-1.6 %
70,Boost Press Ctrl A/B,BP_A act:98 kPa
Mode 9 : Calibration Identification
Type 02 - VIN : 3VWM17AU9KM522339 (Address E8)
Type 04 - Calibration ID : 8V0264M 0001AXAE (Address E8)
Type 06 - Calibration Verification Number : 100AD09E (Address E8)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 10
Ignition cycle count : 82
Conditions completion count / Specified conditions encountered count
Catalyst monitor bank 1 : 15 / 10
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 15 / 10
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 23 / 10
AIR monitor : 10 / 5
EVAP monitor : 7 / 3
Secondary O2 Sensor monitor bank 1 : 13 / 10
Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
