Results 1 to 10 of 13
Thread: Audi A4 2009 battery coding issue
    Feb 2019
    Hello. I changed battery to audi and the battery needs coding. I have tried code battery, but when I press TEST then there comes old battery coding value back. There is 26 digits but car dont accept new coding? can someone give me advice?
    Wednesday,11,December,2019,15:11:31:19148
    VIN: WAUZZZ8K59A085140   License Plate: AUDI
    Mileage: 211710km-131550mi   Repair Order:
    Long Adaptation Channel 004:
    Stored value 8K0915105D  MLA 180722MRY1
    Test value 8K0915105D  MLA 180722MRY1
    Battery Information/Replacement
      N/A
      N/A
      N/A
      N/A
    Autoscan:
    Wednesday,11,December,2019,15:17:52:19148
    VIN: WAUZZZ8K59A085140   License Plate: GML-530
    Mileage: 211710km-131550mi   Repair Order: AUDIA4B8
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 69 72
    VIN: WAUZZZ8K59A085140   Mileage: 211710km-131550miles
    Address 01: Engine (-----CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H12 0002
       Revision: E1H12---
       Coding: 010C000C180F0920
       Shop #: WSC 40350 222 93973
       ASAM Dataset: EV_ECM20TFS8K2907115A A01003
       ROD: EV_ECM20TFS8K2907115A.rod
       VCID: 2D0709A39D9592AF521-8078
    Readiness: 0110 0101
       Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
       Component: ESP8 quattro  H04 0060
       Coding: 07C500
       Shop #: WSC 06335 000 00000
       VCID: 7BA3F7FB13E1CC1F9C5-802E
       Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
       Component: BCM2 1.1      H71 0134
       Coding: 070200
       VCID: 72BDDADF44AB8D57CF3-8026
       Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
       Serial number: 0816000082984019
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000036243002
    03286 - Sensor for Contact with Door Handle; Front Right
                        Fault Status: 00100111
                        Reset counter: 57
                        Mileage: 211717 km
                        Date: 2019.12.11
                        Time: 10:18:07
    03285 - Sensor for Contact with Door Handle; Front Left
                        Reset counter: 17
                        Mileage: 211717 km
                        Date: 2019.12.11
                        Time: 11:05:50
                        Reset counter: 17
                        Mileage: 211717 km
                        Date: 2019.12.11
                        Time: 11:05:50
       Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
       Component: KLIMA 1 ZONE  H06 0140
       Revision: A1000000    Serial number: 0125.07.080210
       Coding: 64000000
       VCID: 70B9D0D74AA7BF47397-8024
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000187436
       Coding: 2600D0914034AF010001000300001D0D0F1C270800010101000000
       VCID: 303910D78A27FF47797-8064
       Component: WWS 190708  H06 0070
       Serial number: SWFBIE 0006256
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10196430
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002607080796
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD17TWM5
       Coding: 30343434363030303030554A304C384B3053
       VCID: 3C2134E756EF0B27D5F-8068
       Serial number: 6334MSME3E15624EM
       Serial number: 6344MSME526D5824J
       Serial number: 6352QSME7E612123D
       Serial number: 6362QSME750B3231A
       Serial number: 63732SME6A492D4BF
       Serial number: 63832SME20522060H
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90304HGM000C0
       Coding: 000017
       VCID: 3D2739E34D75022FE21-8068
       Part No SW: 8K0 920 930 A    HW: 8K0 920 930 A
       Component: KOMBIINSTR.   H16 0224
       Revision: 00000000    Serial number: 9DZ195W78
       Coding: 0F04110002000008010000
       VCID: 2B0307BBA3019C9F4C5-807E
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0091
       Revision: GB102039    Serial number: 3900G0871482C2
       Coding: 000303
       VCID: 46D5560F18A341F7B3B-8012
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 180316C1110708
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Component: SG ext.Player H06 0210
       Revision: 00000000
       Coding: 020202
       VCID: 78A9E8F722D7E707F17-802C
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007498221
       Coding: 011C12204000410001
       VCID: 3FDB43EB4779103FF0D-806A
       Revision: 00002001    Serial number: 0113125985
       Coding: 013A0E2020390041003002
       Shop #: WSC 06325 000 00000
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 17
                        Mileage: 211717 km
                        Date: 2019.12.11
                        Time: 11:22:18
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 17
                        Mileage: 211717 km
                        Date: 2019.12.11
                        Time: 11:22:27
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S1900000
       Coding: 0203010101
       VCID: 6E85CEAF5093A9B72BB-803A
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007485641
       VCID: 3E253EEF40731937FBB-806A
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000184803
       VCID: 313F15D3812DF64F769-8064
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000004
       Shop #: WSC 06334 000 00000
       VCID: 34311CC7723FC3671DF-8060
       Part No SW: 8T1 035 186 C    HW: 8T1 035 186 C
       Component: Concert3      H02 0210
       Revision: 00000004    Serial number: AUZ5Z6H1097355
       Coding: 04020080010205000159070800
       VCID: 372B2BCB6F49287F38D-8062
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007493288
       Coding: 010C12204000210001
       VCID: 7F5B03EB07F9D03FB0D-802A
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 A    HW: 8K0 907 383 A
       Component: Anhaenger     H06 0040
       Revision: 1A002002    Serial number: 00000113071515
       Coding: 0100000000000000
       VCID: 323D1ADF842BCD570F3-8066
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007479851
       VCID: 7EA5FEEF00F3D937BBB-802A
    End----------(Elapsed Time: 01:27, VBatt start/end: 14.1V/14.2V)-----------
    New battery:
    BEM Code:
    000915105DH
    VAO39060220EQ
    And I tried to write coding to 19->Long adaption -> channel 004:
    000915105DH VAO 39060220EQ
    Try: 000915105DH VA0 39060220EQ
    (VA0 instead of VAO)
    Feb 2019
    I tried VAO and VA0. Always same result after I press TEST - old coding comes back.
    What happens if you just change one digit of the existing coding's serial number?
    For example, change:
    8K0915105D MLA 180722MRY1 to
    8K0915105D MLA 180722MRY2
    Feb 2019
    Nothing change. Always after pressed TEST - Old coding is there. 😮
    Feb 2019
    There was that 8k0 coding and bosh battery 85Ah. No fault codes to battery. But car went after battery replace to dealer for service and they said that batterytest gived "bad battery" and need to replace and recode.
  7. #7
    Next thing I would try is setting some values for WSC, Importer, and Equipment Number.
    Go to [Options], click on the User Interface and Identification tab. Your screen will look like this:
    Put non-zero numbers in there.
    For WSC, I suggest the a '0' followed by the last four digits of your postal code or phone number.
    For Importer, use your country's importer code (or pick a 3-digit number at random).
    For Equipment Number, I suggest a '0' followed by the last for digits of your interface serial number.
    Using this method ensures enough randomness that it can't possibly be blocked.
    Then click [Save], and exit and re-start VCDS for these values to take effect.
  8. Likes PetrolDave, Jack@European_Parts liked this post
  9. #8
    Feb 2019
    Hello. Thanks for advice. I tried and changed all those number and tried but nothing changed. Old coding comes back
  10. #9
    Scratching head.
    What happens if you click [Save] despite having the old coding in the Test Value field?
  11. #10
    Feb 2019
    Still old coding stays. But I dont think that it saves the new value. I think the old value Stay there in the field.. 😕
